    4. [ESPHome] Beta release
      Anzic last edited by Anzic
      Switched to NodeJS version 14 frome 12. The dashboard stopped working. Although the adapter itself works. There is such an error in the log:
      esphome.0
      2021-12-03 19:55:22.625	warn	ESPHome Dashboard deactivated
      esphome.0
      2021-12-03 19:55:22.589	error	[dashboardProcess ERROR] from esphome.__main__ import mainModuleNotFoundError: No module named 'esphome'
      esphome.0
      2021-12-03 19:55:22.588	error	[dashboardProcess ERROR] Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome", line 5, in <module>
      I try to execute iobroker rebuild esphome and iobroker rebuild esphome --install I get this error:
      root@iobroker:/opt/iobroker# iobroker rebuild esphome --install
      npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.esphome"
      /usr/bin/python3: No module named pip
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.esphome@0.2.4 install: `npip install`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.esphome@0.2.4 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /opt/iobroker/.npm/_logs/2021-12-03T17_03_35_839Z-debug.log
      What you need to do to "rebuild" the adapter and the dashboard works
      Docker image baunet 6.0.0beta1
      I managed it myself. this command helped - sudo apt install python3-pip
        marsmännchen @Thomas Braun last edited by
        @Dutchman
        Danke für die Aktualisierung. Funktioniert jetzt auf dem Slave.
        Aber hast du vielleicht eine Idee darüber :
        https://forum.iobroker.net/topic/49960/esphome-probe-request-unsuccessful
        MfG
        Patrick
        • Feuersturm
          Feuersturm last edited by Feuersturm
          @Dutchman Ich hatte heute folgende Fehlermeldung im Log
          Ist für die Fargebung rot / gelb der Adapter oder der Admin verantwortlich? Warum wird beim esphome Fehler gelb statt z.B. des Orange (wie bei den Warnungen ) verwendet?
          Hier mal der Fehler in lesbarer Form 😉
          Bisher hab ich es noch nicht gesehen, dass innerhalb einer Warnung / Fehlers die Farbe wechselt.
          Johannes Bauerstatter 1 Reply Last reply Reply Quote 0
          • Johannes Bauerstatter
            Johannes Bauerstatter @Feuersturm last edited by
            Hab heute den Pi 5x neu aufgesetzt und bring es einfach nicht zum laufen. Iobroker läuft.
            Bei einer Installation war nach 4h Schluss.
            Bevor ich jetzt wieder alles mache.
            So wäre meine Ausgangslage:
            Linux raspberrypi 5.10.63-v7l+ #1488 SMP Thu Nov 18 16:15:28 GMT 2021 armv7l
            pi@raspberrypi:~ $ npm -v
            6.14.15
            pi@raspberrypi:~ $ node -v
            v14.18.2
            pi@raspberrypi:~ $ python
            Python 2.7.18 (default, Jul 14 2021, 08:11:37)
            [GCC 10.2.1 20210110] on linux2
            Type "help", "copyright", "credits" or "license" for more information.
            >>> quit()
            pi@raspberrypi:~ $ python3
            Python 3.9.2 (default, Mar 12 2021, 04:06:34)
            >>> quit()
            pi@raspberrypi:~ $
            Ist das so OK? Soll ich lieber im Broker den Adapter installieren oder per npm i ....?
              Thomas Braun Most Active @Johannes Bauerstatter last edited by
              @johannes-bauerstatter sagte in [ESPHome] Beta release:
              Was soll das aussagen?
              Die Versionsnummer sehen aber i. O. aus.
                Johannes Bauerstatter @Thomas Braun last edited by
                @thomas-braun Der Adapter hat im Iobroker 4h lang installiert und hat sich dann beendet ohne das es installiert wurde. Ich versuch es nochmal.
                  Thomas Braun Most Active @Johannes Bauerstatter last edited by Thomas Braun
                  Und wie hast du das gemacht?
                  Entweder über die Admin-GUI oder in der Konsole per
                  iobroker install esphome
                  Das Beta-Repo muss allerdings dazu aktiv sein.
                    Johannes Bauerstatter @Thomas Braun last edited by Johannes Bauerstatter
                    @thomas-braun Habs über die UI gemacht. Jetzt hab ich es mal über die Konsole per
                    gestartet.
                          creating build/temp.linux-armv7l-3.9
                          creating build/temp.linux-armv7l-3.9/c
                          arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.9/c/_cffi_backend.o
                          c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
                              2 | #include <Python.h>
                          compilation terminated.
                          error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                      ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5ijkwnli/cffi_16d10301de7c4069acead825ae282b6b/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-opvq9x1b/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-lf7bqq4f/overlay --compile --install-headers /tmp/pip-build-env-lf7bqq4f/overlay/include/python3.9/cffi Check the logs for full command output.
                    WARNING: Discarding https://files.pythonhosted.org/packages/9b/77/461087a514d2e8ece1c975d8216bc03f7048e6090c5166bc34115afdaa53/cryptography-3.4.7.tar.gz#sha256=3d10de8116d25649631977cb37da6cbdd2d6fa0e0281d014a5b7d337255ca713 (from https://pypi.org/simple/cryptography/) (requires-python:>=3.6). Command errored out with exit status 1: /usr/bin/python3 /tmp/pip-standalone-pip-eo94u2mi/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-lf7bqq4f/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.12; platform_python_implementation != '"'"'PyPy'"'"'' 'setuptools-rust>=0.11.4' Check the logs for full command output.
                    pi@raspberrypi:~ $ iobroker update
                    Used repository: Beta (latest)
                    hash unchanged, use cached sources
                    update done
                    Adapter    "admin"         : 5.2.1    , installed 5.2.1
                    Adapter    "backitup"      : 2.2.2    , installed 2.2.2
                    Adapter    "discovery"     : 2.7.5    , installed 2.7.5
                    Adapter    "esphome"       : 0.2.4    , installed 0.2.4
                    Adapter    "info"          : 1.9.16   , installed 1.9.16
                    Controller "js-controller" : 3.3.21   , installed 3.3.21
                    pi@raspberrypi:~ $
                    In der Iobroker UI wird er unter Instanzen nicht angezeigt. Bei Adapter steht er als installiert 0.2.4.
                    Hab schon ein paar Reboots gemacht, aber er erscheint nicht auch das Dashboard kann nicht eingeblendet werden.
                      Da fehlen wohl die build-essentials
                      apt policy build-essential
                      Wenn die fehlen:
                      sudo apt install build-essential
                        @thomas-braun said in [ESPHome] Beta release:
                        pi@raspberrypi:~ $ sudo apt install build-essential
                        Reading package lists... Done
                        Building dependency tree... Done
                        build-essential is already the newest version (12.9).
                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        pi@raspberrypi:~ $
                          Zeig mal mehr von der Fehlermeldung.
                            apt policy python3-pip
                              Nach einigen Neustarts und nochmaligen
                              scheint es jetzt geklappt zu haben.
                              Jetzt hab ich noch Probleme mit dem Dashboard.
                              esphome.0	2021-12-04 21:00:05.313	warn	(1443) ESPHome Dashboard deactivated
                              esphome.0	2021-12-04 21:00:05.199	error	(1443) [dashboardProcess ERROR] Error: ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome'
                                Das ist offenbar nicht gebaut worden. Siehe die entsprechenden Fehlermeldungen weiter oben.
                                Johannes Bauerstatter 2 Replies Last reply Reply Quote 0
                                  pi@raspberrypi:~ $ apt policy python3-pip
                                  python3-pip:
                                    Installed: 20.3.4-4+rpt1
                                    Candidate: 20.3.4-4+rpt1
                                    Version table:
                                   *** 20.3.4-4+rpt1 500
                                          500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
                                          100 /var/lib/dpkg/status
                                       20.3.4-4 500
                                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                  pi@raspberrypi:~ $
                                  Komisch auf meinem Proxmox System hat es immer ohne irgendwelche Probleme funktioniert. Kann es an der Kombi Raspi 4 mit Bullseye liegen? Hab deinen super Adapter schon oft in Proxmox eingesetzt aber sowas wie mit dem Raspi hat ich noch nie...
                                  Ich versuch nochmal im Iobroker Web de-installieren und neu installieren.
                                    Nein, die Kombi hab ich hier auch.
                                    Der ist nicht von mir.
                                      @thomas-braun Vielen, vielen Dank für deine Bemühungen. Es läuft jetzt. Im Endeffekt musste ich es ein paar mal installieren - deinstallieren, zwischendurch Neustarten bis es funktioniert hat.
                                      @Dutchman Danke für den Adapter.
                                        marsmännchen @Johannes Bauerstatter last edited by marsmännchen
                                        Gibt es eine Möglichkeit ein älteres Release (0.2.3) von GitHub zu installieren? Finde einfach nicht raus wie ich das hinbekomme. Wollte sehen ob es mit dem alten Dashboard wieder funktioniert.
                                        Beim Übertragen des Yaml files habe ich im Log von ESPHome auch etwas gefunden:
                                        Compiling .pioenvs/esp32002/FrameworkArduino/esp32-hal-time.c.o
                                        /home/iobroker/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-spi.c: In function 'spiTransferBytesNL':
                                        /home/iobroker/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-spi.c:922:39: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
                                                         uint8_t * last_out8 = &result[c_longs-1];
                                        /home/iobroker/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-spi.c:923:40: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
                                                         uint8_t * last_data8 = &last_data;
                                        Kann mein Problem damit zusammenhängen?
                                        Edit:
                                        OK, Problem gelöst!
                                        Für die Nachwelt: Solche SSID´s wie: "Trojaner-Verteilersystem Alpha_3" funktionieren scheinbar nicht mehr.
                                          Johannes Bauerstatter @marsmännchen last edited by
                                          Hallo, hab erfolgreich eine Sonoff Bridge mit Esphome bespielt.
                                          Ich empfange bereits im Log den Code kenne mich aber mit den then zu wenig aus. Wenn dieser Code empfangen wird soll ein Datenpunkt im Iobroker auf True springen und nach 1sec wieder zurück auf false.
                                          [D][rf_bridge:056]: Received RFBridge Code: sync=0x32AA low=0x01AE high=0x04EC code=0x550954
                                          Yaml:
                                          esphome:
                                            platform: ESP8266
                                            board: esp01_1m
                                          wifi:
                                            ssid:
                                            password:
                                          logger:
                                            baud_rate: 0
                                          api:
                                          ota:
                                          # Web Server
                                          web_server:
                                            port: 80
                                          uart:
                                            tx_pin: GPIO01
                                            rx_pin: GPIO03
                                            baud_rate: 19200
                                          rf_bridge:
                                            on_code_received:
                                              then:
                                            Johannes Bauerstatter @Johannes Bauerstatter last edited by Johannes Bauerstatter
                                            @johannes-bauerstatter Hallo, konnte es doch lösen.
                                            Falls es jemand brauchen kann:
                                            # Web Server
                                            web_server:
                                              port: 80
                                            uart:
                                              tx_pin: GPIO01
                                              rx_pin: GPIO03
                                              baud_rate: 19200
                                            rf_bridge:
                                              on_code_received:
                                                then:
                                                  - if:
                                                      condition:
                                                        lambda: |-
                                                          return data.code == 0x550954;
                                                      then:
                                                        - binary_sensor.template.publish:
                                                            state: True
                                                        - delay: 2s
                                                            state: False
                                            binary_sensor:
                                              platform: template
                                            mac89muc 1 Reply Last reply Reply Quote 1
                                            1.0k
                                            591
                                            152492
