    • ub.privat
      ub.privat @Thomas Braun last edited by ub.privat
      Schaut schon ein wenig "besser" aus:
      Started iobroker ...
      [DEBUG] [mount] - noserverino option: false
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Uwe,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.20/300_SMARTHOME/310_BACKUP/IOB_1 /opt/iobroker/backups"
      [DEBUG] [mount] - mount successfully completed
      [DEBUG] [mount] - done
      [DEBUG] [iobroker] - host.raspberrypi 15818 states saved
      [DEBUG] [iobroker] - host.raspberrypi 18629 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_12_14-18_36_25_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [influxDB] - InfluxDB-Backup started ...
      [DEBUG] [influxDB] - Start InfluxDB Backup ...
      [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
      [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_12_14-18_36_53_backupiobroker.tar.gz
      [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
      [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
      [DEBUG] [influxDB] - InfluxDB-Backup for is finish
      [DEBUG] [influxDB] - done
      [DEBUG] [mysql] - MySql-Backup started ...
      [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u ioBroker -p**** iobroker -h 192.168.178.20 -P 3307 > /opt/iobroker/backups/mysql_2021_12_14-18_36_55_backupiobroker.sql
      mysqldump: Got error: 1045: "Access denied for user 'ioBroker'@'raspberrypi-3.fritz.box' (using password: YES)" when trying to connect
      [DEBUG] [historyDB] - compress from historyDB started ...
      [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
      [DEBUG] [grafana] - Start Grafana Backup ...
      [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
      [DEBUG] [grafana] - Created dashboard directory
      [DEBUG] [grafana] - Created dashboards_manually_restore directory
      [DEBUG] [grafana] - Created datasource directory
      [DEBUG] [grafana] - start Grafana request ...
      [DEBUG] [grafana] - Grafana is available ... Status: 200
      [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
      [DEBUG] [grafana] - start Grafana backup compress ...
      [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
      [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
      [DEBUG] [grafana] - cannot found Grafana Backup files
      [DEBUG] [grafana] - done
      [DEBUG] [cifs] - done
      [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_12_14-18_36_25_backupiobroker.tar.gz...
      [DEBUG] [googledrive] - Google Drive: Copy influxDB_2021_12_14-18_36_53_backupiobroker.tar.gz...
      [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/mysql_2021_12_14-18_36_55_backupiobroker.tar.gz" not found
      [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_12_14-18_36_58_backupiobroker.tar.gz" not found
      [DEBUG] [googledrive] - done
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [email] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [umount] - mount activ, umount is started ...
      [DEBUG] [umount] - umount successfully completed
      [DEBUG] [umount] - done
      [EXIT] 0
      Nun kommt diese Fehlermeldung:
      InFlux DB und ioBroker - Backup wurden geschrieben! Freu...
      Jetzt nich die mySQL hinbekommen!
      Ich verstehe aber nicht, warum jetzt die GZ-Datei geschrieben wird!?
        Thomas Braun Most Active @ub.privat last edited by Thomas Braun
        @ub-privat
        Der User muss dann auf dem Server auch angelegt sein. Sonst darf der natürlich auch keinen mysqldump ausführen.
        ub.privat 1 Reply Last reply Reply Quote 1
        • ub.privat
          ich muss nun in der MariaDB den Fritzbox-User mit dem entsprechenden Passwort anlegen/einrichten?
          Puuh, da muss ich mal schauen, wie ich das hinbekomme...
          wäre dies die korrekte Vorgehensweise?
          https://forum.iobroker.net/topic/3327/mariadb-auf-diskstation-als-datenbank-für-flot
            @ub-privat
            Keine Ahnung von mariadb.
            ub.privat 2 Replies Last reply Reply Quote 1
            • ub.privat
              OK, Schade.
              Aktuell sind diese User eingerichtet:
              aber ist denn 'ioBroker'@'raspberrypi-3.fritz.box' nicht gleich der Benutzer "iobroker"?
              Wie gesagt, alles "learning by doing" und die grenzenlose Forumshilfe!
              • ub.privat
                dann werede ich erst einmal die iobroker- und influx-Backups beobachten!
                Vielen Dank für deine Hilfe! DANKE.
                • mickym
                  mickym Most Active @ub.privat last edited by mickym
                  gelöscht
                  • mickym
                    mickym Most Active @mickym last edited by mickym
                    @ub-privat Ich versteh das alles ehrlich gesagt nicht. Du gibst doch in dem SQL-Adapter einen Benutzer an und den musst Du in der mySQL (mariaDB) anlegen. Das hat doch nichts mit irgendwelchen Domänennamen etc. zu tun.
                    Bei mir heißt der auch zufälligerweise iobroker:
                    Im backitup Adapter musst Du den mySQL Benutzernamen dann ja auch nochmal eintragen. Verstehe momentan nicht, wo das Problem liegt.
                    ub.privat 1 Reply Last reply Reply Quote 0
                    • ub.privat
                      ub.privat @mickym last edited by
                      @mickym
                      die Einträge habe ich sowohl im SQL und Backitup-Adapter korrekt vorgenommen.
                      In der MariaDB ist er auch angelegt --> siehe Bild weiter oben.
                      Adapter sind auch korrekt = grün.
                      Wo ist dein Bildauschnitt her?
                      mickym Thomas Braun 2 Replies Last reply Reply Quote 0
                      • mickym
                        @ub-privat Ich habe mir für Windows HeidiSQL installiert - damit kann ich die mariaDB easy mit der GUI administrieren. 😉
                          @ub-privat
                          ioBroker (im Backitup-Adapter) ist nicht iobroker (auf der Maria)
                          • ub.privat
                            @mickym
                            Da muss ich nch eine Menge lernen!
                            • ub.privat
                              OK, nun ist der Faden weg! Das verstehe ich nicht... sorry.
                              • mickym
                                @ub-privat Aber ich glaube @Thomas-Braun hat mit Luchs Augen entdeckt, dass Du den iobroker im backitup Adapter falsch geschrieben hast. 😉
                                Thomas Braun ub.privat 2 Replies Last reply Reply Quote 0
                                  Thomas Braun Most Active @mickym last edited by
                                  @mickym
                                  Ja. Ich hab meine Nickelbrille extra poliert.
                                  • ub.privat
                                    ub.privat @mickym last edited by ub.privat
                                    @mickym
                                    ioBroker habe ich schnell in iobroker korrigiert! Fehlermeldung bleibt aber identisch!
                                    [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u iobroker -p**** iobroker -h 192.168.178.20 -P 3307 > /opt/iobroker/backups/mysql_2021_12_14-19_19_30_backupiobroker.sql
                                    mysqldump: Got error: 1045: "Access denied for user 'iobroker'@'raspberrypi-3.fritz.box' (using password: YES)" when trying to connect
                                    • mickym
                                      @ub-privat Hast Du den Port absichtlich verbogen - normalerweise ist der 3306
                                      EDIT: 3306 nicht 3006
                                      • ub.privat
                                        @mickym
                                        Nein definitv nicht. Werde ich auch noch einmal probieren.
                                        • mickym
                                          @ub-privat sagte in Test Adapter Backitup v2.2.x:
                                          @mickym
                                          3306 nicht 3006
                                          • ub.privat
                                            @mickym
                                            @Thomas-Braun
                                            nun scheint es zu funktionieren - manuell!
                                            Alle Datein erscheinen und sind nicht mehr 0kB groß.
                                            Habe in der DB noch einmal das Kennwort neu eingegeben und auf Groß- und Kleinschreibung geachtet.
                                            Jetzt kommt diese Meldung:
                                            [ERROR] [mysql] - [IGNORED] Error: ENOENT: no such file or directory, lstat '/opt/iobroker/backups/mysql_2021_12_14-19_27_16_backupiobroker.sql'
                                            Damit kann ich für heute leben, schaue, ob die automatische Sicherung funktioniert.
                                            Erst einmal allen vielen Dank!
                                            170
                                            2780
                                            2343192
