    4. Test Adapter TrashSchedule
    • Glasfaser
      Glasfaser @Undead2211 last edited by
      @undead2211
      Bitte die Instanzeinstellung von TrashSchedule zeigen .
      Undead2211 1 Reply Last reply Reply Quote 1
      • Undead2211
        Undead2211 @Glasfaser last edited by
        @glasfaser
        • Glasfaser
          @undead2211
          Stelle die Logstufe in der Instanz auf DEBUG und die Ausgabe hier in Code-Tags </> posten .
          • Undead2211
            @glasfaser
            Hier der Log:
            trashschedule.0	2021-12-14 20:47:17.352	debug	(5) filling "nextAfter" event with data: {"minDays":21,"minDate":"2022-01-03T23:00:00.000Z","minTypes":["Biomüll"]}
            trashschedule.0	2021-12-14 20:47:17.350	debug	(5) filling "next" event with data: {"minDays":20,"minDate":"2022-01-02T23:00:00.000Z","minTypes":["Papier"]}
            trashschedule.0	2021-12-14 20:47:17.347	warn	no events matches type "Restmüll" with match "Restmüll". Check configuration of iCal (increase preview) and trashschedule!
            trashschedule.0	2021-12-14 20:47:17.346	debug	(2) processing: Restmüll 4-Rad (Eglosh.) (1647212400000) // dayDiff: 90 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.346	debug	(1) parsing next event {"date":"14.03.2022 ","event":"Restmüll 4-Rad (Eglosh.)","_class":"ical_calendar1 ","_date":"2022-03-13T23:00:00.000Z","_end":"2022-03-14T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Eglosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"4ebff176-ac8d-45f4-83f3-b0849f93e12b","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-03-13T23:00:00.000Z // calculated date (with offset): Mon Mar 14 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.345	debug	(3) event match: "Biomüll" matches type "Biomüll" with pattern "Biomüll (exact match)"
            trashschedule.0	2021-12-14 20:47:17.344	debug	(2) processing: Biomüll (1646953200000) // dayDiff: 87 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.344	debug	(1) parsing next event {"date":"11.03.2022 ","event":"Biomüll","_class":"ical_calendar1 ","_date":"2022-03-10T23:00:00.000Z","_end":"2022-03-11T23:00:00.000Z","_section":"Leerung: Biomüll \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"60560435-0004-4b4e-9ac0-a72142417186","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-03-10T23:00:00.000Z // calculated date (with offset): Fri Mar 11 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.343	debug	(2) processing: Restmüll 4-Rad (Tamm.) (1646780400000) // dayDiff: 85 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.342	debug	(1) parsing next event {"date":"09.03.2022 ","event":"Restmüll 4-Rad (Tamm.)","_class":"ical_calendar1 ","_date":"2022-03-08T23:00:00.000Z","_end":"2022-03-09T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Tamm.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"b9048442-2dd1-4d9f-8e37-8e0d34289ebb","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-03-08T23:00:00.000Z // calculated date (with offset): Wed Mar 09 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.342	debug	(2) processing: Restmüll 4-Rad (Eglosh.) (1646607600000) // dayDiff: 83 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.341	debug	(1) parsing next event {"date":"07.03.2022 ","event":"Restmüll 4-Rad (Eglosh.)","_class":"ical_calendar1 ","_date":"2022-03-06T23:00:00.000Z","_end":"2022-03-07T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Eglosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"78a17016-3a5a-4875-a0a4-f09fb3a1fe26","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-03-06T23:00:00.000Z // calculated date (with offset): Mon Mar 07 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.340	debug	(2) processing: Restmüll (1646348400000) // dayDiff: 80 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.339	debug	(1) parsing next event {"date":"04.03.2022 ","event":"Restmüll ","_class":"ical_calendar1 ","_date":"2022-03-03T23:00:00.000Z","_end":"2022-03-04T23:00:00.000Z","_section":"Leerung: Restmüll \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"50351be1-f1aa-4f92-bd96-57cfa2d98642","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-03-03T23:00:00.000Z // calculated date (with offset): Fri Mar 04 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.339	debug	(2) processing: Glas (Ergosh.) (1646175600000) // dayDiff: 78 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.338	debug	(1) parsing next event {"date":"02.03.2022 ","event":"Glas (Ergosh.)","_class":"ical_calendar1 ","_date":"2022-03-01T23:00:00.000Z","_end":"2022-03-02T23:00:00.000Z","_section":"Leerung: Glas (Ergosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"6ea16ca5-45bd-40d8-8a7c-88acafbafcb6","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-03-01T23:00:00.000Z // calculated date (with offset): Wed Mar 02 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.337	debug	(2) processing: Restmüll 4-Rad (Tamm.) (1646175600000) // dayDiff: 78 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.337	debug	(1) parsing next event {"date":"02.03.2022 ","event":"Restmüll 4-Rad (Tamm.)","_class":"ical_calendar1 ","_date":"2022-03-01T23:00:00.000Z","_end":"2022-03-02T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Tamm.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"796bd76a-a6b1-4c9f-ad5b-a9f7d856859f","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-03-01T23:00:00.000Z // calculated date (with offset): Wed Mar 02 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.336	debug	(3) event match: "LVP" matches type "Verpackung" with pattern "LVP (exact match)"
            trashschedule.0	2021-12-14 20:47:17.335	debug	(2) processing: LVP (1646089200000) // dayDiff: 77 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.335	debug	(1) parsing next event {"date":"01.03.2022 ","event":"LVP","_class":"ical_calendar1 ","_date":"2022-02-28T23:00:00.000Z","_end":"2022-03-01T23:00:00.000Z","_section":"Leerung: LVP \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"e7ab53cd-74df-41a8-8b0d-858970efa588","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-28T23:00:00.000Z // calculated date (with offset): Tue Mar 01 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.334	debug	(2) processing: LVP 4-Rad (1646089200000) // dayDiff: 77 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.333	debug	(1) parsing next event {"date":"01.03.2022 ","event":"LVP 4-Rad","_class":"ical_calendar1 ","_date":"2022-02-28T23:00:00.000Z","_end":"2022-03-01T23:00:00.000Z","_section":"Leerung: LVP 4-Rad \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"49a459e9-faee-4d9d-83ce-788102b9e0fa","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-28T23:00:00.000Z // calculated date (with offset): Tue Mar 01 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.332	debug	(2) processing: Restmüll 4-Rad (Eglosh.) (1646002800000) // dayDiff: 76 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.332	debug	(1) parsing next event {"date":"28.02.2022 ","event":"Restmüll 4-Rad (Eglosh.)","_class":"ical_calendar1 ","_date":"2022-02-27T23:00:00.000Z","_end":"2022-02-28T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Eglosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"f2648963-8650-47f2-9a68-c544cc7302d7","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-27T23:00:00.000Z // calculated date (with offset): Mon Feb 28 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.331	debug	(3) event match: "Biomüll" matches type "Biomüll" with pattern "Biomüll (exact match)"
            trashschedule.0	2021-12-14 20:47:17.330	debug	(2) processing: Biomüll (1645743600000) // dayDiff: 73 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.329	debug	(1) parsing next event {"date":"25.02.2022 ","event":"Biomüll","_class":"ical_calendar1 ","_date":"2022-02-24T23:00:00.000Z","_end":"2022-02-25T23:00:00.000Z","_section":"Leerung: Biomüll \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"40bfb593-7115-4919-b4c6-ab798872a616","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-24T23:00:00.000Z // calculated date (with offset): Fri Feb 25 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.329	debug	(3) event match: "Papier" matches type "Papier" with pattern "Papier (exact match)"
            trashschedule.0	2021-12-14 20:47:17.328	debug	(2) processing: Papier (1645743600000) // dayDiff: 73 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.327	debug	(1) parsing next event {"date":"25.02.2022 ","event":"Papier","_class":"ical_calendar1 ","_date":"2022-02-24T23:00:00.000Z","_end":"2022-02-25T23:00:00.000Z","_section":"Leerung: Papier \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"18b60a6d-4de0-4509-87d9-2a68945dc1a7","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-24T23:00:00.000Z // calculated date (with offset): Fri Feb 25 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.327	debug	(2) processing: Restmüll 4-Rad (Tamm.) (1645570800000) // dayDiff: 71 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.326	debug	(1) parsing next event {"date":"23.02.2022 ","event":"Restmüll 4-Rad (Tamm.)","_class":"ical_calendar1 ","_date":"2022-02-22T23:00:00.000Z","_end":"2022-02-23T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Tamm.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"28fcdc39-d53b-461c-81b9-0c2e6b8eab75","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-22T23:00:00.000Z // calculated date (with offset): Wed Feb 23 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.325	debug	(2) processing: Restmüll 4-Rad (Eglosh.) (1645398000000) // dayDiff: 69 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.324	debug	(1) parsing next event {"date":"21.02.2022 ","event":"Restmüll 4-Rad (Eglosh.)","_class":"ical_calendar1 ","_date":"2022-02-20T23:00:00.000Z","_end":"2022-02-21T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Eglosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"8db81d2f-b708-4d78-abb7-466cc6ab9315","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-20T23:00:00.000Z // calculated date (with offset): Mon Feb 21 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.324	debug	(2) processing: Glas (Tamm.) (1645138800000) // dayDiff: 66 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.323	debug	(1) parsing next event {"date":"18.02.2022 ","event":"Glas (Tamm.)","_class":"ical_calendar1 ","_date":"2022-02-17T23:00:00.000Z","_end":"2022-02-18T23:00:00.000Z","_section":"Leerung: Glas (Tamm.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"a49ab65e-f76f-433b-b0b0-bd7d88f59a99","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-17T23:00:00.000Z // calculated date (with offset): Fri Feb 18 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.322	debug	(2) processing: Restmüll (1645138800000) // dayDiff: 66 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.321	debug	(1) parsing next event {"date":"18.02.2022 ","event":"Restmüll ","_class":"ical_calendar1 ","_date":"2022-02-17T23:00:00.000Z","_end":"2022-02-18T23:00:00.000Z","_section":"Leerung: Restmüll \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"79c2bc46-0ea2-446d-a11d-e541ab2c8a22","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-17T23:00:00.000Z // calculated date (with offset): Fri Feb 18 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.321	debug	(2) processing: Papier 4-Rad (1645052400000) // dayDiff: 65 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.320	debug	(1) parsing next event {"date":"17.02.2022 ","event":"Papier 4-Rad","_class":"ical_calendar1 ","_date":"2022-02-16T23:00:00.000Z","_end":"2022-02-17T23:00:00.000Z","_section":"Leerung: Papier 4-Rad \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"f85e7940-c2bb-42dc-a1ec-315c7c3777d2","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-16T23:00:00.000Z // calculated date (with offset): Thu Feb 17 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.319	debug	(2) processing: Restmüll 4-Rad (Tamm.) (1644966000000) // dayDiff: 64 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.307	debug	(1) parsing next event {"date":"16.02.2022 ","event":"Restmüll 4-Rad (Tamm.)","_class":"ical_calendar1 ","_date":"2022-02-15T23:00:00.000Z","_end":"2022-02-16T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Tamm.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"dc4ccfd3-babe-4fd4-8ff0-3e147047bb03","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-15T23:00:00.000Z // calculated date (with offset): Wed Feb 16 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.306	debug	(2) processing: LVP 4-Rad (1644879600000) // dayDiff: 63 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.305	debug	(1) parsing next event {"date":"15.02.2022 ","event":"LVP 4-Rad","_class":"ical_calendar1 ","_date":"2022-02-14T23:00:00.000Z","_end":"2022-02-15T23:00:00.000Z","_section":"Leerung: LVP 4-Rad \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"92a20ed3-56ed-4783-b922-2b99d70803c2","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-14T23:00:00.000Z // calculated date (with offset): Tue Feb 15 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.305	debug	(2) processing: Restmüll 4-Rad (Eglosh.) (1644793200000) // dayDiff: 62 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.304	debug	(1) parsing next event {"date":"14.02.2022 ","event":"Restmüll 4-Rad (Eglosh.)","_class":"ical_calendar1 ","_date":"2022-02-13T23:00:00.000Z","_end":"2022-02-14T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Eglosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"20bd80f6-3ce2-42dd-aa2b-a5dd274252e2","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-13T23:00:00.000Z // calculated date (with offset): Mon Feb 14 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.303	debug	(3) event match: "Biomüll" matches type "Biomüll" with pattern "Biomüll (exact match)"
            trashschedule.0	2021-12-14 20:47:17.302	debug	(2) processing: Biomüll (1644534000000) // dayDiff: 59 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.302	debug	(1) parsing next event {"date":"11.02.2022 ","event":"Biomüll","_class":"ical_calendar1 ","_date":"2022-02-10T23:00:00.000Z","_end":"2022-02-11T23:00:00.000Z","_section":"Leerung: Biomüll \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"d3d6dece-c456-4c18-8a5a-a5fc86468bb3","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-10T23:00:00.000Z // calculated date (with offset): Fri Feb 11 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.301	debug	(2) processing: Restmüll 4-Rad (Tamm.) (1644361200000) // dayDiff: 57 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.300	debug	(1) parsing next event {"date":"09.02.2022 ","event":"Restmüll 4-Rad (Tamm.)","_class":"ical_calendar1 ","_date":"2022-02-08T23:00:00.000Z","_end":"2022-02-09T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Tamm.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"ed33173b-ebf6-46df-8386-1582399e74ac","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-08T23:00:00.000Z // calculated date (with offset): Wed Feb 09 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.299	debug	(2) processing: Restmüll 4-Rad (Eglosh.) (1644188400000) // dayDiff: 55 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.299	debug	(1) parsing next event {"date":"07.02.2022 ","event":"Restmüll 4-Rad (Eglosh.)","_class":"ical_calendar1 ","_date":"2022-02-06T23:00:00.000Z","_end":"2022-02-07T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Eglosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"c279ec6a-600e-45d2-9bec-1f6a527e909a","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-06T23:00:00.000Z // calculated date (with offset): Mon Feb 07 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.298	debug	(2) processing: Restmüll (1643929200000) // dayDiff: 52 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.297	debug	(1) parsing next event {"date":"04.02.2022 ","event":"Restmüll ","_class":"ical_calendar1 ","_date":"2022-02-03T23:00:00.000Z","_end":"2022-02-04T23:00:00.000Z","_section":"Leerung: Restmüll \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"3259e1e7-5dc3-4593-bd18-c1f9705f3e35","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-03T23:00:00.000Z // calculated date (with offset): Fri Feb 04 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.296	debug	(2) processing: Glas (Ergosh.) (1643756400000) // dayDiff: 50 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.295	debug	(1) parsing next event {"date":"02.02.2022 ","event":"Glas (Ergosh.)","_class":"ical_calendar1 ","_date":"2022-02-01T23:00:00.000Z","_end":"2022-02-02T23:00:00.000Z","_section":"Leerung: Glas (Ergosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"eb1c2069-aaf7-4aa2-980d-a41dc6f06418","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-01T23:00:00.000Z // calculated date (with offset): Wed Feb 02 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.295	debug	(2) processing: Restmüll 4-Rad (Tamm.) (1643756400000) // dayDiff: 50 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.294	debug	(1) parsing next event {"date":"02.02.2022 ","event":"Restmüll 4-Rad (Tamm.)","_class":"ical_calendar1 ","_date":"2022-02-01T23:00:00.000Z","_end":"2022-02-02T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Tamm.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"50389c56-8225-4a3c-a353-6e2222c0dfda","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-02-01T23:00:00.000Z // calculated date (with offset): Wed Feb 02 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.293	debug	(3) event match: "LVP" matches type "Verpackung" with pattern "LVP (exact match)"
            trashschedule.0	2021-12-14 20:47:17.292	debug	(2) processing: LVP (1643670000000) // dayDiff: 49 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.292	debug	(1) parsing next event {"date":"01.02.2022 ","event":"LVP","_class":"ical_calendar1 ","_date":"2022-01-31T23:00:00.000Z","_end":"2022-02-01T23:00:00.000Z","_section":"Leerung: LVP \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"cf951e96-6815-4ce9-a8a5-01a2b2a6bcb0","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-31T23:00:00.000Z // calculated date (with offset): Tue Feb 01 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.291	debug	(2) processing: LVP 4-Rad (1643670000000) // dayDiff: 49 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.290	debug	(1) parsing next event {"date":"01.02.2022 ","event":"LVP 4-Rad","_class":"ical_calendar1 ","_date":"2022-01-31T23:00:00.000Z","_end":"2022-02-01T23:00:00.000Z","_section":"Leerung: LVP 4-Rad \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"684ee34a-3cd0-4742-88f9-25e9c0ba11a8","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-31T23:00:00.000Z // calculated date (with offset): Tue Feb 01 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.289	debug	(2) processing: Restmüll 4-Rad (Eglosh.) (1643583600000) // dayDiff: 48 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.288	debug	(1) parsing next event {"date":"31.01.2022 ","event":"Restmüll 4-Rad (Eglosh.)","_class":"ical_calendar1 ","_date":"2022-01-30T23:00:00.000Z","_end":"2022-01-31T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Eglosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"b4b84923-e511-4c01-8a94-ad8cca6dc9d8","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-30T23:00:00.000Z // calculated date (with offset): Mon Jan 31 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.288	debug	(3) event match: "Biomüll" matches type "Biomüll" with pattern "Biomüll (exact match)"
            trashschedule.0	2021-12-14 20:47:17.287	debug	(2) processing: Biomüll (1643324400000) // dayDiff: 45 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.286	debug	(1) parsing next event {"date":"28.01.2022 ","event":"Biomüll","_class":"ical_calendar1 ","_date":"2022-01-27T23:00:00.000Z","_end":"2022-01-28T23:00:00.000Z","_section":"Leerung: Biomüll \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"fed532c7-37b8-4f87-9339-b1656721f328","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-27T23:00:00.000Z // calculated date (with offset): Fri Jan 28 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.286	debug	(3) event match: "Papier" matches type "Papier" with pattern "Papier (exact match)"
            trashschedule.0	2021-12-14 20:47:17.285	debug	(2) processing: Papier (1643324400000) // dayDiff: 45 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.284	debug	(1) parsing next event {"date":"28.01.2022 ","event":"Papier","_class":"ical_calendar1 ","_date":"2022-01-27T23:00:00.000Z","_end":"2022-01-28T23:00:00.000Z","_section":"Leerung: Papier \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"40135db5-c187-4585-bc4e-442957c2179a","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-27T23:00:00.000Z // calculated date (with offset): Fri Jan 28 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.283	debug	(2) processing: Restmüll 4-Rad (Tamm.) (1643151600000) // dayDiff: 43 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.281	debug	(1) parsing next event {"date":"26.01.2022 ","event":"Restmüll 4-Rad (Tamm.)","_class":"ical_calendar1 ","_date":"2022-01-25T23:00:00.000Z","_end":"2022-01-26T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Tamm.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"1d4ac4c7-723e-40f8-b697-be060b22d791","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-25T23:00:00.000Z // calculated date (with offset): Wed Jan 26 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.280	debug	(2) processing: Restmüll 4-Rad (Eglosh.) (1642978800000) // dayDiff: 41 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.280	debug	(1) parsing next event {"date":"24.01.2022 ","event":"Restmüll 4-Rad (Eglosh.)","_class":"ical_calendar1 ","_date":"2022-01-23T23:00:00.000Z","_end":"2022-01-24T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Eglosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"dacd5b44-3a40-462b-a422-dc0df8c250ff","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-23T23:00:00.000Z // calculated date (with offset): Mon Jan 24 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.278	debug	(2) processing: Glas (Tamm.) (1642719600000) // dayDiff: 38 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.276	debug	(1) parsing next event {"date":"21.01.2022 ","event":"Glas (Tamm.)","_class":"ical_calendar1 ","_date":"2022-01-20T23:00:00.000Z","_end":"2022-01-21T23:00:00.000Z","_section":"Leerung: Glas (Tamm.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"c3013ce8-02f8-4409-a4ee-a44ad30d15c7","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-20T23:00:00.000Z // calculated date (with offset): Fri Jan 21 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.276	debug	(2) processing: Restmüll (1642719600000) // dayDiff: 38 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.275	debug	(1) parsing next event {"date":"21.01.2022 ","event":"Restmüll ","_class":"ical_calendar1 ","_date":"2022-01-20T23:00:00.000Z","_end":"2022-01-21T23:00:00.000Z","_section":"Leerung: Restmüll \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"85d3a4af-8c68-4af2-ae13-31fa785b634c","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-20T23:00:00.000Z // calculated date (with offset): Fri Jan 21 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.274	debug	(2) processing: Papier 4-Rad (1642633200000) // dayDiff: 37 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.273	debug	(1) parsing next event {"date":"20.01.2022 ","event":"Papier 4-Rad","_class":"ical_calendar1 ","_date":"2022-01-19T23:00:00.000Z","_end":"2022-01-20T23:00:00.000Z","_section":"Leerung: Papier 4-Rad \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"c52da833-729a-4033-a35a-76e11df0a0cc","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-19T23:00:00.000Z // calculated date (with offset): Thu Jan 20 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.272	debug	(2) processing: Restmüll 4-Rad (Tamm.) (1642546800000) // dayDiff: 36 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.271	debug	(1) parsing next event {"date":"19.01.2022 ","event":"Restmüll 4-Rad (Tamm.)","_class":"ical_calendar1 ","_date":"2022-01-18T23:00:00.000Z","_end":"2022-01-19T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Tamm.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"4b94fe29-a121-4250-a406-d414a9b8359c","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-18T23:00:00.000Z // calculated date (with offset): Wed Jan 19 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.270	debug	(2) processing: LVP 4-Rad (1642460400000) // dayDiff: 35 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.269	debug	(1) parsing next event {"date":"18.01.2022 ","event":"LVP 4-Rad","_class":"ical_calendar1 ","_date":"2022-01-17T23:00:00.000Z","_end":"2022-01-18T23:00:00.000Z","_section":"Leerung: LVP 4-Rad \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"e811dfa2-8f96-4cb8-b80d-3301f78048ee","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-17T23:00:00.000Z // calculated date (with offset): Tue Jan 18 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.268	debug	(2) processing: Restmüll 4-Rad (Eglosh.) (1642374000000) // dayDiff: 34 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.267	debug	(1) parsing next event {"date":"17.01.2022 ","event":"Restmüll 4-Rad (Eglosh.)","_class":"ical_calendar1 ","_date":"2022-01-16T23:00:00.000Z","_end":"2022-01-17T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Eglosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"6708e51e-3588-40ab-a088-802ef25c76cb","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-16T23:00:00.000Z // calculated date (with offset): Mon Jan 17 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.266	debug	(3) event match: "Biomüll" matches type "Biomüll" with pattern "Biomüll (exact match)"
            trashschedule.0	2021-12-14 20:47:17.265	debug	(2) processing: Biomüll (1642114800000) // dayDiff: 31 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.263	debug	(1) parsing next event {"date":"14.01.2022 ","event":"Biomüll","_class":"ical_calendar1 ","_date":"2022-01-13T23:00:00.000Z","_end":"2022-01-14T23:00:00.000Z","_section":"Leerung: Biomüll \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"027a3586-c4d3-4a71-82c8-f29e7d647552","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-13T23:00:00.000Z // calculated date (with offset): Fri Jan 14 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.262	debug	(2) processing: Restmüll 4-Rad (Tamm.) (1641942000000) // dayDiff: 29 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.261	debug	(1) parsing next event {"date":"12.01.2022 ","event":"Restmüll 4-Rad (Tamm.)","_class":"ical_calendar1 ","_date":"2022-01-11T23:00:00.000Z","_end":"2022-01-12T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Tamm.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"534d061c-b256-47a3-8ee5-2fcb6c11a446","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-11T23:00:00.000Z // calculated date (with offset): Wed Jan 12 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.261	debug	(2) processing: Restmüll 4-Rad (Eglosh.) (1641769200000) // dayDiff: 27 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.260	debug	(1) parsing next event {"date":"10.01.2022 ","event":"Restmüll 4-Rad (Eglosh.)","_class":"ical_calendar1 ","_date":"2022-01-09T23:00:00.000Z","_end":"2022-01-10T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Eglosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"41a903f1-8da2-408f-b50b-2d3059d9cf39","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-09T23:00:00.000Z // calculated date (with offset): Mon Jan 10 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.259	debug	(2) processing: Restmüll (1641596400000) // dayDiff: 25 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.258	debug	(1) parsing next event {"date":"08.01.2022 ","event":"Restmüll ","_class":"ical_calendar1 ","_date":"2022-01-07T23:00:00.000Z","_end":"2022-01-08T23:00:00.000Z","_section":"Leerung: Restmüll \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"593dc0e8-1a96-4d7e-b7d4-89e69d76e817","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-07T23:00:00.000Z // calculated date (with offset): Sat Jan 08 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.256	debug	(4) filled type: "Glas"
            trashschedule.0	2021-12-14 20:47:17.254	debug	(3) event match: "Glas" matches type "Glas" with pattern "Glas (exact match)"
            trashschedule.0	2021-12-14 20:47:17.254	debug	(2) processing: Glas (1641510000000) // dayDiff: 24 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.252	debug	(1) parsing next event {"date":"07.01.2022 ","event":"Glas","_class":"ical_calendar1 ","_date":"2022-01-06T23:00:00.000Z","_end":"2022-01-07T23:00:00.000Z","_section":"Leerung: Glas \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"cfecf8e4-53a5-4c7e-907c-b2e6b53cc999","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-06T23:00:00.000Z // calculated date (with offset): Fri Jan 07 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.250	debug	(4) filled type: "Verpackung"
            trashschedule.0	2021-12-14 20:47:17.249	debug	(3) event match: "LVP" matches type "Verpackung" with pattern "LVP (exact match)"
            trashschedule.0	2021-12-14 20:47:17.248	debug	(2) processing: LVP (1641337200000) // dayDiff: 22 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.246	debug	(1) parsing next event {"date":"05.01.2022 ","event":"LVP","_class":"ical_calendar1 ","_date":"2022-01-04T23:00:00.000Z","_end":"2022-01-05T23:00:00.000Z","_section":"Leerung: LVP \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"b55a645b-7945-4afd-b7f7-507fbe409915","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-04T23:00:00.000Z // calculated date (with offset): Wed Jan 05 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.245	debug	(2) processing: LVP 4-Rad (1641337200000) // dayDiff: 22 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.244	debug	(1) parsing next event {"date":"05.01.2022 ","event":"LVP 4-Rad","_class":"ical_calendar1 ","_date":"2022-01-04T23:00:00.000Z","_end":"2022-01-05T23:00:00.000Z","_section":"Leerung: LVP 4-Rad \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"2166abd7-bdab-4c3a-b9b8-8f12fb490837","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-04T23:00:00.000Z // calculated date (with offset): Wed Jan 05 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.243	debug	(2) processing: Restmüll 4-Rad (Tamm.) (1641337200000) // dayDiff: 22 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.241	debug	(1) parsing next event {"date":"05.01.2022 ","event":"Restmüll 4-Rad (Tamm.)","_class":"ical_calendar1 ","_date":"2022-01-04T23:00:00.000Z","_end":"2022-01-05T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Tamm.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"cb95e1d2-8274-4ce4-95eb-7571fdc2aebd","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-04T23:00:00.000Z // calculated date (with offset): Wed Jan 05 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.240	debug	(4) filled type: "Biomüll"
            trashschedule.0	2021-12-14 20:47:17.238	debug	(3) event match: "Biomüll" matches type "Biomüll" with pattern "Biomüll (exact match)"
            trashschedule.0	2021-12-14 20:47:17.237	debug	(2) processing: Biomüll (1641250800000) // dayDiff: 21 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.235	debug	(1) parsing next event {"date":"04.01.2022 ","event":"Biomüll","_class":"ical_calendar1 ","_date":"2022-01-03T23:00:00.000Z","_end":"2022-01-04T23:00:00.000Z","_section":"Leerung: Biomüll \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"a44f533e-8d17-41a4-b875-44cbc9650fd1","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-03T23:00:00.000Z // calculated date (with offset): Tue Jan 04 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.234	debug	(4) filled type: "Papier"
            trashschedule.0	2021-12-14 20:47:17.228	debug	(3) event match: "Papier" matches type "Papier" with pattern "Papier (exact match)"
            trashschedule.0	2021-12-14 20:47:17.226	debug	(2) processing: Papier (1641164400000) // dayDiff: 20 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.225	debug	(1) parsing next event {"date":"03.01.2022 ","event":"Papier","_class":"ical_calendar1 ","_date":"2022-01-02T23:00:00.000Z","_end":"2022-01-03T23:00:00.000Z","_section":"Leerung: Papier \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"16436b05-376e-4e16-a975-ee9b27a0a90c","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-02T23:00:00.000Z // calculated date (with offset): Mon Jan 03 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.224	debug	(2) processing: Restmüll 4-Rad (Eglosh.) (1641164400000) // dayDiff: 20 // current hour (date): 20 (1639436400000) // skipsamedayathour (config): 22
            trashschedule.0	2021-12-14 20:47:17.223	debug	(1) parsing next event {"date":"03.01.2022 ","event":"Restmüll 4-Rad (Eglosh.)","_class":"ical_calendar1 ","_date":"2022-01-02T23:00:00.000Z","_end":"2022-01-03T23:00:00.000Z","_section":"Leerung: Restmüll 4-Rad (Eglosh.) \nBezirk: Eglosheim_und_Tammerfeld","_IDID":"0c991b4d-caae-4b85-8100-94079d2abf11","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"calendar1","_calColor":"#000000"} // originalDate: 2022-01-02T23:00:00.000Z // calculated date (with offset): Mon Jan 03 2022 00:00:00 GMT+0100 (GMT+01:00)
            trashschedule.0	2021-12-14 20:47:17.213	debug	(0) offset (config): 0
            trashschedule.0	2021-12-14 20:47:17.212	debug	Start processing 50 iCal events
            trashschedule.0	2021-12-14 20:47:17.206	debug	updating data
            trashschedule.0	2021-12-14 20:47:17.198	debug	re-creating refresh timeout in 767802ms (00:12:47)
            trashschedule.0	2021-12-14 20:47:17.126	debug	Trash type found: "Verpackung"
            trashschedule.0	2021-12-14 20:47:17.056	debug	Trash type found: "Glas"
            trashschedule.0	2021-12-14 20:47:17.032	debug	Trash type found: "Papier"
            trashschedule.0	2021-12-14 20:47:16.962	debug	Trash type found: "Biomüll"
            trashschedule.0	2021-12-14 20:47:16.925	debug	Trash type found: "Restmüll"
            trashschedule.0	2021-12-14 20:47:16.763	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v12.22.0, js-controller: 3.3.21
            trashschedule.0	2021-12-14 20:47:16.322	debug	Plugin sentry Initialize Plugin (enabled=true)
            trashschedule.0	2021-12-14 20:47:10.627	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            trashschedule.0	2021-12-14 20:47:10.626	debug	Plugin sentry destroyed
            trashschedule.0	2021-12-14 20:47:10.624	info	terminating
            trashschedule.0	2021-12-14 20:47:10.623	debug	clearing refresh timeout
            trashschedule.0	2021-12-14 20:47:10.622	info	cleaned everything up...
            trashschedule.0	2021-12-14 20:47:10.615	info	Got terminate signal TERMINATE_YOURSELF
              Homoran Global Moderator Administrators @Undead2211 last edited by
              @undead2211 Geht doch 😉
              Hast du das formatiert mit den Zeilenumbrüchen?
              sind da noch Leerzeichen in den Zeilen?
              Wenn du Genauer Treffer abhakst wundert es mich, dass der "einfache" Restmüll nicht auch zu sehen ist, außer...
              von welchem Datum sind dann die *Restmüll 4-Rad"
              💡 Oder hast du im Filterfeld noch ein Leerzeichen?
              Glasfaser 2 Replies Last reply Reply Quote 1
              • Glasfaser
                Glasfaser @Homoran last edited by
                @homoran sagte in Test Adapter TrashSchedule:
                da ist ein Leerzeichen
                Homoran 1 Reply Last reply Reply Quote 2
                  Homoran Global Moderator Administrators @Glasfaser last edited by
                  @glasfaser sagte in Test Adapter TrashSchedule:
                  da haben sich die Posts überschnitten!
                  DANKE!
                  @Undead2211
                  dann dürfte das Problem ja gelöst sein
                  • Glasfaser
                    Glasfaser @Homoran last edited by Glasfaser
                    kann das sein , das daß von Ical kommt , denn Restmüll 4-Rad (Tamm.) hat er nicht gefiltert :
                    EDIT
                    Probehalber ein Leerzeichen in TrashSchedule eintargen !?
                      weil er auf exakten Treffer "Restmüll " filtert und 4-Rad... ist ja noch länger
                        Homoran Global Moderator Administrators @Glasfaser last edited by Homoran
                        Hat er doch - das muss raus!
                        nein, das log sagt, dass der trashschedule mit Leerzeichen parst
                          Minta79 @Glasfaser last edited by
                          @glasfaser Hat sich erledigt. Ich hatte die Tagesvorschau im iCal Adapter nicht groß genug eingestellt.
                            Homoran Global Moderator Administrators @Minta79 last edited by
                            @minta79 sagte in Test Adapter TrashSchedule:
                            ich dachte 90 Tage!?
                            das muss reichen
                            • Glasfaser
                              Der Text sollte dort nicht rein , hatte ein fobidden konnte vorhin nicht löschen 😞
                              • Undead2211
                                Mein ioBroker läuft in einem Dockercontainer und der direkte export hat so leider nicht funktioniert (hat einen neuen Tab auf gemacht und ewig geladen ohne etwas zu machen.
                                Deshalb habe ich den log direkt aus dem Interface kopiert. Ich vermute ich muss da noch was öffnen das das funktioniert?!
                                Wie dem auch sei, ich habe in der Trashkonfiguration weder in der Spalte "Name", noch in der Spalte "Gilt für Termine" ein Leerzeichen. Weder vor noch nach dem Restmüll?!
                                ...ACH DU SCHEIßE...
                                Während ich es schreibe fällt der Groschen... Ich hab es eben im Kalender gecheckt und die Stand hat tatsächlich in den Kalendereinträgen ein Leerzeichen drin! WTF
                                OK Damit kann ich nun umgehen. Vielen Dank für eure Hilfe und das "erörtern" der Herangehensweise zur Fehlerfindung in ioBroker.
                                Hat mir sehr geholfen.
                                Jetzt kann ich mir aussuchen ob ich im Filter ein Leerzeichen einbaue und vermutlich dann im Folgejahr auf die schnauze falle wenn ein anderer Sachbearbeiter den Kalender machen muss, oder ob ich den Kalender in der Hoffnung anpasse, dass die das nächstes Jahr dann richtig machen.
                                Wozu würdet Ihr tendieren?
                                Vielen Dank nochmal
                                • Glasfaser
                                  das muss reichen
                                  Das ist nicht @Undead2211
                                  • Undead2211
                                    Hier nochmal der Beweis, wenn ich ein Leerzeichen am Ende eintrage, findet er es instant.
                                    #DankeStadtverwaltung
                                    Chaot da_Woody 2 Replies Last reply Reply Quote 1
                                      ich geh ins Bett 😞
                                      • Chaot
                                        Chaot @Undead2211 last edited by
                                        @undead2211 sagte in Test Adapter TrashSchedule:
                                        Also alles wie Gewohnt 😲
                                        • da_Woody
                                          da_Woody @Undead2211 last edited by
                                          tja, so spielt das leben... 😉 dachte mir aber schon beim ersten post, (gerade erst gelesen) das deine aussage: Ein Jährliches editieren des städtischen Kalenders kommt für mich eigentlich nicht in Frage da das alles andere als SMART wäre. etwas heftig ist. ioB und die adapter können nur mit dem umgehn, mit was sie gefüttert werden.
                                          da gerade in dem fall viel zusammenspielt, importirter ical, ical-adapter, trashshedule, kanns da schnell eng werden.
                                          hab zufällig auch heute den neuen müll-ical importiert. und durfte, wie jedes jahr, manuell die dezemberdaten löschen. unsere schlauen geben den immer mit dezember dieses jahres - dezember nächsten jahres raus. somit hat man dann im dezember doppelt die termine drinnen. gefällt mir nicht, also muss ich manuell ran. 🙂 hat also mit smart nichts zu tun. sind wir doch froh, das die kalender zum importieren zur verfügung gestellt werden... 🙂
                                          Chaot 1 Reply Last reply Reply Quote 1
                                          • Chaot
                                            Chaot @da_Woody last edited by
                                            @da_woody Na ja, dafür ist der Kalender bei uns so geheim das ich nur maximal 6 Wochen abrufen kann.
                                            Alles ist Möglich im Neuland.
                                            adapter calendar ical kalender müll trash
                                            185
                                            1434
                                            435562
