      Fortune95 @simatec last edited by
      @simatec sagte in Test Adapter shuttercontrol v1.4.x:
      @fortune95 Also ich habe deine Situation noch einmal mit convert und ohne Convert nachgestellt und kann keinen Fehler feststellen
      Rolladen fährt bei offenen Fenster runter:
      shuttercontrol.013905	2021-12-07 15:25:30.227	debug	shutterDownChildren #1 Test old height: 0% new height: 100%
      shuttercontrol.013905	2021-12-07 15:25:30.226	debug	last automatic Action for Test: Down_ChildrenTime
      shuttercontrol.013905	2021-12-07 15:25:30.142	info	Children down #26 Set ID: Test value: 100%
      Fenster wird geschlossen:
      shuttercontrol.013905	2021-12-07 15:26:05.031	debug	save back trigger action: down for device Test
      shuttercontrol.013905	2021-12-07 15:26:05.030	debug	#1 shutter trigger released Test already in place: 100%
      shuttercontrol.013905	2021-12-07 15:26:04.948	debug	Test - shutter trigger Change is:upDown
      shuttercontrol.013905	2021-12-07 15:26:04.947	debug	Test - shutter trigger Action is:down
      shuttercontrol.013905	2021-12-07 15:26:04.947	debug	Test - shutter trigger Height is:100
      shuttercontrol.013905	2021-12-07 15:26:04.946	debug	Test - shutter current Height is:100
      shuttercontrol.013905	2021-12-07 15:26:04.945	debug	Test - shutter current state.val is:100
      Hier noch die Config des Test-Rolllades:
              "enabled": true,
              "shutterName": "Test",
              "name": "javascript.0.Rolladen.Test.rollo.LEVEL",
              "triggerID": "javascript.0.Rolladen.Test.rollo.fensterkontakt",
              "typeUp": "children",
              "typeDown": "children",
              "type": "in- & outside temperature",
              "heightDownSun": "20",
              "direction": "290",
              "directionRange": "15",
              "tempInside": "23",
              "tempSensor": "javascript.0.Rolladen.Test.rollo.innentemp",
              "outsideTempSensor": "javascript.0.Rolladen.Test.rollo.aussentemp",
              "tempOutside": "23",
              "lightSensor": "javascript.0.Rolladen.Test.rollo.lichtsensor",
              "valueLight": "",
              "heightUp": "0",
              "heightDown": "100",
              "triggerState": "false",
              "triggerStateTilted": "none",
              "triggerDrive": "35",
              "triggerDriveTildet": "35",
              "triggerChange": "upDown",
              "elevation": "1.5",
              "autoDrive": "upDown",
              "hysteresisOutside": "5",
              "hysteresisInside": "10",
              "hysteresisLight": "",
              "currentAction": "up",
              "currentHeight": "0",
              "oldHeight": "0",
              "firstCompleteUp": "",
              "triggerHeight": "0",
              "LateDown": false,
              "inSummerNotDown": false,
              "KeepSunProtect": false,
              "triggerAction": "0",
              "driveAfterClose": false,
              "useXmasLevel": false,
              "XmasLevel": "",
              "betweenPosition": false,
              "betweenPositionLevel": "30",
              "trigDelyUp": "",
              "trigDelyDown": "",
              "sunProtectEndDely": "",
              "sunProtectEndtimerid": "",
              "enableAlarmWind1": false,
              "enableAlarmWind2": false,
              "enableAlarmRain": false,
              "enableAlarmFrost": false,
              "enableAlarmFire": false,
              "alarmTriggerAction": "",
              "alarmTriggerLevel": "",
              "lastAutoAction": ""
      Rollladen fährt Runter:
      2021-12-07 16:29:00.025 - info: shuttercontrol.0 (1090698) Sleep down #26 Set ID: Schlafzimmer Rechts value: 0%
      2021-12-07 16:29:00.036 - debug: shuttercontrol.0 (1090698) last automatic Action for Schlafzimmer Rechts: Down_SleepTime
      2021-12-07 16:29:00.036 - debug: shuttercontrol.0 (1090698) shutterDownSleep #1 Schlafzimmer Rechts old height: 100% new height: 0%
      2021-12-07 16:37:03.104 - debug: shuttercontrol.0 (1090698) TriggerID changed: alias.0.Schlafzimmer.Fensterkontakt_Schlafzimmer_rechts.ACTUAL Value: 0
      2021-12-07 16:37:03.106 - debug: shuttercontrol.0 (1090698) Schlafzimmer Rechts - shutter conversion is:false
      2021-12-07 16:37:03.112 - debug: shuttercontrol.0 (1090698) Schlafzimmer Rechts - shutter current Height is:0
      2021-12-07 16:37:03.112 - debug: shuttercontrol.0 (1090698) Schlafzimmer Rechts - shutter trigger Height is:100
      2021-12-07 16:37:03.112 - debug: shuttercontrol.0 (1090698) Schlafzimmer Rechts - shutter trigger Action is:up
      2021-12-07 16:37:03.113 - debug: shuttercontrol.0 (1090698) Schlafzimmer Rechts - shutter trigger Change is:upDown
      2021-12-07 16:37:03.116 - info: shuttercontrol.0 (1090698) Window is still closed -> drive to last height: Set ID: Schlafzimmer Rechts value: 100%
      Config des Rollladen:
              "enabled": true,
              "shutterName": "Schlafzimmer Rechts",
              "name": "alias.0.Schlafzimmer.Rolladen_Schlafzimmer_Rechts.SET",
              "triggerID": "alias.0.Schlafzimmer.Fensterkontakt_Schlafzimmer_rechts.ACTUAL",
              "typeUp": "sleep",
              "typeDown": "sleep",
              "type": "off",
              "heightDownSun": "30",
              "direction": "120",
              "directionRange": "50",
              "tempInside": "23",
              "tempSensor": "",
              "outsideTempSensor": "",
              "lightSensor": "",
              "valueLight": "15",
              "heightUp": "100",
              "heightDown": "0",
              "triggerState": "0",
              "triggerDrive": "30",
              "triggerDriveTildet": "30",
              "elevation": "8",
              "hysteresisInside": "5",
              "hysteresisLight": "5",
              "currentAction": "",
              "currentHeight": "",
              "oldHeight": "",
              "triggerHeight": "",
              "LateDown": false,
              "triggerAction": "",
              "XmasLevel": "0",
              "betweenPositionLevel": "50",
              "trigDelyUp": "",
              "trigDelyDown": "",
        @simatec Wie hast du 1.4.3 installiert? Über Github?
        Wenn du es über Github installiert hast, musst du noch einen Upload machen.
        Nein, ganz normal aktualisiert. 🤷‍♂️
        • Jens16
          Jens16 last edited by
          besteht die Möglichkeit bei [Einstellungen Helligkeitssensor] auch wie bei zum Beispiel [Einstellungen für den Wohnbereich] frühste / späteste Zeit für das hoch und runderfahren ein zu stellen?
          mfg Jens
          simatec Schmakus 2 Replies Last reply Reply Quote 0
          • Nightfly1983
            Nightfly1983 @simatec last edited by
            @simatec Im Log bei Errors steht nix zu shuttercontrol
            • simatec
              simatec Developer Most Active @Jens16 last edited by
              @jens16 sagte in Test Adapter shuttercontrol v1.4.x:
              stellen
              Nein die Möglichkeit besteht nicht ... Hier wird komplett nach den Lux-Werten gefahren
              • simatec
                simatec Developer Most Active @Fortune95 last edited by
                @fortune95 Denke ich hab den Fehler gefunden ... Im Schlafbereich wurde der Reset des Trigger noch nicht umgesetzt ... Hatte ich wohl vergessen.
                Kannst du bitte mal die DEV-Version über den Githublink installieren und testen?
                https://github.com/simatec/ioBroker.shuttercontrol/tarball/dev
                • simatec
                  simatec Developer Most Active @Nightfly1983 last edited by
                  @nightfly1983 Trage mal bei der Höhe fürs kippen bitte Werte ein und teste nochmal
                  Nightfly1983 1 Reply Last reply Reply Quote 0
                    Tom Haase @simatec last edited by
                    Bitte teste mal die 1.4.3 ... dein Problem sollte gefixt sein.
                    Leider keine Veränderung. Die Weihnachtseinstellung wird komplett ignoriert. Vielleicht finde ich am WE Zeit für Logs....
                    Nightfly1983 simatec 2 Replies Last reply Reply Quote 0
                      👍 👍 👍 Super! 🙂 DANKE!!!
                      2021-12-07 17:49:36.946 - debug: shuttercontrol.0 (1107019) TriggerID changed: alias.0.Schlafzimmer.Fensterkontakt_Schlafzimmer_rechts.ACTUAL Value: 0
                      2021-12-07 17:49:36.954 - debug: shuttercontrol.0 (1107019) Schlafzimmer Rechts - shutter conversion is:false
                      2021-12-07 17:49:36.969 - debug: shuttercontrol.0 (1107019) Schlafzimmer Rechts - shutter current Height is:0
                      2021-12-07 17:49:36.970 - debug: shuttercontrol.0 (1107019) Schlafzimmer Rechts - shutter trigger Height is:0
                      2021-12-07 17:49:36.971 - debug: shuttercontrol.0 (1107019) Schlafzimmer Rechts - shutter trigger Action is:down
                      2021-12-07 17:49:36.972 - debug: shuttercontrol.0 (1107019) Schlafzimmer Rechts - shutter trigger Change is:upDown
                      2021-12-07 17:49:36.991 - debug: shuttercontrol.0 (1107019) #1 shutter trigger released Schlafzimmer Rechts already in place: 0%
                      2021-12-07 17:49:36.993 - debug: shuttercontrol.0 (1107019) save back trigger action: down for device Schlafzimmer Rechts
                      könnte man auch den eingestellten Wert bei geöffneten Fenster direkt anfahren?
                      • simatec
                        @fortune95 Bein dafür kippt es die Option drive after close
                          @simatec
                          Dann bleibt es aber bis zum schließen, komplett auf, oder?
                          Ich möchte es ja, wie in der "Nacht" beim öffnen auf Lüftungsstellung haben. Das war so mein Gedanke...🤔
                            Funbug @simatec last edited by
                            @funbug sagte in Test Adapter shuttercontrol v1.4.x:
                            (bestimmter Wert, nicht boolen)
                            das ist sicher mit shuttercontrol und 1-2 Skripten machbar.
                            Aber da benötige ich mehr Infos ... Was für Werte bekommst du genau, und was kannst du ansteuern?
                            Hier mal ein Printscreen von allen Objekten, welches ein Gerät liefert.
                            Beim Objekt targetPostion trage ich den Wert ein, wohin das Fenster oder der Rollladen fahren soll.
                            CurrentPosition gibt dann die erreichte Position an. State geht während dem Fahren auf "Execution" sobald fertig auf "Done" und runState geht während dem Fahren auf "ExecutionActive" sobald fertig auf "ExecutionCompleted".
                            Möchte ich zum Beispiel ein Fenster öffnen, muss zuerst geprüft werden, dass der Rollladen aktuell nicht am fahren ist und dass die aktuelle Position "CurrentPosition" kleiner "40" ist.
                            Möchte ich hingegen mit dem Rollladen hoch oder runter fahren, so muss zuvor geprüft werden, dass dasjenige Fenster aktuell nicht fährt und die "CurrentPosition" kleiner "10" ist.
                            Schön währe, wenn die Bedingung nicht erfüllt ist, der Befehl dennoch ausgeführt wird, jedoch zuvor die Bedingung dafür erstellt wird.
                            Ich hab gelesen, dass der Adapter eine Fenster Position prüfen kann, den Befehl je nach Setting dann erst ausführt, wenn die Fenster Position dies zulässt.
                            • 2afs
                              2afs @simatec last edited by
                              Hallo @simatec ,
                              ich setzte derzeit die stable shuttercontrol v1.2.1 im IOBROKER ein.
                              Jetzt wo es schon recht Weihnachtlich wird habe ich die Weihnachtseinstellungen konfiguriert und bekomme die Positionsverstellung nicht hin.
                              Zu den definierten Zeiten wenn der Rollladen herunter bis zur Weihnachtseinstellung (50%) fahren soll bekommt ein 100% geöffneter Rolladen noch einmal den Befehl Position 100%. Er bewegt sich also nicht. Es ist nur zu sehen (letzte Änderung im VIS) das die Position 100% noch einmal gesetzt wurde.
                              Spätes Schliessen funktioniert dann wieder richtig und die Rollläden schliessen. Gibt es hierzu einen fix oder workaround?
                              Danke und Gruß
                              • da_Woody
                                da_Woody last edited by
                                @2afs ich denk mal das das in den latest gefixt ist. 1.4.3 ist die latest im moment. da hat sich seite deiner version verdammt viel getan.
                                mach einen npm install und dann mal schauen.
                                • Nightfly1983
                                  Nightfly1983 @Tom Haase last edited by
                                  @tom-haase Da schließe ich mich an, die Weihnachtsposition wurde angefahren, aber das später schließen hat leider nicht geklappt, alle Rollläden waren heute Morgen noch in der Weihnachtsstellung 😕
                                  • Nightfly1983
                                    @simatec Probiere ich heute Nachmittag direkt, danke für den Hinweis. Aber bei Sensor für das Kippen trage ich weiterhin nicht vorhanden ein und bei der Höhe einfach das gleiche wie beim öffnen?!
                                    • simatec
                                      @nightfly1983
                                      Ja genau
                                      • simatec
                                        simatec Developer Most Active @Tom Haase last edited by
                                        @tom-haase Ich habe das jetzt noch einmal getestet ... Bei mir fahren die Rollläden alle in die Weihnachtseinstellung.
                                        Zeige doch mal deinen Debuglog und die Config als json
                                        • BanditFG
                                          BanditFG last edited by
                                          @simatec
                                          hallo,
                                          ich habe gestern die v1.4.3 installiert, die Weihnachtsposition wurde richtig angefahren und auch beim später schliessen wurde die Frostschutzposition angefahren.. hab erstmal eins von 5 Fenstern getestet.. alle anderen Rollos funktionieren nochmal, 30min nach Sonnenuntergang sie die jetzt immer 3 sec Zeitversetz in die Frostschutzposition gefahren...
                                          Wenn das Versetzt fahren noch für die Rollos umgesetzt wird welche Später (22:00) runterfahren sollen, bin ich glücklich.
                                          • simatec
                                            @nightfly1983 Konnte ich nicht nachstellen ... Bei mir fahren alle Testrollläden
                                            81.1k
                                            332
                                            7405
                                            10546898
