    4. IoBroker simple-api adapter, POST mit setbulk, Fehler oder kann nicht lesen
      apollon77 last edited by
      ääähm räusper … hab vergessen zu committen ... kommt in 30 mins oder :-((
        Jetzt :-))
        • greyhound
          greyhound last edited by
          Moin, Moin,
          habe mir zwischenzeitlich den Code angeschaut und die mir fehlende Methode "setValueFromBody" eingebaut.
          1591_fiddler-composer.png Response
              "id": "javascript.0.Nuki.Devices.NukiSL1.NukiBridgeResponse2",
              "val": "{\"nukiId\": 91049449, \"state\": 3, \"stateName\": \"unlocked\", \"batteryCritical\": false}"
          ````Log
          2017-03-08 11:47:10.210 - [32minfo[39m: simple-api.0 starting. Version 1.4.0 in C:/ioBroker/node_modules/iobroker.simple-api, node: v4.5.0
          2017-03-08 11:47:10.219 - [32minfo[39m: simple-api.0 simpleAPI server listening on port 8087
          2017-03-08 11:47:10.222 - [32minfo[39m: simple-api.0 http server listening on port 8087
          2017-03-08 11:47:18.064 - [34mdebug[39m: simple-api.0 POST-setBulk: body = ""
          2017-03-08 11:47:18.064 - [34mdebug[39m: simple-api.0 POST-setBulk: values = {"javascript.0.Nuki.Devices.NukiSL1.NukiBridgeResponse2":""{12345678}"","prettyPrint":true,"user":"system.user.admin"}
          2017-03-08 11:47:18.064 - [34mdebug[39m: simple-api.0 "javascript.0.Nuki.Devices.NukiSL1.NukiBridgeResponse2"
          2017-03-08 11:47:18.066 - [34mdebug[39m: simple-api.0 POST-setBulk for id=javascript.0.Nuki.Devices.NukiSL1.NukiBridgeResponse2, oid=NukiBridgeResponse2used=javascript.0.Nuki.Devices.NukiSL1.NukiBridgeResponse2, value="{12345678}"
          2017-03-08 11:47:18.068 - [34mdebug[39m: simple-api.0 Add to Response: {"id":"javascript.0.Nuki.Devices.NukiSL1.NukiBridgeResponse2","val":""{12345678}""}
          2017-03-08 11:53:49.255 - [34mdebug[39m: simple-api.0 POST-setValueFromBody: values = {"javascript.0.Nuki.Devices.NukiSL1.NukiBridgeResponse2":"{"nukiId": 91049449, "state": 3, "stateName": "unlocked", "batteryCritical": false}","prettyPrint":true,"user":"system.user.admin"}
          2017-03-08 11:53:49.255 - [34mdebug[39m: simple-api.0 POST-setValueFromBody: _id2="javascript.0.Nuki.Devices.NukiSL1.NukiBridgeResponse2"
          2017-03-08 11:53:49.256 - [34mdebug[39m: simple-api.0 POST-setValueFromBody for id=javascript.0.Nuki.Devices.NukiSL1.NukiBridgeResponse2, oid=NukiBridgeResponse2used=javascript.0.Nuki.Devices.NukiSL1.NukiBridgeResponse2, value={"nukiId": 91049449, "state": 3, "stateName": "unlocked", "batteryCritical": false}
          2017-03-08 11:53:49.258 - [34mdebug[39m: simple-api.0 Add to Response: {"id":"javascript.0.Nuki.Devices.NukiSL1.NukiBridgeResponse2","val":"{"nukiId": 91049449, "state": 3, "stateName": "unlocked", "batteryCritical": false}"}
          Werde meine Erweiterung als Pull-request einreichen.
          Nochmal Danke für deine Hilfe und Geduld
          Gruß GH
            Super, reiche ein, ich checke und dann gehts fix 🙂
            • greyhound
              ist drin
                1.5.0 auf github … bitte testen
                • greyhound
                  Danke für die Übernahme.
                  Ich bin gerade beim Testen mit node 6.9 / 6.10. Bekomme beim installieren diverser Adapter ecklige Warnings und Fehlermeldungen
                  2017-03-10 16:36:45.823  - info: iobroker npm install iobroker.mqtt --production --prefix "/opt/iobroker" (System call)
                  2017-03-10 16:37:16.892  - info: iobroker In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:
                  ../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle<v8::integer>) [with T = v8::Int32; v8::Handle <v8::integer>= v8::Local<v8::integer>]’:
                  ../node_modules/nan/nan_new.h:34:64: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /opt/iobroker/.node-gyp/6.9.5/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                   To<v8::int32>(v8::Handle <v8::integer>i)   { return i->ToInt32(); }
                  2017-03-10 16:37:16.895  - info: iobroker ../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle<v8::integer>) [with T = v8::Uint32; v8::Handle <v8::integer>= v8::Local<v8::integer>]’:../node_modules/nan/nan_new.h:39:65: warning: ‘v8::Local <v8::uint32>v8::Value::ToUint32() const’ is deprecated (declared at /opt/iobroker/.node-gyp/6.9.5/include/node/v8.h:8196): Use maybe version [-Wdeprecated-declarations]
                   To<v8::uint32>(v8::Handle <v8::integer>i)  { return i->ToUint32(); }
                   2017-03-10 16:37:16.931  - info: iobroker In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: At global scope:
                  ../node_modules/nan/nan.h:261:25: error: redefinition of ‘template <class t="">v8::Local _NanEnsureLocal(v8::Local)’
                   NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
                  ../node_modules/nan/nan.h:256:25: note: ‘template <class t="">v8::Local _NanEnsureLocal(v8::Handle)’ previously declared here
                   NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
                  ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:
                  ../node_modules/nan/nan.h:289:71: warning: ‘bool v8::Isolate::IdleNotification(int)’ is deprecated (declared at /opt/iobroker/.node-gyp/6.9.5/include/node/v8.h:6113): use IdleNotificationDeadline() [-Wdeprecated-declarations]
                       return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
                   . . .</class></class></v8::integer></v8::uint32></v8::uint32></v8::integer></v8::integer></v8::integer></v8::integer></v8::int32></v8::int32></v8::integer></v8::integer></v8::integer>
                  Am Schluss werden die Adapter in der Regel auch installiert und sind als Instanz vorhanden. Habe bisher nicht getestet, ob die Adapter wirklich auch funktionieren.
                  Weißt du, ob es an der node-Version liegt? Welche ist die letzte Version unter der alles laufen sollte?
                  Danke und Gruß
                  GH
                    Das liegt nur bedingt an node, sondern eher an den "c-binary-Teilen" die einige Libraries drin haben die der Adapter benutzt. Das sind compiler-Meldungen und viele davon Warnungen weil die Checks im Compiler recht strikt sind, aber dennoch nur warnen.
                    Wenn es fehlschlagen würde würdest Du nen Fehler bekommen.
                    In sofern: unschön, aber ignore. Wenn DU was dagegen tun willst dann verursachende Library raussuchen und dort ein Ticket aufmachen 🙂
                    • greyhound
                      bin wieder auf node 4.7 zurück, da sieht dass kompilieren besser aus.
                      Und das mit dem callback von meiner Nuki-Bridge mit POST setValueFromBody hat auch funktioniert. - Danke
                      Wie ich in meinem pull geschrieben habe, bin ich noch imer der Meinung das da etwas quer läuft bei der POST-Variante von setBulk. Entweder stimmt die Beschreibung nicht oder die Implementierung.
                      GH
                        Ich musste nochmal was fixen … update auf github
                        • greyhound
                          bei mir geht noch alles, die Version war aber auch 1.5.0 oder?
                          Muss langsam Schluss machen, Frauchen wartet schon.
                          Wochenende bin ich auch Unterwegs, wohl erst Montagabend wieder on.
                          GH
                            Ja, Version bleibt bis zum Release auf 1.5.0
                            Nach dem Update ggf manuell restarten
                            • greyhound
                              hatte ich so gemacht, sah gut aus.
                              Kann ich im Code verifizieren, dass meine aktive Version die richtige ist?
                                So, jetzt haben wirs … ich hab das nochmal komplett geändert nachdem ich das bisherige Konzept verstanden habe!
                                Es ändert sich für Deine Funktion leicht der aufruf!!
                                POST http://127.0.0.1:18183/setValueFromBody ... user=admin&...
                                bzw im Normalfall kein Fragezeichen und keine Parameter.
                                0.5.1 auf Github bitte testen!
                                • greyhound
                                  bin wieder zu Hause und habe die neue Version getestet.
                                  • setValueFromBody funktioniert bei mir
                                  callback-Post http://192.168.200.110:8087/setValueFromBody/javascript.0.Nuki.Devices.NukiSL1.NukiBridgeResponse
                                  Body: {\"nukiId\": 123456789, \"state\": 3, \"stateName\": \"unlocked\", \"batteryCritical\": false}
                                  • und set funktioniert auch
                                  GET http://192.168.200.110:8087/set/javascript.0.alarm.Devices.Cams.Cam1.alarm_ack?value=true
                                    eXTreMe last edited by
                                    Würde das Thema hier gerne nochmal aufgreifen. Komme mit den ganzen Beiträgen in diesem Forentopic leider nicht weiter da ich oft nur "Bahnhof" verstehe.
                                    kann jemand Schritt für Schritt beschreiben wie ich den simple api Adapter mit Nuki genau nutze? Ich habe leider noch recht wenig Plan von APIs 😞
                                    Was muss ich alles Konfigurieren?
                                    Ich nehme an die Steuerung und Statusabfrage erfolgt ausschließlich per Script, oder? Wie hat das Script auszusehen?
                                    Objekte werden sicher nicht automatisch generiert, oder?
                                    Ein paar Kleine Hilfestellungen mit Beispielen würden mich sicher schon etwas weiterbringen.
                                    Danke für eure Hilfe!
                                      Dann solltest du bitte ein paar mehr Infos geben. Ich kann beispielsweise mit "mit Nuki" nichts anfangen …
                                      • eric2905
                                        eric2905 last edited by
                                        Moin eXTreMe,
                                        hast Du Dir die Doku zum Adapter (auf Github) mal durchgelesen?
                                        ==> https://github.com/ioBroker/ioBroker.simple-api
                                        Da ist sehr genau beschreiben, wie man über Webcommands (html) über den Adapter was alles machen kann:
                                        • Werte auslesen
                                        • Werte setzen (was auch eine Aktion auslösen kann, z.B. State auf true = Licht an)
                                        Aber mehr Randinformationen sind immer gut.
                                        Was genau hast Du vor?
                                        Was hast Du bisher, mit welchem Erfolg, schon probiert?
                                        Fehlermeldungen
                                        Usw.
                                        Gruß,
                                        Eric
                                        Von unterwegs getippert
                                          Nuki ist ein Smart Lock, also ein fernsteuerbares Türschloss welches entweder direkt per bluetooth zwischen handy und schloss kommuniziert oder vom handy über internet an eine optional erhältliche bridge welche dann wiederum per bluetooth an das schloss funkt. hat man eine bridge so kann man auch im lokalen netz eine http api nutzen. https://nuki.io/de/
                                          ja ich habe mir die doku zum adapter mehrmals durchgelesen aber leider nicht verstanden.
                                          Also ich weiß über welche URL ich mir z.B. den Status des Türschlosses anzeigen lassen kann oder über welche URL ich das Schloss sperren oder öffnen kann. Das steht alles in der Nuki API gut erklärt: https://nuki.io/wp-content/uploads/2016 … I-v1.5.pdf
                                          Das habe ich über meinen Browser durch aufruf der URL mit den jeweiligen Parametern getestet und klappt auch.
                                          Was mir jedoch überhaupt nicht klar wird ist wie genau ich jetzt über iobroker das ganze einbinde um z.b. den status abzufragen, das schloss sperren oder öffnen zu lassen und die jewiligen antwortparameter die auf meine aktionen geantwortet werden in entsprechende datenpunkte in iobroker übernehme.
                                          wie genau hat das javascript auszusehen?
                                          kann mir das jemand an einem codebeispiel erklären?
                                          Vielen Dank!
                                            Also simpleAPI ist dazu da um mit eigenen Skripten von Aussen auf ioBroker zuzugreifen.
                                            Was Du eher brauchst ist wirklich ein JavaScript was mit deinem Türschloss kommuniziert.
                                            Such mal im Forum nach "request", so heisst die nodejs Library um HTTP Requests (GET/POST u.ä.) zu machen. Das wäre Dein Ansatz.
                                            Für ein Beispiel fehlt mir gerade die Zeit, sorry
                                            8331
