      sigi234 Forum Testing Most Active @MCU last edited by sigi234
      @mcu sagte in jarvis v3.0.0 (beta) - just another remarkable vis:
      @sigi234 F5 und dann F2
      Nein
      Log:
      arvis.0
      2021-12-03 19:16:48.298	info	Client with IP 127.0.0.1 connected
      jarvis.0
      2021-12-03 19:16:48.292	info	Client connecting...
      jarvis.0
      2021-12-03 19:14:53.372	info	Client with IP 127.0.0.1 connected
      jarvis.0
      2021-12-03 19:14:53.367	info	Client connecting...
      jarvis.0
      2021-12-03 19:12:40.177	info	Client with IP 127.0.0.1 connected
      jarvis.0
      2021-12-03 19:12:40.171	info	Client connecting...
      jarvis.0
      2021-12-03 19:11:15.684	info	Client with IP 127.0.0.1 connected
      jarvis.0
      2021-12-03 19:11:15.683	info	Client connecting...
      jarvis.0
      2021-12-03 19:11:11.698	info	Client with IP 127.0.0.1 connected
      jarvis.0
      2021-12-03 19:11:11.693	info	Client connecting...
      jarvis.0
      2021-12-03 19:10:50.234	info	Client with IP 127.0.0.1 connected
      jarvis.0
      2021-12-03 19:10:50.233	info	Client connecting...
      jarvis.0
      2021-12-03 19:10:35.295	info	Client with IP 127.0.0.1 connected
      jarvis.0
      2021-12-03 19:10:35.290	info	Client connecting...
      jarvis.0
      2021-12-03 18:45:57.616	warn	State "alexa2.0.Echo-Devices._object Object_.Player.controlPlay" has no existing object, this might lead to an error in future versions
      jarvis.0
      2021-12-03 18:45:57.609	warn	Used invalid characters: alexa2.0.Echo-Devices.[object Object].Player.controlPlay changed to alexa2.0.Echo-Devices._object Object_.Player.controlPlay
      jarvis.0
      2021-12-03 18:40:15.564	info	Client with IP 127.0.0.1 connected
      jarvis.0
      2021-12-03 18:40:15.559	info	Client connecting...
        MCU @sigi234 last edited by MCU
        @sigi234 Dann mal direkt in die Browserzeile:
        http://192.168.178.XXX:8082/jarvis/index.html#/configuration/styles
        Dann jarvis mal pausieren und neustarten.
          Seite kommt
            @sigi234 Ich hatte das auch mal die Tage, echt komisch.
              @sigi234 Hast du irgendetwas Besonderes gemacht? Oder kam das plötzlich?
                Widget im Tab Layout hinzugefügt und bearbeitet ( Media Control Widget Yamaha)
                  @sigi234 Hab es mal als issue aufgenommen:
                  https://github.com/Zefau/ioBroker.jarvis/issues/1250
                  mcuiobroker created this issue in Zefau/ioBroker.jarvis
                  closed F2 oder Konfiguration sporadisch nicht erreichbar #1250
                  stephan1827 1 Reply Last reply Reply Quote 1
                  • stephan1827
                    stephan1827 @MCU last edited by
                    @mcu wie hast Du es hier hinbekommen den Rahmen in der normalen Ansicht blinken zu lassen?
                    https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/styles/statelist-1/pulsierende-rechtecke/inset-nach-innen
                    Ich finde die Einstellung Body Style nur bei dem Wert selber. Dann blinkt der Rahmen zwar, wenn ich das Popup öffne aber ich möchte das der Rahmen des Widgets pulsiert wenn die Batterie leer ist oder das Gerät nicht erreichbar ist.
                    Stephan
                      MCU @stephan1827 last edited by MCU
                      @stephan1827 Dafür musst du dann ein Feature Request einstellen -> Binding fürs Widget.
                      Warum soll das Popup blinken? Das Widget blinken ok, aber das Popup?
                      Das Widget könnte doch blinken, wenn die Batterie einen bestimmten Zustand hat.
                      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/styles/widgets/.q-item__section--main#widget-border-animation-blink
                      stephan1827 1 Reply Last reply Reply Quote 0
                      • stephan1827
                        @mcu Genau so will es auch haben, das Widget soll blinken, wenn die Batterie leer ist oder die Verbindung unterbrochen wurde. In dem Beispiel ist mir nicht klar wie da den Batterie und Verbindungsstatus dran bekomme.
                          @stephan1827 Du musst diese Zeilen entsprechend in die CSS/Styles schreiben:
                          .jarvis-widget-27165a76-beaf-4cd6-9752-ab01ce85f343 {
                          	animation: border_animation 2s 5; /* infinite = immer  Anzahl = 5 */
                          Ich bin gerade dabei es einfacher machen zu können, das dauert aber noch.
                          Ziel: Man kann DPs auf true setzen und dann blinkt das Widget.
                          Ein ähnliches Verfahren wird schon bei der Security genutzt, kannst du Dir gerne anschauen:
                          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/security
                          J M 2 Replies Last reply Reply Quote 1
                            j1s2e3 @MCU last edited by
                            Ich versuche gerade meinen RGBW Controller (FRGBW71L von Eltako) in Jarvis abzubilden.
                            So wie ich gesehen habe, gibt es nur LightHueBody und LightColorBody.
                            LightHueBody habe ich wohl zum Laufen bekommen. Braucht einen DP vom Typ Number wo dann die Gradzahl 0-359 reingeschrieben wird. Aber was ist mit Sättigung und Value? Muss ich da "normale" Level-Slider nehmen?
                            LightColorBody wurde mir beim Gerät Importieren voreingestellt. Aber funktioniert nicht. Wird nichtmal angezeigt. Wenn ich unter Geräteeinstellungen auf Bodyelement klicke, dann ist LightColorBody nicht vorhanden. Sehe nur LastChangeBody, LevelBody und CustomTextBody.
                            Was triggert das LightColorBody, so das es wählbar ist?
                            Wie, wann bekommen ich unter Action Element LightColorState angeboten?
                            Welche Art DP muss ich für LightColorBody und LightColorState anlegen (String, Number...)???
                            Wie muss der Inhalt von diesem DP aussehen (z.B. String #0011223344 - rgbw in hex)? Oder anders gefragt, was schreibt das LightColorBody Widget in den Datenpunkt?
                            Wenn ich direkt R, G, B und W mit Slidern einstellen möchte, geht dann auch sowas wie der LighHueBody, nur dass dann z.B. bei Rot ein Farbbalken von schwarz bis max. rot angezeigt wird? Ditto für grün, blau und weiß?
                            Gibt es auch einen Gradienten für die Farbtemperatur von Warmweiss nach Kaltweiss?
                            Zefau P 2 Replies Last reply Reply Quote 1
                            • Zefau
                              Zefau @j1s2e3 last edited by
                              @j1s2e3 sagte in jarvis v3.0.0 (beta) - just another remarkable vis:
                              Ist das Gewerk auf Licht eingestellt?
                                MCU @MCU last edited by MCU
                                @stephan1827 @RkcCorian Ist das so richtig?
                                  j1s2e3 @Zefau last edited by
                                  @zefau Danke, dass war es. Gewerk stand auf Sonstiges nach dem Importieren und ich wusste nicht, dass Gewerk Einfluss auf die Konfigurationsdialoge hat.
                                  Meine Test-DP:
                                  Und so sieht es jetzt erstmal aus:
                                  LightColorBody schreibt #RGB als String wie vermutet.
                                  Für R, G, B, W und Farbtemperatur muss ich normale Levelslider nehmen. Richtig? Mit Farbgradienten hinterlegte Varianten gibt es nicht?
                                  • Zefau
                                    LightColorBody erkennt das Input-Format und gibt das entsprechende Format auch wieder aus.
                                    Mögliche Formate:
                                    • Hex-Wert (mit oder ohne vorangestellter #)
                                    • Hex-Wert mit Alpha-Kanal (mit oder ohne vorangestellter #)
                                    • Hue-Wert
                                    • RGB
                                    Einzelne Farb-Kanäle können nicht angesteuert werden. Hierfür ist ein Level-Slider zu nehmen, richtig.
                                    Für die Farbgradienten kannst du gerne ein Feature Request aufmachen - ist eine gute Idee.
                                    Johannes Bauerstatter J 2 Replies Last reply Reply Quote 0
                                      Ceel last edited by
                                      Hallo
                                      ist es möglich nur einen wert z.B. 0 in ein Objekt durch einen klick zu schreiben?
                                      kein 1 und 0 sondern nur eine z.B. 0 oder eine 2
                                        MCU @Ceel last edited by MCU
                                        @ceel In den Datenpunkt-Eigenschaften:
                                        {"on":2,"off":2}
                                        https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/beispiele/geraete-einstellungen/datenpunkt-eigenschaften/on-und-off
                                          Algie last edited by
                                          ist es möglich den Wert auf 14% zu bekommen?
                                            MCU @Algie last edited by MCU
                                            @algie Datenpunkt-Eigenschaften: z.B. Formel selbst kontrollieren
                                            {"value":"val => parseFloat(Math.abs(val*100)).toFixed(0)"}
                                            https://mcuiobroker.gitbook.io/jarvis-infos/v3-fuer-einsteiger/konfigurations-tabs/geraete/geraete-dp#berechnungen-nachkommastellen
                                            254
                                            4489
                                            2645317
