    2. English
    4. Device Configure failed Zigbee
    • david83
      david83 last edited by david83
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Dell Lapto E7270
      Arbeitsspeicher: 6GB
      Festplattenart: SSD
      Betriebssystem: Proxmox / Debian LXC Container
      Node-Version: 3.3.21
      Nodejs-Version: 12.22.7
      NPM-Version: 6.14.15
      Installationsart: Skript
      Image genutzt: Nein
      Hallo zusammen. Ich habe heute das Update vom Zigbee Adapter 1.5.6 auf 1.6.6 durchgeführt. Soweit scheint er zu laufen, allerdings bekomme ich von mehreren Geräten des TuYa TS0207_water_leak_detector
      Wassermelder
      folgende Fehlermeldungen:
      Wo liegt das Problem und was kann ich dagegen tun?
      DeviceConfigure failed 0x847127fffe0543b2 TS0207, attempt 3 (Error: ConfigureReporting 0x847127fffe0543b2/1 genPowerCfg([{"attribute":"batteryPercentageRemaining","minimumReportInterval":3600,"maximumReportInterval":62000,"reportableChange":0}], {"sendWhenActive":false,"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 42924 - 1 - 74 - 1 - 7 after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:554:17) at processTimers (internal/timers.js:497:7))
      zigbee.0
      2021-12-04 12:25:08.775	warn	DeviceConfigure failed 0x847127fffe11e324 TS0207, attempt 1 (Error: Bind 0x847127fffe11e324/1 genPowerCfg from '0x00124b0021b7802b/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:554:17) at processTimers (internal/timers.js:497:7))
      zigbee.0
      2021-12-04 12:24:58.752	warn	DeviceConfigure failed 0x847127fffe054398 TS0207, attempt 1 (Error: Bind 0x847127fffe054398/1 genPowerCfg from '0x00124b0021b7802b/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:554:17) at processTimers (internal/timers.js:497:7))
      zigbee.0
      2021-12-04 12:24:48.731	warn	DeviceConfigure failed 0x847127fffe0543c6 TS0207, attempt 1 (Error: Bind 0x847127fffe0543c6/1 genPowerCfg from '0x00124b0021b7802b/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:554:17) at processTimers (internal/timers.js:497:7))
      zigbee.0
      2021-12-04 12:24:38.713	warn	DeviceConfigure failed 0x847127fffe11e16f TS0207, attempt 1 (Error: Bind 0x847127fffe11e16f/1 genPowerCfg from '0x00124b0021b7802b/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:554:17) at processTimers (internal/timers.js:497:7))
      zigbee.0
      2021-12-04 12:24:28.694	warn	DeviceConfigure failed 0x847127fffe0543b2 TS0207, attempt 1 (Error: Bind 0x847127fffe0543b2/1 genPowerCfg from '0x00124b0021b7802b/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:554:17) at processTimers (internal/timers.js:497:7))
      zigbee.0
      2021-12-04 12:24:18.674	warn	DeviceConfigure failed 0xcc86ecfffebc10dd TS0207, attempt 1 (Error: Bind 0xcc86ecfffebc10dd/1 genPowerCfg from '0x00124b0021b7802b/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:554:17) at processTimers (internal/timers.js:497:7))
      • Asgothian
        Asgothian Developer @david83 last edited by
        @david83 du kannst versuchen die betroffenen Sensoren “aufzuwecken”, damit sie auf die Versuche sie zu gieren. Das tun batteriebetriebene Geräte sonst oft nicht.
        A.
        david83 1 Reply Last reply Reply Quote 0
        • david83
          david83 @Asgothian last edited by
          @asgothian
          Ok danke dir. Komisch ich habe ja etliche Batteriebetriebene Geräte, aber nur diese haben diese Meldung geschmissen..
          • Asgothian
            @david83 Nur wenige batteriebetriebene geräte bedürfen einer Konfiguration durch den Koordinator.
            A.
