    4. Falsche Admin Adapter Version wird angezeigt
      Keule @Homoran last edited by
      Sorry, ich wollte jetzt nicht noch mehr Verwirrung stiften, sonders das Problem besser darstellen.
      Nach dem Upgrade auf die 5.2.1 beta:
      holger@iobroker:~$ iobroker update -i
      Used repository: beta
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.2.1    , installed 5.1.29 [Updateable]
      Adapter    "amazon-dash"   : 1.1.0    , installed 1.1.0
      Adapter    "backitup"      : 2.2.2    , installed 2.2.2
      Adapter    "cloud"         : 4.1.0    , installed 4.1.0
      Adapter    "cul"           : 1.3.5    , installed 1.3.5
      Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
      Adapter    "denon"         : 1.11.2   , installed 1.11.2
      Adapter    "discovery"     : 2.7.5    , installed 2.7.5
      Adapter    "flot"          : 1.10.7   , installed 1.10.7
      Adapter    "harmony"       : 1.2.2    , installed 1.2.2
      Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
      Adapter    "hm-rpc"        : 1.14.50  , installed 1.14.50
      Adapter    "influxdb"      : 2.2.0    , installed 2.2.0
      Adapter    "info"          : 1.9.16   , installed 1.9.16
      Adapter    "javascript"    : 5.2.16   , installed 5.2.16
      Controller "js-controller" : 3.3.21   , installed 3.3.21
      Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
      Adapter    "mqtt"          : 2.4.1    , installed 2.4.1
      Adapter    "node-red"      : 2.4.1    , installed 2.4.1
      Adapter    "shelly"        : 5.0.0    , installed 5.0.0
      Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
      Adapter    "socketio"      : 3.1.5    , installed 3.1.5
      Adapter    "sonoff"        : 2.4.7    , installed 2.4.7
      Adapter    "sql"           : 1.15.7   , installed 1.15.7
      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
      Adapter    "vis"           : 1.4.6    , installed 1.4.6
      Adapter    "web"           : 3.4.16   , installed 3.4.16
      Adapter    "zigbee"        : 1.6.8    , installed 1.6.8
      Adapter    "zwave2"        : 2.4.1    , installed 2.4.1
      holger@iobroker:~$ iobroker list adapters
      system.adapter.admin                   : admin          - v5.2.1
      system.adapter.amazon-dash             : amazon-dash    - v1.1.0
      system.adapter.backitup                : backitup       - v2.2.2
      system.adapter.cloud                   : cloud          - v4.1.0
      system.adapter.cul                     : cul            - v1.3.5
      system.adapter.daswetter               : daswetter      - v3.0.9
      system.adapter.denon                   : denon          - v1.11.2
      system.adapter.discovery               : discovery      - v2.7.5
      system.adapter.flot                    : flot           - v1.10.7
      system.adapter.harmony                 : harmony        - v1.2.2
      system.adapter.hm-rega                 : hm-rega        - v3.0.33
      system.adapter.hm-rpc                  : hm-rpc         - v1.14.50
      system.adapter.influxdb                : influxdb       - v2.2.0
      system.adapter.info                    : info           - v1.9.16
      system.adapter.javascript              : javascript     - v5.2.16
      system.adapter.mihome-vacuum           : mihome-vacuum  - v3.3.1
      system.adapter.mqtt                    : mqtt           - v2.4.1
      system.adapter.node-red                : node-red       - v2.4.1
      system.adapter.shelly                  : shelly         - v5.0.0
      system.adapter.simple-api              : simple-api     - v2.6.2
      system.adapter.socketio                : socketio       - v3.1.5
      system.adapter.sonoff                  : sonoff         - v2.4.7
      system.adapter.sql                     : sql            - v1.15.7
      system.adapter.telegram                : telegram       - v1.10.0
      system.adapter.vis                     : vis            - v1.4.6
      system.adapter.web                     : web            - v3.4.16
      system.adapter.zigbee                  : zigbee         - v1.6.8
      system.adapter.zwave2                  : zwave2         - v2.4.1
        Homoran Global Moderator Administrators @Keule last edited by
        @keule sagte in Falsche Admin Adapter Version wird angezeigt:
        das muss man machen bevor etwas verändert wird.
        Jetzt ist es auch egal 😞
        Mach mal ein iobroker upload all
          @keule Die anderen Möglichkeiten wären:
          • du hast zwei Installationen parallel auf deinem Server
          • du hast ein Multihost-System mit verschiedenen Admin-Versionen
          • bei dir ist etwas grundsätzlich faul
          K 2 Replies Last reply Reply Quote 0
            OK, ich mache nur noch, was DU sagst 😬
            holger@iobroker:~$ iobroker upload all
            upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
            upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
            upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
            upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/        javascript
            upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
            upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
            upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/        json
            upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascri        pt
            upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/        json
            upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascrip        t
            upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map applicati        on/json
            upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javas        cript
            upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-WRE3EG62.js.map build/chunk-WRE3EG6        2.js.map application/json
            upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-WRE3EG62.js build/chunk-WRE3EG62.js        application/javascript
            upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-FLBBXTIS.js.map build/chunk-FLBBXTI        S.js.map application/json
            upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-FLBBXTIS.js build/chunk-FLBBXTIS.js        application/javascript
            upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-DDIJC5B5.js.map build/chunk-DDIJC5B        5.js.map application/json
            upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-DDIJC5B5.js build/chunk-DDIJC5B5.js        application/javascript
            upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascrip        t
            upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javas        cript
            upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/qujiabao_gas.png img/qujiabao_gas.png ima        ge/png
            upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/owvfni3.png img/owvfni3.png image/png
            upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/konke_kpdr.png img/konke_kpdr.png image/p        ng
            upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/group_4.png img/group_4.png image/png
            upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto.png img/gledopto.png image/png
            upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/exp_light.png img/exp_light.png image/png
            upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/danfoss_ally.png img/danfoss_ally.png imag        e/png
            upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cc2538_router_v1.png img/cc2538_router_v1.        png image/png
            upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/basiczbr3.png img/basiczbr3.png image/png
            upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0502A.png img/TS0502A.png image/png
            upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_50067.png img/Paulmann_50067.png        image/png
            upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
            upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.pn        g image/png
            upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Sp        irit_04.png image/png
            upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/        png
            upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png im        age/png
            upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad_LeTV_8.png img/DIYRuZ_FreeP        ad_LeTV_8.png image/png
            upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png        image/png
            upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png im        age/png
            upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/pn        g
            upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
            upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
            upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.p        ng image/png
            upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
            upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
            upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
            upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
            upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
            upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
            upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
            upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
            upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js applica        tion/javascript
            upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
            upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1d        b.png image/png
            upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js.map static/js/run        time-main.8b37c647.js.map application/json
            upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js static/js/runtime        -main.8b37c647.js application/javascript
            upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.67ec0642.chunk.js.map static/js/main.        67ec0642.chunk.js.map application/json
            upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.67ec0642.chunk.js static/js/main.67ec        0642.chunk.js application/javascript
            upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.d0deddb4.chunk.js.map static/js/2.d0dedd        b4.chunk.js.map application/json
            upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.d0deddb4.chunk.js.LICENSE.txt static/js/2        .d0deddb4.chunk.js.LICENSE.txt text/plain
            upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.d0deddb4.chunk.js static/js/2.d0deddb4.ch        unk.js application/javascript
            upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/mai        n.e2d673ee.chunk.css.map application/json
            upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2        d673ee.chunk.css text/css
            upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.d22aed1b.chunk.css.map static/css/2.d22a        ed1b.chunk.css.map application/json
            upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.d22aed1b.chunk.css static/css/2.d22aed1b        .chunk.css text/css
            upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
            upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
            upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
            upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/j        son
            upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_        55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
            upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_        100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
            upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256        x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
            upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_        256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
            upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_25        6x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
            upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-s        oft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
            upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a        _256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
            upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_        fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
            upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-        soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
            upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_25        6x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
            upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-th        ick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
            upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8e        e_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
            upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_25        6x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
            upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1        c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
            upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111        111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
            upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffff        ff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
            upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-th        ick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
            upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
            upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
            upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-        4.5.4.css text/css
            upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.        xml application/xml
            upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map ap        plication/json
            upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
            upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.        fancytree.min.css text/css
            upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree        /ui.fancytree.min-win7.css text/css
            upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytr        ee/ui.fancytree.jquery.min.css text/css
            upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image        /png
            upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif i        mage/gif
            upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image        /gif
            upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png ima        ge/png
            upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png i        mage/png
            upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
            upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
            upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
            upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
            upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
            upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
            upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
            upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui.html widgets/jqui.html text/html
            upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBool.png widgets/basic/img/Prev        _ValueBool.png image/png
            upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.        js application/javascript
            upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javas        cript
            upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png        image/png
            upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
            upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
            upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
            upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
            upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
            upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
            upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
            upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
            upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
            upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
            upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
            upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
            upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
            upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
            upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
            upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
            upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
            upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
            upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
            upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
            upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
            upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
            upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
            upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
            upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
            upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
            upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
            upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
            upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
            upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
            upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
            upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
            upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
            upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html
            upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
            Update "system.adapter.telegram.0"
            upload [7] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js words.js application/javascript
            upload [6] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
            upload [5] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/jsonCustom.json jsonCustom.json application/json
            upload [4] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/jsonConfig.json jsonConfig.json application/json
            upload [3] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index_m.html index_m.html text/html
            upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html index.html text/html
            upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom_m.html custom_m.html text/html
            upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom.html custom.html text/html
            Update "system.adapter.sql.0"
            upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
            upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
            upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
            upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
            upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/words.js words.js application/javascript
            upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
            upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index_m.html index_m.html text/html
            upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
            Adapter "system.adapter.web.0" restarted.
            upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
            upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
            upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
            upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
            upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
            upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
            upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
            upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
            upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
            upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
            upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
            upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
            upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
            upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js words.js application/javascript
            upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
            upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.html index_m.html text/html
            upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index.html index.html text/html
            upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
            upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
            upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
            upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
            upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
            upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
            upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
            upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
            upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
            upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
            upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
            upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
            upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
            upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/javascript/javascript.js vs/basic-languages/javascript/javascript.js application/javascript
            upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.5a275f96.chunk.js static/js/main.5a275f96.chunk.js application/javascript
            upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/index_m.html index_m.html text/html
            upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/de.js google-blockly/own/msg/de.js application/javascript
            upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_sendto.js google-blockly/own/blocks_sendto.js application/javascript
            upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/it.js google-blockly/msg/js/it.js application/javascript
            upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur null
            upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur null
            upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
            upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/dropdown-arrow.svg google-blockly/media/dropdown-arrow.svg image/svg+xml
            upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
            upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
            upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
            upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
            upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
            upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
            upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
            upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
            upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
            upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
            upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
            upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
            upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
            upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
            upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
            upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
            upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
            Update "system.adapter.javascript.0"
            upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
            upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/feednami.min.js lib/js/feednami.min.js application/javascript
            upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/xubuntu.png lib/img/logos/xubuntu.png image/png
            upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/pclinuxos.png lib/img/logos/pclinuxos.png image/png
            upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/freebsd.png lib/img/logos/freebsd.png image/png
            upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/usb.png lib/img/icons/usb.png image/png
            upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/bluetooth.png lib/img/icons/bluetooth.png image/png
            upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
            upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/audio.png lib/img/icons/audio.png image/png
            upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
            upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
            upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
            upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
            upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
            upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
            upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
            upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
            upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
            upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
            upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
            upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
            upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
            upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
            upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
            upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
            upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
            upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
            upload [15] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/words.js words.js application/javascript
            upload [14] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonCustom.json jsonCustom.json application/json
            upload [13] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonConfig.json jsonConfig.json application/json
            upload [12] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/influxdb.png influxdb.png image/png
            upload [11] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/index_m.html index_m.html text/html
            upload [10] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [9] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [8] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [7] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [6] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [5] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [4] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [3] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [2] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [1] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [0] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/custom_m.html custom_m.html text/html
            Update "system.adapter.influxdb.0"
            upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/93_hm-es-pmsw1-pl_thumb.png icons/93_hm-es-pmsw1-pl_thumb.png image/png
            upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/46_hm-lc-sw4-pcb_thumb.png icons/46_hm-lc-sw4-pcb_thumb.png image/png
            upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/187_hmip-rcb1_thumb.png icons/187_hmip-rcb1_thumb.png image/png
            upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/178_hmip-etrv-b1_thumb.png icons/178_hmip-etrv-b1_thumb.png image/png
            upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/168_hmip-smi55_thumb.png icons/168_hmip-smi55_thumb.png image/png
            upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/159_hmip-mod-rc8_thumb.png icons/159_hmip-mod-rc8_thumb.png image/png
            upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/14_hm-sec-key_thumb.png icons/14_hm-sec-key_thumb.png image/png
            upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/140_alpha-ip-rgb_thumb.png icons/140_alpha-ip-rgb_thumb.png image/png
            upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/132_hmip-smo_thumb.png icons/132_hmip-smo_thumb.png image/png
            upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/121_hmip-wth_thumb.png icons/121_hmip-wth_thumb.png image/png
            upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
            upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-uk_thumb.png icons/113_hmip-psm-uk_thumb.png image/png
            upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
            upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-it_thumb.png icons/113_hmip-psm-it_thumb.png image/png
            upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-ch_thumb.png icons/113_hmip-psm-ch_thumb.png image/png
            upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png
            upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/111_hm-lc-rgbw-wm_thumb.png icons/111_hm-lc-rgbw-wm_thumb.png image/png
            upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/110_hm-es-pmsw1-dr_thump.png icons/110_hm-es-pmsw1-dr_thump.png image/png
            upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/109_hm-lc-sw1-pl-ct_thump.png icons/109_hm-lc-sw1-pl-ct_thump.png image/png
            upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/108_hm-rc-dis-h-x-eu_thump.png icons/108_hm-rc-dis-h-x-eu_thump.png image/png
            upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R5_thumb.png icons/107_hm-es-pmsw1-pl-R5_thumb.png image/png
            upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R4_thumb.png icons/107_hm-es-pmsw1-pl-R4_thumb.png image/png
            upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R3_thumb.png icons/107_hm-es-pmsw1-pl-R3_thumb.png image/png
            upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R2_thumb.png icons/107_hm-es-pmsw1-pl-R2_thumb.png image/png
            upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/105_hm-sec-sd-2-team_thumb.png icons/105_hm-sec-sd-2-team_thumb.png image/png
            upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/104_hm-sec-sd-2_thumb.png icons/104_hm-sec-sd-2_thumb.png image/png
            upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/103_hm-sen-mdir-wm55_thumb.png icons/103_hm-sen-mdir-wm55_thumb.png image/png
            upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/102_hm-es-tx-wm_thumb.png icons/102_hm-es-tx-wm_thumb.png image/png
            upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/101_hm-sen-db-pcb_thumb.png icons/101_hm-sen-db-pcb_thumb.png image/png
            upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/100_hm-rc-8_thumb.png icons/100_hm-rc-8_thumb.png image/png
            upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
            Update "system.adapter.hm-rpc.0"
            Update "system.adapter.hm-rpc.1"
            upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
            upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
            upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
            upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
            Update "system.adapter.hm-rega.0"
            upload [3] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/words.js words.js application/javascript
            upload [2] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index_m.html index_m.html text/html
            upload [1] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index.html index.html text/html
            upload [0] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/harmony.png harmony.png image/png
            Update "system.adapter.harmony.0"
            upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
            Update "system.adapter.flot.0"
            upload [20] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js js/flot.js application/javascript
            upload [19] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js.map js/edit.js.map application/json
            upload [18] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
            upload [17] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html.map index.html.map application/json
            upload [16] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
            upload [15] flot /opt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
            upload [14] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html.map edit.html.map application/json
            upload [13] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
            upload [12] flot /opt/iobroker/node_modules/iobroker.flot/www/css/jquery.colorpicker.css css/jquery.colorpicker.css text/css
            upload [11] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/ui-colorpicker.png css/images/ui-colorpicker.png image/png
            upload [10] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/preview-opacity.png css/images/preview-opacity.png image/png
            upload [9] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map.png css/images/map.png image/png
            upload [8] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-pointer.png css/images/map-pointer.png image/png
            upload [7] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-opacity.png css/images/map-opacity.png image/png
            upload [6] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar.png css/images/bar.png image/png
            upload [5] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-pointer.png css/images/bar-pointer.png image/png
            upload [4] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-opacity.png css/images/bar-opacity.png image/png
            upload [3] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-alpha.png css/images/bar-alpha.png image/png
            upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/map.png css/images/128/map.png image/png
            upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar.png css/images/128/bar.png image/png
            upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar-alpha.png css/images/128/bar-alpha.png image/png
            upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
            upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
            upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
            upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
            upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
            upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
            upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
            upload [2] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js words.js application/javascript
            upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.html index_m.html text/html
            upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.png denon.png image/png
            upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/75.png icons/viento-wind/galeria2-Beaufort/75.png image/png
            upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/3.png icons/viento-wind/galeria2-Beaufort/3.png image/png
            upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria1/16.png icons/viento-wind/galeria1/16.png image/png
            upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/60.png icons/viento-wind/Beaufort-White/60.png image/png
            upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/15.png icons/viento-wind/Beaufort-White/15.png image/png
            upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria6/11.svg icons/tiempo-weather/galeria6/11.svg image/svg+xml
            upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/PNG/White/9.png icons/tiempo-weather/galeria5/PNG/White/9.png image/png
            upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria4/3.png icons/tiempo-weather/galeria4/3.png image/png
            upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria4/11.png icons/tiempo-weather/galeria4/11.png image/png
            upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/2.png icons/tiempo-weather/galeria3/2.png image/png
            upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/10.png icons/tiempo-weather/galeria3/10.png image/png
            upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria2/19.png icons/tiempo-weather/galeria2/19.png image/png
            upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria2/1.png icons/tiempo-weather/galeria2/1.png image/png
            upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria1/18.png icons/tiempo-weather/galeria1/18.png image/png
            upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/9.png icons/luna-moon/9.png image/png
            upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/26.png icons/luna-moon/26.png image/png
            upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/25.png icons/luna-moon/25.png image/png
            upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/24.png icons/luna-moon/24.png image/png
            upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/23.png icons/luna-moon/23.png image/png
            upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/22.png icons/luna-moon/22.png image/png
            upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/21.png icons/luna-moon/21.png image/png
            upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/20.png icons/luna-moon/20.png image/png
            upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/2.png icons/luna-moon/2.png image/png
            upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/19.png icons/luna-moon/19.png image/png
            upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/18.png icons/luna-moon/18.png image/png
            upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/17.png icons/luna-moon/17.png image/png
            upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/16.png icons/luna-moon/16.png image/png
            upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/15.png icons/luna-moon/15.png image/png
            upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/14.png icons/luna-moon/14.png image/png
            upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/13.png icons/luna-moon/13.png image/png
            upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/12.png icons/luna-moon/12.png image/png
            upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/11.png icons/luna-moon/11.png image/png
            upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/10.png icons/luna-moon/10.png image/png
            upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/1.png icons/luna-moon/1.png image/png
            upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/0.png icons/luna-moon/0.png image/png
            upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/daswettercom.png daswettercom.png image/png
            upload [13] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/words.js words.js application/javascript
            upload [12] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/index_m.html index_m.html text/html
            upload [11] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/index.html index.html text/html
            upload [10] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [9] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [8] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [7] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [6] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [5] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [4] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [3] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [2] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [1] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [0] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/busware.jpg busware.jpg image/jpeg
            upload [17] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
            upload [16] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/jsonConfig.json jsonConfig.json application/json
            upload [15] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
            upload [14] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/img/info-big.png img/info-big.png image/png
            upload [13] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [12] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [11] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [10] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [9] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [8] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [7] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
            upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
            upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
            upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
            upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
            upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
            upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
            upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
            upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
            upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
            upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
            upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
            upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
            upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
            upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
            upload [3] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/words.js words.js application/javascript
            upload [2] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/index_m.html index_m.html text/html
            upload [1] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/index.html index.html text/html
            upload [0] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/amazon-dash.png amazon-dash.png image/png
            upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
            upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
            upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
            upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
            upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
              Keule @Homoran last edited by Keule
              • du hast zwei Installationen parallel auf deinem Server - Wüsste ich nicht
              • du hast ein Multihost-System mit verschiedenen Admin-Versionen - eigentlich auch nicht
              • bei dir ist etwas grundsätzlich faul - ich hoffe nicht
                Ich hatte auch schon, vor meiner Anfrage hier, den Adapter entfernt mit:
                iobroker del admin
                  Homoran Global Moderator Administrators @Keule last edited by
                  @keule sagte in Falsche Admin Adapter Version wird angezeigt:
                  und wie dann neu installiert?
                    und wie sieht es nach dem upload aus?
                      @homoran sagte in Falsche Admin Adapter Version wird angezeigt:
                      iobroker install admin@5.1.25
                        Hab ich doch oben gepostet
                          nicht optimal!
                          das erzeugt keine Instanz und macht dann auch nicht den notwendigen upload
                          Dazu hätte es iobroker add admin benötigt
                            • einen Screenshot vom Admin?
                            • eine erneute Ausgabe von iobroker update -i?
                            Sorry, aber die hab ich wohl übersehen
                            K 2 Replies Last reply Reply Quote 0
                              Ja, iobroker add admin habe ich auch gemacht.
                              Der Adapter läuft ja auch. Nur wird immer noch 5.1.29 als installiert angezeigt - bei, meiner Meinung nach, real installierter 5.1.25, sowie auch bei 5.2.1.
                              BTW: Wie mache ich das hier so kenntlich? 758d3002-3f0d-4f04-95c0-a97854d6529d-grafik.png
                                Du hattest von upload gesprochen
                                  Homoran Global Moderator Administrators @Keule last edited by Homoran
                                  das sollte bei sauberer Installation und nach erfolgtem Upload definitiv nicht mehr sein. Zumal iobroker list adapters ja die richtige Version anzeigt.
                                  Jetzt komme ich allmählich an meine Grenzen 😞
                                  Zeig mal bitte zusätzlich noch iobroker list instances
                                  BTW Code/Befehle in ` setzen
                                    Vielen Dank übrigens für deine Gedult 👼
                                      holger@iobroker:~$ iobroker list instances
                                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        system.adapter.amazon-dash.0            : amazon-dash           : iobroker                                 - disabled
                                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                      + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                                        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                                      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                                      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                        system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 0
                                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1999, bind: 0.0.0.0 (SSL)
                                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1500, bind: 0.0.0.0
                                      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 0
                                      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                                      + system.adapter.zwave2.0                 : zwave2                : iobroker                                 -  enabled
                                      + instance is alive
                                        ja! ich wollte wissen was der Upload gebracht hatte?
                                        und das siehst du im Admin und mit iobroker update -i
                                          holger@iobroker:~$ iobroker update -i
                                          Used repository: beta
                                          hash changed or no sources cached => force download of new sources
                                          update done
                                          Adapter    "admin"         : 5.2.1    , installed 5.1.29 [Updateable]
                                          Adapter    "amazon-dash"   : 1.1.0    , installed 1.1.0
                                          Adapter    "backitup"      : 2.2.2    , installed 2.2.2
                                          Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                                          Adapter    "cul"           : 1.3.5    , installed 1.3.5
                                          Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
                                          Adapter    "denon"         : 1.11.2   , installed 1.11.2
                                          Adapter    "discovery"     : 2.7.5    , installed 2.7.5
                                          Adapter    "flot"          : 1.10.7   , installed 1.10.7
                                          Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                                          Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
                                          Adapter    "hm-rpc"        : 1.14.50  , installed 1.14.50
                                          Adapter    "influxdb"      : 2.2.0    , installed 2.2.0
                                          Adapter    "info"          : 1.9.16   , installed 1.9.16
                                          Adapter    "javascript"    : 5.2.16   , installed 5.2.16
                                          Controller "js-controller" : 3.3.21   , installed 3.3.21
                                          Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
                                          Adapter    "mqtt"          : 2.4.1    , installed 2.4.1
                                          Adapter    "node-red"      : 2.4.1    , installed 2.4.1
                                          Adapter    "shelly"        : 5.0.0    , installed 5.0.0
                                          Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
                                          Adapter    "socketio"      : 3.1.5    , installed 3.1.5
                                          Adapter    "sonoff"        : 2.4.7    , installed 2.4.7
                                          Adapter    "sql"           : 1.15.7   , installed 1.15.7
                                          Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                                          Adapter    "vis"           : 1.4.6    , installed 1.4.6
                                          Adapter    "web"           : 3.4.16   , installed 3.4.16
                                          Adapter    "zigbee"        : 1.6.8    , installed 1.6.8
                                          Adapter    "zwave2"        : 2.4.1    , installed 2.4.1
                                            @keule Mach mal einen reboot
                                            2486
