    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. Разные ошибки
    Разные ошибки
      spectrekr last edited by
      Попробовал сделать экспорт всех скриптов, получил ошибку.
      ! TypeError: 2017-02-15 12:23:57.693 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      ! TypeError: 2017-02-15 12:23:57.693 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! TypeError: 2017-02-15 12:23:57.693 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      ! TypeError: 2017-02-15 12:23:57.693 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:228:12)
      ! TypeError: 2017-02-15 12:23:57.693 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:270:10)
      ! TypeError: 2017-02-15 12:23:57.693 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! TypeError: 2017-02-15 12:23:57.693 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
      ! TypeError: 2017-02-15 12:23:57.693 error at Object.States.change (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:228:25)
      ! TypeError: 2017-02-15 12:23:57.693 error at processMessage (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:1282:26)
      ! TypeError: 2017-02-15 12:23:57.693 error at Object.readObjectsAsZip (/opt/iobroker/node_modules/iobroker.js-controller/lib/zipFiles.js:249:13)
      ! TypeError: 2017-02-15 12:23:57.693 error objects.getConfigKeys is not a function
      ! message 2017-02-15 12:23:57.679 error messagebox.system.host.raspberrypi [object Object] objects.getConfigKeys is not a function
      • Bluefox
        Bluefox last edited by
        @spectrekr:
        ! message 2017-02-15 12:23:57.679 error messagebox.system.host.raspberrypi [object Object] objects.getConfigKeys is not a function `
        Multihost?
          @Bluefox:
          @spectrekr:
          ! message 2017-02-15 12:23:57.679 error messagebox.system.host.raspberrypi [object Object] objects.getConfigKeys is not a function Multihost?
          Да.
          • Bluefox
            @spectrekr:
            @Bluefox:
            @spectrekr:
            Да. `
            Ошибка.. Поправлю в следующей версии.
            Спасибо.
            • Bluefox
              @spectrekr:
              Настройка let's encrypt.
              ! 2016-11-01 12:13:37.224 - error: uncaught exception: listen EACCES 0.0.0.0:80 2016-11-01 12:13:37.238 - error: Error: listen EACCES 0.0.0.0:80 at Object.exports._errnoException (util.js:874:11) at exports._exceptionWithHostPort (util.js:897:20) at Server._listen2 (net.js:1221:19) at listen (net.js:1270:10) at Server.listen (net.js:1366:5) at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:69:21) at initWebServer (/opt/iobroker/node_modules/iobroker.admin/admin.js:523:28) at /opt/iobroker/node_modules/iobroker.admin/admin.js:255:25 at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:360:21) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12) at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8) at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12) at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16) at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:444:14) at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:261:10) at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8) at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8) at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:135:10) at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14) at emitTwo (events.js:87:13) 2016-11-01 12:13:37.245 - info: admin.0 terminating https server on port 8081 2016-11-01 12:13:37.269 - info: admin.0 https server listening on port 8081 2016-11-01 12:13:37.271 - info: admin.0 Use link "https://localhost:8081" to configure. 2016-11-01 12:13:38.259 - info: admin.0 terminating https server on port 8081 2016-11-01 12:13:39.783 - error: host.Cubian instance system.adapter.admin.0 terminated with code 6 (uncaught exception) 2016-11-01 12:13:39.786 - info: host.Cubian Restart adapter system.adapter.admin.0 because enabled</anonymous></anonymous></anonymous></anonymous></anonymous> `
              Кто то висит на порту 80 и не даёт запустить web.
              Lets Encrypt работает только с 80. Хотя если на рутере перенаправить 80 на что либо другое, то тоже будет работать.
                @Bluefox:
                @spectrekr:
                Lets Encrypt работает только с 80. Хотя если на рутере перенаправить 80 на что либо другое, то тоже будет работать. `
                Странно, висеть больше не чему. Ну в любом случае обновился.
                  ford7 last edited by
                  Подскажите, node-red ругается на node.js- как поправить?
                  node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB
                  node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB
                  node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------
                  node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode.
                  node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
                  node-red.0 2017-03-09 10:48:09.753 warn ^^^^^
                  node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1
                  node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100
                  web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin
                  web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin
                  web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin
                  node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] *****************************************************************
                  node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 *
                  node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] *****************************************************************
                    Haus last edited by
                    @ford7:
                    ! node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode. node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:09.753 warn ^^^^^ node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1 node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100 node-red.0 2017-03-09 10:48:09.753 warn web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] ***************************************************************** node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 * node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] ***************************************************************** `
                    Сменить nodejs нужна версия v4.x и выше.
                    • I
                      Izzm last edited by
                      Обновился до крайней версии. MQTT сервер стал заваливать сообщениями в лог.
                      Перезапускал отдельно драйвер, перезагружал сервер целиком. Эффекта нет.
                      js-controller 0.16.2
                      Admin 1.7.0
                      JS 3.2.6
                      • Bluefox
                        @Izzm:
                        Admin 1.7.0
                        JS 3.2.6 `
                        А на самом деле эти переменные существуют?
                          @Haus:
                          Сменить nodejs нужна версия v4.x и выше. `
                          Как это сделать, подскажите.
                            Haus last edited by
                            @ford7:
                            @Haus:
                            Сменить nodejs нужна версия v4.x и выше. Как это сделать, подскажите.
                            apt-get --purge remove node
                            apt-get --purge remove nodejs
                            apt-get autoremove
                            reboot
                            apt-get update
                            apt-get upgrade
                            apt-get install curl build-essential
                            curl -sL https://deb.nodesource.com/setup_4.x | bash -
                            apt-get install -y nodejs
                              @Haus:
                              apt-get autoremove
                              reboot
                              apt-get update
                              apt-get upgrade
                              Обновил, сейчас сыплются ошибки с sql и s7
                              host.zvmubn 2017-03-10 12:25:46.641 error instance system.adapter.s7.0 terminated with code 0 (OK)
                              s7.0 2017-03-10 12:25:46.627 info terminating
                              s7.0 2017-03-10 12:25:46.206 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.s7, node: v4.8.0
                              s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..js (module.js:416:10)
                              s7.0 2017-03-10 12:25:46.116 error at Module._compile (module.js:409:26)
                              s7.0 2017-03-10 12:25:46.116 error at Object. (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/lib/node-snap7.js:6:45)
                              s7.0 2017-03-10 12:25:46.116 error at bindings (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/node_modules/bindings/bindings.js:76:44)
                              s7.0 2017-03-10 12:25:46.116 error at require (internal/module.js:12:17)
                              s7.0 2017-03-10 12:25:46.116 error at Module.require (module.js:353:17)
                              s7.0 2017-03-10 12:25:46.116 error at Function.Module._load (module.js:300:12)
                              s7.0 2017-03-10 12:25:46.116 error at Module.load (module.js:343:32)
                              s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..node (module.js:434:18)
                              s7.0 2017-03-10 12:25:46.116 error at Error (native)
                              s7.0 2017-03-10 12:25:46.116 error Error: Module did not self-register.
                              s7.0 2017-03-10 12:25:46.108 error uncaught exception: Module did not self-register.
                              host.zvmubn 2017-03-10 12:25:45.677 info instance system.adapter.s7.0 started with pid 7860
                              sql.0 2017-03-10 12:25:31.347 error TypeError: Cannot read property 'borrow' of undefined
                              sql.0 2017-03-10 12:25:31.347 error Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md
                              host.zvmubn 2017-03-10 12:25:15.668 info Restart adapter system.adapter.s7.0 because enabled
                              host.zvmubn 2017-03-10 12:25:15.668 error instance system.adapter.s7.0 terminated with code 0 (OK)
                                Haus last edited by
                                @ford7:
                                @Haus:
                                apt-get autoremove
                                reboot
                                apt-get update
                                apt-get upgrade
                                ! host.zvmubn 2017-03-10 12:25:46.641 error instance system.adapter.s7.0 terminated with code 0 (OK) s7.0 2017-03-10 12:25:46.627 info terminating s7.0 2017-03-10 12:25:46.206 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.s7, node: v4.8.0 s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..js (module.js:416:10) s7.0 2017-03-10 12:25:46.116 error at Module._compile (module.js:409:26) s7.0 2017-03-10 12:25:46.116 error at Object. (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/lib/node-snap7.js:6:45) s7.0 2017-03-10 12:25:46.116 error at bindings (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/node_modules/bindings/bindings.js:76:44) s7.0 2017-03-10 12:25:46.116 error at require (internal/module.js:12:17) s7.0 2017-03-10 12:25:46.116 error at Module.require (module.js:353:17) s7.0 2017-03-10 12:25:46.116 error at Function.Module._load (module.js:300:12) s7.0 2017-03-10 12:25:46.116 error at Module.load (module.js:343:32) s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..node (module.js:434:18) s7.0 2017-03-10 12:25:46.116 error at Error (native) s7.0 2017-03-10 12:25:46.116 error Error: Module did not self-register. s7.0 2017-03-10 12:25:46.108 error uncaught exception: Module did not self-register. host.zvmubn 2017-03-10 12:25:45.677 info instance system.adapter.s7.0 started with pid 7860 sql.0 2017-03-10 12:25:31.347 error TypeError: Cannot read property 'borrow' of undefined sql.0 2017-03-10 12:25:31.347 error Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md host.zvmubn 2017-03-10 12:25:15.668 info Restart adapter system.adapter.s7.0 because enabled host.zvmubn 2017-03-10 12:25:15.668 error instance system.adapter.s7.0 terminated with code 0 (OK) `
                                node.js Version? npm Version?
                                node -v
                                npm -v
                                Если команда node -v выдаёт ошибку, то выполнить:
                                ln -s /usr/bin/nodejs /usr/bin/node
                                  @Haus:
                                  node -v
                                  npm -v
                                  root@zvmubn:/opt/iobroker# node -v
                                  v4.8.0
                                  root@zvmubn:/opt/iobroker# npm -v
                                  2.15.11
                                  • Bluefox
                                    @ford7:
                                    @Haus:
                                    node -v
                                    npm -v
                                    v4.8.0
                                    2.15.11
                                    При смене ноды нужно все бинарные пакеты перекомпилировать.
                                    Попробуй
                                    cd /opt/iobroker
                                    iobroker stop
                                    npm i node-gyp -g --force
                                    npm i iobroker.s7 --force
                                    npm i iobroker.sql --force
                                    iobroker start
                                    Может быть нужно выполнить как sudo. Зависит от того какая у тебя система
                                    • I
                                      Izzm last edited by
                                      @Bluefox:
                                      @Izzm:
                                      Admin 1.7.0
                                      JS 3.2.6 А на самом деле эти переменные существуют?
                                      Нет, их не существует.Существует только в system.host.Server-Izzm.outputCount и system.host.Server-Izzm.inputCount.
                                        @Bluefox:
                                        Попробуй
                                        cd /opt/iobroker
                                        iobroker stop
                                        iobroker start
                                        Может быть нужно выполнить как sudo. Зависит от того какая у тебя система `
                                        Все получилось, спасибо!
                                          при обновлении rflink драйвера, есть ошибки:
                                          npm install iobroker.rflink@1.1.2 --production --prefix "/opt/iobroker" (System call)
                                          node-pre-gyp
                                          ERR! Tried to download: https://github.com/voodootikigod/node-serialport/releases/download/3.1.2/serialport-v3.1.2-node-v46-linux-arm.tar.gz
                                          node-pre-gyp ERR! Pre-built binaries not found for serialport@3.1.2 and node@4.2.1 (node-v46 ABI) (falling back to source compile with node-gyp)
                                          node-pre-gyp
                                          ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.2.1 (node-v46 ABI) (falling back to source compile with node-gyp)
                                          Ошибки не критические, все ставится и работает, но мало ли.
                                          • Bluefox
                                            @spectrekr:
                                            node-pre-gyp
                                            node-pre-gyp
                                            Ошибки не критические, все ставится и работает, но мало ли. `
                                            Это нормально. Просто нет для твоей системы готового бинарника и он переходит на компиляцию.
                                            192
                                            55990
