    4. JavaScript
    5. [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten
    • Latzi
      Latzi @ticaki last edited by
      @ticaki
      Guten Morgen,
      ich bekomme warn bezüglich der refresh Datenpunkte, was soll ich unternehmen?
      2021-12-12 07:55:57.862 - info: javascript.0 (23974) Start javascript script.js.common.UWZ_melden_V0_99_Beta1
      2021-12-12 07:55:57.905 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: Skripts gestartet: ID:1533.1505777283394
      2021-12-12 07:55:57.910 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: registered 1 subscription and 0 schedules
      2021-12-12 07:55:57.970 - warn: javascript.0 (23974) You are assigning a string to the state "javascript.0.wetterwarnung.config.warnzelle.dwd.refresh#" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
      2021-12-12 07:55:57.980 - warn: javascript.0 (23974) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1962:33)
      2021-12-12 07:55:57.981 - warn: javascript.0 (23974) at processImmediate (internal/timers.js:466:21)
      2021-12-12 07:55:58.000 - info: javascript.0 (23974) State value to set for "javascript.0.wetterwarnung.config.warnzelle.dwd.refresh#" has to be type "boolean" but received type "string"
      2021-12-12 07:55:58.302 - warn: javascript.0 (23974) You are assigning a string to the state "javascript.0.wetterwarnung.config.warnzelle.uwz.refresh#" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
      2021-12-12 07:55:58.304 - warn: javascript.0 (23974) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1962:33)
      2021-12-12 07:55:58.304 - warn: javascript.0 (23974) at processImmediate (internal/timers.js:466:21)
      2021-12-12 07:55:58.311 - info: javascript.0 (23974) State value to set for "javascript.0.wetterwarnung.config.warnzelle.uwz.refresh#" has to be type "boolean" but received type "string"
      2021-12-12 07:55:58.600 - warn: javascript.0 (23974) You are assigning a string to the state "javascript.0.wetterwarnung.config.warnzelle.zamg.refresh#" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
      2021-12-12 07:55:58.601 - warn: javascript.0 (23974) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1962:33)
      2021-12-12 07:55:58.602 - warn: javascript.0 (23974) at processImmediate (internal/timers.js:466:21)
      2021-12-12 07:55:58.609 - info: javascript.0 (23974) State value to set for "javascript.0.wetterwarnung.config.warnzelle.zamg.refresh#" has to be type "boolean" but received type "string"
      2021-12-12 07:55:58.622 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: Rufe Daten vom Server ab - ZAMG Area
      2021-12-12 07:55:58.696 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: Status: 200
      2021-12-12 07:55:59.012 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: MODE wurde geändert. MODE: 2 firstRun:true
      2021-12-12 07:55:59.013 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: InitDatabase() first: true
      2021-12-12 07:55:59.014 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: Standalone UWZ Datenabruf aktiviert
      2021-12-12 07:55:59.015 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: Rufe Daten vom Server ab - UWZ
      2021-12-12 07:55:59.162 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: AREA: UWZAT00754
      2021-12-12 07:55:59.163 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: Status: 200
      2021-12-12 07:55:59.163 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: Url: http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=UWZAT00754
      2021-12-12 07:55:59.166 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: ZAMG aktivieren, Warncell vorhanden
      2021-12-12 07:55:59.167 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: Rufe Daten vom Server ab -ZAMG
      2021-12-12 07:55:59.183 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: 1. addDatabaseData() ID + JSON:javascript.0.wetterwarnung.data.uwz-id.UWZAT00754.warning.object - {}
      2021-12-12 07:55:59.239 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: 1. addDatabaseData() ID + JSON:javascript.0.wetterwarnung.data.uwz-id.UWZAT00754.warning1.object - {}
      2021-12-12 07:55:59.281 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: 1. addDatabaseData() ID + JSON:javascript.0.wetterwarnung.data.uwz-id.UWZAT00754.warning2.object - {}
      2021-12-12 07:55:59.323 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: 1. addDatabaseData() ID + JSON:javascript.0.wetterwarnung.data.uwz-id.UWZAT00754.warning3.object - {}
      2021-12-12 07:55:59.364 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: Status: 200
      2021-12-12 07:55:59.364 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: Url: https://warnungen.zamg.at/wsapp/api/getWarningsForCoords?lon=14.62274&lat=48.332741&lang=de
      2021-12-12 07:55:59.400 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: 1. addDatabaseData() ID + JSON:javascript.0.wetterwarnung.data.uwz-id.UWZAT00754.warning4.object - {}
      2021-12-12 07:55:59.446 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: []
      2021-12-12 07:55:59.673 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: []
        Megawaldi @ticaki last edited by
        @ticaki
        Guten Morgen,
        auch nach dem löschen der entsprechenden Datenpunkte habe ich auch immer den typfehler:
        javascript.0
        	2021-12-12 10:44:38.802	info	State value to set for "0_userdata.0.wetterwarnung.config.warnzelle.zamg.refresh#" has to be type "boolean" but received type "string"
        javascript.0
        	2021-12-12 10:44:38.801	warn	at processImmediate (internal/timers.js:466:21)
        javascript.0
        	2021-12-12 10:44:38.801	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1962:33)
        javascript.0
        	2021-12-12 10:44:38.801	warn	You are assigning a string to the state "0_userdata.0.wetterwarnung.config.warnzelle.zamg.refresh#" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
        javascript.0
        	2021-12-12 10:44:38.726	info	State value to set for "0_userdata.0.wetterwarnung.config.warnzelle.uwz.refresh#" has to be type "boolean" but received type "string"
        javascript.0
        	2021-12-12 10:44:38.725	warn	at processImmediate (internal/timers.js:466:21)
        javascript.0
        	2021-12-12 10:44:38.725	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1962:33)
        javascript.0
        	2021-12-12 10:44:38.725	warn	You are assigning a string to the state "0_userdata.0.wetterwarnung.config.warnzelle.uwz.refresh#" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
        javascript.0
        	2021-12-12 10:44:38.360	info	State value to set for "0_userdata.0.wetterwarnung.config.warnzelle.dwd.refresh#" has to be type "boolean" but received type "string"
        javascript.0
        	2021-12-12 10:44:38.358	warn	at processImmediate (internal/timers.js:466:21)
        javascript.0
        	2021-12-12 10:44:38.358	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1962:33)
        javascript.0
        	2021-12-12 10:44:38.357	warn	You are assigning a string to the state "0_userdata.0.wetterwarnung.config.warnzelle.dwd.refresh#" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
          ticaki @Latzi last edited by ticaki
          @latzi
          @Megawaldi
          Update, war ein copy paste Fehler. Frage mich nur wieso ich den nicht hatte. Der Fehler war bei mir schon mehr als 4 Tage drin und ich hab mehr als einmal die States alle gelöscht.
          EDIT: Nur zur Info: Beim Verwenden von ZAMG und dem einfügen von Koordinaten über Objekte. Die Zahl muß einen . als Dezimaltrennzeichen haben.
          EDIT2: Daten die im Skript stehen lassen sich nicht löschen nur deaktivieren.
          Latzi 1 Reply Last reply Reply Quote 1
          • Latzi
            @ticaki
            auf der ZAMG-Seite sehe ich folgende Meldung:
            Im Datenpunkt "Glatteis" taucht aber leider nichts auf.
            Meine Koordinaten:
            var zamgCoordinates = [{breiten:48.332741,laengen:14.62274}];
              @latzi sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
              Bei mir gehts.
              Ist die Warnung unter data.zamg? Wenn nein, ist die koordinate unter config.warnzelle deaktiviert.
              steht dein minlevel im Skript auf höher als 1?Bildschirmfoto 2021-12-12 um 11.42.05.png
              Latzi 1 Reply Last reply Reply Quote 0
              • Latzi
                @ticaki
                Ich bin schlicht und ergreifend ein Idiot 😉
                Habe die Datenpunkte gelöscht und danach in der Config UWZ udn ZAMG nicht aktiviert!
                Das habe ich erst bemerkt, nachdem ich auf debug gestellt habe - da kam die Warnung!
                ALEES GUT, TOLLE ARBEIT 👏 👏
                  sigi234 Forum Testing Most Active @ticaki last edited by
                  @ticaki
                  • kann man bei dem DP 0_userdata.0.wetterwarnung.config.mode einen Bindestrich einfügen?
                  • Wo sehe ich die Anzahl der Warnungen, bzw. ob es eine Warnung gibt? Summer aller Warnungen
                    ticaki @sigi234 last edited by
                    @sigi234
                    //Version 0.99.02 Beta 1
                    • / als Trenner zwischen den Modes
                    • neuer State totalWarnings
                    • kleiner Bug behoben.
                    Der totalWarnings State kann rumspringen während der Verarbeitung er wird bei jedem Verändern der Datenbank und nach dem Durchlauf des Benachrichtigungs und Filtercode gesetzt.
                      Allgemeine Infos:
                      Diese Erweiterungen sind für den Einbau von Nina gedacht, das mit den Warncellen hauptsächlich damit der Nutzer bei der Eingabe einer dieser nicht nachvollziehbaren ID's sieht ob sie richtig ist. Darüber ist mir folgender Gedanke gekommen.
                      Es gibt Leute die Warnungen für z.B. Hamburg und Berlin bekommen wollen, andererseits auch Leute die wie ich auf dem Berg leben und im Tal arbeiten obwohl zwischen beiden Orten nicht wirklich eine Distanz liegt. Wäre es da nicht sinnvoll wenn ich Warngruppen einrichte. So das es die Möglichkeit gibt das unterschiedliche Warncellen zusammengefasst werden können (also keine doppelten Warnungen) im Zuge dessen könne ich die Warntypen vereinfachen und auch unterschiedliche Datenquellen zusamemnfassen. Damit meine ich das eine UWZ und DWD Warnung vor Schnee nicht mehr 2 Warnungen sondern nur noch eine Warnung ist.
                      Im Warntext würde das z.B. so aussehen
                      Amtliche WARNUNG vor FROST des DWD und des UWZ für Hamburg und Berlin:
                      Benötigt natürlich einiges an Änderungen (1-2 Wochen) und wird wohl auch nicht direkt problemlos funktionieren, da es soviele Kombinationen an Möglichkeiten gibt, die ich unmöglich testen kann. Dazu kommt noch das ich nur Meldungen zusammenfassen könnte die den gleichen Zeitraum umfassen.
                      Desweiteren würde ich immer die Meldung vom DWD bzw. ZAMG als Vorlage verwenden und UWZ als "da auch".
                        @ticaki
                        Ich würde UWZ ganz raus nehmen.
                        • Nashra
                          Nashra Most Active Forum Testing @sigi234 last edited by Nashra
                          @sigi234 sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                          @ticaki
                          Warum? UWZ ist hier bei uns genauer als DWD und NINA meldet wenn überhaupt wenn es fast vorbei ist 😂
                            ticaki @Nashra last edited by
                            @nashra
                            Danke ich hatte den gleichen Gedanken wie sigi, das hat sich damit erledigt 🙂
                            Latzi Nashra 2 Replies Last reply Reply Quote 1
                            • Latzi
                              Latzi @ticaki last edited by Latzi
                              @ticaki sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                              Bitte nicht UWZ rausnehmen, war im letzten Sommer das präziseste was an Vorhersage für mich möglich war!
                              • Nashra
                                Nashra Most Active Forum Testing @ticaki last edited by
                                @nashra
                                Danke. Problem ist wohl bei den verschiedenen Systemen das sie jeh nach Region unterschiedlich gut bzw. aktuell sind.
                                Hier z.B.
                                DWD schickt Sturmmeldung. Was passiert, nix
                                UWZ meldet, dann kommt auch was
                                NINA, naja. Kleines Beispiel, Samstags 12 Uhr Sirenentest, Meldung dazu kommt um 12:10 Uhr oder manchmal auch gar nicht. Beim Wetter ist es genauso.
                                  ticaki @Nashra last edited by ticaki
                                  @nashra
                                  Das mit der Sturmmeldung sollte aber mit DWD2 (das genauer) nicht mehr vorkommen. Ich hab hier immer Gewitterwarnungen ohne Gewitter. Aber seit DWD2 ist bis jetzt noch nix gewarnt worden das auch nicht da war.
                                  • Nashra
                                    Hm, ist DWD2 eine neue Api von DooferWetterdienstDeutschland 😂
                                    wenn Du schreibst das der besser ist, lasse ich mich mal überraschen.
                                      @nashra
                                      Ne das ist meine Bezeichung:
                                      Erläuterung:
                                      DWD Adapter ruft Daten für den Kreis ab, also alle Warnungen die innerhalb eines Kreis veröffentlicht werden abgerufen. Irgendwo in deinem Kreis wird also Sturm sein. 🙂
                                      Ich hab dann letztens etwas mit maps.dwd.de rumgespielt und dort einen möglichkeit gefunden Warnungen für ein Dorf/Stadt/Region abzurufen.
                                      Dazu suche hier: https://www.dwd.de/DE/leistungen/opendata/help/warnungen/cap_warncellids_csv.csv?__blob=publicationFile&v=3
                                      deine Gemeinde und trage diese in
                                      var dwdWarncellId='';
                                      ein.
                                      Danach erhälst du nur noch Warnungen die der DWD für den Bereich deines Ortes vorgesehen hat. Hat dein Ort extreme Höhenunterschiede (oder wie hier in der Gegend eine "Stadt" deren weitester Stadtteil 10 km entfernt ist) kann das aber noch immer ungenau sein.
                                      • Nashra
                                        Danke für die Erklärung, hört sich interessant an. Dann lasse ich mich mal überraschen 👍
                                          @nashra sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                                          Ich glaube wir reden aneinander vorbei.
                                          Das oben ist seit 2 Wochen in dem Script verfügbar.
                                          • Nashra
                                            Ähm, ja. Ist irgendwie untergegangen bzw. nicht mitbekommen da Privat einiges um die Ohren.
                                            Dann muß ich mal das Skript einbauen 🙂
                                            von 12345 oder komplett neu?
                                            1.0k
                                            1521
                                            567295
