    4. [ESPHome] Beta release
    • Johannes Bauerstatter
      Johannes Bauerstatter @Thomas Braun last edited by Johannes Bauerstatter
      Ist eine ganz frische Installation auf einem Raspi 4.
      pi@raspberrypi:~ $ sudo apt install --reinstall lsb-release
      Reading package lists... Done
      Building dependency tree... Done
      0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
      Need to get 28.1 kB of archives.
      After this operation, 0 B of additional disk space will be used.
      Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf lsb-release all 11.1.0+rpi1 [28.1 kB]
      Fetched 28.1 kB in 1s (19.0 kB/s)
      Traceback (most recent call last):
        File "/usr/bin/apt-listchanges", line 29, in <module>
          import apt_pkg
      ModuleNotFoundError: No module named 'apt_pkg'
      (Reading database ... 50809 files and directories currently installed.)
      Preparing to unpack .../lsb-release_11.1.0+rpi1_all.deb ...
      Unpacking lsb-release (11.1.0+rpi1) over (11.1.0+rpi1) ...
      Setting up lsb-release (11.1.0+rpi1) ...
      Processing triggers for man-db (2.9.4-2) ...
      pi@raspberrypi:~ $
      NPM version: 6.14.15
      npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
      Exception:Traceback (most recent call last):  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 215, in main    status = self.run(options, args)  File "/tmp/tmpys8yyc8z/pip.zip/pip/commands/install.py", line 272, in run    with self._build_session(options) as session:  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 66, in _build_session    session = PipSession(  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 329, in __init__    self.headers["User-Agent"] = user_agent()  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 93, in user_agent    from pip._vendor import distro  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 1050, in <module>    _distro = LinuxDistribution()  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 593, in __init__    self._lsb_release_info = self._get_lsb_release_info() \  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_info    raise subprocess.CalledProcessError(code, cmd, stdout, stderr)subprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
      Traceback (most recent call last):  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
          main()  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main    bootstrap(tmpdir=tmpdir)  File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 172, in bootstrap    sys.exit(pip.main(["install", "--upgrade"] + args))  File "/tmp/tmpys8yyc8z/pip.zip/pip/__init__.py", line 233, in main  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 248, in main  File "/tmp/tmpys8yyc8z/pip.zip/pip/basecommand.py", line 66, in _build_session  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 329, in __init__  File "/tmp/tmpys8yyc8z/pip.zip/pip/download.py", line 93, in user_agent  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible  File "<frozen zipimport>", line 259, in load_module  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 1050, in <module>  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 593, in __init__  File "/tmp/tmpys8yyc8z/pip.zip/pip/_vendor/distro.py", line 931, in _get_lsb_release_infosubprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1.
      Error: Exited with code 1.    at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)    at ChildProcess.emit (events.js:400:28)
          at maybeClose (internal/child_process.js:1058:16)    at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.esphome@0.2.4 install: `npip install`npm ERR! Exit status 1
      npm ERR! npm ERR! Failed at the iobroker.esphome@0.2.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-12-03T15_55_36_557Z-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.esphome@0.2.4: 1
      ERROR: process exited with code 25
        Thomas Braun Most Active @Johannes Bauerstatter last edited by
        @johannes-bauerstatter sagte in [ESPHome] Beta release:
        ModuleNotFoundError: No module named 'apt_pkg'        (Reading database ... 50809 files and directories currently installed.)
        Gaaaaaaanz merkwürdige Meldungen. Was zur Hölle hast du da wie installiert?
        Ich würd's nochmal ganz frisch installieren.
        Johannes Bauerstatter O 2 Replies Last reply Reply Quote 0
          @thomas-braun Ok. Welche Python Version soll ich nehmen?
            Thomas Braun Most Active @Johannes Bauerstatter last edited by Thomas Braun
            Die vorgesehene/vorinstallierte?
            Da ist was total schräg bei dir. Hier ist das ganz fluffig:
            echad@chet:~ $ iobroker install esphome
            NPM version: 8.1.4
            host.chet install adapter esphome
            upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
            upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
            upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
            upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
            upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png
            upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
            host.chet object system.adapter.esphome created/updated
            Aus der Readme:
            Required
            • NodeJS >= 12.x
            • Python >=3.7, <4.0
            • API is activated in YAML
              Anzic last edited by Anzic
              Switched to NodeJS version 14 frome 12. The dashboard stopped working. Although the adapter itself works. There is such an error in the log:
              esphome.0
              2021-12-03 19:55:22.625	warn	ESPHome Dashboard deactivated
              esphome.0
              2021-12-03 19:55:22.589	error	[dashboardProcess ERROR] from esphome.__main__ import mainModuleNotFoundError: No module named 'esphome'
              esphome.0
              2021-12-03 19:55:22.588	error	[dashboardProcess ERROR] Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome", line 5, in <module>
              I try to execute iobroker rebuild esphome and iobroker rebuild esphome --install I get this error:
              root@iobroker:/opt/iobroker# iobroker rebuild esphome --install
              npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.esphome"
              /usr/bin/python3: No module named pip
              npm ERR! errno 1
              npm ERR!
              npm ERR!     /opt/iobroker/.npm/_logs/2021-12-03T17_03_35_839Z-debug.log
              What you need to do to "rebuild" the adapter and the dashboard works
              Docker image baunet 6.0.0beta1
              I managed it myself. this command helped - sudo apt install python3-pip
                marsmännchen @Thomas Braun last edited by
                @Dutchman
                Danke für die Aktualisierung. Funktioniert jetzt auf dem Slave.
                Aber hast du vielleicht eine Idee darüber :
                https://forum.iobroker.net/topic/49960/esphome-probe-request-unsuccessful
                MfG
                Patrick
                • Feuersturm
                  Feuersturm last edited by Feuersturm
                  @Dutchman Ich hatte heute folgende Fehlermeldung im Log
                  Ist für die Fargebung rot / gelb der Adapter oder der Admin verantwortlich? Warum wird beim esphome Fehler gelb statt z.B. des Orange (wie bei den Warnungen ) verwendet?
                  Hier mal der Fehler in lesbarer Form 😉
                  Bisher hab ich es noch nicht gesehen, dass innerhalb einer Warnung / Fehlers die Farbe wechselt.
                  Johannes Bauerstatter 1 Reply Last reply Reply Quote 0
                    Johannes Bauerstatter @Feuersturm last edited by
                    Hab heute den Pi 5x neu aufgesetzt und bring es einfach nicht zum laufen. Iobroker läuft.
                    Bei einer Installation war nach 4h Schluss.
                    Bevor ich jetzt wieder alles mache.
                    So wäre meine Ausgangslage:
                    Linux raspberrypi 5.10.63-v7l+ #1488 SMP Thu Nov 18 16:15:28 GMT 2021 armv7l
                    pi@raspberrypi:~ $ npm -v
                    6.14.15
                    pi@raspberrypi:~ $ node -v
                    v14.18.2
                    pi@raspberrypi:~ $ python
                    Python 2.7.18 (default, Jul 14 2021, 08:11:37)
                    [GCC 10.2.1 20210110] on linux2
                    Type "help", "copyright", "credits" or "license" for more information.
                    >>> quit()
                    pi@raspberrypi:~ $ python3
                    Python 3.9.2 (default, Mar 12 2021, 04:06:34)
                    >>> quit()
                    pi@raspberrypi:~ $
                    Ist das so OK? Soll ich lieber im Broker den Adapter installieren oder per npm i ....?
                      Was soll das aussagen?
                      Die Versionsnummer sehen aber i. O. aus.
                        @thomas-braun Der Adapter hat im Iobroker 4h lang installiert und hat sich dann beendet ohne das es installiert wurde. Ich versuch es nochmal.
                          Und wie hast du das gemacht?
                          Entweder über die Admin-GUI oder in der Konsole per
                          Das Beta-Repo muss allerdings dazu aktiv sein.
                            @thomas-braun Habs über die UI gemacht. Jetzt hab ich es mal über die Konsole per
                            gestartet.
                                  creating build/temp.linux-armv7l-3.9
                                  creating build/temp.linux-armv7l-3.9/c
                                  arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.9/c/_cffi_backend.o
                                  c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
                                      2 | #include <Python.h>
                                  compilation terminated.
                                  error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                              ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-opvq9x1b/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-lf7bqq4f/overlay --compile --install-headers /tmp/pip-build-env-lf7bqq4f/overlay/include/python3.9/cffi Check the logs for full command output.
                            WARNING: Discarding https://files.pythonhosted.org/packages/9b/77/461087a514d2e8ece1c975d8216bc03f7048e6090c5166bc34115afdaa53/cryptography-3.4.7.tar.gz#sha256=3d10de8116d25649631977cb37da6cbdd2d6fa0e0281d014a5b7d337255ca713 (from https://pypi.org/simple/cryptography/) (requires-python:>=3.6). Command errored out with exit status 1: /usr/bin/python3 /tmp/pip-standalone-pip-eo94u2mi/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-lf7bqq4f/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.12; platform_python_implementation != '"'"'PyPy'"'"'' 'setuptools-rust>=0.11.4' Check the logs for full command output.
                            pi@raspberrypi:~ $ iobroker update
                            Used repository: Beta (latest)
                            hash unchanged, use cached sources
                            update done
                            Adapter    "admin"         : 5.2.1    , installed 5.2.1
                            Adapter    "backitup"      : 2.2.2    , installed 2.2.2
                            Adapter    "discovery"     : 2.7.5    , installed 2.7.5
                            Adapter    "esphome"       : 0.2.4    , installed 0.2.4
                            Adapter    "info"          : 1.9.16   , installed 1.9.16
                            Controller "js-controller" : 3.3.21   , installed 3.3.21
                            pi@raspberrypi:~ $
                            In der Iobroker UI wird er unter Instanzen nicht angezeigt. Bei Adapter steht er als installiert 0.2.4.
                            Hab schon ein paar Reboots gemacht, aber er erscheint nicht auch das Dashboard kann nicht eingeblendet werden.
                              Da fehlen wohl die build-essentials
                              apt policy build-essential
                              Wenn die fehlen:
                              sudo apt install build-essential
                                @thomas-braun said in [ESPHome] Beta release:
                                pi@raspberrypi:~ $ sudo apt install build-essential
                                build-essential is already the newest version (12.9).
                                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                pi@raspberrypi:~ $
                                  Zeig mal mehr von der Fehlermeldung.
                                    apt policy python3-pip
                                      Nach einigen Neustarts und nochmaligen
                                      scheint es jetzt geklappt zu haben.
                                      Jetzt hab ich noch Probleme mit dem Dashboard.
                                      esphome.0	2021-12-04 21:00:05.313	warn	(1443) ESPHome Dashboard deactivated
                                      esphome.0	2021-12-04 21:00:05.199	error	(1443) [dashboardProcess ERROR] Error: ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome'
                                        Das ist offenbar nicht gebaut worden. Siehe die entsprechenden Fehlermeldungen weiter oben.
                                        Johannes Bauerstatter 2 Replies Last reply Reply Quote 0
                                          pi@raspberrypi:~ $ apt policy python3-pip
                                          python3-pip:
                                            Installed: 20.3.4-4+rpt1
                                            Candidate: 20.3.4-4+rpt1
                                            Version table:
                                           *** 20.3.4-4+rpt1 500
                                                  500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
                                                  100 /var/lib/dpkg/status
                                               20.3.4-4 500
                                                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                          pi@raspberrypi:~ $
                                          Komisch auf meinem Proxmox System hat es immer ohne irgendwelche Probleme funktioniert. Kann es an der Kombi Raspi 4 mit Bullseye liegen? Hab deinen super Adapter schon oft in Proxmox eingesetzt aber sowas wie mit dem Raspi hat ich noch nie...
                                          Ich versuch nochmal im Iobroker Web de-installieren und neu installieren.
                                            Nein, die Kombi hab ich hier auch.
                                            Der ist nicht von mir.
                                            1.0k
                                            591
                                            152484
