    4. Test Adapter e3dc-rscp v0.0.x GitHub
    • git-kick
      git-kick Developer @ArnoD last edited by
      @arnod said in Test Adapter e3dc-rscp v0.0.x GitHub:
      @ujok sagte in Test Adapter e3dc-rscp v0.0.x GitHub:
      https://github.com/git-kick/ioBroker.e3dc-rscp/tree/v0.0.16-beta2
      Ok States werden jetzt angelegt:
      Das ist gut. Aber sehe ich das richtig, dass die Werte nicht unter WB_0 einsortiert werden, sondern daneben?
      • git-kick
        git-kick Developer @ArnoD last edited by git-kick
        Im LOG sind mehrere Warnungen:
        2021-12-05 12:36:19.891  - info: e3dc-rscp.0 (23219) starting. Version 0.0.16-beta in /opt/iobroker/node_modules/iobroker.e3dc-rscp, node: v12.22.7, js-controller: 3.3.20
        2021-12-05 12:36:20.003  - info: e3dc-rscp.0 (23219) Connection to E3/DC is established
        2021-12-05 12:36:27.472  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_UNKNOWN_TAG (7) - tag TAG_PVI_REQ_TEMPERATURE_COUNT (0x2000101)
        2021-12-05 12:36:27.479  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DEVICE_ID (0xe000018)
        2021-12-05 12:36:27.480  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_BAT_CAPACITY (0xe000019)
        2021-12-05 12:36:27.483  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_USER_PARAM (0xe00001a)
        2021-12-05 12:36:27.485  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_MAX_CURRENT (0xe00001b)
        2021-12-05 12:36:27.486  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PHASE_VOLTAGE (0xe00001c)
        2021-12-05 12:36:27.489  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DISPLAY_SPEECH (0xe00001d)
        2021-12-05 12:36:27.490  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DESIGN (0xe00001e)
        2021-12-05 12:36:27.494  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_CP_PEGEL (0xe000024)
        2021-12-05 12:36:27.497  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PP_IN_A (0xe000025)
        2021-12-05 12:36:27.497  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_STATUS_DIODE (0xe000026)
        2021-12-05 12:36:27.498  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_1 (0xe000027)
        2021-12-05 12:36:27.498  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_2 (0xe000028)
        2021-12-05 12:36:34.538  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_UNKNOWN_TAG (7) - tag TAG_PVI_REQ_TEMPERATURE_COUNT (0x2000101)
        2021-12-05 12:36:34.540  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DEVICE_ID (0xe000018)
        2021-12-05 12:36:34.540  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_BAT_CAPACITY (0xe000019)
        2021-12-05 12:36:34.540  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_USER_PARAM (0xe00001a)
        2021-12-05 12:36:34.541  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_MAX_CURRENT (0xe00001b)
        2021-12-05 12:36:34.541  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PHASE_VOLTAGE (0xe00001c)
        2021-12-05 12:36:34.541  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DISPLAY_SPEECH (0xe00001d)
        2021-12-05 12:36:34.541  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DESIGN (0xe00001e)
        2021-12-05 12:36:34.542  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_CP_PEGEL (0xe000024)
        2021-12-05 12:36:34.542  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PP_IN_A (0xe000025)
        2021-12-05 12:36:34.542  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_STATUS_DIODE (0xe000026)
        2021-12-05 12:36:34.549  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_1 (0xe000027)
        2021-12-05 12:36:34.549  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_2 (0xe000028)
        2021-12-05 12:36:41.339  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_UNKNOWN_TAG (7) - tag TAG_PVI_REQ_TEMPERATURE_COUNT (0x2000101)
        2021-12-05 12:36:41.340  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DEVICE_ID (0xe000018)
        2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_BAT_CAPACITY (0xe000019)
        2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_USER_PARAM (0xe00001a)
        2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_MAX_CURRENT (0xe00001b)
        2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PHASE_VOLTAGE (0xe00001c)
        2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DISPLAY_SPEECH (0xe00001d)
        2021-12-05 12:36:41.341  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DESIGN (0xe00001e)
        2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_CP_PEGEL (0xe000024)
        2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PP_IN_A (0xe000025)
        2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_STATUS_DIODE (0xe000026)
        2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_1 (0xe000027)
        2021-12-05 12:36:41.342  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_2 (0xe000028)
        2021-12-05 12:36:48.181  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_UNKNOWN_TAG (7) - tag TAG_PVI_REQ_TEMPERATURE_COUNT (0x2000101)
        2021-12-05 12:36:48.182  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DEVICE_ID (0xe000018)
        2021-12-05 12:36:48.182  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_BAT_CAPACITY (0xe000019)
        2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_USER_PARAM (0xe00001a)
        2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_MAX_CURRENT (0xe00001b)
        2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PHASE_VOLTAGE (0xe00001c)
        2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DISPLAY_SPEECH (0xe00001d)
        2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DESIGN (0xe00001e)
        2021-12-05 12:36:48.183  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_CP_PEGEL (0xe000024)
        2021-12-05 12:36:48.184  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_PP_IN_A (0xe000025)
        2021-12-05 12:36:48.184  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_STATUS_DIODE (0xe000026)
        2021-12-05 12:36:48.184  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_1 (0xe000027)
        2021-12-05 12:36:48.184  - warn: e3dc-rscp.0 (23219) Received data type ERROR: RSCP_ERR_ACCESS_DENIED (2) - tag TAG_WB_REQ_DIAG_DIG_IN_2 (0xe000028)
        Ok, dann sind die DIAG... tags anscheinend nicht für uns USER zugänglich (es gibt noch INSTALLER, PARTNER und drei E3DC-Level) - ich nehme die DIAG... Tags raus.
        Die Meldung bzgl. TAG_PVI_REQ_TEMPERATURE_COUNT ist merkwürdig. Mein E3/DC antwortet hier einwandfrei (Wert 4). Option wäre hier, diese Meldung in den debug-Level zu verschieben. Aber eigentlich finde ich es in dieser Phasse ganz gut, wenn wir solche vom E3/DC gemeldeten Fehler auch zu sehen bekommen.
        In deinem silly-Log sehe ich auch mehrmals, wie der Wert 4 ankommt. Lass uns weiter beobachten, ob der TAG_PVI_REQ_TEMPERATURE_COUNT Fehler wieder auftritt.
          ArnoD @git-kick last edited by
          Ja, die Werte werden zweimal angelegt, einmal unter WB_0 und einmal unter WB
          git-kick 1 Reply Last reply Reply Quote 0
          • git-kick
            In diesem Screenshot sieht es aber so aus, dass einige Werte unter WB sind und andere unter WB_0 - was korrekt wäre...
            https://forum.iobroker.net/assets/uploads/files/1638706251081-wallbox1.png
            Aber ein paar sind auch doppelt vorhanden. Kannst du bitte nochmal den Objektbaum löschen, den Adapter neu starten und dann den Objektbaum nochmal posten?
            • git-kick
              Die Leistungs Werte L1 bis L3 sind schon mal richtig.
              Beim Tag ENERGY_ALL stimmt der Wert nicht, zeigt bei mir nur 4300 W an und das Auto wird aber mit 10330 W geladen.
              (beim rscpgui wird hier Wh angegeben, denke aber das es auch nicht richtig ist)
              Ich denke hier habe ich die falsche Einheit eingetragen. ENERGY ist eindeutig Wh (oder kWh), nicht W. Also ich denke RscpGui liegt hier richtig.
              Könnte 4,3 kWh geladen nicht stimmen? Eine knappe halbe Stunde mit 10330 W?
                Hier den Objektbaum WB:
                und hier mit aufgeklapptem Objektbaum WB_0:
                  Ok habe die Werte jetzt noch mal angesehen.
                  Also, wenn etwas einigermaßen stimmt dann Wh. Komme zwar nicht genau auf die Werte, aber annähernd.
                    Uli in IDLE_PERIODS_DISCHARGE sind keine Werte enthalten, ist das noch nicht so weit oder liegt es an der v0.0.16-beta2 ?
                    • git-kick
                      Bei mir sind (mit v0.0.16-beta3) alle Werte da, es gibt aber eine kleine Verzögerung beim ersten Öffnen der Tages-Ordner, bis die Werte angezeigt werden (max. etwa 1 Sekunde). Bist du sicher, dass die Werte dauerhaft nicht erscheinen? Wenn ja, bitte ich wieder um ein silly-log ab Adapter-Start 😇
                      • git-kick
                        git-kick Developer @git-kick last edited by git-kick
                        Neue WB bugfix Version:
                        https://github.com/git-kick/ioBroker.e3dc-rscp/tree/v0.0.16-beta3
                        Ich habe ein falsches (PVI) Anfragetag aus der WB-Anfrage entfernt - evtl. hilft das gegen die Doppel im Objektbaum (bin nicht sicher)
                        Bitte auch die Werte
                        "WB.WB_0.EXTERN_DATA_SUN",
                        "WB.WB_0.EXTERN_DATA_NET",
                        "WB.WB_0.EXTERN_DATA_ALL",
                        "WB.WB_0.EXTERN_DATA_ALG",
                        "WB.WB_0.EXTERN_RSP_PARAM_1",
                        "WB.WB_0.EXTERN_RSP_PARAM_2"
                        prüfen, denn die kommen alle in extra Containern, da habe ich das Handling jetzt eingebaut. Zudem sollten die ByteArray-Werte jetzt als hex dump (z.B. "FA AB 01 02") dargestellt werden.
                        v0.0.16-beta3
                        • WB inbound containers are now handled
                        • ByteArray values are translated to "hex dump" strings
                        • wrong PVI request tag was removed from WB get data frame
                        P.S. das silly-log (txt-Datei) war sehr hilfreich, bitte bei WB-Fehlern wieder beilegen, dann habe ich viel bessere Karten bei der Fehlersuche ...
                          @ujok
                          Habe die neue Version installiert.
                          Bei den SYS_SPECS ist jetzt was durcheinander gekommen, da sieht die Beschriftung jetzt so aus:
                            ArnoD @ArnoD last edited by ArnoD
                            WB sieht jetzt gut aus und ist alles unter WB_0 abgelegt:
                            Nur manche Werte sehen jetzt komisch aus.
                            Keine Warnungen im LOG
                              LOG Datei Silly:
                              Neues Textdokument.txt
                                Habe jetzt das E-Auto angesteckt, und die Werte L1-L3 sind richtig.
                                Alle ENERGY Werte werden jetzt in Wh angezeigt.
                                • git-kick
                                  Durch den Ausfall des Forum-Servers sind ein paar (wenige) Posts verloren gegangen.
                                  Um wieder gemeinsam aufzusetzen, hier meine aktuelle Version:
                                  https://github.com/git-kick/ioBroker.e3dc-rscp/tree/v0.0.16-beta4
                                  Ich habe die falsche Darstellung der Namen und Strings (u.a. unter SYS_SPECS) korrigiert.
                                  Bitte die Daten unter WB prüfen, insbesondere die ByteArrays (EXTERN_..., RSP_PARAM_...), diese Werte sollten jetzt in Hex-Darstellung (z.B. "F0 11 00 0D") erscheinen.
                                    Version 0.6.16-beta4 installiert.
                                    Falsche Darstellung der Namen unter SYS_SPECS 👍
                                    Keine Warnungen oder Fehlermeldungen im LOG 👍
                                    Bei EMS.IDLE_PERIODS_DISCHARGE werden keine States angelegt.
                                    Ja ist so, da ich nicht weiß, was du genau benötigst, hier ein Screenshot:
                                    git-kick 2 Replies Last reply Reply Quote 0
                                    • git-kick
                                      Bei mir werden die EMS.IDLE_PERIODS_DISCHARGE immer sauber angelegt, deshalb tu ich mich schwer mit der Fehlersuche. Kannst du dazu bitte ein silly-Log posten?
                                      • git-kick
                                        Danke, ich wollte zunächst nur wissen, ob die ByteArrays jetzt ordentlich dargestellt werden, denn diesen RSCP-Datentyp hatten wir bisher noch nicht. Was die Bytefolgen bedeuten, ist ein anderesThema, da müssen die E3/DC oder Easyconnect Wallbox-Besitzer ran, soweit das überhaupt relevant ist...
                                        Um die noch fehlenden Namen im Screenshot kümmere ich mich.
                                          @ujok
                                          Ok habe mir jetzt mal EXTERN_DATA_ALG genauer angesehen.
                                          In der Tag Liste ist folgende Beschreibung enthalten:
                                          contains EXTERN_DATA (length 7) and EXTERN_DATA_LEN =7 / Byte 1: uint8, PreCharge in [%] / Byte 2: uint8, 1: Sonnenmode, 0: Misch. / Byte 3: uint8, 1: Auto l„dt, 0: l„dt nicht / Byte 4: uint8, 1: Typ2 verriegelt, 0: entr. / Byte 5: uint8, Anzahl akt. Phasen [0-3] / Byte 6: uint4 low, 1: Schuko belegt / uint4 high, 1: Schuko an /
                                          Jetzt bin ich nicht so fit in HEX und umwandlung in Byte 🙂
                                          Beim HEX Wert beginnend von links sind die ersten beiden Stellen PreCharge in [%]
                                          Die Stelle 3 und 4 die Phasen mit denen geladen wird.
                                          Die Stelle 5 und 6 vereint mehrere Bedeutungen. Stecker gesteckt, Stecker verriegel/entriegelt, Sonnenmode/Mischmode, Auto lädt/lädt nicht
                                          Die Stelle 7 und 8 ist der aktuelle Ladestrom.
                                          HEX Wert 32 03 28 14 00 00 00 00 bedeutet demnach
                                          32 = 50% (gleich mit Wert e3dc-rscp.0.WB.WB_0.SOC)
                                          03 = drei Phasen
                                          28 = angesteckt, verriegelt, Mischmode, Auto lädt (Hier weiß ich noch nicht wie sich das zusammensetzt)
                                          14 = Laden mit 20A
                                          Die restlichen Stellen haben keine Bedeutung.
                                          EXTERN_DATA ist anscheinend der Rückgabewert der Ladeleistung, hier hat von links nur die Stelle 5 und 6 eine Bedeutung und ist immer gleich mit EXTERN_DATA_ALG Stelle 7 und 8
                                          EXTERN_DATA_ALL ist gleich mit EXTERN_DATA_NET und Zeigt die Ladeleistung an, bei EXTERN_DATA_ALL wird auf den letzten beiden Stellen von links noch PreCharge in [%] angezeigt.
                                            Hier der LOG File:
                                            1.0k
                                            battery e3dc electricity energy photovoltaic rscp
                                            38
                                            470
                                            101891
