    4. Test Adapter e3dc-rscp v0.0.x GitHub
    • git-kick
      git-kick Developer @git-kick last edited by
      Bugfix release
      Hinweis: es wird jetzt vsl. einige Releases zur Fehlerbereinigung für die WB-Tags geben...
      0.0.16-beta
      • Bugfix: Wallbox count (WB_CONNECTED_DEVICES) was not handled correctly.
      • Bugfix: name for 3 SET_POWER objects is now displayed.
      • Bugfix: removed needless vertical scrollbar from configuration page (index_m.html).
        ArnoD last edited by ArnoD
        0.0.16-beta installiert.
        Es werden keine States unter WB angelegt.
        LOG Silly:
        2021-12-05 10:42:52.016 - debug: e3dc-rscp.0 (16517) Sending request TAG_WB_REQ_CONNECTED_DEVICES
        2021-12-05 10:42:52.016 - silly: e3dc-rscp.0 (16517) OUT: magic: >E3DC< is OK - ctrl: >0011< is OK - Version 1, with CRC - seconds: 1638697371 - nseconds: 0 - length: 7
        TAG_WB_REQ_CONNECTED_DEVICES - type: 0x00 - None - length: 0
        CRC32
        2021-12-05 10:42:52.016 - silly: e3dc-rscp.0 (16517) E3 DC 00 11 9B 89 AC 61 00 00 00 00 00 00 00 00 -- .......a........
        07 00 1C 10 04 0E 00 00 00 43 81 74 59 -- .........C.tY
        2021-12-05 10:42:52.017 - silly: e3dc-rscp.0 (16517) Successfully written data to socket
        2021-12-05 10:42:52.034 - silly: e3dc-rscp.0 (16517) Received response
        2021-12-05 10:42:52.035 - silly: e3dc-rscp.0 (16517) TAG_WB_CONNECTED_DEVICES
        2021-12-05 10:42:52.035 - silly: e3dc-rscp.0 (16517) IN: magic: >E3DC< is OK - ctrl: >0011< is OK - Version 1, with CRC - seconds: 1638697373 - nseconds: 84939000 - length: 18
        TAG_WB_CONNECTED_DEVICES - type: 0x0E - Container - length: 11
        TAG_WB_INDEX - type: 0x06 - Int32 - length: 4 value: 0
        no CRC32
        2021-12-05 10:42:52.035 - silly: e3dc-rscp.0 (16517) E3 DC 00 11 9D 89 AC 61 00 00 00 00 F8 10 10 05 -- .......a........
        12 00 1C 10 84 0E 0E 0B 00 01 00 04 0E 06 04 00 -- ................
        00 00 00 00 07 AF BA 54 00 00 00 00 00 00 00 00 -- .......T........
        00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -- ................
        2021-12-05 10:42:52.036 - silly: e3dc-rscp.0 (16517) processTree: path = , tree = [ {TAG_WB_CONNECTED_DEVICES(Container) = [ {TAG_WB_INDEX(Int32) = 0}, ]}, ]
        2021-12-05 10:42:52.036 - silly: e3dc-rscp.0 (16517) processTree: path = , tree = [ {TAG_WB_INDEX(Int32) = 0}, ]
        2021-12-05 10:42:52.036 - silly: e3dc-rscp.0 (16517) Message queue is empty
        Uli ich kann diesen Tag "TAG_WB_REQ_CONNECTED_DEVICES" auch nicht in der Tag liste finden. Habe dort nur "TAG_WB_DEVICE_CONNECTED" finden können. Bist du sicher das es so richtig ist ?
        git-kick 1 Reply Last reply Reply Quote 0
        • git-kick
          git-kick Developer @ArnoD last edited by
          @arnod
          Danke für das Log, das hilft!
          Das Tag TAG_WB_REQ_CONNECTED_DEVICES habe ich aus dem RscpGUI (rxhan) abgekupfert.
          Aber da kommt ja (anders als erwartet) ein Container zurück, den muss ich erstmal auflösen und den größten Index-Wert abspeichern.
          Also ihr braucht WB erstmal nicht weiter testen bis zum nächsten Bugfix.
          • git-kick
            Hier der Fix:
            https://github.com/git-kick/ioBroker.e3dc-rscp/tree/v0.0.16-beta2
            @arnod, kannst du bitte nochmal testen? Jetzt sollte ein WB_0 angelegt werden, nachdem der WB_CONNECTED_DEVICES Container eingetroffen ist.
            (Bin nicht sicher, ob dieser Weg der "blinden Entwicklung" uns hinreichend voranbringt - sagt Bescheid, wenn Euch das zu lästig wird.)
              ArnoD @ArnoD last edited by
              @arnod sagte in Test Adapter e3dc-rscp v0.0.x GitHub:
              e3dc-rscp.0.EMS.BALANCED_PHASES = 7
              Mit dem Wert kann ich nichts anfange, dachte immer ich hätte nur 3 Phasen Weiß jemand mehr darüber?
              Habe jetzt in der Tag Liste nach Phases gesucht und folgendes unter dem Tag "TAG_PM_ACTIVE_PHASES" gefunden:
              //just the three lowest bits of activePhases are used to define / //what phase is switched on. If the lowest bit is 1 phase1 is active / //if the lowest bit is 0 phase 1 is inactive ... / static const unsigned char PHASE_1 = 1 / static const unsigned char PHASE_2 = 2 / static const unsigned char PHASE_3 = 4 / f.e. if active Phases = 7 -> all phases are active
              Demnach würde das Ganze so aussehn:
              1 = L1
              2 = L2
              3 = L1 und L2
              4 = L3
              5 = L1 und L3
              6 = L2 und L3
              7 = L1, L2, L3
              Das würde bei mir auch zutreffen mit 7
                ArnoD @git-kick last edited by
                @ujok sagte in Test Adapter e3dc-rscp v0.0.x GitHub:
                Mach ich gleich.
                Das wird mir bestimmt nicht lästig, bin wirklich froh, dass du das machst.
                  Ok States werden jetzt angelegt:
                  Im LOG sind mehrere Warnungen:
                  2021-12-05 12:36:19.891  - info: e3dc-rscp.0 (23219) starting. Version 0.0.16-beta in /opt/iobroker/node_modules/iobroker.e3dc-rscp, node: v12.22.7, js-controller: 3.3.20
                  2021-12-05 12:36:20.003  - info: e3dc-rscp.0 (23219) Connection to E3/DC is established
                  2021-12-05 12:36:27.472  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_UNKNOWN_TAG (7) - tag TAG_PVI_REQ_TEMPERATURE_COUNT (0x2000101)
                  2021-12-05 12:36:27.479  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DEVICE_ID (0xe000018)
                  2021-12-05 12:36:27.480  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_BAT_CAPACITY (0xe000019)
                  2021-12-05 12:36:27.483  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_USER_PARAM (0xe00001a)
                  2021-12-05 12:36:27.485  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_MAX_CURRENT (0xe00001b)
                  2021-12-05 12:36:27.486  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PHASE_VOLTAGE (0xe00001c)
                  2021-12-05 12:36:27.489  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DISPLAY_SPEECH (0xe00001d)
                  2021-12-05 12:36:27.490  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DESIGN (0xe00001e)
                  2021-12-05 12:36:27.494  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_CP_PEGEL (0xe000024)
                  2021-12-05 12:36:27.497  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PP_IN_A (0xe000025)
                  2021-12-05 12:36:27.497  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_STATUS_DIODE (0xe000026)
                  2021-12-05 12:36:27.498  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_1 (0xe000027)
                  2021-12-05 12:36:27.498  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_2 (0xe000028)
                  2021-12-05 12:36:34.538  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_UNKNOWN_TAG (7) - tag TAG_PVI_REQ_TEMPERATURE_COUNT (0x2000101)
                  2021-12-05 12:36:34.540  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DEVICE_ID (0xe000018)
                  2021-12-05 12:36:34.540  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_BAT_CAPACITY (0xe000019)
                  2021-12-05 12:36:34.540  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_USER_PARAM (0xe00001a)
                  2021-12-05 12:36:34.541  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_MAX_CURRENT (0xe00001b)
                  2021-12-05 12:36:34.541  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PHASE_VOLTAGE (0xe00001c)
                  2021-12-05 12:36:34.541  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DISPLAY_SPEECH (0xe00001d)
                  2021-12-05 12:36:34.541  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DESIGN (0xe00001e)
                  2021-12-05 12:36:34.542  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_CP_PEGEL (0xe000024)
                  2021-12-05 12:36:34.542  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PP_IN_A (0xe000025)
                  2021-12-05 12:36:34.542  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_STATUS_DIODE (0xe000026)
                  2021-12-05 12:36:34.549  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_1 (0xe000027)
                  2021-12-05 12:36:34.549  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_2 (0xe000028)
                  2021-12-05 12:36:41.339  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_UNKNOWN_TAG (7) - tag TAG_PVI_REQ_TEMPERATURE_COUNT (0x2000101)
                  2021-12-05 12:36:41.340  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DEVICE_ID (0xe000018)
                  2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_BAT_CAPACITY (0xe000019)
                  2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_USER_PARAM (0xe00001a)
                  2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_MAX_CURRENT (0xe00001b)
                  2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PHASE_VOLTAGE (0xe00001c)
                  2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DISPLAY_SPEECH (0xe00001d)
                  2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DESIGN (0xe00001e)
                  2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_CP_PEGEL (0xe000024)
                  2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PP_IN_A (0xe000025)
                  2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_STATUS_DIODE (0xe000026)
                  2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_1 (0xe000027)
                  2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_2 (0xe000028)
                  2021-12-05 12:36:48.181  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_UNKNOWN_TAG (7) - tag TAG_PVI_REQ_TEMPERATURE_COUNT (0x2000101)
                  2021-12-05 12:36:48.182  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DEVICE_ID (0xe000018)
                  2021-12-05 12:36:48.182  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_BAT_CAPACITY (0xe000019)
                  2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_USER_PARAM (0xe00001a)
                  2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_MAX_CURRENT (0xe00001b)
                  2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PHASE_VOLTAGE (0xe00001c)
                  2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DISPLAY_SPEECH (0xe00001d)
                  2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DESIGN (0xe00001e)
                  2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_CP_PEGEL (0xe000024)
                  2021-12-05 12:36:48.184  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PP_IN_A (0xe000025)
                  2021-12-05 12:36:48.184  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_STATUS_DIODE (0xe000026)
                  2021-12-05 12:36:48.184  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_1 (0xe000027)
                  2021-12-05 12:36:48.184  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_2 (0xe000028)
                  git-kick 2 Replies Last reply Reply Quote 0
                    und hier das LOG auf silly eingestellt:
                    Neues Textdokument.txt
                      Habe jetzt das Auto mal angesteckt und es werden bereits einige Werte übertragen:
                      Nachtrag:
                      ohne PV-Leistung vom Dach kann ich jetzt nicht alles testen.
                      Die Leistungs Werte L1 bis L3 sind schon mal richtig.
                      Beim Tag ENERGY_ALL stimmt der Wert nicht, zeigt bei mir nur 4300 W an und das Auto wird aber mit 10330 W geladen.
                      (beim rscpgui wird hier Wh angegeben, denke aber das es auch nicht richtig ist)
                      Kann es sein das einige States doppelt angelegt wurden, einmal unter WB_0 und einmal unter WB
                      • git-kick
                        @arnod said in Test Adapter e3dc-rscp v0.0.x GitHub:
                        1 = L1
                        2 = L2
                        3 = L1 und L2
                        4 = L3
                        5 = L1 und L3
                        6 = L2 und L3
                        7 = L1, L2, L3
                        Danke @ArnoD, das baue ich gleich als Wertemenge für die ...PHASES Tags mit Wert 7 ein.
                        • git-kick
                          Das ist gut. Aber sehe ich das richtig, dass die Werte nicht unter WB_0 einsortiert werden, sondern daneben?
                          • git-kick
                            git-kick Developer @ArnoD last edited by git-kick
                            Ok, dann sind die DIAG... tags anscheinend nicht für uns USER zugänglich (es gibt noch INSTALLER, PARTNER und drei E3DC-Level) - ich nehme die DIAG... Tags raus.
                            Die Meldung bzgl. TAG_PVI_REQ_TEMPERATURE_COUNT ist merkwürdig. Mein E3/DC antwortet hier einwandfrei (Wert 4). Option wäre hier, diese Meldung in den debug-Level zu verschieben. Aber eigentlich finde ich es in dieser Phasse ganz gut, wenn wir solche vom E3/DC gemeldeten Fehler auch zu sehen bekommen.
                            In deinem silly-Log sehe ich auch mehrmals, wie der Wert 4 ankommt. Lass uns weiter beobachten, ob der TAG_PVI_REQ_TEMPERATURE_COUNT Fehler wieder auftritt.
                              Ja, die Werte werden zweimal angelegt, einmal unter WB_0 und einmal unter WB
                              • git-kick
                                In diesem Screenshot sieht es aber so aus, dass einige Werte unter WB sind und andere unter WB_0 - was korrekt wäre...
                                https://forum.iobroker.net/assets/uploads/files/1638706251081-wallbox1.png
                                Aber ein paar sind auch doppelt vorhanden. Kannst du bitte nochmal den Objektbaum löschen, den Adapter neu starten und dann den Objektbaum nochmal posten?
                                • git-kick
                                  Ich denke hier habe ich die falsche Einheit eingetragen. ENERGY ist eindeutig Wh (oder kWh), nicht W. Also ich denke RscpGui liegt hier richtig.
                                  Könnte 4,3 kWh geladen nicht stimmen? Eine knappe halbe Stunde mit 10330 W?
                                    Hier den Objektbaum WB:
                                    und hier mit aufgeklapptem Objektbaum WB_0:
                                      Ok habe die Werte jetzt noch mal angesehen.
                                      Also, wenn etwas einigermaßen stimmt dann Wh. Komme zwar nicht genau auf die Werte, aber annähernd.
                                        Uli in IDLE_PERIODS_DISCHARGE sind keine Werte enthalten, ist das noch nicht so weit oder liegt es an der v0.0.16-beta2 ?
                                        • git-kick
                                          Bei mir sind (mit v0.0.16-beta3) alle Werte da, es gibt aber eine kleine Verzögerung beim ersten Öffnen der Tages-Ordner, bis die Werte angezeigt werden (max. etwa 1 Sekunde). Bist du sicher, dass die Werte dauerhaft nicht erscheinen? Wenn ja, bitte ich wieder um ein silly-log ab Adapter-Start 😇
                                          • git-kick
                                            git-kick Developer @git-kick last edited by git-kick
                                            Neue WB bugfix Version:
                                            https://github.com/git-kick/ioBroker.e3dc-rscp/tree/v0.0.16-beta3
                                            Ich habe ein falsches (PVI) Anfragetag aus der WB-Anfrage entfernt - evtl. hilft das gegen die Doppel im Objektbaum (bin nicht sicher)
                                            Bitte auch die Werte
                                            "WB.WB_0.EXTERN_DATA_SUN",
                                            "WB.WB_0.EXTERN_DATA_NET",
                                            "WB.WB_0.EXTERN_DATA_ALL",
                                            "WB.WB_0.EXTERN_DATA_ALG",
                                            "WB.WB_0.EXTERN_RSP_PARAM_1",
                                            "WB.WB_0.EXTERN_RSP_PARAM_2"
                                            prüfen, denn die kommen alle in extra Containern, da habe ich das Handling jetzt eingebaut. Zudem sollten die ByteArray-Werte jetzt als hex dump (z.B. "FA AB 01 02") dargestellt werden.
                                            v0.0.16-beta3
                                            • WB inbound containers are now handled
                                            • ByteArray values are translated to "hex dump" strings
                                            • wrong PVI request tag was removed from WB get data frame
                                            P.S. das silly-log (txt-Datei) war sehr hilfreich, bitte bei WB-Fehlern wieder beilegen, dann habe ich viel bessere Karten bei der Fehlersuche ...
                                            battery e3dc electricity energy photovoltaic rscp
                                            38
                                            470
                                            101840
