    4. Falsche Admin Adapter Version wird angezeigt
      Homoran Global Moderator Administrators @Keule last edited by
      @keule sagte in Falsche Admin Adapter Version wird angezeigt:
      Erledigt
      Reboot oder Problem?
        Keule @Homoran last edited by Keule
        @homoran sagte in Falsche Admin Adapter Version wird angezeigt:
        Erledigt
        Leider nur reboot gemacht. 🙈
        Problem noch da
        holger@iobroker:~$ iobroker update -i
        Used repository: beta
        hash unchanged, use cached sources
        update done
        Adapter    "admin"         : 5.2.1    , installed 5.1.29 [Updateable]
        Adapter    "amazon-dash"   : 1.1.0    , installed 1.1.0
        Adapter    "backitup"      : 2.2.2    , installed 2.2.2
        Adapter    "cloud"         : 4.1.0    , installed 4.1.0
        Adapter    "cul"           : 1.3.5    , installed 1.3.5
        Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
        Adapter    "denon"         : 1.11.2   , installed 1.11.2
        Adapter    "discovery"     : 2.7.5    , installed 2.7.5
        Adapter    "flot"          : 1.10.7   , installed 1.10.7
        Adapter    "harmony"       : 1.2.2    , installed 1.2.2
        Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
        Adapter    "hm-rpc"        : 1.14.50  , installed 1.14.50
        Adapter    "influxdb"      : 2.2.0    , installed 2.2.0
        Adapter    "info"          : 1.9.16   , installed 1.9.16
        Adapter    "javascript"    : 5.2.16   , installed 5.2.16
        Controller "js-controller" : 3.3.21   , installed 3.3.21
        Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
        Adapter    "mqtt"          : 2.4.1    , installed 2.4.1
        Adapter    "node-red"      : 2.4.1    , installed 2.4.1
        Adapter    "shelly"        : 5.0.0    , installed 5.0.0
        Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
        Adapter    "socketio"      : 3.1.5    , installed 3.1.5
        Adapter    "sonoff"        : 2.4.7    , installed 2.4.7
        Adapter    "sql"           : 1.15.7   , installed 1.15.7
        Adapter    "telegram"      : 1.10.0   , installed 1.10.0
        Adapter    "vis"           : 1.4.6    , installed 1.4.6
        Adapter    "web"           : 3.4.16   , installed 3.4.16
        Adapter    "zigbee"        : 1.6.8    , installed 1.6.8
        Adapter    "zwave2"        : 2.4.1    , installed 2.4.1
          Thomas Braun Most Active @Keule last edited by
          @keule
          iobroker update
          iobroker upgrade
          Homoran K 2 Replies Last reply Reply Quote 0
            @thomas-braun controller ist auch schon die neueste
            Hab echt keine Ahnung mehr
            vielleicht doch npm v8 😂
              Keule @Thomas Braun last edited by
              @thomas-braun sagte in Falsche Admin Adapter Version wird angezeigt:
              @keule
              iobroker update
              iobroker upgrade
              update done
              holger@iobroker:~$ iobroker upgrade
              All adapters are up to date
                Dann warte ich, bis es eine neue stable vom admin Adapter gibt. Vielleicht repariert sich das dann ja wieder 😉
                  @keule
                  iobroker upload all
                  Wenn das nicht fruchtet mal
                  iobroker upgrade admin@5.2.1
                    nee, das ist nicht das Problem.
                    Bei dir wird irgendwo nicht die richtige Version eingetragen.
                    An einem anderen Ort schon
                    Nur fehlt mir das Wissen wo, und erst recht wieso
                      haben wir gerade gemacht - und einen reboot
                        @keule
                        iobroker upload all
                        holger@iobroker:~$ iobroker upload all
                        upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
                        upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
                        upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
                        upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
                        upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
                        upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
                        upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/json
                        upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascript
                        upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/json
                        upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascript
                        upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
                        upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
                        upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-WRE3EG62.js.map build/chunk-WRE3EG62.js.map application/json
                        upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-WRE3EG62.js build/chunk-WRE3EG62.js application/javascript
                        upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-FLBBXTIS.js.map build/chunk-FLBBXTIS.js.map application/json
                        upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-FLBBXTIS.js build/chunk-FLBBXTIS.js application/javascript
                        upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-DDIJC5B5.js.map build/chunk-DDIJC5B5.js.map application/json
                        upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-DDIJC5B5.js build/chunk-DDIJC5B5.js application/javascript
                        upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
                        upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                        upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/qujiabao_gas.png img/qujiabao_gas.png image/png
                        upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/owvfni3.png img/owvfni3.png image/png
                        upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/konke_kpdr.png img/konke_kpdr.png image/png
                        upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/group_4.png img/group_4.png image/png
                        upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto.png img/gledopto.png image/png
                        upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/exp_light.png img/exp_light.png image/png
                        upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/danfoss_ally.png img/danfoss_ally.png image/png
                        upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cc2538_router_v1.png img/cc2538_router_v1.png image/png
                        upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/basiczbr3.png img/basiczbr3.png image/png
                        upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0502A.png img/TS0502A.png image/png
                        upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_50067.png img/Paulmann_50067.png image/png
                        upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
                        upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                        upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                        upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
                        upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
                        upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad_LeTV_8.png img/DIYRuZ_FreePad_LeTV_8.png image/png
                        upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
                        upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
                        upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
                        upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                        upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                        upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                        upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
                        upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
                        upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                        upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                        upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                        upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                        upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
                        upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                        upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                        upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                        upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
                        upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js.map static/js/runtime-main.8b37c647.js.map application/json
                        upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js static/js/runtime-main.8b37c647.js application/javascript
                        upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.67ec0642.chunk.js.map static/js/main.67ec0642.chunk.js.map application/json
                        upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.67ec0642.chunk.js static/js/main.67ec0642.chunk.js application/javascript
                        upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.d0deddb4.chunk.js.map static/js/2.d0deddb4.chunk.js.map application/json
                        upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.d0deddb4.chunk.js.LICENSE.txt static/js/2.d0deddb4.chunk.js.LICENSE.txt text/plain
                        upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.d0deddb4.chunk.js static/js/2.d0deddb4.chunk.js application/javascript
                        upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                        upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                        upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.d22aed1b.chunk.css.map static/css/2.d22aed1b.chunk.css.map application/json
                        upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.d22aed1b.chunk.css static/css/2.d22aed1b.chunk.css text/css
                        upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
                        upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                        upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                        upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                        upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
                        upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
                        upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
                        upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
                        upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
                        upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
                        upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
                        upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
                        upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
                        upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
                        upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
                        upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
                        upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
                        upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
                        upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
                        upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
                        upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
                        upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
                        upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
                        upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
                        upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
                        upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
                        upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
                        upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                        upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
                        upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
                        upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
                        upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
                        upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
                        upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
                        upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
                        upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                        upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
                        upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                        upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                        upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                        upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                        upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                        upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui.html widgets/jqui.html text/html
                        upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBool.png widgets/basic/img/Prev_ValueBool.png image/png
                        upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.js application/javascript
                        upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javascript
                        upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png image/png
                        upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
                        upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
                        upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
                        upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
                        upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
                        upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
                        upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
                        upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
                        upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
                        upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
                        upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
                        upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
                        upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
                        upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
                        upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
                        upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
                        upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
                        upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
                        upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
                        upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
                        upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
                        upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
                        upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
                        upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
                        upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
                        upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
                        upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
                        upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                        upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                        upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                        upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
                        upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
                        upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
                        upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html
                        upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                        Update "system.adapter.telegram.0"
                        upload [7] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js words.js application/javascript
                        upload [6] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
                        upload [5] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/jsonCustom.json jsonCustom.json application/json
                        upload [4] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/jsonConfig.json jsonConfig.json application/json
                        upload [3] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index_m.html index_m.html text/html
                        upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html index.html text/html
                        upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom_m.html custom_m.html text/html
                        upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom.html custom.html text/html
                        Update "system.adapter.sql.0"
                        upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
                        upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
                        upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
                        upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                        upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/words.js words.js application/javascript
                        upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                        upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index_m.html index_m.html text/html
                        upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
                        Adapter "system.adapter.web.0" restarted.
                        upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
                        upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
                        upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
                        upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
                        upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                        upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                        upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
                        upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                        upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
                        upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
                        upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
                        upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
                        upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
                        upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js words.js application/javascript
                        upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
                        upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.html index_m.html text/html
                        upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index.html index.html text/html
                        upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                        upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                        upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                        upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                        upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                        upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                        upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                        upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                        upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                        upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                        upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                        upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                        upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                        upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/javascript/javascript.js vs/basic-languages/javascript/javascript.js application/javascript
                        upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.5a275f96.chunk.js static/js/main.5a275f96.chunk.js application/javascript
                        upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/index_m.html index_m.html text/html
                        upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/de.js google-blockly/own/msg/de.js application/javascript
                        upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_sendto.js google-blockly/own/blocks_sendto.js application/javascript
                        upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/it.js google-blockly/msg/js/it.js application/javascript
                        upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur null
                        upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur null
                        upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
                        upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/dropdown-arrow.svg google-blockly/media/dropdown-arrow.svg image/svg+xml
                        upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
                        upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
                        upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
                        upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                        upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
                        upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
                        upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
                        upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
                        upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
                        upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
                        upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
                        upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
                        upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
                        upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
                        upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                        upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
                        upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                        Update "system.adapter.javascript.0"
                        upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                        upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/feednami.min.js lib/js/feednami.min.js application/javascript
                        upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/xubuntu.png lib/img/logos/xubuntu.png image/png
                        upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/pclinuxos.png lib/img/logos/pclinuxos.png image/png
                        upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/freebsd.png lib/img/logos/freebsd.png image/png
                        upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/usb.png lib/img/icons/usb.png image/png
                        upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/bluetooth.png lib/img/icons/bluetooth.png image/png
                        upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                        upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/audio.png lib/img/icons/audio.png image/png
                        upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                        upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                        upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                        upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                        upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                        upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                        upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                        upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                        upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                        upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                        upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                        upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                        upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                        upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                        upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                        upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                        upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                        upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                        upload [15] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/words.js words.js application/javascript
                        upload [14] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonCustom.json jsonCustom.json application/json
                        upload [13] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonConfig.json jsonConfig.json application/json
                        upload [12] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/influxdb.png influxdb.png image/png
                        upload [11] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/index_m.html index_m.html text/html
                        upload [10] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [9] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [8] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [7] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [6] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [5] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [4] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [3] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [2] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [1] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [0] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/custom_m.html custom_m.html text/html
                        Update "system.adapter.influxdb.0"
                        upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/93_hm-es-pmsw1-pl_thumb.png icons/93_hm-es-pmsw1-pl_thumb.png image/png
                        upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/46_hm-lc-sw4-pcb_thumb.png icons/46_hm-lc-sw4-pcb_thumb.png image/png
                        upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/187_hmip-rcb1_thumb.png icons/187_hmip-rcb1_thumb.png image/png
                        upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/178_hmip-etrv-b1_thumb.png icons/178_hmip-etrv-b1_thumb.png image/png
                        upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/168_hmip-smi55_thumb.png icons/168_hmip-smi55_thumb.png image/png
                        upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/159_hmip-mod-rc8_thumb.png icons/159_hmip-mod-rc8_thumb.png image/png
                        upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/14_hm-sec-key_thumb.png icons/14_hm-sec-key_thumb.png image/png
                        upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/140_alpha-ip-rgb_thumb.png icons/140_alpha-ip-rgb_thumb.png image/png
                        upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/132_hmip-smo_thumb.png icons/132_hmip-smo_thumb.png image/png
                        upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/121_hmip-wth_thumb.png icons/121_hmip-wth_thumb.png image/png
                        upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
                        upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-uk_thumb.png icons/113_hmip-psm-uk_thumb.png image/png
                        upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
                        upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-it_thumb.png icons/113_hmip-psm-it_thumb.png image/png
                        upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-ch_thumb.png icons/113_hmip-psm-ch_thumb.png image/png
                        upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png
                        upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/111_hm-lc-rgbw-wm_thumb.png icons/111_hm-lc-rgbw-wm_thumb.png image/png
                        upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/110_hm-es-pmsw1-dr_thump.png icons/110_hm-es-pmsw1-dr_thump.png image/png
                        upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/109_hm-lc-sw1-pl-ct_thump.png icons/109_hm-lc-sw1-pl-ct_thump.png image/png
                        upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/108_hm-rc-dis-h-x-eu_thump.png icons/108_hm-rc-dis-h-x-eu_thump.png image/png
                        upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R5_thumb.png icons/107_hm-es-pmsw1-pl-R5_thumb.png image/png
                        upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R4_thumb.png icons/107_hm-es-pmsw1-pl-R4_thumb.png image/png
                        upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R3_thumb.png icons/107_hm-es-pmsw1-pl-R3_thumb.png image/png
                        upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R2_thumb.png icons/107_hm-es-pmsw1-pl-R2_thumb.png image/png
                        upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/105_hm-sec-sd-2-team_thumb.png icons/105_hm-sec-sd-2-team_thumb.png image/png
                        upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/104_hm-sec-sd-2_thumb.png icons/104_hm-sec-sd-2_thumb.png image/png
                        upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/103_hm-sen-mdir-wm55_thumb.png icons/103_hm-sen-mdir-wm55_thumb.png image/png
                        upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/102_hm-es-tx-wm_thumb.png icons/102_hm-es-tx-wm_thumb.png image/png
                        upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/101_hm-sen-db-pcb_thumb.png icons/101_hm-sen-db-pcb_thumb.png image/png
                        upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/100_hm-rc-8_thumb.png icons/100_hm-rc-8_thumb.png image/png
                        upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                        Update "system.adapter.hm-rpc.0"
                        Update "system.adapter.hm-rpc.1"
                        upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                        upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                        upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                        upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                        Update "system.adapter.hm-rega.0"
                        upload [3] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/words.js words.js application/javascript
                        upload [2] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index_m.html index_m.html text/html
                        upload [1] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index.html index.html text/html
                        upload [0] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/harmony.png harmony.png image/png
                        Update "system.adapter.harmony.0"
                        upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
                        Update "system.adapter.flot.0"
                        upload [20] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js js/flot.js application/javascript
                        upload [19] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js.map js/edit.js.map application/json
                        upload [18] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
                        upload [17] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html.map index.html.map application/json
                        upload [16] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
                        upload [15] flot /opt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
                        upload [14] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html.map edit.html.map application/json
                        upload [13] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
                        upload [12] flot /opt/iobroker/node_modules/iobroker.flot/www/css/jquery.colorpicker.css css/jquery.colorpicker.css text/css
                        upload [11] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/ui-colorpicker.png css/images/ui-colorpicker.png image/png
                        upload [10] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/preview-opacity.png css/images/preview-opacity.png image/png
                        upload [9] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map.png css/images/map.png image/png
                        upload [8] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-pointer.png css/images/map-pointer.png image/png
                        upload [7] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-opacity.png css/images/map-opacity.png image/png
                        upload [6] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar.png css/images/bar.png image/png
                        upload [5] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-pointer.png css/images/bar-pointer.png image/png
                        upload [4] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-opacity.png css/images/bar-opacity.png image/png
                        upload [3] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-alpha.png css/images/bar-alpha.png image/png
                        upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/map.png css/images/128/map.png image/png
                        upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar.png css/images/128/bar.png image/png
                        upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar-alpha.png css/images/128/bar-alpha.png image/png
                        upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                        upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                        upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                        upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                        upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                        upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                        upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                        upload [2] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js words.js application/javascript
                        upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.html index_m.html text/html
                        upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.png denon.png image/png
                        upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/75.png icons/viento-wind/galeria2-Beaufort/75.png image/png
                        upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/3.png icons/viento-wind/galeria2-Beaufort/3.png image/png
                        upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria1/16.png icons/viento-wind/galeria1/16.png image/png
                        upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/60.png icons/viento-wind/Beaufort-White/60.png image/png
                        upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/15.png icons/viento-wind/Beaufort-White/15.png image/png
                        upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria6/11.svg icons/tiempo-weather/galeria6/11.svg image/svg+xml
                        upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/PNG/White/9.png icons/tiempo-weather/galeria5/PNG/White/9.png image/png
                        upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria4/3.png icons/tiempo-weather/galeria4/3.png image/png
                        upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria4/11.png icons/tiempo-weather/galeria4/11.png image/png
                        upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/2.png icons/tiempo-weather/galeria3/2.png image/png
                        upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/10.png icons/tiempo-weather/galeria3/10.png image/png
                        upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria2/19.png icons/tiempo-weather/galeria2/19.png image/png
                        upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria2/1.png icons/tiempo-weather/galeria2/1.png image/png
                        upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria1/18.png icons/tiempo-weather/galeria1/18.png image/png
                        upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/9.png icons/luna-moon/9.png image/png
                        upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/26.png icons/luna-moon/26.png image/png
                        upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/25.png icons/luna-moon/25.png image/png
                        upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/24.png icons/luna-moon/24.png image/png
                        upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/23.png icons/luna-moon/23.png image/png
                        upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/22.png icons/luna-moon/22.png image/png
                        upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/21.png icons/luna-moon/21.png image/png
                        upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/20.png icons/luna-moon/20.png image/png
                        upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/2.png icons/luna-moon/2.png image/png
                        upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/19.png icons/luna-moon/19.png image/png
                        upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/18.png icons/luna-moon/18.png image/png
                        upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/17.png icons/luna-moon/17.png image/png
                        upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/16.png icons/luna-moon/16.png image/png
                        upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/15.png icons/luna-moon/15.png image/png
                        upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/14.png icons/luna-moon/14.png image/png
                        upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/13.png icons/luna-moon/13.png image/png
                        upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/12.png icons/luna-moon/12.png image/png
                        upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/11.png icons/luna-moon/11.png image/png
                        upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/10.png icons/luna-moon/10.png image/png
                        upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/1.png icons/luna-moon/1.png image/png
                        upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/0.png icons/luna-moon/0.png image/png
                        upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/daswettercom.png daswettercom.png image/png
                        upload [13] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/words.js words.js application/javascript
                        upload [12] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/index_m.html index_m.html text/html
                        upload [11] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/index.html index.html text/html
                        upload [10] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [9] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [8] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [7] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [6] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [5] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [4] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [3] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [2] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [1] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [0] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/busware.jpg busware.jpg image/jpeg
                        upload [17] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
                        upload [16] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/jsonConfig.json jsonConfig.json application/json
                        upload [15] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
                        upload [14] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/img/info-big.png img/info-big.png image/png
                        upload [13] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [12] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [11] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [10] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [9] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [8] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [7] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
                        upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
                        upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
                        upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
                        upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                        upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                        upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                        upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                        upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                        upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                        upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                        upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                        upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                        upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                        upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                        upload [3] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/words.js words.js application/javascript
                        upload [2] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/index_m.html index_m.html text/html
                        upload [1] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/index.html index.html text/html
                        upload [0] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/amazon-dash.png amazon-dash.png image/png
                        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
                        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                        holger@iobroker:~$ iobroker upgrade admin@5.2.1
                        Would you like to reinstall version 5.2.1 of admin now? [(y)es, (n)o]: y
                        Update admin from @5.2.1 to @5.2.1
                        host.iobroker Adapter "system.adapter.admin.0" is stopped.
                        NPM version: 6.14.15
                        npm install iobroker.admin@5.2.1 --loglevel error --prefix "/opt/iobroker" (System call)
                        Adapter "admin" updated
                        host.iobroker Adapter "system.adapter.admin.0" is started
                        Keine Veränderung
                        holger@iobroker:~$ iobroker update
                        Used repository: beta
                        hash unchanged, use cached sources
                        update done
                        Adapter    "admin"         : 5.2.1    , installed 5.1.29 [Updateable]
                        Adapter    "amazon-dash"   : 1.1.0    , installed 1.1.0
                        Adapter    "backitup"      : 2.2.2    , installed 2.2.2
                        Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                        Adapter    "cul"           : 1.3.5    , installed 1.3.5
                        Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
                        Adapter    "denon"         : 1.11.2   , installed 1.11.2
                        Adapter    "discovery"     : 2.7.5    , installed 2.7.5
                        Adapter    "flot"          : 1.10.7   , installed 1.10.7
                        Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                        Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
                        Adapter    "hm-rpc"        : 1.14.50  , installed 1.14.50
                        Adapter    "influxdb"      : 2.2.0    , installed 2.2.0
                        Adapter    "info"          : 1.9.16   , installed 1.9.16
                        Adapter    "javascript"    : 5.2.16   , installed 5.2.16
                        Controller "js-controller" : 3.3.21   , installed 3.3.21
                        Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
                        Adapter    "mqtt"          : 2.4.1    , installed 2.4.1
                        Adapter    "node-red"      : 2.4.1    , installed 2.4.1
                        Adapter    "shelly"        : 5.0.0    , installed 5.0.0
                        Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
                        Adapter    "socketio"      : 3.1.5    , installed 3.1.5
                        Adapter    "sonoff"        : 2.4.7    , installed 2.4.7
                        Adapter    "sql"           : 1.15.7   , installed 1.15.7
                        Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                        Adapter    "vis"           : 1.4.6    , installed 1.4.6
                        Adapter    "web"           : 3.4.16   , installed 3.4.16
                        Adapter    "zigbee"        : 1.6.8    , installed 1.6.8
                        Adapter    "zwave2"        : 2.4.1    , installed 2.4.1
                        2484
