    4. Admin 1.7.0 Fehler
    Admin 1.7.0 Fehler
    • vauvau07
      vauvau07 last edited by
      Es kann auch einwandfrei funktionieren.
      • N
        Nepomukl last edited by
        Der Aufruf mit
        "iobroker start admin.0"
        brachte wieder Leben in meinen Broker. Er hat sich aber gefühlt sehr zäh wieder hoch geschraubt obwohl auf einem Cubie.
        Anfangs kamen etliche Fehlermeldungen
        vis.0	2017-03-08 20:09:58.568	error	at ontimeout (timers.js:365:14)
        vis.0	2017-03-08 20:09:58.568	error	at Timeout._onTimeout (/ssd/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2581:27)
        vis.0	2017-03-08 20:09:58.568	error	at new ObjectsInMemServer (/ssd/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2734:7)
        vis.0	2017-03-08 20:09:58.568	error	at /ssd/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2727:9
        vis.0	2017-03-08 20:09:58.568	error	at _initWebServer (/ssd/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2629:24)
        vis.0	2017-03-08 20:09:58.568	error	at Server.listen (net.js:1391:5)
        vis.0	2017-03-08 20:09:58.568	error	at listen (net.js:1295:10)
        vis.0	2017-03-08 20:09:58.568	error	at Server._listen2 (net.js:1259:14)
        vis.0	2017-03-08 20:09:58.568	error	at exports._exceptionWithHostPort (util.js:1045:20)
        vis.0	2017-03-08 20:09:58.568	error	at Object.exports._errnoException (util.js:1022:11)
        vis.0	2017-03-08 20:09:58.568	error	Error: listen EADDRINUSE :::9001
        vis.0	2017-03-08 20:09:58.568	error	^
        vis.0	2017-03-08 20:09:58.568	error	events.js:160 throw er; // Unhandled 'error' event
        telegram.0	2017-03-08 20:09:42.552	error	no connection to objects DB
        sayit.0	2017-03-08 20:09:27.174	error	no connection to objects DB
        ical.0	2017-03-08 20:09:24.182	error	no connection to objects DB
        text2command.0	2017-03-08 20:09:23.250	error	no connection to objects DB
        hm-rpc.0	2017-03-08 20:09:18.981	error	no connection to states DB: Connection timeout
        scenes.0	2017-03-08 20:09:15.894	error	no connection to states DB: Connection timeout
        javascript.0	2017-03-08 20:09:08.355	error	no connection to states DB: Connection timeout
        web.0	2017-03-08 20:08:57.330	error	no connection to states DB: Connection timeout
        vis.0	2017-03-08 20:08:56.952	error	no connection to states DB: Connection timeout
        denke aber das da das Timing nicht gepasst hat. Jetzt ist Ruhe und es lüppt wie es soll (denke ich).
        Den hm-rpc musste ich als einzigen per Hand noch einmal durch starten, der hatte irgendwie geklemmt.
        Andreas
        • N
          nobse last edited by
          Hallo
          habe auch das Update 0.16.2 problemlos durchgeführt.
          C:\ioBroker>npm -v
          3.10.10
          C:\ioBroker>node -v
          v6.10.0
          Mein ioBroker läuft auf einem Windows Server 2012 und nach Start vom ioBroker werden 7 NODE Fenster gestartet. Wenn ich diese dann schliesse stürtst ioBroker ab.
          Wie kann ich verhindern das diese 7 Fenster geöffnet werden.
          Vielen Dank
          • Bluefox
            Bluefox last edited by
            Unter windows läuft ioBroker wie ein Service. Wenn ein Fenster angezeigt wird, heißt es iobroker wird als Program gestartet.
            Am Besten du stoppst iobroker service
            net stop iobroker
            Schließt auch alle Fenster
            und dann wieder den Service startest
            net start iobroker
            starten stoppen geht nur als Administrator.
            • Bluefox
              @Nepomukl:
              Der Aufruf mit
              Andreas `
              Hast du vom update ioBroker gestoppt? Sieht so aus als nicht.
              • N
                @Bluefox Vielen Dank jetzt sind die Fenster weg. Das war aber erst nach dem Update so. Vorher ging es immer ohne Fenster.
                • N
                  Jo Bluefox,
                  war gestoppt. Den ersten Updateversuch hatte ich von der Weboberfläche gestartet.
                  Da blieb er ja hängen. Obwohl da stand iobroker gestoppt oder so ähnlich.
                  Auf der Konsole konnte ich ihn dann nochmals stoppen.
                  Alle weiteren Schritte waren dann nur noch Konsole.
                  Die Fehlermeldungen kamen dann als die Weboberfläche wieder erreichbar war.
                  • N
                    So, ich glaube ich habe das Problem bei mir identifiziert.
                    Sobald ich in der Konfig des Admin Adapters von allen IP-Adressen auf die IP-Adresse des Cubies umstelle
                    geht nichts mehr.
                    Beim speichern und schließen des Konfigdialoges bleibt dieser auch stehen.
                    Im Anschluss bleibt die Weboberfläche weg. Im Hintergrund läuft noch alles.
                    Kann die Einstellung so bleiben auf alle IP's?
                    Und wo kann ich die Konfig zurück stellen? Welches File speichert die Werte?
                    Denn wenn ich ein Backup zurück hole ist es das gleiche Spiel. Es sei denn es ist ein ganz altes.
                    Gruß Andreas
                    • N
                      Hat keiner eine Idee?
                      hab schon in iobroker-data/files/admin.admin weg gelöscht und den Admin Adapter neu installiert.
                      Komme immer noch nicht auf die Weboberfläche.
                      Sagt mir wenigstens wo die Javascripte gespeichert sind. Das ich die nicht alle neu machen muss, welchen Ordner muss ich seperat sichern.
                      Für die ganzen Views muss ich ja nur iobroker-data/files/Vis sichern, oder?
                      Dann kann ich nämlich auch mit einer alten Datensicherung leben.
                        apollon77 last edited by
                        Versuch doch mal iobroker add admin … dann gibts im Zweifel ne neue Admin instanz die tut 🙂 vorher ggf mit iobroker stopn admin.0 die nicht gehende ausmachen.
                        War das nicht so das man "0.0.0.0" wählen muss beim Bindung weil sonst komische Dinge passieren ?!
                        • N
                          Besten Dank
                          Admin.1 läuft. Konnte jetzt Admin.0 weg löschen.
                          Werde dann noch probieren auf die 0 zurück zu kommen.
                          Woher soll man denn das wissen mit dem 0.0.0.0 ?
                          Da sollte zumindest die Auswahl gesperrt werden.
                            @Nepomukl:
                            Woher soll man denn das wissen mit dem 0.0.0.0 ? `
                            http://www.iobroker.net/?page_id=5473&l … figuration
                            Ist sogar rot!
                            Rainer
                            • N
                              Newmiraculix last edited by
                              Hallo zusammen.
                              ich hab auch Probleme und jetzt mit Hilfe dieses Posts und der Anleitung auf der Webseite versucht diese zu lösen.Leider ohne Erfolg 😞
                              Ich habe jetzt über die Konsole versucht js-controller und admin Adapter zu updaten. Js-controller war auch kein Problem. Aber wenn ich versuche admin zu aktualisieren bekomme ich folgende Meldung:
                              iobroker.core@0.1.0 /opt/iobroker
                              └── (empty)
                              npm ERR! code 1
                              Ich habe auch schon versucht eine zweite Admin Instanz anzulegen, aber ich kann einfach nicht auf über den Browser zugreifen.
                              Markus
                                hater last edited by
                                Selbes Problem bei mir, ich kriege allerdings die Fehlermeldung bei jeglicher Operation am ioBroker.
                                ! events.js:141
                                ! throw er; // Unhandled 'error' event
                                ! Error: listen EADDRINUSE :::9001
                                ! at Object.exports._errnoException (util.js:907:11)
                                ! at exports._exceptionWithHostPort (util.js:930:20)
                                ! at Server._listen2 (net.js:1250:14)
                                ! at listen (net.js:1286:10)
                                ! at Server.listen (net.js:1382:5)
                                ! at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2629:24)
                                ! at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2727:9
                                ! at new ObjectsInMemServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2734:7)
                                ! at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2581:27)
                                ! at Timer.listOnTimeout (timers.js:92:15)
                                Eine Neuinstallation des jscontrollers hat ebenfalls keinen Erfolg gezeigt.Eine Neuinstallation des Admin Adapters schlägt mit der genannten Meldung ebenfalls fehl.
                                Basissystem: Synology Docker.
                                  Dazu gibt es einen separaten Thread.
                                  Sollte es jedoch bei deiner Installation in Docker auf ??? Wirklich der Fall sein, dass der port 9001 vergeben ist hilft der Workaround nicht!
                                  zuerst iobroker im Installationsverzeichnis stoppen mit sudo iobroker stop
                                  Dann die Installation durchführen
                                  Dann iobroker wieder starten
                                  Rainer
                                    Vorher ein "iobroker stop" gemacht und geschaut das keine Prozesse mehr laufen?
                                    • Patrick
                                      Patrick last edited by
                                      Nach dem Update kann ich iobroker nicht Mal.mehr über die Kommandozeile starten ~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201703 ... 81fd65.jpg">https://uploads.tapatalk-cdn.com/20170311/41f5086c07c0e536806c626dbe81fd65.jpg</link_text>" />
                                      Hat noch jemand dieses Problem?
                                      Oder sogar ne Lösung?
                                      Gesendet von meinem EVA-L09 mit Tapatalk~~
                                        ENOSPC!
                                        Deine Speicherkarte ist voll
                                        Rainer
                                        • Patrick
                                          Nachtrag node -v 6. 9.4
                                          Npm 3.10.10
                                          • Patrick
                                            @Homoran:
                                            ENOSPC!
                                            Rainer `
                                            Hmm ok irgendwas müllt da die Speisekarte voll nach dem ich was lösche ist es kurz drauf wider voll
                                            36
                                            5881
