    4. Backitup Fehler Synology NAS
    • Xnetworker X
      Xnetworker X last edited by
      Re: Backitup Fehler bei NAS Nutzung
      Systemdata
      Hardwaresystem: PI4
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Mac
      Nodejs-Version: 14.18.2
      NPM-Version: 6.14.15
      Link Re: Backitup Fehler bei NAS Nutzung
      Eine Verbindung zum NAS ist nicht möglich. Backups werden aber lokal auf dem Raspberry erstellt und gespeichert. Rechtevergabe und Ordner auf NAS habe ich mehrmals geprüft. Es klappt weder mit CIFS, noch mit NFS. Wärend der Ausführung zeigt es mir folgende Log-Daten an:
      Started iobroker ...
      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.1.5","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/volume1/backup","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****"}
      [DEBUG] [mount] - noserverino option: false
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.1.5/volume1/backup /opt/iobroker/backups"
      [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.1.5/volume1/backup /opt/iobroker/backups"
      [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.1.5/volume1/backup /opt/iobroker/backups
      mount error(2): No such file or directory
      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
      [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.1.5/volume1/backup /opt/iobroker/backups
      [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.1.5","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/volume1/backup","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.1.5/volume1/backup /opt/iobroker/backups\nmount error(2): No such file or directory\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)\n"},"done":[],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [iobroker] - host.raspberrypi 12059 states saved
      [DEBUG] [iobroker] - host.raspberrypi 13823 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_12_18-12_09_40_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [cifs] - done
      [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.1.5","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/volume1/backup","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0}
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [historyHTML] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.1.5","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/volume1/backup","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_12_18-12_09_40_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.1.5/volume1/backup /opt/iobroker/backups\nmount error(2): No such file or directory\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"18. Dezember 2021 um 12:09 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [historyJSON] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.1.5","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/volume1/backup","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_12_18-12_09_40_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.1.5/volume1/backup /opt/iobroker/backups\nmount error(2): No such file or directory\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"18. Dezember 2021 um 12:09 Uhr"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.1.5","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/volume1/backup","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
        Thomas Braun Most Active @Xnetworker X last edited by
        @xnetworker-x
        Prüf mal den Pfad der Freigabe. Da scheint was nicht zu passen.
        Xnetworker X 1 Reply Last reply Reply Quote 0
        • Xnetworker X
          Xnetworker X @Thomas Braun last edited by
          Das habe ich mehrfach geprüft und finde keinen Fehler.
          Bildschirmfoto 2021-12-18 um 12.49.51.png Bildschirmfoto 2021-12-18 um 12.50.03.png
          Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
          • Glasfaser
            Glasfaser @Xnetworker X last edited by Glasfaser
            @xnetworker-x
            nur so , ohne Volume
            /backup
              @xnetworker-x Der Pfad ist auch nicht vollständig/zu kurz. Du gibst ja volume1/backups/iobroker frei.
              • Xnetworker X
                Xnetworker X @Glasfaser last edited by
                @glasfaser
                Das war der Fehler. Danke
