    4. Alexa Ansagen I Telegram I EMail I Alias I VISU I HTML
    • dslraser
      dslraser Forum Testing Most Active @FuXXz2 last edited by dslraser
      @fuxxz2 sagte in Alexa Ansagen I Telegram I EMail I Alias I VISU I HTML:
      Ich kriege meine Probleme irgendwie nicht in den Griff.
      Hast du eine Idee?
      Sobald ich das Script, in diesem Fall Bewegungsmelder starte, schmiert der komplette Javascript Adapter ab.
      host.iobroker
      2021-12-13 19:14:57.436 error instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      javascript.0
      2021-12-13 19:14:56.827 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
      javascript.0
      2021-12-13 19:14:56.814 error State "0_userdata.0.Geraete_zaehlen.Bewegungsmelder.Haus.03_HTML_Daten.02_HTML_Eigene_Einstellungen.05_Rahmenbreite_Ueberschrift_Bewegungsmelder_Liste" not found
      javascript.0
      2021-12-13 19:14:56.814 error Error: State "0_userdata.0.Geraete_zaehlen.Bewegungsmelder.Haus.03_HTML_Daten.02_HTML_Eigene_Einstellungen.05_Rahmenbreite_Ueberschrift_Bewegungsmelder_Liste" not found at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:83:39) at setStateHelper (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:390:30) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1967:33) at processImmediate (internal/timers.js:463:21)
      javascript.0
      2021-12-13 19:14:56.814 error unhandled promise rejection: State "0_userdata.0.Geraete_zaehlen.Bewegungsmelder.Haus.03_HTML_Daten.02_HTML_Eigene_Einstellungen.05_Rahmenbreite_Ueberschrift_Bewegungsmelder_Liste" not found
      javascript.0
      2021-12-13 19:14:56.813 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      javascript.0
      2021-12-13 19:14:56.812 warn at processImmediate (internal/timers.js:463:21)
      javascript.0
      2021-12-13 19:14:56.812 warn at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1967:33)
      javascript.0
      2021-12-13 19:14:56.810 warn State "0_userdata.0.Geraete_zaehlen.Bewegungsmelder.Haus.03_HTML_Daten.02_HTML_Eigene_Einstellungen.05_Rahmenbreite_Ueberschrift_Bewegungsmelder_Liste" not found
      javascript.0
      2021-12-13 19:14:48.047 error Cannot create directory /opt/iobroker/javabackup: Error: ENOENT: no such file or directory, mkdir ' /opt/iobroker/javabackup'
      host.iobroker
      2021-12-13 19:14:14.532 error instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      javascript.0
      2021-12-13 19:14:13.908 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
      javascript.0
      2021-12-13 19:14:13.885 error State "0_userdata.0.Geraete_zaehlen.Bewegungsmelder.Haus.03_HTML_Daten.02_HTML_Eigene_Einstellungen.06_Rahmenstyle_Ueberschrift_Bewegungsmelder_Liste" not found
      javascript.0
      2021-12-13 19:14:13.885 error Error: State "0_userdata.0.Geraete_zaehlen.Bewegungsmelder.Haus.03_HTML_Daten.02_HTML_Eigene_Einstellungen.06_Rahmenstyle_Ueberschrift_Bewegungsmelder_Liste" not found at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:83:39) at setStateHelper (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:390:30) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1967:33) at processImmediate (internal/timers.js:463:21)
      javascript.0
      2021-12-13 19:14:13.884 error unhandled promise rejection: State "0_userdata.0.Geraete_zaehlen.Bewegungsmelder.Haus.03_HTML_Daten.02_HTML_Eigene_Einstellungen.06_Rahmenstyle_Ueberschrift_Bewegungsmelder_Liste" not found
      javascript.0
      2021-12-13 19:14:13.882 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      javascript.0
      2021-12-13 19:14:13.881 warn at processImmediate (internal/timers.js:463:21)
      javascript.0
      2021-12-13 19:14:13.881 warn at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1967:33)
      javascript.0
      2021-12-13 19:14:13.879 warn State "0_userdata.0.Geraete_zaehlen.Bewegungsmelder.Haus.03_HTML_Daten.02_HTML_Eigene_Einstellungen.06_Rahmenstyle_Ueberschrift_Bewegungsmelder_Liste" not found
      javascript.0
      2021-12-13 19:14:06.107 error Cannot create directory /opt/iobroker/javabackup: Error: ENOENT: no such file or directory, mkdir ' /opt/iobroker/javabackup'
      Er faselt immer was von "not found" aber die Datenpunkte sind alle vorhanden.
      was ist das ? Hast Du mal Deine Einstellungen im Adapter überprüft ?
      Ich meine den letzten Eintrag im Spoiler ganz unten.
        FuXXz2 @dslraser last edited by
        @dslraser
        Die anderen Zeilen sind ja interessant 🙂
        Die Zeile ganz unten war etwas anderes, nur ein Test.
        Sobald ich aber das Script an mache, kommt so oft UNCAUGHT Exception, bis der Adapter aus bleibt.
        Gefolgt von dieser Meldung
        • dslraser
          @fuxxz2
          aber dieser Fehler passiert doch anscheinend zuerst. Vielleicht sind dann die anderen Fehler Folgefehler ?
          • dslraser
            @fuxxz2
            welche Javascript Adapter Version verwendest Du ?
              @dslraser Nicht mehr, ich hatte in den Einstellungen des Java Adapters unter Mirror scripts to file path: etwas eingetragen. Habe ich aber raus genommen und daher kommt der 1. Eintrag nicht mehr.
              Version ist 5.2.13
              Was aber auch noch neu ist, das Alias erstellen Script wirst beim starten Warnungen raus, die vorher nicht gekommen sind. Weiß nicht, ob das was damit zu tun hat.
              javascript.0
              2021-12-14 04:05:35.491 warn Object alias.0.Licht.Esszimmer_Kugel is invalid: obj.common.custom has an invalid type! Expected "object", received "object"
              javascript.0
              2021-12-14 04:05:35.491 warn Object alias.0.Licht.Kueche_Vitrine_unten is invalid: obj.common.custom has an invalid type! Expected "object", received "object"
              javascript.0
              2021-12-14 04:05:35.492 warn Object alias.0.Licht.Wohnzimmer_Leselampe is invalid: obj.common.custom has an invalid type! Expected "object", received "object"
              javascript.0
              2021-12-14 04:05:35.492 warn Object alias.0.Licht.Kueche_Kugel is invalid: obj.common.custom has an invalid type! Expected "object", received "object"
              javascript.0
              2021-12-14 04:05:35.490 warn This object will not be created in future versions. Please report this to the developer.
              javascript.0
              javascript.0
              2021-12-14 04:05:35.491 warn This object will not be created in future versions. Please report this to the developer.
              javascript.0
              javascript.0
              2021-12-14 04:05:35.490 warn Object alias.0.Licht.Kueche_Fenster_unten is invalid: obj.common.custom has an invalid type! Expected "object", received "object"
              javascript.0
              2021-12-14 04:05:35.490 warn Object alias.0.Licht.Kueche_Vitrine_oben is invalid: obj.common.custom has an invalid type! Expected "object", received "object"
              javascript.0
              2021-12-14 04:05:35.489 warn This object will not be created in future versions. Please report this to the developer.
              • dslraser
                Spoiler
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                Das Script nutze ich aktuell nicht. Ich nehme den alias-manager.
                  Danke nochmal für deine Hilfe.
                  Habe jetzt Luftfeuchtigkeit und Batterie Prozent eingepflegt. Da kommt übrigens das gleiche Problem. Habe dann einfach das Script mehrmals gestartet, Pause gemacht und dann ging es irgendwann 🙂
                  Irgendwie spielt hier die Zeit eine Rolle, sehr seltsam 🙂
                  Btw.
                  Im Jarvis sind die Tabellen extrem groß, weiß du woher das kommt? Muss ich da beim Jarvis Forum vorbei schauen oder hast du eine Idee?
                  Die Knöpfe zum einklappen und Theme wechseln klappen in Jarvis nicht oder? Ich glaube du hattest mal erwähnt dass diese nur in iQontrol laufen oder?
                  • dslraser
                    @fuxxz2
                    Die Fehler habe ich beim erstellen der Datenpunkte jetzt übrigens auch. Ich habe noch nicht rausgefunden was da jetzt anders läuft, hat ja lange Zeit so funktioniert.
                    Die Button zum schalten und Themen sind nur für iQontrol.
                    Die Themen umschalten geht aber auch über die Datenpunkte. Die Größe der Tabelle müsstest Du dann in den Datenpunkten bei den eigenen html anpassen.
                    • dslraser
                      EDIT:
                      @fuxxz2
                      Ich bin jetzt beim Javascript Adapter in mehreren Schritten rückwärts bis zur (5.2.8) zurück, da kommen dann keine Fehlermeldungen und alles läuft wie es soll.
                      Alle Versionen danach bringen bei mir diesen Fehler, selbst die stable 5.2.13
                      Kannst ja auch mal testen ob es dann bei Dir auch wieder funktioniert wie es soll.
                      EDIT: mit der 5.2.18 funktioniert es bei mir wieder
                        Mit der 5.2.18 hatte ich den Fehler gerade auch. Aber nach nem neu Start des iobrokers geht es dann meistens.
                        Habe mal ne Frage zum Batterie Script. Einige Geräte haben ja einen Datenpunkt für Battery in % und andere einen für voltage in V.
                        Wieder andere Geräte haben beide Datenpunkte.
                        wie löst man das am besten? Mit den beiden Scripten habe ich ja 2 Listen mit doppelten Geräten, mit Volt und %
                        Am besten wäre, wenn man eine Liste hat mit allen Geräten und bei denen, die entsprechende Datenpunkte haben steht dann Batterie 100% / 3.0Volt.
                        Geht sowas?
                        dslraser 3 Replies Last reply Reply Quote 0
                        • dslraser
                          @fuxxz2
                          geht bestimmt, aber nicht mit dem Blockly, das wäre ein größerer Umbau.
                          Die aktualle Javascript Adapter Version habe ich eben bestimmt 20 Mal getestet, DP erstellt und löschen lassen usw. , bei mir kam kein Fehler, aber es könnte trotzdem hiermit zu tun haben
                          https://github.com/ioBroker/ioBroker.javascript/issues/924
                          Acgua created this issue in ioBroker/ioBroker.javascript
                          closed createState()/createStateAsync() issue, if 2nd param = initial value, and 3rd param = common obj #924
                          • dslraser
                            jetzt habe ich es noch x mal probiert, nun habe ich den Fehler doch manchmal wieder....sehr seltsam.
                            • dslraser
                              @fuxxz2
                              Hi, wie besprochen hier mal eine Version zum Testen. Da habe ich den aktuellen Fehler (beim Datenpunkte erstellen) mit einem Workaround behoben.
                              Über Feedback, ob das bei Dir Funktioniert würde ich mich freuen.
                              Steckdosen_1_8_0.zip
                                @dslraser Bisher kein Fehler.
                                Ich setze aber gerade einen Test-Iobroker neu auf, dort teste ich es gleich bzw. morgen auch nochmal
                                Btw.
                                Kann man irgendwie die Eigenen Einstellungen HTML sichern? Das ist immer viel Arbeit die für alle Ansichten manuell einzutragen. Durch "debuggen" musste ich aber hin un wieder mal die Scripts auf false setzen und dann wird immer alles gelöscht.
                                Habe schon den Objektbaum exportiert und importiert, aber er übernimmt leider keine Werte.
                                • dslraser
                                  @fuxxz2
                                  ich habe gerade noch einen Fehler gefunden...Ich bin gerade auf der Suche danach.
                                  • dslraser
                                    @fuxxz2
                                    In der Version 1.8.1 gibt es eine wichtige Änderung zu vorher.
                                    Diese Datenpunkte werden bei jedem Blockly Start gelöscht und neu erstellt, damit die dann je nach Einstellung im Blockly (also was Alexa an geht) richtig erstellt werden, also mit oder ohne SmartNamen. Aktuell war es so, das falls Alexa_Ansage_verwendenbeim ersten Blockly Start auf wahr stand, SmartNamen angelegt wurden, stand es auf false, dann wurden keine SmartNamen erstellt. Wenn denn mal alle Datenpunkte erstellt waren und nur die Alexa Option umgestellt wurde, dann wurde an den Datenpunkten nichts mehr verändert bzw. nichts überschrieben, weil die ja schon existierten.
                                    Diese Datenpunkte sind gemeint:
                                    Alle anderen Datenpunkte werden beim Blockly Start nicht gelöscht und neu erstellt, nur wenn Steckdosen_verwendenauf falsch gestellt wird, dann werden alle zuvor durch das Blockly erstellten Datenpunkte gelöscht.
                                    • dslraser
                                      Btw.
                                      Du könntest für Dich die eigenen HTML Einstellungen permanent ändern. (ich nutze eigentlich nur das dunkle Thema)
                                      Zur Erklärung:
                                      Wenn das Blockly die Datenpunkte zum ersten mal erstellt (oder nach dem löschen neu erstellt), dann sind die eigenen HTML Einstellungen in der Grundeinstellung leer. Das ist so von mir gewollt, da man über den Button/Symbol den man in iQontrol mit dem linken Symbol klicken kann, oder auch in den Objekten drücken kann) die HTML Themen durchklicken kann.
                                      In den Objekten der Button 06_Trigger_Farbe_iQontrol_Steckdosen_Liste
                                      Wenn dann keine Werte in den eigenen HTML Einstellungen drinn wären, dann kommen Fehler im Blockly und in iQontrol gibt es gar keine Anzeige mehr, auch nichts mehr was man anklicken könnte. Also habe ich es so gemacht, das, wenn da keine Werte eingetragen wurden, erstmal "Grundwerte" eingetragen werden, die man später auch verändern kann und dann nicht mehr beim Blockly Neustart überschrieben werden sollen. So kann man auch besser sehen, was da überhaupt für Werte rein müßten.
                                      Wenn Du diese eigenen Grundwerte auf Deine Vorstellungen verändern willst, dann kannst Du im Blockly mal die Funktion main aufklappen, da gibt es einen Baustein mit sehr vielen Triggern. Da kannst Du die Werte reinschreiben die Du gern haben möchtest. Also hier alles aufklappen und Deine Werte eintragen. Du kannst Dir diesen gesamten Triggerbaustein samt Inhalt auch exportieren. Einfach den Trigger anklicken, so das der einen gelben Rand hat, danach auf exportieren klicken, dann hast Du nur diesen Baustein samt Inhalt exportiert. Später könntest Du den original Baustein samt Inhalt löschen und Deinen exportierten Baustein wieder importieren und an dieser Stelle wieder einfügen. Aktuell habe ich aber nicht vor am Blockly an dieser Stelle etwas zu ändern, von der her sollte es reichen die Grundwerte an dieser Stelle für Dich zu ändern.
                                        Das klingt erstmal nach einem Hilftmittel, ich versuche es mal. Danke für die Infos
                                        • dslraser
                                          Ich habe alle Versionen auf 1.8.1 abgeändert.
                                            dittmar last edited by dittmar
                                            Hallo @dslraser,
                                            ich habe heute versucht das Fenster-Abfrage Script umzusetzen bei mir (habe aber das 1.6.7 verwendet)
                                            Aber irgendetwas habe ich bei den Alias falsch gemacht.
                                            Ich habe meine angelegten Aliase über das Menü Geräte angelegt und verknüpft mit den entsprechenden Datenpunkten.
                                            Aber alle Aliase erscheinen als Ordner, und er Zustand davon als "ACTUAL". Somit scheint die Zählen Funktion bei mir nicht richtig zu funktionieren...
                                            kannst du dir evtl. denken was bei mir schief gelaufen ist? und kann ich das beheben?
                                            Danke für deine Hilfe!
                                            alexa ansage blockly fenster iqontrol jarvis javascript tür-fenster-kontakt
                                            40
                                            524
                                            114315
