    4. [gelöst] Samsung Internet Browser Problem mit ioBroker
      Rushmed Most Active last edited by Rushmed
      Ok, habe jetzt debug Zugriff auf den Samsung Browser. Wo kann ich da nach Problemen suchen?
      Fehlt der App etwa Javascript?
      sigi234 Glasfaser Feuersturm 3 Replies Last reply Reply Quote 0
        sigi234 Forum Testing Most Active @Rushmed last edited by
        @rushmed
        Console , steht da was?
        • Glasfaser
          Glasfaser @Rushmed last edited by
          @rushmed
          Ich denke mal da steht einiges laut Warn/Error Anzeige
            sigi234 Forum Testing Most Active @Rushmed last edited by sigi234
            @rushmed
            Deaktiviere mal den Info Adapter.
              Rushmed Most Active @sigi234 last edited by
              @sigi234 ja
              iobroker.admin@5.1.28
              socket.io.js:59 [2021-12-04T12:10:21.256Z] Try to connect
              socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619821257&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
              SocketClient.connect @ socket.io.js:91
              (anonymous) @ Connection.ts:239
              u @ runtime.js:63
              (anonymous) @ runtime.js:294
              (anonymous) @ runtime.js:119
              n @ asyncToGenerator.js:3
              i @ asyncToGenerator.js:25
              (anonymous) @ asyncToGenerator.js:32
              (anonymous) @ asyncToGenerator.js:21
              (anonymous) @ 5.fdbcba88.chunk.js:2
              (anonymous) @ Connection.ts:99
              socket.io.js:59 [2021-12-04T12:10:21.344Z] Start reconnect 0
              socket.io.js:61 [2021-12-04T12:10:21.345Z] ws connection error: CLOSE_ABNORMAL
              error @ socket.io.js:61
              socket.onclose @ socket.io.js:128
              socket.io.js:59 [2021-12-04T12:10:21.345Z] Reconnect is already running 0
              socket.io.js:59 [2021-12-04T12:10:21.368Z] Try to connect
              socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619821370&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
              (anonymous) @ socket.io.js:372
              socket.io.js:59 [2021-12-04T12:10:21.429Z] Start reconnect 1
              socket.io.js:61 [2021-12-04T12:10:21.430Z] ws connection error: CLOSE_ABNORMAL
              socket.io.js:59 [2021-12-04T12:10:21.430Z] Reconnect is already running 1
              socket.io.js:59 [2021-12-04T12:10:22.430Z] Try to connect
              socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619822432&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
              socket.io.js:59 [2021-12-04T12:10:22.520Z] Start reconnect 2
              socket.io.js:61 [2021-12-04T12:10:22.521Z] ws connection error: CLOSE_ABNORMAL
              socket.io.js:59 [2021-12-04T12:10:22.521Z] Reconnect is already running 2
              socket.io.js:59 [2021-12-04T12:10:24.521Z] Try to connect
              socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619824521&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
              socket.io.js:59 [2021-12-04T12:10:24.582Z] Start reconnect 3
              socket.io.js:61 [2021-12-04T12:10:24.583Z] ws connection error: CLOSE_ABNORMAL
              socket.io.js:59 [2021-12-04T12:10:24.583Z] Reconnect is already running 3
              socket.io.js:59 [2021-12-04T12:10:27.583Z] Try to connect
              socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619827584&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
              socket.io.js:59 [2021-12-04T12:10:27.674Z] Start reconnect 4
              socket.io.js:61 [2021-12-04T12:10:27.674Z] ws connection error: CLOSE_ABNORMAL
              socket.io.js:59 [2021-12-04T12:10:27.675Z] Reconnect is already running 4
              socket.io.js:59 [2021-12-04T12:10:31.675Z] Try to connect
              socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619831676&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
              socket.io.js:59 [2021-12-04T12:10:31.764Z] Start reconnect 5
              socket.io.js:61 [2021-12-04T12:10:31.767Z] ws connection error: CLOSE_ABNORMAL
              socket.io.js:59 [2021-12-04T12:10:31.775Z] Reconnect is already running 5
              socket.io.js:59 [2021-12-04T12:10:36.767Z] Try to connect
              socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619836768&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
              socket.io.js:59 [2021-12-04T12:10:36.857Z] Start reconnect 5
              socket.io.js:61 [2021-12-04T12:10:36.858Z] ws connection error: CLOSE_ABNORMAL
              socket.io.js:59 [2021-12-04T12:10:36.859Z] Reconnect is already running 5
              Glasfaser sigi234 2 Replies Last reply Reply Quote 0
              • Glasfaser
                Glasfaser @Rushmed last edited by Glasfaser
                @rushmed sagte in Samsung Internet Browser Problem mit ioBroker Web UI:
                Mhh . hast du HTTPS , obwohl @Feuersturm es auch nicht nutzt
                EDIT :
                Laut
                ist bei dir HTTP ( ws )
                  @rushmed
                  Zeig mal Instanzeinstellungen: socketio.0
                    Ich habe weder HTTPS noch eine socketio. Instanz.
                    Ich leg mal eine an.
                    Edit:
                    Authentifizierung habe ich aktiv.
                    Mit dem alten Admin UI komme ich schonmal zum Login Screen und bleibe danach hängen.
                    • Feuersturm
                      Feuersturm @Rushmed last edited by
                      Wie hast du das gemacht?
                      • Glasfaser
                        Glasfaser last edited by Glasfaser
                        Samsung (Android) Internet Browsern
                        Ohmm .. das ist aber Google laut deinem Screenshot
                          @Feuersturm Link
                          @Glasfaser siehe Link der Debugging Zugang aufs Telefon wird über Chrome gestartet.
                          Seffe 1 Reply Last reply Reply Quote 0
                          • Seffe
                            Seffe @Rushmed last edited by Seffe
                            @rushmed Konntest du das Problem lösen?
                            Hätte noch den Vorschlag den Hacken beim erzwingen der Websockets in der Instanz Web.0 zu deaktivieren.
                            Hiermit geht zumindest wieder der Zugriff auf die ViS mit dem neuen Samsung Internet Browser.Websocket.jpg
                            M R 2 Replies Last reply Reply Quote 0
                              MK-66 @Seffe last edited by
                              @seffe @Rushmed
                              Was aber beim neuen Samsung Internet Browser 16.0.2.19 trotzdem nicht mehr geht, ist der Zugriff auf Flot Diagramme, zumindest bei mir nicht (Websockets erzwingen ist deaktiviert). Sobald mehrere Flots geladen werden sollen, passiert außer einem derhenden Kreis einfach gar nichts und irgendwann stürzt der Browser dann auch noch ab. Wenn nur ein einzelnes Flot geladen werden soll, geht es. Mit Chrome und FF gibt es da keine Probleme.
                                Rushmed Most Active @Seffe last edited by
                                @seffe Nein, es funktionier immernoch nicht. Das Erzwingen der Websockets war bereits deaktiviert.
                                Ich sehe aber Licht am Ende des Tunnels. In der aktuellen Samsung Internet beta 16.2.1.25 komme ich wieder in die Admin Oberfläche. 👍
                                Flot und Vis habe ich nicht getestet, ich visualisiere alles mit einer Kombi aus Grafana und HabPanel und das ging beides immer.
                                  Mit der aktuellen Version 16.2.1.56 von Samsung Internet besteht das Problem nichtmehr.
                                  Feuersturm 1 Reply Last reply Reply Quote 1
                                  • Feuersturm
                                    @rushmed Dankeschön. Funktioniert bei mir jetzt auch wieder.
                                    internet samsung webgui
                                    949
