    4. Synology Adapter bleibt "gelb"
    • ub.privat
      ub.privat @Glasfaser last edited by
      @glasfaser
      So, wie gesagt alles durchgeführt, aber ohne Besserung. Leider.
      Anbei der Logauszug.
      Username ist in den Einstellungen aber Admin!
      synology.0
      2021-12-10 20:01:15.081	debug	-----------------------------------------------------------------------------------------------------
      synology.0
      2021-12-10 20:01:15.079	debug	Error: Reconnection after 10s
      synology.0
      2021-12-10 20:01:15.078	debug	*** ERROR : src: sendPolling syno[dsm][listPackages] To use the adapter, the user must be in the Administrators group! Also check the username and password in the adapter settings. Please try to enter the password again! code: 400 message: No such account or incorrect password
      synology.0
      2021-12-10 20:01:15.077	debug	* No response, read next.
      synology.0
      2021-12-10 20:01:14.641	debug	* Get info from (firstPoll) api: DSM method: listPackages params: {"version":1}
      synology.0
      2021-12-10 20:01:14.641	debug	* sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"listPackages","params":{"version":1}}
      synology.0
      2021-12-10 20:01:14.640	debug	-----------------------------------------------------------------------------------------------------
      synology.0
      2021-12-10 20:01:14.640	debug	Error: Reconnection after 10s
      synology.0
      2021-12-10 20:01:14.639	debug	*** ERROR : src: sendPolling syno[dsm][listPackages] To use the adapter, the user must be in the Administrators group! Also check the username and password in the adapter settings. Please try to enter the password again! code: 400 message: No such account or incorrect password
      synology.0
      2021-12-10 20:01:14.638	debug	* No response, read next.
      synology.0
      2021-12-10 20:01:13.899	debug	* Get info from (firstPoll) api: DSM method: listPackages params: {"version":1}
      synology.0
      2021-12-10 20:01:13.898	debug	* sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"listPackages","params":{"version":1}}
      synology.0
      2021-12-10 20:01:13.896	debug	-----------------------------------------------------------------------------------------------------
      synology.0
      2021-12-10 20:01:10.258	info	Connecting to Synology 192.168.178.20:5000
      synology.0
      2021-12-10 20:01:10.195	info	starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.synology, node: v14.18.2, js-controller: 3.3.21
      synology.0
      2021-12-10 20:01:09.069	debug	Plugin sentry Initialize Plugin (enabled=true)
      synology.0
      2021-12-10 20:00:47.243	warn	get state error: Connection is closed.
      synology.0
      2021-12-10 20:00:47.241	warn	Could not perform strict object check of state synology.0.info.connection: Connection is closed.
      synology.0
      2021-12-10 20:00:47.240	info	terminating with timeout
      synology.0
      2021-12-10 20:00:47.234	warn	redis get synology.0.info.connection, error - Connection is closed.
      synology.0
      2021-12-10 20:00:46.545	warn	get state error: Connection is closed.
      synology.0
      2021-12-10 20:00:46.444	warn	redis get synology.0.info.connection, error - Connection is closed.
      synology.0
      2021-12-10 20:00:45.737	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      synology.0
      2021-12-10 20:00:45.735	info	terminating
      synology.0
      2021-12-10 20:00:45.733	info	Got terminate signal TERMINATE_YOURSELF
      synology.0
      2021-12-10 20:00:12.413	info	Connecting to Synology 192.168.178.20:5000
      synology.0
      2021-12-10 20:00:12.300	info	starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.synology, node: v14.18.2, js-controller: 3.3.21
      • Glasfaser
        Glasfaser @ub.privat last edited by
        @ub-privat
        ist hier dein Uwe aufgeführt !?
        • Glasfaser
          Glasfaser @Glasfaser last edited by
          @ub-privat
          @glasfaser sagte in Synology Adapter bleibt "gelb":
          Es kann auch sein das es in der SYN bei der Firewall der Zugang gesperrt wurde
          Auch das überprüft !?
          ub.privat 1 Reply Last reply Reply Quote 0
          • ub.privat
            @glasfaser
            Ja ist er!
            • Glasfaser
              @ub-privat sagte in Synology Adapter bleibt "gelb":
              Ja ist er!
              Hast du oben meinen weiteren Hinweis/Anfrage gelesen !?
              ub.privat 1 Reply Last reply Reply Quote 1
              • ub.privat
                @glasfaser
                nein, leider nicht -- sich überschnitten. Hier muss unter Freigabe der iobroker rein!?
                • Glasfaser
                  müssen nicht , nur zwecks vieler anfragen wäre es ratsam.
                  Lege doch einen neuen User an mit Adminrechte und ein Passwort ohne Sonderzeichen !?
                  ub.privat da_Woody 2 Replies Last reply Reply Quote 0
                  • ub.privat
                    @glasfaser
                    Das war die Lösung!
                    Perfekt und DANKE = wieder etwas gelernt!👍
                    • da_Woody
                      da_Woody @Glasfaser last edited by
                      @glasfaser ich nehm da meinen admin acc. wozu soviele user? für backitup dann auch noch einen user, u.s.w...
                      • Glasfaser
                        Glasfaser @da_Woody last edited by Glasfaser
                        @da_woody sagte in Synology Adapter bleibt "gelb":
                        wozu soviele user?
                        Ja , braucht man nicht .....
                        Das war ja nur ein ToDo um den Fehler zu finden ,
                        es sollte nicht heißen : " nimm einen extra AdminUser für den Adapter .... " .
                        Pedder007 1 Reply Last reply Reply Quote 1
                        • Pedder007
                          Pedder007 @Glasfaser last edited by
                          Hallo @glasfaser,
                          ich laufe hier leider gerade auf dieselben Probleme. Log-Meldung sieht aus wie bei ub-privat:
                          synology.0
                          2021-12-19 21:23:38.291	debug	Error: Reconnection after 10s
                          synology.0
                          2021-12-19 21:23:38.288	debug	*** ERROR : src: sendPolling syno[dsm][getPollingData] To use the adapter, the user must be in the Administrators group! code: 400 message: No such account or incorrect password
                          synology.0
                          2021-12-19 21:23:38.284	debug	* No response, read next.
                          synology.0
                          2021-12-19 21:23:33.837	debug	* Get info from (firstPoll) api: DSM method: getPollingData params: {}
                          synology.0
                          2021-12-19 21:23:33.835	debug	* sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
                          synology.0
                          2021-12-19 21:23:33.833	debug	-----------------------------------------------------------------------------------------------------
                          synology.0
                          2021-12-19 21:23:29.028	info	Connecting to Synology 192.xxx.xxx.xxx:xxxxx
                          synology.0
                          2021-12-19 21:23:28.974	info	starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.synology, node: v14.18.2, js-controller: 3.3.21
                          Ich habe es bereits mit 2 verschiedenen neuen Nutzern auf der Syn versucht:
                          DS218play
                          DSM 6.2.4-25556 Update 2
                          Die Admin-Nutzer Parameter auf der Synology stimmen auch alle.
                          Allerdings bekomme ich meinen Adapter nicht auf die 2.0.0 gezogen und kann somit auch nicht die API 6.2.4, bzw. 7 auswählen.
                          Habe natürlich auch schon die Anleitung hier im Chat befolgt, aber der Adapter bleibt auf 1.1.3, auch wenn ich über die Katze installiere.
                          Hast Du evtl. noch eine andere Idee?
                          • Glasfaser
                            @pedder007 sagte in Synology Adapter bleibt "gelb":
                            Auch den richtigen Link:
                            https://github.com/iobroker-community-adapters/ioBroker.synology
                            Mache danach mal ein
                            iobroker u all
                            Pedder007 1 Reply Last reply Reply Quote 0
                            • Pedder007
                              Pedder007 @Glasfaser last edited by Pedder007
                              @glasfaser said in Synology Adapter bleibt "gelb":
                              Hi danke für die schnelle Rückmeldung.
                              Muss mich aber mal als Shell-Dummy outen 😉
                              Was mache ich mit dem Link, bzw. wie verwende ich den?
                              Edit: Habs gefunden, Du meinst in dem Install-Pop-Up:
                              • Glasfaser
                                Glasfaser @Pedder007 last edited by
                                Ja ... richtig , dort.
                                Pedder007 2 Replies Last reply Reply Quote 1
                                • Pedder007
                                  @glasfaser BINGO 👍 👍 👍
                                  Adapter vers. 2.0.1 und nun läufts mit Auswahl der API 6.2.3
                                  update all brauchte ich schon gar nicht mehr 🙂
                                  • Pedder007
                                    @glasfaser, sorry ich bins dann doch nochmal.
                                    Ich hatte mir jetzt eine Blockly gebaut, mit welchem ich die Syn (nach ein paar Minuten theoretischem Stromausfall) herunterfahren möchte. Ich dachte ich könnte das einfach so machen:
                                    Das setzt mir zwar den Shutdown Datenpunkt im Adapter auf true (mit 'aktualisiere ...' sogar inkl. Ack. Flag) aber die Syn nimmt sich davon rein gar nichts an.
                                    Von der Syn Seite betrachtet ist der Nutzer die ganze Zeit angemeldet und sollte auch (hier oben alles beachtet) die richtigen Berechtigungen haben. Der ioBroker Client ist auch als vertrauenswürdig eingestuft.
                                    Im Log kann ich leider auch nichts entdecken:
                                    synology.0
                                    2021-12-20 22:58:42.173	debug	* The response is received, parse:
                                    synology.0
                                    2021-12-20 22:58:42.054	debug	* Get info from (fastPoll) api: DSM method: getInfo params: {}
                                    synology.0
                                    2021-12-20 22:58:42.054	debug	* sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
                                    synology.0
                                    2021-12-20 22:58:42.053	debug	-----------------------------------------------------------------------------------------------------
                                    synology.0
                                    2021-12-20 22:58:42.053	debug	SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false}
                                    synology.0
                                    2021-12-20 22:58:42.052	debug	* The response is received, parse:
                                    synology.0
                                    2021-12-20 22:58:41.771	debug	* Get info from (fastPoll) api: DSM method: getSystemStatus params: {}
                                    synology.0
                                    2021-12-20 22:58:41.771	debug	* sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}}
                                    synology.0
                                    2021-12-20 22:58:41.770	debug	-----------------------------------------------------------------------------------------------------
                                    synology.0
                                    2021-12-20 22:58:41.770	debug	SystemUtilization - Response: {"cpu":{"15min_load":35,"1min_load":56,"5min_load":36,"device":"System","other_load":2,"system_load":0,"user_load":1},"disk":{"disk":[{"device":"sda","display_name":"Drive 1","read_access":0,"read_byte":0,"type":"internal","utilization":1,"write_access":4,"write_byte":19456},{"device":"sdb","display_name":"Drive 2","read_access":0,"read_byte":0,"type":"internal","utilization":1,"write_access":4,"write_byte":19456}],"total":{"device":"total","read_access":0,"read_byte":0,"utilization":1,"write_access":8,"write_byte":38912}},"lun":[],"memory":{"avail_real":148584,"avail_swap":1967836,"buffer":18196,"cached":141140,"device":"Memory","memory_size":1048576,"real_usage":53,"si_disk":0,"so_disk":0,"swap_usage":6,"total_real":658392,"total_swap":2097084},"network":[{"device":"total","rx":2227,"tx":1364},{"device":"eth0","rx":2227,"tx":1364}],"space":{"total":{"device":"total","read_access":0,"read_byte":0,"utilization":0,"write_access":1,"write_byte":6826},"volume":[{"device":"dm-0","display_name":"volume1","read_access":0,"read_byte":0,"utilization":0,"write_access":1,"write_byte":6826}]},"time":1640037520}
                                    synology.0
                                    2021-12-20 22:58:41.768	debug	* The response is received, parse:
                                    synology.0
                                    2021-12-20 22:58:40.553	debug	* Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
                                    synology.0
                                    2021-12-20 22:58:40.552	debug	* sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
                                    Hast Du dazu eine Idee?
                                    Oder liegt es evtl. an der Kombi:
                                    DS218play
                                    mit Instanz API Version 6.2.3?
                                    In den anderen Threads welche ich zu der Frage 'Syn-Shutdown' im Forum gefunden habe, kann ich leider auch keine Hinweise dazu entdecken.
                                    PS.
                                    Ich muss für heute leider Schluss machen, sonst wird das Schlafdefizit zu groß 😉
                                    • da_Woody
                                      da_Woody last edited by da_Woody
                                      das Schlafdefizit
                                      du kannst ruhig auspennen und aufhören mit blockly zu turnen... 😉
                                      https://github.com/iobroker-community-adapters/ioBroker.synology/issues/38
                                      Lyxon1337 created this issue in iobroker-community-adapters/ioBroker.synology
                                      closed commands - reboot/shutdown - not work #38
                                      • Pedder007
                                        Pedder007 @da_Woody last edited by Pedder007
                                        @da_woody danke fürs ein Hinweis, da hätte ich ja wirklich noch lange turnen können 😵‍💫
                                        Also abwarten und Tee trinken …, oder Glühwein 😉
                                        • Pedder007
                                          @da_woody + @Glasfaser
                                          Da sich am Synology Adapter wohl aktuell noch nichts tut, habe ich den Spieß an der Stelle jetzt erst einmal umgedreht 🙂
                                          Die Synology schaut von sich aus was los ist und entscheidet dann nach 4 Minuten runter zu fahren:
                                          (Bei 'Netzwerk-USV-Server-IP' einfach den IOBroker eingetragen, worauf bei mir auch der NUT Server läuft.)
                                          So bleiben dann nach rd. 5 Minuten noch reichlich Reserven für die beiden Raspis und den Switch inkl. WLAN der da dran hängt 😉
                                          synology nas synology nas mit io-broker
                                          3608
