Test Alpha Homekit-Controller 0.0.x
Muss noch irgendetwas anderes auf dem PI installiert werden?pi@IoBroker:~ $ rfkill ID TYPE DEVICE SOFT HARD 0 wlan phy0 unblocked unblocked 1 bluetooth hci0 unblocked unblocked pi@IoBroker:~ $ -
@fortune95 Nein, eigentlich nicht.
Ich wollte nur sehen, ob da vielleicht ein Block reinspringt.Das System ist aber auf Stand?
sudo apt update -
Es waren 5 Aktualisierungen verfügbar aber nichts was auf bluetooth verweist.
pi@IoBroker:~ $ sudo systemctl status bluetooth.service ● bluetooth.service - Bluetooth service Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled) Active: active (running) since Sat 2021-12-11 11:04:09 CET; 5 days ago Docs: man:bluetoothd(8) Main PID: 13358 (bluetoothd) Status: "Running" Tasks: 1 (limit: 8986) CPU: 226ms CGroup: /system.slice/bluetooth.service └─13358 /usr/libexec/bluetooth/bluetoothd --noplugin=sap Dez 16 05:58:47 IoBroker bluetoothd[13358]: Endpoint registered: sender=:1.162 path=/MediaEndpoint/A2DPSink/sbc Dez 16 05:58:47 IoBroker bluetoothd[13358]: Endpoint registered: sender=:1.162 path=/MediaEndpoint/A2DPSource/sbc Dez 16 06:29:08 IoBroker bluetoothd[13358]: Endpoint unregistered: sender=:1.162 path=/MediaEndpoint/A2DPSink/sbc Dez 16 06:29:08 IoBroker bluetoothd[13358]: Endpoint unregistered: sender=:1.162 path=/MediaEndpoint/A2DPSource/sbc Dez 16 06:33:34 IoBroker bluetoothd[13358]: Endpoint registered: sender=:1.185 path=/MediaEndpoint/A2DPSink/sbc Dez 16 06:33:34 IoBroker bluetoothd[13358]: Endpoint registered: sender=:1.185 path=/MediaEndpoint/A2DPSource/sbc Dez 16 06:33:43 IoBroker bluetoothd[13358]: Endpoint unregistered: sender=:1.185 path=/MediaEndpoint/A2DPSink/sbc Dez 16 06:33:43 IoBroker bluetoothd[13358]: Endpoint unregistered: sender=:1.185 path=/MediaEndpoint/A2DPSource/sbc Dez 16 17:21:17 IoBroker bluetoothd[13358]: Endpoint registered: sender=:1.212 path=/MediaEndpoint/A2DPSink/sbc Dez 16 17:21:17 IoBroker bluetoothd[13358]: Endpoint registered: sender=:1.212 path=/MediaEndpoint/A2DPSource/sbc -
Hab mal in der shell einen Scan gemacht und der Eve Degree hat schon wieder eine neue MAC / ID ohne das ich ihn resettet hatte:
pi@IoBroker:~ $ bluetoothctl Agent registered [CHG] Controller DC:A6:32:C5:C7:A3 Pairable: yes [bluetooth]# scan on Discovery started [CHG] Controller DC:A6:32:C5:C7:A3 Discovering: yes [NEW] Device 42:44:5A:66:3A:E8 42-44-5A-66-3A-E8 [NEW] Device 7E:3F:40:40:12:A6 7E-3F-40-40-12-A6 [NEW] Device 44:82:C0:5F:44:BD 44-82-C0-5F-44-BD [NEW] Device 42:88:76:5F:D3:01 42-88-76-5F-D3-01 [NEW] Device 61:EE:B0:2B:D6:3F 61-EE-B0-2B-D6-3F [NEW] Device 08:7F:14:63:58:14 08-7F-14-63-58-14 [CHG] Device 44:82:C0:5F:44:BD RSSI: -61 [NEW] Device 61:DB:6A:65:19:41 61-DB-6A-65-19-41 [CHG] Device 42:44:5A:66:3A:E8 RSSI: -45 [NEW] Device D9:58:61:08:E7:D9 Eve Degree 053B [CHG] Device 42:44:5A:66:3A:E8 RSSI: -55 [CHG] Device 42:44:5A:66:3A:E8 RSSI: -47 [NEW] Device ED:FA:08:0F:72:FD Eve Room 632D -
@fortune95 Und wird bestimmt wenn du adapter startest wieder als "ready topair/unpaired" berichtet oder? Das ist das was ich nicht kapiere ...
Habe den PI runtergefahren und einmal vom Strom genommen und wieder gestartet, aber es tut sich weiterhin nix...
Er zeigt nur den Room als pairbar an, welcher auch noch wirklich nicht gepaired wurden ist.
@fortune95
Liegt es evtl. an bullseye? -
Um einzugrenzen ob der BLE Controller funktioniert, habe ich mir einen Eve Energy organisiert...
und den bekomme ich auch gepaired.
Einiges wurde leider Aufgrund der Datenflut in der Shell beim debuggen überschrieben.
@fortune95 Der Energy sieht so aus wie meiner ... da ist alles ok ...
Also von daher wäre ich grad dabei das irgendwas mit dem Device "matchig" ist ... wenns für das "Room"-Teil aber mit Apple Home geht zu pairen und alles da ist und auch stabil dann habe ich aktuell ehrlich keine Idee mehr
Ein zweites solches Room" hast Du nicht per Zufall?
@apollon77
Room leider nicht da habe ich nur den einen, Degree wäre kein Problem. Room müsste ich sonst noch einen kaufen. -
@fortune95 ääähhmm nee warte mal ... war doch ein Degree der spinnt oder? Wäre die Frage ob ein andere auch spinnt ...
@apollon77
die machen beide die gleichen Probleme...
Über den Extend laufen sie alle... prinzipiell. Beim Degree fehlt beispielsweise nur der Luftdruck.
Einen Thermo hab ich auch noch im Einsatz, den müsste ich mal über BLE testen.
Schön wäre es wenn sie über beide Schnittstellen gehen würden, einige stehen ja in ausreichender Reichweite.
Den Degree könnte ich sofort eintüten...
@fortune95 Ich kann jetzt nur mal den Eve support anschreiben und schauen ob die irgendwas sagen - wenn ich da jemanden kriege der kompetent antworten kann
@apollon77
Wie gesagt das Angebot steht!
Bin begeistert wie ihr die Dinge supported und immer wieder weiterentwickelt!
DANKE! -
@fortune95 Ahh du meintest mir zuschicken ... jetzt hab ichs kapiert
ich schreib dir ne PN ...können wir versuchen -
Hat jemand schon ein Nuki Smart Lock mit dem Adapter genutzt? Scheinbar findet der Adapter das Gerät nicht, obwohl es einen Sticker mit Homekit QR und PIN hat.
@strathcole auch hier wie oben gesagt mal debug log aktivieren. Dann siehst du genau was er findet. Und bei wlan bedenke gleiches Netzwerk wegen UDP bzw bei BLE die Entfernung.
@apollon77 Ja, das ist ja das Komische daran. WLan ist dasselbe, Bluetooth-Entfernung < 3 Meter. Er findet das Gerät gar nicht. Nur ein Gardena Gateway und Tahoma Box.
Gibt es irgendwie die Möglichkeit, eine Geräte-IP manuell anzugeben? -
@strathcole ne reicht nicht weil in der UDP Message wichtige Infos stehen wenn’s um das pairing und so geht. Ohne die ist pairing nur bedingt möglich. Udp muss gehen. Muss man es vllt manuell irgendwie einschalten?
