      Thomas Braun Most Active @ub.privat last edited by
      @ub-privat
      sudo apt install mariadb-client-10.3
      ub.privat 2 Replies Last reply Reply Quote 0
      • ub.privat
        ub.privat @Thomas Braun last edited by
        das System noch einmal neu gebootet. Nun nochmals manuell das Backup anstoßen?
        • ub.privat
          ub.privat @Thomas Braun last edited by ub.privat
          Schaut schon ein wenig "besser" aus:
          Started iobroker ...
          [DEBUG] [mount] - noserverino option: false
          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Uwe,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.20/300_SMARTHOME/310_BACKUP/IOB_1 /opt/iobroker/backups"
          [DEBUG] [mount] - mount successfully completed
          [DEBUG] [mount] - done
          [DEBUG] [iobroker] - host.raspberrypi 15818 states saved
          [DEBUG] [iobroker] - host.raspberrypi 18629 objects saved
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_12_14-18_36_25_backupiobroker.tar.gz
          [DEBUG] [iobroker] - done
          [DEBUG] [influxDB] - InfluxDB-Backup started ...
          [DEBUG] [influxDB] - Start InfluxDB Backup ...
          [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
          [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_12_14-18_36_53_backupiobroker.tar.gz
          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
          [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
          [DEBUG] [influxDB] - InfluxDB-Backup for is finish
          [DEBUG] [influxDB] - done
          [DEBUG] [mysql] - MySql-Backup started ...
          [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u ioBroker -p**** iobroker -h 192.168.178.20 -P 3307 > /opt/iobroker/backups/mysql_2021_12_14-18_36_55_backupiobroker.sql
          mysqldump: Got error: 1045: "Access denied for user 'ioBroker'@'raspberrypi-3.fritz.box' (using password: YES)" when trying to connect
          [DEBUG] [historyDB] - compress from historyDB started ...
          [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
          [DEBUG] [grafana] - Start Grafana Backup ...
          [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
          [DEBUG] [grafana] - Created dashboard directory
          [DEBUG] [grafana] - Created dashboards_manually_restore directory
          [DEBUG] [grafana] - Created datasource directory
          [DEBUG] [grafana] - start Grafana request ...
          [DEBUG] [grafana] - Grafana is available ... Status: 200
          [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
          [DEBUG] [grafana] - start Grafana backup compress ...
          [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
          [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
          [DEBUG] [grafana] - cannot found Grafana Backup files
          [DEBUG] [grafana] - done
          [DEBUG] [cifs] - done
          [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_12_14-18_36_25_backupiobroker.tar.gz...
          [DEBUG] [googledrive] - Google Drive: Copy influxDB_2021_12_14-18_36_53_backupiobroker.tar.gz...
          [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/mysql_2021_12_14-18_36_55_backupiobroker.tar.gz" not found
          [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_12_14-18_36_58_backupiobroker.tar.gz" not found
          [DEBUG] [googledrive] - done
          [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
          [DEBUG] [clean] - done
          [DEBUG] [email] - done
          [DEBUG] [historyHTML] - new history html values created
          [DEBUG] [historyHTML] - done
          [DEBUG] [historyJSON] - new history json values created
          [DEBUG] [historyJSON] - done
          [DEBUG] [umount] - mount activ, umount is started ...
          [DEBUG] [umount] - umount successfully completed
          [DEBUG] [umount] - done
          [EXIT] 0
          Nun kommt diese Fehlermeldung:
          InFlux DB und ioBroker - Backup wurden geschrieben! Freu...
          Jetzt nich die mySQL hinbekommen!
          Ich verstehe aber nicht, warum jetzt die GZ-Datei geschrieben wird!?
            Thomas Braun Most Active @ub.privat last edited by Thomas Braun
            @ub-privat
            Der User muss dann auf dem Server auch angelegt sein. Sonst darf der natürlich auch keinen mysqldump ausführen.
            ub.privat 1 Reply Last reply Reply Quote 1
            • ub.privat
              ich muss nun in der MariaDB den Fritzbox-User mit dem entsprechenden Passwort anlegen/einrichten?
              Puuh, da muss ich mal schauen, wie ich das hinbekomme...
              wäre dies die korrekte Vorgehensweise?
              https://forum.iobroker.net/topic/3327/mariadb-auf-diskstation-als-datenbank-für-flot
                @ub-privat
                Keine Ahnung von mariadb.
                ub.privat 2 Replies Last reply Reply Quote 1
                • ub.privat
                  OK, Schade.
                  Aktuell sind diese User eingerichtet:
                  aber ist denn 'ioBroker'@'raspberrypi-3.fritz.box' nicht gleich der Benutzer "iobroker"?
                  Wie gesagt, alles "learning by doing" und die grenzenlose Forumshilfe!
                  • ub.privat
                    dann werede ich erst einmal die iobroker- und influx-Backups beobachten!
                    Vielen Dank für deine Hilfe! DANKE.
                    • mickym
                      mickym Most Active @ub.privat last edited by mickym
                      gelöscht
                      • mickym
                        mickym Most Active @mickym last edited by mickym
                        @ub-privat Ich versteh das alles ehrlich gesagt nicht. Du gibst doch in dem SQL-Adapter einen Benutzer an und den musst Du in der mySQL (mariaDB) anlegen. Das hat doch nichts mit irgendwelchen Domänennamen etc. zu tun.
                        Bei mir heißt der auch zufälligerweise iobroker:
                        Im backitup Adapter musst Du den mySQL Benutzernamen dann ja auch nochmal eintragen. Verstehe momentan nicht, wo das Problem liegt.
                        ub.privat 1 Reply Last reply Reply Quote 0
                        • ub.privat
                          ub.privat @mickym last edited by
                          @mickym
                          die Einträge habe ich sowohl im SQL und Backitup-Adapter korrekt vorgenommen.
                          In der MariaDB ist er auch angelegt --> siehe Bild weiter oben.
                          Adapter sind auch korrekt = grün.
                          Wo ist dein Bildauschnitt her?
                          mickym Thomas Braun 2 Replies Last reply Reply Quote 0
                          • mickym
                            @ub-privat Ich habe mir für Windows HeidiSQL installiert - damit kann ich die mariaDB easy mit der GUI administrieren. 😉
                              @ub-privat
                              ioBroker (im Backitup-Adapter) ist nicht iobroker (auf der Maria)
                              • ub.privat
                                @mickym
                                Da muss ich nch eine Menge lernen!
                                • ub.privat
                                  OK, nun ist der Faden weg! Das verstehe ich nicht... sorry.
                                  • mickym
                                    @ub-privat Aber ich glaube @Thomas-Braun hat mit Luchs Augen entdeckt, dass Du den iobroker im backitup Adapter falsch geschrieben hast. 😉
                                    Thomas Braun ub.privat 2 Replies Last reply Reply Quote 0
                                      Thomas Braun Most Active @mickym last edited by
                                      @mickym
                                      Ja. Ich hab meine Nickelbrille extra poliert.
                                      • ub.privat
                                        ub.privat @mickym last edited by ub.privat
                                        @mickym
                                        ioBroker habe ich schnell in iobroker korrigiert! Fehlermeldung bleibt aber identisch!
                                        [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u iobroker -p**** iobroker -h 192.168.178.20 -P 3307 > /opt/iobroker/backups/mysql_2021_12_14-19_19_30_backupiobroker.sql
                                        mysqldump: Got error: 1045: "Access denied for user 'iobroker'@'raspberrypi-3.fritz.box' (using password: YES)" when trying to connect
                                        • mickym
                                          @ub-privat Hast Du den Port absichtlich verbogen - normalerweise ist der 3306
                                          EDIT: 3306 nicht 3006
                                          • ub.privat
                                            @mickym
                                            Nein definitv nicht. Werde ich auch noch einmal probieren.
                                            170
                                            2780
                                            2343199
