    4. [Gelöst] Zigbee Probleme bei Update
      Sammyray last edited by Sammyray
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC
      Arbeitsspeicher: 4GB
      Festplattenart: SSD
      Betriebssystem: Linux
      Node-Version: 14.8.2
      Nodejs-Version: 14.8.2
      NPM-Version: 6.14.15
      bei mir läuft die 1.4.1 stabil, aber ich würde gerne einmal updaten, da 2 neue Geräte nicht korrekt erkannt werden.
      Wenn ich versuche auf die 1.6.6 upzudaten, erscheinen folgende Fehler:
      zigbee.0 2021-12-10 09:47:28.177 error Error herdsman start
      zigbee.0 2021-12-10 09:47:28.177 error Failed to start Zigbee
      zigbee.0 2021-12-10 09:47:28.177 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0 2021-12-10 09:47:28.118 info Installed Version: iobroker.zigbee@1.6.6
      zigbee.0 2021-12-10 09:47:28.105 info Starting Zigbee npm ...
      zigbee.0 2021-12-10 09:47:28.104 info Try to reconnect. 1 attempts left
      zigbee.0 2021-12-10 09:47:18.103 error Error herdsman start
      zigbee.0 2021-12-10 09:47:18.103 error Failed to start Zigbee
      zigbee.0 2021-12-10 09:47:18.102 error Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      zigbee.0 2021-12-10 09:47:18.058 error Re-commissioning your network will require re-pairing of all devices!
      zigbee.0 2021-12-10 09:47:18.058 error If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
      zigbee.0 2021-12-10 09:47:18.058 error Please update configuration to prevent further issues.
      zigbee.0 2021-12-10 09:47:18.058 error - Channel List: configured=11, adapter=
      zigbee.0 2021-12-10 09:47:18.057 error - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
      zigbee.0 2021-12-10 09:47:18.057 error - Extended PAN ID: configured=00124b0018eb435b, adapter=0000000000000000
      zigbee.0 2021-12-10 09:47:18.057 error - PAN ID: configured=6754, adapter=65535
      zigbee.0 2021-12-10 09:47:18.057 error Configuration is not consistent with adapter state/backup!
      zigbee.0 2021-12-10 09:47:17.994 info Installed Version: iobroker.zigbee@1.6.6
      zigbee.0 2021-12-10 09:47:17.832 info Starting Zigbee npm ...
      host.ioboker 2021-12-10 09:47:17.846 info iobroker exit 0
      zigbee.0 2021-12-10 09:47:17.797 info starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.21
      host.iobroker 2021-12-10 09:47:16.852 info instance system.adapter.zigbee.0 started with pid 12206
      host.iobroker 2021-12-10 09:47:16.831 info "system.adapter.zigbee.0" enabled
      Ich habe natürlich zuerst die Suche bemüht, da gab es ja diverse Leute mit Problemen, aber ich hab nichts passendes für mich gefunden 😞
      Die PAN ID hat beim Adapter eine Stelle mehr und bei der Extended stehen nur Nullen.
      Leider bin ich nicht wirklich gut in dem Thema und könnte auf jeden Fall Hilfe gebrauchen.
      Ich benutze den CC2538+CC2592 Stick von dimaiv, falls das wichtig ist für die Problemlösung. Unter 1.4.1 läuft wieder alles wie es soll.
      Danke für eure Unterstützung!
        Thomas Braun Most Active @Sammyray last edited by
        @sammyray sagte in Zigbee Probleme bei Update:
        Trag die jeweils anderen Werte entsprechend im Adapter ein.
          Sammyray @Thomas Braun last edited by
          So meinst du, oder verstehe ich das falsch?
          Falls ich es richtig verstehe hab ich es bereits probiert - ändert aber nichts - die Fehlermeldung bleibt die gleiche: angeblich immer noch 65535 und nur Nullen bei der Extended 😞
          Latzi 1 Reply Last reply Reply Quote 0
          • Latzi
            Latzi @Sammyray last edited by
            @sammyray
            Welche Firmware hat dein Stick?
              Sammyray @Latzi last edited by
              @latzi
              Hab ich mich noch nie mit beschäftigt 🙈
              Wird die unter "revision" angezeigt? Falls ja, ist das die 20190523 - hört sich alt an...
              Falls nicht, bitte sagen wo ich die auslesen kann 🙂
              • Latzi
                Latzi @Sammyray last edited by Latzi
                @sammyray
                dazu entweder beim Adapterstart auf "debug" stellen (da sollte die FW angezeigt werden), oder bei laufendem Adapter (was eher nicht funktionieren wird, wenn der Adpater nicht tut) die Kachel des Coordinator ansehen
                20190523 klingt gut (und auch schlecht, weil alt) scheint die gleiche wie bei mir zu sein, versuch´s mal damit:
                https://forum.iobroker.net/topic/46927/zigbee-neue-version-1-6-x/170?_=1639110276900
                Edit: Verwende die 1.6.8 aus dem latest repo!
                  @latzi
                  Ein Traum - besten Dank, es funktioniert und war gar nicht so kompliziert 🙂
                  Liegt das an der FW des Sticks und sollten wir dann aktiv werden, den upzudaten?
                  • Latzi
                    @sammyray
                    Perfekt, @arteck ist der Wahnsinn, oder?
                    Firmware-Update ist kritisch (glaub ich), da die Geräte neu angelernt werden müssten.
                    Edit: Bitte Beitrag als [gelöst] kennzeichnen
                      @latzi
                      Jaa, richtig gut 🙂
                      Hab ich auch gelesen, bei mir würde sich der Aufwand aber aktuell noch in Grenzen halten. Naja, ich lasse es erstmal so, bis es irgendwann nicht mehr gehen sollte...
                      Nochmal vielen Dank und schon mal ein schönes Wochenende! 🙂
