    4. [ESPHome] Beta release
    • Johannes Bauerstatter
      Johannes Bauerstatter @Thomas Braun last edited by
      @thomas-braun Ok. Welche Python Version soll ich nehmen?
        Thomas Braun Most Active @Johannes Bauerstatter last edited by Thomas Braun
        @johannes-bauerstatter
        Die vorgesehene/vorinstallierte?
        Da ist was total schräg bei dir. Hier ist das ganz fluffig:
        echad@chet:~ $ iobroker install esphome
        NPM version: 8.1.4
        npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
        host.chet install adapter esphome
        upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
        upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
        upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
        upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
        upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png
        upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
        host.chet object system.adapter.esphome created/updated
        Aus der Readme:
        Required
        • NodeJS >= 12.x
        • Python >=3.7, <4.0
        • API is activated in YAML
          Anzic last edited by Anzic
          Switched to NodeJS version 14 frome 12. The dashboard stopped working. Although the adapter itself works. There is such an error in the log:
          esphome.0
          2021-12-03 19:55:22.625	warn	ESPHome Dashboard deactivated
          esphome.0
          2021-12-03 19:55:22.589	error	[dashboardProcess ERROR] from esphome.__main__ import mainModuleNotFoundError: No module named 'esphome'
          esphome.0
          2021-12-03 19:55:22.588	error	[dashboardProcess ERROR] Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome", line 5, in <module>
          I try to execute iobroker rebuild esphome and iobroker rebuild esphome --install I get this error:
          root@iobroker:/opt/iobroker# iobroker rebuild esphome --install
          npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.esphome"
          /usr/bin/python3: No module named pip
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! iobroker.esphome@0.2.4 install: `npip install`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the iobroker.esphome@0.2.4 install script.
          npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR!     /opt/iobroker/.npm/_logs/2021-12-03T17_03_35_839Z-debug.log
          What you need to do to "rebuild" the adapter and the dashboard works
          Docker image baunet 6.0.0beta1
          I managed it myself. this command helped - sudo apt install python3-pip
            marsmännchen @Thomas Braun last edited by
            @Dutchman
            Danke für die Aktualisierung. Funktioniert jetzt auf dem Slave.
            Aber hast du vielleicht eine Idee darüber :
            https://forum.iobroker.net/topic/49960/esphome-probe-request-unsuccessful
            MfG
            Patrick
            • Feuersturm
              Feuersturm last edited by Feuersturm
              @Dutchman Ich hatte heute folgende Fehlermeldung im Log
              Ist für die Fargebung rot / gelb der Adapter oder der Admin verantwortlich? Warum wird beim esphome Fehler gelb statt z.B. des Orange (wie bei den Warnungen ) verwendet?
              Hier mal der Fehler in lesbarer Form 😉
              Bisher hab ich es noch nicht gesehen, dass innerhalb einer Warnung / Fehlers die Farbe wechselt.
              Johannes Bauerstatter 1 Reply Last reply Reply Quote 0
                Johannes Bauerstatter @Feuersturm last edited by
                Hab heute den Pi 5x neu aufgesetzt und bring es einfach nicht zum laufen. Iobroker läuft.
                Bei einer Installation war nach 4h Schluss.
                Bevor ich jetzt wieder alles mache.
                So wäre meine Ausgangslage:
                Linux raspberrypi 5.10.63-v7l+ #1488 SMP Thu Nov 18 16:15:28 GMT 2021 armv7l
                pi@raspberrypi:~ $ npm -v
                6.14.15
                pi@raspberrypi:~ $ node -v
                v14.18.2
                pi@raspberrypi:~ $ python
                Python 2.7.18 (default, Jul 14 2021, 08:11:37)
                [GCC 10.2.1 20210110] on linux2
                Type "help", "copyright", "credits" or "license" for more information.
                >>> quit()
                pi@raspberrypi:~ $ python3
                Python 3.9.2 (default, Mar 12 2021, 04:06:34)
                >>> quit()
                pi@raspberrypi:~ $
                Ist das so OK? Soll ich lieber im Broker den Adapter installieren oder per npm i ....?
                  @johannes-bauerstatter sagte in [ESPHome] Beta release:
                  Was soll das aussagen?
                  Die Versionsnummer sehen aber i. O. aus.
                    @thomas-braun Der Adapter hat im Iobroker 4h lang installiert und hat sich dann beendet ohne das es installiert wurde. Ich versuch es nochmal.
                      Und wie hast du das gemacht?
                      Entweder über die Admin-GUI oder in der Konsole per
                      Das Beta-Repo muss allerdings dazu aktiv sein.
                        Johannes Bauerstatter @Thomas Braun last edited by Johannes Bauerstatter
                        @thomas-braun Habs über die UI gemacht. Jetzt hab ich es mal über die Konsole per
                        gestartet.
                              creating build/temp.linux-armv7l-3.9
                              creating build/temp.linux-armv7l-3.9/c
                              arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.9/c/_cffi_backend.o
                              c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
                                  2 | #include <Python.h>
                              compilation terminated.
                              error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                          ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-opvq9x1b/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-lf7bqq4f/overlay --compile --install-headers /tmp/pip-build-env-lf7bqq4f/overlay/include/python3.9/cffi Check the logs for full command output.
                        WARNING: Discarding https://files.pythonhosted.org/packages/9b/77/461087a514d2e8ece1c975d8216bc03f7048e6090c5166bc34115afdaa53/cryptography-3.4.7.tar.gz#sha256=3d10de8116d25649631977cb37da6cbdd2d6fa0e0281d014a5b7d337255ca713 (from https://pypi.org/simple/cryptography/) (requires-python:>=3.6). Command errored out with exit status 1: /usr/bin/python3 /tmp/pip-standalone-pip-eo94u2mi/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-lf7bqq4f/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.12; platform_python_implementation != '"'"'PyPy'"'"'' 'setuptools-rust>=0.11.4' Check the logs for full command output.
                        pi@raspberrypi:~ $ iobroker update
                        Used repository: Beta (latest)
                        hash unchanged, use cached sources
                        update done
                        Adapter    "admin"         : 5.2.1    , installed 5.2.1
                        Adapter    "backitup"      : 2.2.2    , installed 2.2.2
                        Adapter    "discovery"     : 2.7.5    , installed 2.7.5
                        Adapter    "esphome"       : 0.2.4    , installed 0.2.4
                        Adapter    "info"          : 1.9.16   , installed 1.9.16
                        Controller "js-controller" : 3.3.21   , installed 3.3.21
                        pi@raspberrypi:~ $
                        In der Iobroker UI wird er unter Instanzen nicht angezeigt. Bei Adapter steht er als installiert 0.2.4.
                        Hab schon ein paar Reboots gemacht, aber er erscheint nicht auch das Dashboard kann nicht eingeblendet werden.
                          Da fehlen wohl die build-essentials
                          apt policy build-essential
                          Wenn die fehlen:
                          sudo apt install build-essential
                            @thomas-braun said in [ESPHome] Beta release:
                            pi@raspberrypi:~ $ sudo apt install build-essential
                            Reading package lists... Done
                            Building dependency tree... Done
                            build-essential is already the newest version (12.9).
                            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            pi@raspberrypi:~ $
                              Zeig mal mehr von der Fehlermeldung.
                                apt policy python3-pip
                                  Nach einigen Neustarts und nochmaligen
                                  scheint es jetzt geklappt zu haben.
                                  Jetzt hab ich noch Probleme mit dem Dashboard.
                                  esphome.0	2021-12-04 21:00:05.313	warn	(1443) ESPHome Dashboard deactivated
                                  esphome.0	2021-12-04 21:00:05.199	error	(1443) [dashboardProcess ERROR] Error: ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome'
                                    Das ist offenbar nicht gebaut worden. Siehe die entsprechenden Fehlermeldungen weiter oben.
                                    Johannes Bauerstatter 2 Replies Last reply Reply Quote 0
                                      pi@raspberrypi:~ $ apt policy python3-pip
                                      python3-pip:
                                        Installed: 20.3.4-4+rpt1
                                        Candidate: 20.3.4-4+rpt1
                                        Version table:
                                       *** 20.3.4-4+rpt1 500
                                              500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
                                              100 /var/lib/dpkg/status
                                           20.3.4-4 500
                                              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                      pi@raspberrypi:~ $
                                      Komisch auf meinem Proxmox System hat es immer ohne irgendwelche Probleme funktioniert. Kann es an der Kombi Raspi 4 mit Bullseye liegen? Hab deinen super Adapter schon oft in Proxmox eingesetzt aber sowas wie mit dem Raspi hat ich noch nie...
                                      Ich versuch nochmal im Iobroker Web de-installieren und neu installieren.
                                        Nein, die Kombi hab ich hier auch.
                                        Der ist nicht von mir.
                                          @thomas-braun Vielen, vielen Dank für deine Bemühungen. Es läuft jetzt. Im Endeffekt musste ich es ein paar mal installieren - deinstallieren, zwischendurch Neustarten bis es funktioniert hat.
                                          @Dutchman Danke für den Adapter.
                                            marsmännchen @Johannes Bauerstatter last edited by marsmännchen
                                            Gibt es eine Möglichkeit ein älteres Release (0.2.3) von GitHub zu installieren? Finde einfach nicht raus wie ich das hinbekomme. Wollte sehen ob es mit dem alten Dashboard wieder funktioniert.
                                            Beim Übertragen des Yaml files habe ich im Log von ESPHome auch etwas gefunden:
                                            Compiling .pioenvs/esp32002/FrameworkArduino/esp32-hal-time.c.o
                                            /home/iobroker/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-spi.c: In function 'spiTransferBytesNL':
                                            /home/iobroker/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-spi.c:922:39: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
                                                             uint8_t * last_out8 = &result[c_longs-1];
                                            /home/iobroker/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-spi.c:923:40: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
                                                             uint8_t * last_data8 = &last_data;
                                            Kann mein Problem damit zusammenhängen?
                                            Edit:
                                            OK, Problem gelöst!
                                            Für die Nachwelt: Solche SSID´s wie: "Trojaner-Verteilersystem Alpha_3" funktionieren scheinbar nicht mehr.
                                            591
                                            152854
