    • ub.privat
      ub.privat @Thomas Braun last edited by
      das System noch einmal neu gebootet. Nun nochmals manuell das Backup anstoßen?
      • ub.privat
        ub.privat @Thomas Braun last edited by ub.privat
        Schaut schon ein wenig "besser" aus:
        Started iobroker ...
        [DEBUG] [mount] - noserverino option: false
        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Uwe,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.20/300_SMARTHOME/310_BACKUP/IOB_1 /opt/iobroker/backups"
        [DEBUG] [mount] - mount successfully completed
        [DEBUG] [mount] - done
        [DEBUG] [iobroker] - host.raspberrypi 15818 states saved
        [DEBUG] [iobroker] - host.raspberrypi 18629 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_12_14-18_36_25_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        [DEBUG] [influxDB] - InfluxDB-Backup started ...
        [DEBUG] [influxDB] - Start InfluxDB Backup ...
        [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
        [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_12_14-18_36_53_backupiobroker.tar.gz
        [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
        [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
        [DEBUG] [influxDB] - InfluxDB-Backup for is finish
        [DEBUG] [influxDB] - done
        [DEBUG] [mysql] - MySql-Backup started ...
        [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u ioBroker -p**** iobroker -h 192.168.178.20 -P 3307 > /opt/iobroker/backups/mysql_2021_12_14-18_36_55_backupiobroker.sql
        mysqldump: Got error: 1045: "Access denied for user 'ioBroker'@'raspberrypi-3.fritz.box' (using password: YES)" when trying to connect
        [DEBUG] [historyDB] - compress from historyDB started ...
        [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
        [DEBUG] [grafana] - Start Grafana Backup ...
        [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
        [DEBUG] [grafana] - Created dashboard directory
        [DEBUG] [grafana] - Created dashboards_manually_restore directory
        [DEBUG] [grafana] - Created datasource directory
        [DEBUG] [grafana] - start Grafana request ...
        [DEBUG] [grafana] - Grafana is available ... Status: 200
        [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
        [DEBUG] [grafana] - start Grafana backup compress ...
        [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
        [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
        [DEBUG] [grafana] - cannot found Grafana Backup files
        [DEBUG] [grafana] - done
        [DEBUG] [cifs] - done
        [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_12_14-18_36_25_backupiobroker.tar.gz...
        [DEBUG] [googledrive] - Google Drive: Copy influxDB_2021_12_14-18_36_53_backupiobroker.tar.gz...
        [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/mysql_2021_12_14-18_36_55_backupiobroker.tar.gz" not found
        [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_12_14-18_36_58_backupiobroker.tar.gz" not found
        [DEBUG] [googledrive] - done
        [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
        [DEBUG] [clean] - done
        [DEBUG] [email] - done
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        [DEBUG] [umount] - mount activ, umount is started ...
        [DEBUG] [umount] - umount successfully completed
        [DEBUG] [umount] - done
        [EXIT] 0
        Nun kommt diese Fehlermeldung:
        InFlux DB und ioBroker - Backup wurden geschrieben! Freu...
        Jetzt nich die mySQL hinbekommen!
        Ich verstehe aber nicht, warum jetzt die GZ-Datei geschrieben wird!?
          Thomas Braun Most Active @ub.privat last edited by Thomas Braun
          @ub-privat
          Der User muss dann auf dem Server auch angelegt sein. Sonst darf der natürlich auch keinen mysqldump ausführen.
          ub.privat 1 Reply Last reply Reply Quote 1
          • ub.privat
            ich muss nun in der MariaDB den Fritzbox-User mit dem entsprechenden Passwort anlegen/einrichten?
            Puuh, da muss ich mal schauen, wie ich das hinbekomme...
            wäre dies die korrekte Vorgehensweise?
            https://forum.iobroker.net/topic/3327/mariadb-auf-diskstation-als-datenbank-für-flot
              @ub-privat
              Keine Ahnung von mariadb.
              ub.privat 2 Replies Last reply Reply Quote 1
              • ub.privat
                OK, Schade.
                Aktuell sind diese User eingerichtet:
                aber ist denn 'ioBroker'@'raspberrypi-3.fritz.box' nicht gleich der Benutzer "iobroker"?
                Wie gesagt, alles "learning by doing" und die grenzenlose Forumshilfe!
                • ub.privat
                  dann werede ich erst einmal die iobroker- und influx-Backups beobachten!
                  Vielen Dank für deine Hilfe! DANKE.
                  • mickym
                    mickym Most Active @ub.privat last edited by mickym
                    gelöscht
                    • mickym
                      mickym Most Active @mickym last edited by mickym
                      @ub-privat Ich versteh das alles ehrlich gesagt nicht. Du gibst doch in dem SQL-Adapter einen Benutzer an und den musst Du in der mySQL (mariaDB) anlegen. Das hat doch nichts mit irgendwelchen Domänennamen etc. zu tun.
                      Bei mir heißt der auch zufälligerweise iobroker:
                      Im backitup Adapter musst Du den mySQL Benutzernamen dann ja auch nochmal eintragen. Verstehe momentan nicht, wo das Problem liegt.
                      ub.privat 1 Reply Last reply Reply Quote 0
                      • ub.privat
                        ub.privat @mickym last edited by
                        @mickym
                        die Einträge habe ich sowohl im SQL und Backitup-Adapter korrekt vorgenommen.
                        In der MariaDB ist er auch angelegt --> siehe Bild weiter oben.
                        Adapter sind auch korrekt = grün.
                        Wo ist dein Bildauschnitt her?
                        mickym Thomas Braun 2 Replies Last reply Reply Quote 0
                        • mickym
                          @ub-privat Ich habe mir für Windows HeidiSQL installiert - damit kann ich die mariaDB easy mit der GUI administrieren. 😉
                            @ub-privat
                            ioBroker (im Backitup-Adapter) ist nicht iobroker (auf der Maria)
                            • ub.privat
                              @mickym
                              Da muss ich nch eine Menge lernen!
                              • ub.privat
                                OK, nun ist der Faden weg! Das verstehe ich nicht... sorry.
                                • mickym
                                  @ub-privat Aber ich glaube @Thomas-Braun hat mit Luchs Augen entdeckt, dass Du den iobroker im backitup Adapter falsch geschrieben hast. 😉
                                  Thomas Braun ub.privat 2 Replies Last reply Reply Quote 0
                                    Thomas Braun Most Active @mickym last edited by
                                    @mickym
                                    Ja. Ich hab meine Nickelbrille extra poliert.
                                    • ub.privat
                                      ub.privat @mickym last edited by ub.privat
                                      @mickym
                                      ioBroker habe ich schnell in iobroker korrigiert! Fehlermeldung bleibt aber identisch!
                                      [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u iobroker -p**** iobroker -h 192.168.178.20 -P 3307 > /opt/iobroker/backups/mysql_2021_12_14-19_19_30_backupiobroker.sql
                                      mysqldump: Got error: 1045: "Access denied for user 'iobroker'@'raspberrypi-3.fritz.box' (using password: YES)" when trying to connect
                                      • mickym
                                        @ub-privat Hast Du den Port absichtlich verbogen - normalerweise ist der 3306
                                        EDIT: 3306 nicht 3006
                                        • ub.privat
                                          @mickym
                                          Nein definitv nicht. Werde ich auch noch einmal probieren.
                                          • mickym
                                            @ub-privat sagte in Test Adapter Backitup v2.2.x:
                                            @mickym
                                            3306 nicht 3006
                                            170
                                            2780
                                            2343199
