    4. Falsche Admin Adapter Version wird angezeigt
      Keule @Homoran last edited by
      @homoran sagte in Falsche Admin Adapter Version wird angezeigt:
      @keule sagte in Falsche Admin Adapter Version wird angezeigt:
      und das siehst du im Admin und mit iobroker update -i
      holger@iobroker:~$ iobroker update -i
      Used repository: beta
      hash changed or no sources cached => force download of new sources
      update done
      Adapter    "admin"         : 5.2.1    , installed 5.1.29 [Updateable]
      Adapter    "amazon-dash"   : 1.1.0    , installed 1.1.0
      Adapter    "backitup"      : 2.2.2    , installed 2.2.2
      Adapter    "cloud"         : 4.1.0    , installed 4.1.0
      Adapter    "cul"           : 1.3.5    , installed 1.3.5
      Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
      Adapter    "denon"         : 1.11.2   , installed 1.11.2
      Adapter    "discovery"     : 2.7.5    , installed 2.7.5
      Adapter    "flot"          : 1.10.7   , installed 1.10.7
      Adapter    "harmony"       : 1.2.2    , installed 1.2.2
      Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
      Adapter    "hm-rpc"        : 1.14.50  , installed 1.14.50
      Adapter    "influxdb"      : 2.2.0    , installed 2.2.0
      Adapter    "info"          : 1.9.16   , installed 1.9.16
      Adapter    "javascript"    : 5.2.16   , installed 5.2.16
      Controller "js-controller" : 3.3.21   , installed 3.3.21
      Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
      Adapter    "mqtt"          : 2.4.1    , installed 2.4.1
      Adapter    "node-red"      : 2.4.1    , installed 2.4.1
      Adapter    "shelly"        : 5.0.0    , installed 5.0.0
      Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
      Adapter    "socketio"      : 3.1.5    , installed 3.1.5
      Adapter    "sonoff"        : 2.4.7    , installed 2.4.7
      Adapter    "sql"           : 1.15.7   , installed 1.15.7
      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
      Adapter    "vis"           : 1.4.6    , installed 1.4.6
      Adapter    "web"           : 3.4.16   , installed 3.4.16
      Adapter    "zigbee"        : 1.6.8    , installed 1.6.8
      Adapter    "zwave2"        : 2.4.1    , installed 2.4.1
        Homoran Global Moderator Administrators @Keule last edited by
        @keule Mach mal einen reboot
          Erledigt
            Erledigt
            Reboot oder Problem?
              Keule @Homoran last edited by Keule
              Erledigt
              Leider nur reboot gemacht. 🙈
              Problem noch da
              hash unchanged, use cached sources
              update done
                Thomas Braun Most Active @Keule last edited by
                @keule
                iobroker update
                iobroker upgrade
                Homoran K 2 Replies Last reply Reply Quote 0
                  @thomas-braun controller ist auch schon die neueste
                  Hab echt keine Ahnung mehr
                  vielleicht doch npm v8 😂
                    Keule @Thomas Braun last edited by
                    @thomas-braun sagte in Falsche Admin Adapter Version wird angezeigt:
                    @keule
                    iobroker update
                    iobroker upgrade
                    update done
                    holger@iobroker:~$ iobroker upgrade
                    All adapters are up to date
                      Dann warte ich, bis es eine neue stable vom admin Adapter gibt. Vielleicht repariert sich das dann ja wieder 😉
                        @keule
                        iobroker upload all
                        Wenn das nicht fruchtet mal
                        iobroker upgrade admin@5.2.1
                          nee, das ist nicht das Problem.
                          Bei dir wird irgendwo nicht die richtige Version eingetragen.
                          An einem anderen Ort schon
                          Nur fehlt mir das Wissen wo, und erst recht wieso
                            haben wir gerade gemacht - und einen reboot
                              @keule
                              iobroker upload all
                              holger@iobroker:~$ iobroker upload all
                              upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
                              upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
                              upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
                              upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
                              upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
                              upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
                              upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/json
                              upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascript
                              upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/json
                              upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascript
                              upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
                              upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
                              upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-WRE3EG62.js.map build/chunk-WRE3EG62.js.map application/json
                              upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-WRE3EG62.js build/chunk-WRE3EG62.js application/javascript
                              upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-FLBBXTIS.js.map build/chunk-FLBBXTIS.js.map application/json
                              upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-FLBBXTIS.js build/chunk-FLBBXTIS.js application/javascript
                              upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-DDIJC5B5.js.map build/chunk-DDIJC5B5.js.map application/json
                              upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-DDIJC5B5.js build/chunk-DDIJC5B5.js application/javascript
                              upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
                              upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                              upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/qujiabao_gas.png img/qujiabao_gas.png image/png
                              upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/owvfni3.png img/owvfni3.png image/png
                              upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/konke_kpdr.png img/konke_kpdr.png image/png
                              upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/group_4.png img/group_4.png image/png
                              upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto.png img/gledopto.png image/png
                              upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/exp_light.png img/exp_light.png image/png
                              upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/danfoss_ally.png img/danfoss_ally.png image/png
                              upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cc2538_router_v1.png img/cc2538_router_v1.png image/png
                              upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/basiczbr3.png img/basiczbr3.png image/png
                              upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0502A.png img/TS0502A.png image/png
                              upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_50067.png img/Paulmann_50067.png image/png
                              upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
                              upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                              upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                              upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
                              upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
                              upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad_LeTV_8.png img/DIYRuZ_FreePad_LeTV_8.png image/png
                              upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
                              upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
                              upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
                              upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                              upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                              upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                              upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
                              upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
                              upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                              upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                              upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                              upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                              upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
                              upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                              upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                              upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                              upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
                              upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js.map static/js/runtime-main.8b37c647.js.map application/json
                              upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js static/js/runtime-main.8b37c647.js application/javascript
                              upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.67ec0642.chunk.js.map static/js/main.67ec0642.chunk.js.map application/json
                              upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.67ec0642.chunk.js static/js/main.67ec0642.chunk.js application/javascript
                              upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.d0deddb4.chunk.js.map static/js/2.d0deddb4.chunk.js.map application/json
                              upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.d0deddb4.chunk.js.LICENSE.txt static/js/2.d0deddb4.chunk.js.LICENSE.txt text/plain
                              upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.d0deddb4.chunk.js static/js/2.d0deddb4.chunk.js application/javascript
                              upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                              upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                              upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.d22aed1b.chunk.css.map static/css/2.d22aed1b.chunk.css.map application/json
                              upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.d22aed1b.chunk.css static/css/2.d22aed1b.chunk.css text/css
                              upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
                              upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                              upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                              upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                              upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
                              upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
                              upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
                              upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
                              upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
                              upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
                              upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
                              upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
                              upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
                              upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
                              upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
                              upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
                              upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
                              upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
                              upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
                              upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
                              upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
                              upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
                              upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
                              upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
                              upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
                              upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
                              upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
                              upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                              upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
                              upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
                              upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
                              upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
                              upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
                              upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
                              upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
                              upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                              upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
                              upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                              upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                              upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                              upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                              upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                              upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui.html widgets/jqui.html text/html
                              upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBool.png widgets/basic/img/Prev_ValueBool.png image/png
                              upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.js application/javascript
                              upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javascript
                              upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png image/png
                              upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
                              upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
                              upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
                              upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
                              upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
                              upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
                              upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
                              upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
                              upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
                              upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
                              upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
                              upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
                              upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
                              upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
                              upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
                              upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
                              upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
                              upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
                              upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
                              upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
                              upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
                              upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
                              upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
                              upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
                              upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
                              upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
                              upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
                              upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                              upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                              upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                              upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
                              upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
                              upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
                              upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html
                              upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                              Update "system.adapter.telegram.0"
                              upload [7] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js words.js application/javascript
                              upload [6] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
                              upload [5] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/jsonCustom.json jsonCustom.json application/json
                              upload [4] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/jsonConfig.json jsonConfig.json application/json
                              upload [3] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index_m.html index_m.html text/html
                              upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html index.html text/html
                              upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom_m.html custom_m.html text/html
                              upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom.html custom.html text/html
                              Update "system.adapter.sql.0"
                              upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
                              upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
                              upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
                              upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                              upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/words.js words.js application/javascript
                              upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                              upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index_m.html index_m.html text/html
                              upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
                              Adapter "system.adapter.web.0" restarted.
                              upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
                              upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
                              upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
                              upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
                              upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                              upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                              upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
                              upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                              upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
                              upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
                              upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
                              upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
                              upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
                              upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js words.js application/javascript
                              upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
                              upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.html index_m.html text/html
                              upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index.html index.html text/html
                              upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                              upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                              upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                              upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                              upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                              upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                              upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                              upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                              upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                              upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                              upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                              upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                              upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                              upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/javascript/javascript.js vs/basic-languages/javascript/javascript.js application/javascript
                              upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.5a275f96.chunk.js static/js/main.5a275f96.chunk.js application/javascript
                              upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/index_m.html index_m.html text/html
                              upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/de.js google-blockly/own/msg/de.js application/javascript
                              upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_sendto.js google-blockly/own/blocks_sendto.js application/javascript
                              upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/it.js google-blockly/msg/js/it.js application/javascript
                              upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur null
                              upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur null
                              upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
                              upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/dropdown-arrow.svg google-blockly/media/dropdown-arrow.svg image/svg+xml
                              upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
                              upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
                              upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
                              upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                              upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
                              upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
                              upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
                              upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
                              upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
                              upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
                              upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
                              upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
                              upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
                              upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
                              upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                              upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
                              upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                              Update "system.adapter.javascript.0"
                              upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                              upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/feednami.min.js lib/js/feednami.min.js application/javascript
                              upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/xubuntu.png lib/img/logos/xubuntu.png image/png
                              upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/pclinuxos.png lib/img/logos/pclinuxos.png image/png
                              upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/freebsd.png lib/img/logos/freebsd.png image/png
                              upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/usb.png lib/img/icons/usb.png image/png
                              upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/bluetooth.png lib/img/icons/bluetooth.png image/png
                              upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                              upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/audio.png lib/img/icons/audio.png image/png
                              upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                              upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                              upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                              upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                              upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                              upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                              upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                              upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                              upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                              upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                              upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                              upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                              upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                              upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                              upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                              upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                              upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                              upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                              upload [15] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/words.js words.js application/javascript
                              upload [14] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonCustom.json jsonCustom.json application/json
                              upload [13] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonConfig.json jsonConfig.json application/json
                              upload [12] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/influxdb.png influxdb.png image/png
                              upload [11] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/index_m.html index_m.html text/html
                              upload [10] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [9] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [8] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [7] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [5] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [4] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [3] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [2] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [1] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [0] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/custom_m.html custom_m.html text/html
                              Update "system.adapter.influxdb.0"
                              upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/93_hm-es-pmsw1-pl_thumb.png icons/93_hm-es-pmsw1-pl_thumb.png image/png
                              upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/46_hm-lc-sw4-pcb_thumb.png icons/46_hm-lc-sw4-pcb_thumb.png image/png
                              upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/187_hmip-rcb1_thumb.png icons/187_hmip-rcb1_thumb.png image/png
                              upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/178_hmip-etrv-b1_thumb.png icons/178_hmip-etrv-b1_thumb.png image/png
                              upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/168_hmip-smi55_thumb.png icons/168_hmip-smi55_thumb.png image/png
                              upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/159_hmip-mod-rc8_thumb.png icons/159_hmip-mod-rc8_thumb.png image/png
                              upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/14_hm-sec-key_thumb.png icons/14_hm-sec-key_thumb.png image/png
                              upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/140_alpha-ip-rgb_thumb.png icons/140_alpha-ip-rgb_thumb.png image/png
                              upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/132_hmip-smo_thumb.png icons/132_hmip-smo_thumb.png image/png
                              upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/121_hmip-wth_thumb.png icons/121_hmip-wth_thumb.png image/png
                              upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
                              upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-uk_thumb.png icons/113_hmip-psm-uk_thumb.png image/png
                              upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
                              upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-it_thumb.png icons/113_hmip-psm-it_thumb.png image/png
                              upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-ch_thumb.png icons/113_hmip-psm-ch_thumb.png image/png
                              upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png
                              upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/111_hm-lc-rgbw-wm_thumb.png icons/111_hm-lc-rgbw-wm_thumb.png image/png
                              upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/110_hm-es-pmsw1-dr_thump.png icons/110_hm-es-pmsw1-dr_thump.png image/png
                              upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/109_hm-lc-sw1-pl-ct_thump.png icons/109_hm-lc-sw1-pl-ct_thump.png image/png
                              upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/108_hm-rc-dis-h-x-eu_thump.png icons/108_hm-rc-dis-h-x-eu_thump.png image/png
                              upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R5_thumb.png icons/107_hm-es-pmsw1-pl-R5_thumb.png image/png
                              upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R4_thumb.png icons/107_hm-es-pmsw1-pl-R4_thumb.png image/png
                              upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R3_thumb.png icons/107_hm-es-pmsw1-pl-R3_thumb.png image/png
                              upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R2_thumb.png icons/107_hm-es-pmsw1-pl-R2_thumb.png image/png
                              upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/105_hm-sec-sd-2-team_thumb.png icons/105_hm-sec-sd-2-team_thumb.png image/png
                              upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/104_hm-sec-sd-2_thumb.png icons/104_hm-sec-sd-2_thumb.png image/png
                              upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/103_hm-sen-mdir-wm55_thumb.png icons/103_hm-sen-mdir-wm55_thumb.png image/png
                              upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/102_hm-es-tx-wm_thumb.png icons/102_hm-es-tx-wm_thumb.png image/png
                              upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/101_hm-sen-db-pcb_thumb.png icons/101_hm-sen-db-pcb_thumb.png image/png
                              upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/100_hm-rc-8_thumb.png icons/100_hm-rc-8_thumb.png image/png
                              upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                              Update "system.adapter.hm-rpc.0"
                              Update "system.adapter.hm-rpc.1"
                              upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                              upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                              upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                              upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                              Update "system.adapter.hm-rega.0"
                              upload [3] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/words.js words.js application/javascript
                              upload [2] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index_m.html index_m.html text/html
                              upload [1] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index.html index.html text/html
                              upload [0] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/harmony.png harmony.png image/png
                              Update "system.adapter.harmony.0"
                              upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
                              Update "system.adapter.flot.0"
                              upload [20] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js js/flot.js application/javascript
                              upload [19] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js.map js/edit.js.map application/json
                              upload [18] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
                              upload [17] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html.map index.html.map application/json
                              upload [16] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
                              upload [15] flot /opt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
                              upload [14] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html.map edit.html.map application/json
                              upload [13] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
                              upload [12] flot /opt/iobroker/node_modules/iobroker.flot/www/css/jquery.colorpicker.css css/jquery.colorpicker.css text/css
                              upload [11] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/ui-colorpicker.png css/images/ui-colorpicker.png image/png
                              upload [10] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/preview-opacity.png css/images/preview-opacity.png image/png
                              upload [9] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map.png css/images/map.png image/png
                              upload [8] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-pointer.png css/images/map-pointer.png image/png
                              upload [7] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-opacity.png css/images/map-opacity.png image/png
                              upload [6] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar.png css/images/bar.png image/png
                              upload [5] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-pointer.png css/images/bar-pointer.png image/png
                              upload [4] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-opacity.png css/images/bar-opacity.png image/png
                              upload [3] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-alpha.png css/images/bar-alpha.png image/png
                              upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/map.png css/images/128/map.png image/png
                              upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar.png css/images/128/bar.png image/png
                              upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar-alpha.png css/images/128/bar-alpha.png image/png
                              upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                              upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                              upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                              upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                              upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                              upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                              upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                              upload [2] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js words.js application/javascript
                              upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.html index_m.html text/html
                              upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.png denon.png image/png
                              upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/75.png icons/viento-wind/galeria2-Beaufort/75.png image/png
                              upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/3.png icons/viento-wind/galeria2-Beaufort/3.png image/png
                              upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria1/16.png icons/viento-wind/galeria1/16.png image/png
                              upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/60.png icons/viento-wind/Beaufort-White/60.png image/png
                              upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/15.png icons/viento-wind/Beaufort-White/15.png image/png
                              upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria6/11.svg icons/tiempo-weather/galeria6/11.svg image/svg+xml
                              upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/PNG/White/9.png icons/tiempo-weather/galeria5/PNG/White/9.png image/png
                              upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria4/3.png icons/tiempo-weather/galeria4/3.png image/png
                              upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria4/11.png icons/tiempo-weather/galeria4/11.png image/png
                              upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/2.png icons/tiempo-weather/galeria3/2.png image/png
                              upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/10.png icons/tiempo-weather/galeria3/10.png image/png
                              upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria2/19.png icons/tiempo-weather/galeria2/19.png image/png
                              upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria2/1.png icons/tiempo-weather/galeria2/1.png image/png
                              upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria1/18.png icons/tiempo-weather/galeria1/18.png image/png
                              upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/9.png icons/luna-moon/9.png image/png
                              upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/26.png icons/luna-moon/26.png image/png
                              upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/25.png icons/luna-moon/25.png image/png
                              upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/24.png icons/luna-moon/24.png image/png
                              upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/23.png icons/luna-moon/23.png image/png
                              upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/22.png icons/luna-moon/22.png image/png
                              upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/21.png icons/luna-moon/21.png image/png
                              upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/20.png icons/luna-moon/20.png image/png
                              upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/2.png icons/luna-moon/2.png image/png
                              upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/19.png icons/luna-moon/19.png image/png
                              upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/18.png icons/luna-moon/18.png image/png
                              upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/17.png icons/luna-moon/17.png image/png
                              upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/16.png icons/luna-moon/16.png image/png
                              upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/15.png icons/luna-moon/15.png image/png
                              upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/14.png icons/luna-moon/14.png image/png
                              upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/13.png icons/luna-moon/13.png image/png
                              upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/12.png icons/luna-moon/12.png image/png
                              upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/11.png icons/luna-moon/11.png image/png
                              upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/10.png icons/luna-moon/10.png image/png
                              upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/1.png icons/luna-moon/1.png image/png
                              upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/0.png icons/luna-moon/0.png image/png
                              upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/daswettercom.png daswettercom.png image/png
                              upload [13] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/words.js words.js application/javascript
                              upload [12] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/index_m.html index_m.html text/html
                              upload [11] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/index.html index.html text/html
                              upload [10] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [9] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [8] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [7] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [5] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [4] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [3] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [2] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [1] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [0] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/busware.jpg busware.jpg image/jpeg
                              upload [17] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
                              upload [16] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/jsonConfig.json jsonConfig.json application/json
                              upload [15] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
                              upload [14] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/img/info-big.png img/info-big.png image/png
                              upload [13] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [12] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [11] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [10] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [9] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [8] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [7] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
                              upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
                              upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
                              upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
                              upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                              upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                              upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                              upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                              upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                              upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                              upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                              upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                              upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                              upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                              upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                              upload [3] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/words.js words.js application/javascript
                              upload [2] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/index_m.html index_m.html text/html
                              upload [1] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/index.html index.html text/html
                              upload [0] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/amazon-dash.png amazon-dash.png image/png
                              upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                              upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
                              upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                              upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                              upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                              holger@iobroker:~$ iobroker upgrade admin@5.2.1
                              Would you like to reinstall version 5.2.1 of admin now? [(y)es, (n)o]: y
                              Update admin from @5.2.1 to @5.2.1
                              host.iobroker Adapter "system.adapter.admin.0" is stopped.
                              NPM version: 6.14.15
                              npm install iobroker.admin@5.2.1 --loglevel error --prefix "/opt/iobroker" (System call)
                              Adapter "admin" updated
                              host.iobroker Adapter "system.adapter.admin.0" is started
                              Keine Veränderung
                              holger@iobroker:~$ iobroker update
                              Used repository: beta
                              hash unchanged, use cached sources
                              update done
                              Adapter    "admin"         : 5.2.1    , installed 5.1.29 [Updateable]
                              Adapter    "amazon-dash"   : 1.1.0    , installed 1.1.0
                              Adapter    "backitup"      : 2.2.2    , installed 2.2.2
                              Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                              Adapter    "cul"           : 1.3.5    , installed 1.3.5
                              Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
                              Adapter    "denon"         : 1.11.2   , installed 1.11.2
                              Adapter    "discovery"     : 2.7.5    , installed 2.7.5
                              Adapter    "flot"          : 1.10.7   , installed 1.10.7
                              Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                              Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
                              Adapter    "hm-rpc"        : 1.14.50  , installed 1.14.50
                              Adapter    "influxdb"      : 2.2.0    , installed 2.2.0
                              Adapter    "info"          : 1.9.16   , installed 1.9.16
                              Adapter    "javascript"    : 5.2.16   , installed 5.2.16
                              Controller "js-controller" : 3.3.21   , installed 3.3.21
                              Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
                              Adapter    "mqtt"          : 2.4.1    , installed 2.4.1
                              Adapter    "node-red"      : 2.4.1    , installed 2.4.1
                              Adapter    "shelly"        : 5.0.0    , installed 5.0.0
                              Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
                              Adapter    "socketio"      : 3.1.5    , installed 3.1.5
                              Adapter    "sonoff"        : 2.4.7    , installed 2.4.7
                              Adapter    "sql"           : 1.15.7   , installed 1.15.7
                              Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                              Adapter    "vis"           : 1.4.6    , installed 1.4.6
                              Adapter    "web"           : 3.4.16   , installed 3.4.16
                              Adapter    "zigbee"        : 1.6.8    , installed 1.6.8
                              Adapter    "zwave2"        : 2.4.1    , installed 2.4.1
                              2484
