    4. [ESPHome] Beta release
      Thomas Braun Most Active @Johannes Bauerstatter last edited by
      @johannes-bauerstatter
      Da ist irgendwas kaputt.
      sudo apt update
      sudo apt install --reinstall lsb-release
      Johannes Bauerstatter 1 Reply Last reply Reply Quote 0
      • Johannes Bauerstatter
        Johannes Bauerstatter @Thomas Braun last edited by Johannes Bauerstatter
        Ist eine ganz frische Installation auf einem Raspi 4.
        pi@raspberrypi:~ $ sudo apt install --reinstall lsb-release
        Reading package lists... Done
        Building dependency tree... Done
        0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
        Need to get 28.1 kB of archives.
        After this operation, 0 B of additional disk space will be used.
        Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf lsb-release all 11.1.0+rpi1 [28.1 kB]
        Fetched 28.1 kB in 1s (19.0 kB/s)
        Traceback (most recent call last):
          File "/usr/bin/apt-listchanges", line 29, in <module>
            import apt_pkg
        ModuleNotFoundError: No module named 'apt_pkg'
        (Reading database ... 50809 files and directories currently installed.)
        Preparing to unpack .../lsb-release_11.1.0+rpi1_all.deb ...
        Unpacking lsb-release (11.1.0+rpi1) over (11.1.0+rpi1) ...
        Setting up lsb-release (11.1.0+rpi1) ...
        Processing triggers for man-db (2.9.4-2) ...
        pi@raspberrypi:~ $
        NPM version: 6.14.15
        npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
        Exception:Traceback (most recent call last):  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 215, in main    status = self.run(options, args)  File "/tmp/tmpys8yyc8z/pip.zip/pip/commands/install.py", line 272, in run    with self._build_session(options) as session:  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 66, in _build_session    session = PipSession(  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 329, in __init__    self.headers["User-Agent"] = user_agent()  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 93, in user_agent    from pip._vendor import distro  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 1050, in <module>    _distro = LinuxDistribution()  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 593, in __init__    self._lsb_release_info = self._get_lsb_release_info() \  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_info    raise subprocess.CalledProcessError(code, cmd, stdout, stderr)subprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
        Traceback (most recent call last):  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
            main()  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main    bootstrap(tmpdir=tmpdir)  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 172, in bootstrap    sys.exit(pip.main(["install", "--upgrade"] + args))  File "/tmp/tmpys8yyc8z/pip.zip/pip/__init__.py", line 233, in main  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 248, in main  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 66, in _build_session  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 329, in __init__  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 93, in user_agent  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 1050, in <module>  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 593, in __init__  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_infosubprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
        Error: Exited with code 1.    at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)    at ChildProcess.emit (events.js:400:28)
            at maybeClose (internal/child_process.js:1058:16)    at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! iobroker.esphome@0.2.4 install: `npip install`npm ERR! Exit status 1
        npm ERR! npm ERR! Failed at the iobroker.esphome@0.2.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-12-03T15_55_36_557Z-debug.log
        ERROR: host.raspberrypi Cannot install iobroker.esphome@0.2.4: 1
        ERROR: process exited with code 25
          @johannes-bauerstatter sagte in [ESPHome] Beta release:
          ModuleNotFoundError: No module named 'apt_pkg'        (Reading database ... 50809 files and directories currently installed.)
          Gaaaaaaanz merkwürdige Meldungen. Was zur Hölle hast du da wie installiert?
          Ich würd's nochmal ganz frisch installieren.
          Johannes Bauerstatter O 2 Replies Last reply Reply Quote 0
            @thomas-braun Ok. Welche Python Version soll ich nehmen?
              Thomas Braun Most Active @Johannes Bauerstatter last edited by Thomas Braun
              Die vorgesehene/vorinstallierte?
              Da ist was total schräg bei dir. Hier ist das ganz fluffig:
              echad@chet:~ $ iobroker install esphome
              NPM version: 8.1.4
              host.chet install adapter esphome
              upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
              upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
              upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
              upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
              upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png
              upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
              host.chet object system.adapter.esphome created/updated
              Aus der Readme:
              Required
              • NodeJS >= 12.x
              • Python >=3.7, <4.0
              • API is activated in YAML
                Anzic last edited by Anzic
                Switched to NodeJS version 14 frome 12. The dashboard stopped working. Although the adapter itself works. There is such an error in the log:
                esphome.0
                2021-12-03 19:55:22.625	warn	ESPHome Dashboard deactivated
                esphome.0
                2021-12-03 19:55:22.589	error	[dashboardProcess ERROR] from esphome.__main__ import mainModuleNotFoundError: No module named 'esphome'
                esphome.0
                2021-12-03 19:55:22.588	error	[dashboardProcess ERROR] Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome", line 5, in <module>
                I try to execute iobroker rebuild esphome and iobroker rebuild esphome --install I get this error:
                root@iobroker:/opt/iobroker# iobroker rebuild esphome --install
                npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.esphome"
                /usr/bin/python3: No module named pip
                npm ERR! errno 1
                npm ERR!
                npm ERR!     /opt/iobroker/.npm/_logs/2021-12-03T17_03_35_839Z-debug.log
                What you need to do to "rebuild" the adapter and the dashboard works
                Docker image baunet 6.0.0beta1
                I managed it myself. this command helped - sudo apt install python3-pip
                  marsmännchen @Thomas Braun last edited by
                  @Dutchman
                  Danke für die Aktualisierung. Funktioniert jetzt auf dem Slave.
                  Aber hast du vielleicht eine Idee darüber :
                  https://forum.iobroker.net/topic/49960/esphome-probe-request-unsuccessful
                  MfG
                  Patrick
                  • Feuersturm
                    Feuersturm last edited by Feuersturm
                    @Dutchman Ich hatte heute folgende Fehlermeldung im Log
                    Ist für die Fargebung rot / gelb der Adapter oder der Admin verantwortlich? Warum wird beim esphome Fehler gelb statt z.B. des Orange (wie bei den Warnungen ) verwendet?
                    Hier mal der Fehler in lesbarer Form 😉
                    Bisher hab ich es noch nicht gesehen, dass innerhalb einer Warnung / Fehlers die Farbe wechselt.
                      Johannes Bauerstatter @Feuersturm last edited by
                      Hab heute den Pi 5x neu aufgesetzt und bring es einfach nicht zum laufen. Iobroker läuft.
                      Bei einer Installation war nach 4h Schluss.
                      Bevor ich jetzt wieder alles mache.
                      So wäre meine Ausgangslage:
                      Linux raspberrypi 5.10.63-v7l+ #1488 SMP Thu Nov 18 16:15:28 GMT 2021 armv7l
                      pi@raspberrypi:~ $ npm -v
                      6.14.15
                      pi@raspberrypi:~ $ node -v
                      v14.18.2
                      pi@raspberrypi:~ $ python
                      Python 2.7.18 (default, Jul 14 2021, 08:11:37)
                      [GCC 10.2.1 20210110] on linux2
                      Type "help", "copyright", "credits" or "license" for more information.
                      >>> quit()
                      pi@raspberrypi:~ $ python3
                      Python 3.9.2 (default, Mar 12 2021, 04:06:34)
                      >>> quit()
                      pi@raspberrypi:~ $
                      Ist das so OK? Soll ich lieber im Broker den Adapter installieren oder per npm i ....?
                        Was soll das aussagen?
                        Die Versionsnummer sehen aber i. O. aus.
                          @thomas-braun Der Adapter hat im Iobroker 4h lang installiert und hat sich dann beendet ohne das es installiert wurde. Ich versuch es nochmal.
                            Und wie hast du das gemacht?
                            Entweder über die Admin-GUI oder in der Konsole per
                            Das Beta-Repo muss allerdings dazu aktiv sein.
                              @thomas-braun Habs über die UI gemacht. Jetzt hab ich es mal über die Konsole per
                              gestartet.
                                    creating build/temp.linux-armv7l-3.9
                                    creating build/temp.linux-armv7l-3.9/c
                                    arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.9/c/_cffi_backend.o
                                    c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
                                        2 | #include <Python.h>
                                    compilation terminated.
                                    error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                                ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-opvq9x1b/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-lf7bqq4f/overlay --compile --install-headers /tmp/pip-build-env-lf7bqq4f/overlay/include/python3.9/cffi Check the logs for full command output.
                              WARNING: Discarding https://files.pythonhosted.org/packages/9b/77/461087a514d2e8ece1c975d8216bc03f7048e6090c5166bc34115afdaa53/cryptography-3.4.7.tar.gz#sha256=3d10de8116d25649631977cb37da6cbdd2d6fa0e0281d014a5b7d337255ca713 (from https://pypi.org/simple/cryptography/) (requires-python:>=3.6). Command errored out with exit status 1: /usr/bin/python3 /tmp/pip-standalone-pip-eo94u2mi/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-lf7bqq4f/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.12; platform_python_implementation != '"'"'PyPy'"'"'' 'setuptools-rust>=0.11.4' Check the logs for full command output.
                              pi@raspberrypi:~ $ iobroker update
                              Used repository: Beta (latest)
                              hash unchanged, use cached sources
                              update done
                              Adapter    "admin"         : 5.2.1    , installed 5.2.1
                              Adapter    "backitup"      : 2.2.2    , installed 2.2.2
                              Adapter    "discovery"     : 2.7.5    , installed 2.7.5
                              Adapter    "esphome"       : 0.2.4    , installed 0.2.4
                              Adapter    "info"          : 1.9.16   , installed 1.9.16
                              Controller "js-controller" : 3.3.21   , installed 3.3.21
                              pi@raspberrypi:~ $
                              In der Iobroker UI wird er unter Instanzen nicht angezeigt. Bei Adapter steht er als installiert 0.2.4.
                              Hab schon ein paar Reboots gemacht, aber er erscheint nicht auch das Dashboard kann nicht eingeblendet werden.
                                Da fehlen wohl die build-essentials
                                apt policy build-essential
                                Wenn die fehlen:
                                sudo apt install build-essential
                                  @thomas-braun said in [ESPHome] Beta release:
                                  pi@raspberrypi:~ $ sudo apt install build-essential
                                  build-essential is already the newest version (12.9).
                                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                  pi@raspberrypi:~ $
                                    Zeig mal mehr von der Fehlermeldung.
                                      apt policy python3-pip
                                        Nach einigen Neustarts und nochmaligen
                                        scheint es jetzt geklappt zu haben.
                                        Jetzt hab ich noch Probleme mit dem Dashboard.
                                        esphome.0	2021-12-04 21:00:05.313	warn	(1443) ESPHome Dashboard deactivated
                                        esphome.0	2021-12-04 21:00:05.199	error	(1443) [dashboardProcess ERROR] Error: ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome'
                                          Das ist offenbar nicht gebaut worden. Siehe die entsprechenden Fehlermeldungen weiter oben.
                                          Johannes Bauerstatter 2 Replies Last reply Reply Quote 0
                                            pi@raspberrypi:~ $ apt policy python3-pip
                                            python3-pip:
                                              Installed: 20.3.4-4+rpt1
                                              Candidate: 20.3.4-4+rpt1
                                              Version table:
                                             *** 20.3.4-4+rpt1 500
                                                    500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
                                                    100 /var/lib/dpkg/status
                                                 20.3.4-4 500
                                                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                            pi@raspberrypi:~ $
                                            Komisch auf meinem Proxmox System hat es immer ohne irgendwelche Probleme funktioniert. Kann es an der Kombi Raspi 4 mit Bullseye liegen? Hab deinen super Adapter schon oft in Proxmox eingesetzt aber sowas wie mit dem Raspi hat ich noch nie...
                                            Ich versuch nochmal im Iobroker Web de-installieren und neu installieren.
                                            1.0k
                                            591
                                            152484
