    4. js-controller 3.3 jetzt im STABLE!
      sandro_gera @apollon77 last edited by sandro_gera
      @apollon77
      Hallo, irgendwie scheint es da ein Problem zu geben.
      Ich bekomme folgende Fehlermeldung
      pi@RaspBee-II-Phoscon:~ $ iob update
      Used repository: Stable (default)
      hash changed or no sources cached => force download of new sources
      Cannot download json from http://download.iobroker.net/sources-dist.json. Error:                      Error: ESOCKETTIMEDOUT
      failed to download new sources, use cached sources
      update done
      Adapter    "deconz"        : 1.3.19   , installed 1.3.19
      Adapter    "hue-extended"  : 2.0.0    , installed 2.0.0
      Controller "js-controller" : 3.3.21   , installed 3.3.18 [Updateable]
      Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
      pi@RaspBee-II-Phoscon:~ $ iob upgrade self
      Update js-controller from @3.3.18 to @3.3.21
      NPM version: 6.14.15
      npm install iobroker.js-controller@3.3.21 --loglevel error --unsafe-perm --prefi                     x "/opt/iobroker" (System call)
      Jetzt schint es funktioniert zu haben
      update done
      Controller "js-controller" : 3.3.21   , installed 3.3.21
      Host    "RaspBee-II-Phoscon" is up to date.
      pi@RaspBee-II-Phoscon:~ $ sudo reboot
        @apollon77
        Also die updates haben beide funktioniert. js controller und Node js sind jetzt aktuell.
        Leider hat das nichts an der Fehlermeldung geändert.
        pi@RaspBee-II-Phoscon:~ $ iob stop
        pi@RaspBee-II-Phoscon:~ $ iob backup
        host.RaspBee-II-Phoscon 6917 states saved
        host.RaspBee-II-Phoscon 8384 objects saved
        <--- Last few GCs --->
        [2241:0x4f8baf8]    19578 ms: Mark-sweep (reduce) 230.4 (235.4) -> 230.4 (235.4)                                 MB, 126.4 / 0.0 ms  (average mu = 0.594, current mu = 0.001) last resort GC in                                 old space requested
        [2241:0x4f8baf8]    19676 ms: Mark-sweep (reduce) 230.4 (233.4) -> 230.4 (233.4)                                 MB, 97.8 / 0.0 ms  (average mu = 0.443, current mu = 0.001) last resort GC in o                                ld space requested
        <--- JS stacktrace --->
        FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memo                                ry
        /usr/bin/iob: Zeile 8:  2240 Abgebrochen             sudo -H -u iobroker node /o                                pt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
          Thomas Braun Most Active @sandro_gera last edited by
          @sandro_gera
          Zeig mal ein
          dmesg -T
          auf der betroffenen Maschine.
            sandro_gera @Thomas Braun last edited by
            @thomas-braun said in js-controller 3.3 jetzt im STABLE!:
            dmesg -T
            pi@RaspBee-II-Phoscon:~ $ dmesg -T
            [Do Dez  9 15:55:57 2021] Booting Linux on physical CPU 0x0
            [Do Dez  9 15:55:57 2021] Linux version 5.10.63-v7+ (dom@buildbot) (arm-linux-gn                                                ueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubu                                                ntu) 2.34) #1496 SMP Wed Dec 1 15:58:11 GMT 2021
            [Do Dez  9 15:55:57 2021] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr                                                =10c5383d
            [Do Dez  9 15:55:57 2021] CPU: div instructions available: patching division cod                                                e
            [Do Dez  9 15:55:57 2021] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing                                                 instruction cache
            [Do Dez  9 15:55:57 2021] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
            [Do Dez  9 15:55:57 2021] random: fast init done
            [Do Dez  9 15:55:57 2021] Memory policy: Data cache writealloc
            [Do Dez  9 15:55:57 2021] Reserved memory: created CMA memory pool at 0x37400000                                                , size 64 MiB
            [Do Dez  9 15:55:57 2021] OF: reserved mem: initialized node linux,cma, compatib                                                le id shared-dma-pool
            [Do Dez  9 15:55:57 2021] Zone ranges:
            [Do Dez  9 15:55:57 2021]   DMA      [mem 0x0000000000000000-0x000000003b3fffff]
            [Do Dez  9 15:55:57 2021]   Normal   empty
            [Do Dez  9 15:55:57 2021] Movable zone start for each node
            [Do Dez  9 15:55:57 2021] Early memory node ranges
            [Do Dez  9 15:55:57 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff                                                ]
            [Do Dez  9 15:55:57 2021] Initmem setup node 0 [mem 0x0000000000000000-0x0000000                                                03b3fffff]
            [Do Dez  9 15:55:57 2021] On node 0 totalpages: 242688
            [Do Dez  9 15:55:57 2021]   DMA zone: 2133 pages used for memmap
            [Do Dez  9 15:55:57 2021]   DMA zone: 0 pages reserved
            [Do Dez  9 15:55:57 2021]   DMA zone: 242688 pages, LIFO batch:63
            [Do Dez  9 15:55:57 2021] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u819                                                20
            [Do Dez  9 15:55:57 2021] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
            [Do Dez  9 15:55:57 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
            [Do Dez  9 15:55:57 2021] Built 1 zonelists, mobility grouping on.  Total pages:                                                 240555
            [Do Dez  9 15:55:57 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1                                                 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=65                                                6 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.                                                mem_size=0x40000000  console=tty1 root=PARTUUID=c089f643-02 rootfstype=ext4 elev                                                ator=deadline fsck.repair=yes rootwait
            [Do Dez  9 15:55:57 2021] Kernel parameter elevator= does not have any effect an                                                ymore.
                                      Please use sysfs to set IO scheduler for individual de                                                vices.
            [Do Dez  9 15:55:57 2021] Dentry cache hash table entries: 131072 (order: 7, 524                                                288 bytes, linear)
            [Do Dez  9 15:55:57 2021] Inode-cache hash table entries: 65536 (order: 6, 26214                                                4 bytes, linear)
            [Do Dez  9 15:55:57 2021] mem auto-init: stack:off, heap alloc:off, heap free:of                                                f
            [Do Dez  9 15:55:57 2021] Memory: 878808K/970752K available (10240K kernel code,                                                 1311K rwdata, 2948K rodata, 1024K init, 859K bss, 26408K reserved, 65536K cma-r                                                eserved)
            [Do Dez  9 15:55:57 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nod                                                es=1
            [Do Dez  9 15:55:57 2021] ftrace: allocating 32054 entries in 63 pages
            [Do Dez  9 15:55:57 2021] ftrace: allocated 63 pages with 6 groups
            [Do Dez  9 15:55:57 2021] rcu: Hierarchical RCU implementation.
            [Do Dez  9 15:55:57 2021]       Rude variant of Tasks RCU enabled.
            [Do Dez  9 15:55:57 2021]       Tracing variant of Tasks RCU enabled.
            [Do Dez  9 15:55:57 2021] rcu: RCU calculated value of scheduler-enlistment dela                                                y is 10 jiffies.
            [Do Dez  9 15:55:57 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
            [Do Dez  9 15:55:57 2021] random: get_random_bytes called from start_kernel+0x3a                                                c/0x580 with crng_init=1
            [Do Dez  9 15:55:57 2021] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
            [Do Dez  9 15:55:57 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff                                                 max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
            [Do Dez  9 15:55:57 2021] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps                                                 every 4398046511078ns
            [Do Dez  9 15:55:57 2021] Switching to timer-based delay loop, resolution 52ns
            [Do Dez  9 15:55:57 2021] Console: colour dummy device 80x30
            [Do Dez  9 15:55:57 2021] printk: console [tty1] enabled
            [Do Dez  9 15:55:57 2021] Calibrating delay loop (skipped), value calculated usi                                                ng timer frequency.. 38.40 BogoMIPS (lpj=192000)
            [Do Dez  9 15:55:57 2021] pid_max: default: 32768 minimum: 301
            [Do Dez  9 15:55:57 2021] LSM: Security Framework initializing
            [Do Dez  9 15:55:57 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 b                                                ytes, linear)
            [Do Dez  9 15:55:57 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8                                                192 bytes, linear)
            [Do Dez  9 15:55:57 2021] cgroup: Disabling memory control group subsystem
            [Do Dez  9 15:55:57 2021] CPU: Testing write buffer coherency: ok
            [Do Dez  9 15:55:57 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
            [Do Dez  9 15:55:57 2021] Setting up static identity map for 0x100000 - 0x10003c
            [Do Dez  9 15:55:57 2021] rcu: Hierarchical SRCU implementation.
            [Do Dez  9 15:55:57 2021] smp: Bringing up secondary CPUs ...
            [Do Dez  9 15:55:57 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
            [Do Dez  9 15:55:57 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
            [Do Dez  9 15:55:57 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
            [Do Dez  9 15:55:57 2021] smp: Brought up 1 node, 4 CPUs
            [Do Dez  9 15:55:57 2021] SMP: Total of 4 processors activated (153.60 BogoMIPS)                                                .
            [Do Dez  9 15:55:57 2021] CPU: All CPU(s) started in HYP mode.
            [Do Dez  9 15:55:57 2021] CPU: Virtualization extensions available.
            [Do Dez  9 15:55:57 2021] devtmpfs: initialized
            [Do Dez  9 15:55:57 2021] VFP support v0.3: implementor 41 architecture 3 part 4                                                0 variant 3 rev 4
            [Do Dez  9 15:55:57 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xf                                                fffffff, max_idle_ns: 19112604462750000 ns
            [Do Dez  9 15:55:57 2021] futex hash table entries: 1024 (order: 4, 65536 bytes,                                                 linear)
            [Do Dez  9 15:55:57 2021] pinctrl core: initialized pinctrl subsystem
            [Do Dez  9 15:55:57 2021] NET: Registered protocol family 16
            [Do Dez  9 15:55:57 2021] DMA: preallocated 1024 KiB pool for atomic coherent al                                                locations
            [Do Dez  9 15:55:57 2021] audit: initializing netlink subsys (disabled)
            [Do Dez  9 15:55:57 2021] thermal_sys: Registered thermal governor 'step_wise'
            [Do Dez  9 15:55:57 2021] audit: type=2000 audit(0.040:1): state=initialized aud                                                it_enabled=0 res=1
            [Do Dez  9 15:55:57 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4                                                 watchpoint registers.
            [Do Dez  9 15:55:57 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
            [Do Dez  9 15:55:57 2021] Serial: AMBA PL011 UART driver
            [Do Dez  9 15:55:57 2021] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
            [Do Dez  9 15:55:57 2021] raspberrypi-firmware soc:firmware: Attached to firmwar                                                e from 2021-12-01T15:07:06, variant start
            [Do Dez  9 15:55:57 2021] raspberrypi-firmware soc:firmware: Firmware hash is 71                                                bd3109023a0c8575585ba87cbb374d2eeb038f
            [Do Dez  9 15:55:57 2021] Kprobes globally optimized
            [Do Dez  9 15:55:57 2021] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmac                                                hans=0x1
            [Do Dez  9 15:55:57 2021] SCSI subsystem initialized
            [Do Dez  9 15:55:57 2021] usbcore: registered new interface driver usbfs
            [Do Dez  9 15:55:57 2021] usbcore: registered new interface driver hub
            [Do Dez  9 15:55:57 2021] usbcore: registered new device driver usb
            [Do Dez  9 15:55:57 2021] clocksource: Switched to clocksource arch_sys_counter
            [Do Dez  9 15:55:58 2021] VFS: Disk quotas dquot_6.6.0
            [Do Dez  9 15:55:58 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 40                                                96 bytes)
            [Do Dez  9 15:55:58 2021] FS-Cache: Loaded
            [Do Dez  9 15:55:58 2021] CacheFiles: Loaded
            [Do Dez  9 15:55:58 2021] NET: Registered protocol family 2
            [Do Dez  9 15:55:58 2021] IP idents hash table entries: 16384 (order: 5, 131072                                                 bytes, linear)
            [Do Dez  9 15:55:58 2021] tcp_listen_portaddr_hash hash table entries: 512 (orde                                                r: 0, 6144 bytes, linear)
            [Do Dez  9 15:55:58 2021] TCP established hash table entries: 8192 (order: 3, 32                                                768 bytes, linear)
            [Do Dez  9 15:55:58 2021] TCP bind hash table entries: 8192 (order: 4, 65536 byt                                                es, linear)
            [Do Dez  9 15:55:58 2021] TCP: Hash tables configured (established 8192 bind 819                                                2)
            [Do Dez  9 15:55:58 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, li                                                near)
            [Do Dez  9 15:55:58 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 byte                                                s, linear)
            [Do Dez  9 15:55:58 2021] NET: Registered protocol family 1
            [Do Dez  9 15:55:58 2021] RPC: Registered named UNIX socket transport module.
            [Do Dez  9 15:55:58 2021] RPC: Registered udp transport module.
            [Do Dez  9 15:55:58 2021] RPC: Registered tcp transport module.
            [Do Dez  9 15:55:58 2021] RPC: Registered tcp NFSv4.1 backchannel transport modu                                                le.
            [Do Dez  9 15:55:58 2021] hw perfevents: enabled with armv7_cortex_a7 PMU driver                                                , 7 counters available
            [Do Dez  9 15:55:58 2021] Initialise system trusted keyrings
            [Do Dez  9 15:55:58 2021] workingset: timestamp_bits=14 max_order=18 bucket_orde                                                r=4
            [Do Dez  9 15:55:58 2021] zbud: loaded
            [Do Dez  9 15:55:58 2021] FS-Cache: Netfs 'nfs' registered for caching
            [Do Dez  9 15:55:58 2021] NFS: Registering the id_resolver key type
            [Do Dez  9 15:55:58 2021] Key type id_resolver registered
            [Do Dez  9 15:55:58 2021] Key type id_legacy registered
            [Do Dez  9 15:55:58 2021] nfs4filelayout_init: NFSv4 File Layout Driver Register                                                ing...
            [Do Dez  9 15:55:58 2021] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver                                                 Registering...
            [Do Dez  9 15:55:58 2021] Key type asymmetric registered
            [Do Dez  9 15:55:58 2021] Asymmetric key parser 'x509' registered
            [Do Dez  9 15:55:58 2021] Block layer SCSI generic (bsg) driver version 0.4 load                                                ed (major 249)
            [Do Dez  9 15:55:58 2021] io scheduler mq-deadline registered
            [Do Dez  9 15:55:58 2021] io scheduler kyber registered
            [Do Dez  9 15:55:58 2021] bcm2708_fb soc:fb: FB found 1 display(s)
            [Do Dez  9 15:55:58 2021] Console: switching to colour frame buffer device 82x26
            [Do Dez  9 15:55:58 2021] bcm2708_fb soc:fb: Registered framebuffer for display                                                 0, size 656x416
            [Do Dez  9 15:55:58 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enable                                                d
            [Do Dez  9 15:55:58 2021] bcm2835-aux-uart 3f215040.serial: there is not valid m                                                aps for state default
            [Do Dez  9 15:55:58 2021] bcm2835-rng 3f104000.rng: hwrng registered
            [Do Dez  9 15:55:58 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_s                                                ize:0x40000000(1024 MiB)
            [Do Dez  9 15:55:59 2021] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registe                                                rs at 0x3f200000
            [Do Dez  9 15:55:59 2021] brd: module loaded
            [Do Dez  9 15:55:59 2021] loop: module loaded
            [Do Dez  9 15:55:59 2021] Loading iSCSI transport class v2.0-870.
            [Do Dez  9 15:55:59 2021] libphy: Fixed MDIO Bus: probed
            [Do Dez  9 15:55:59 2021] usbcore: registered new interface driver lan78xx
            [Do Dez  9 15:55:59 2021] usbcore: registered new interface driver smsc95xx
            [Do Dez  9 15:55:59 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
            [Do Dez  9 15:55:59 2021] Core Release: 2.80a
            [Do Dez  9 15:55:59 2021] Setting default values for core params
            [Do Dez  9 15:55:59 2021] Finished setting default values for core params
            [Do Dez  9 15:55:59 2021] Using Buffer DMA mode
            [Do Dez  9 15:55:59 2021] Periodic Transfer Interrupt Enhancement - disabled
            [Do Dez  9 15:55:59 2021] Multiprocessor Interrupt Enhancement - disabled
            [Do Dez  9 15:55:59 2021] OTG VER PARAM: 0, OTG VER FLAG: 0
            [Do Dez  9 15:56:00 2021] Dedicated Tx FIFOs mode
            [Do Dez  9 15:56:00 2021] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: v                                                irt = b7504000 dma = 0xf7504000 len=9024
            [Do Dez  9 15:56:00 2021] FIQ FSM acceleration enabled for :
                                      Non-periodic Split Transactions
                                      Periodic Split Transactions
                                      High-Speed Isochronous Endpoints
                                      Interrupt/Control Split Transaction hack enabled
            [Do Dez  9 15:56:00 2021] dwc_otg: Microframe scheduler enabled
            [Do Dez  9 15:56:00 2021] WARN::hcd_init_fiq:457: FIQ on core 1
            [Do Dez  9 15:56:00 2021] WARN::hcd_init_fiq:458: FIQ ASM at 807c9984 length 36
            [Do Dez  9 15:56:00 2021] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
            [Do Dez  9 15:56:00 2021] dwc_otg 3f980000.usb: DWC OTG Controller
            [Do Dez  9 15:56:00 2021] dwc_otg 3f980000.usb: new USB bus registered, assigned                                                 bus number 1
            [Do Dez  9 15:56:00 2021] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
            [Do Dez  9 15:56:00 2021] Init: Port Power? op_state=1
            [Do Dez  9 15:56:00 2021] Init: Power Port (0)
            [Do Dez  9 15:56:00 2021] usb usb1: New USB device found, idVendor=1d6b, idProdu                                                ct=0002, bcdDevice= 5.10
            [Do Dez  9 15:56:00 2021] usb usb1: New USB device strings: Mfr=3, Product=2, Se                                                rialNumber=1
            [Do Dez  9 15:56:00 2021] usb usb1: Product: DWC OTG Controller
            [Do Dez  9 15:56:00 2021] usb usb1: Manufacturer: Linux 5.10.63-v7+ dwc_otg_hcd
            [Do Dez  9 15:56:00 2021] usb usb1: SerialNumber: 3f980000.usb
            [Do Dez  9 15:56:00 2021] hub 1-0:1.0: USB hub found
            [Do Dez  9 15:56:00 2021] hub 1-0:1.0: 1 port detected
            [Do Dez  9 15:56:00 2021] dwc_otg: FIQ enabled
            [Do Dez  9 15:56:00 2021] dwc_otg: NAK holdoff enabled
            [Do Dez  9 15:56:00 2021] dwc_otg: FIQ split-transaction FSM enabled
            [Do Dez  9 15:56:00 2021] Module dwc_common_port init
            [Do Dez  9 15:56:00 2021] usbcore: registered new interface driver usb-storage
            [Do Dez  9 15:56:00 2021] mousedev: PS/2 mouse device common for all mice
            [Do Dez  9 15:56:00 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog tim                                                er
            [Do Dez  9 15:56:00 2021] sdhci: Secure Digital Host Controller Interface driver
            [Do Dez  9 15:56:00 2021] sdhci: Copyright(c) Pierre Ossman
            [Do Dez  9 15:56:00 2021] sdhost-bcm2835 3f202000.mmc: could not get clk, deferr                                                ing probe
            [Do Dez  9 15:56:00 2021] sdhci-pltfm: SDHCI platform and OF driver helper
            [Do Dez  9 15:56:00 2021] ledtrig-cpu: registered to indicate activity on CPUs
            [Do Dez  9 15:56:00 2021] hid: raw HID events driver (C) Jiri Kosina
            [Do Dez  9 15:56:00 2021] usbcore: registered new interface driver usbhid
            [Do Dez  9 15:56:00 2021] usbhid: USB HID core driver
            [Do Dez  9 15:56:00 2021] Initializing XFRM netlink socket
            [Do Dez  9 15:56:00 2021] NET: Registered protocol family 17
            [Do Dez  9 15:56:00 2021] Key type dns_resolver registered
            [Do Dez  9 15:56:00 2021] Registering SWP/SWPB emulation handler
            [Do Dez  9 15:56:00 2021] registered taskstats version 1
            [Do Dez  9 15:56:00 2021] Loading compiled-in X.509 certificates
            [Do Dez  9 15:56:00 2021] Key type ._fscrypt registered
            [Do Dez  9 15:56:00 2021] Key type .fscrypt registered
            [Do Dez  9 15:56:00 2021] Key type fscrypt-provisioning registered
            [Do Dez  9 15:56:00 2021] uart-pl011 3f201000.serial: cts_event_workaround enabl                                                ed
            [Do Dez  9 15:56:00 2021] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114                                                , base_baud = 0) is a PL011 rev2
            [Do Dez  9 15:56:00 2021] bcm2835-aux-uart 3f215040.serial: there is not valid m                                                aps for state default
            [Do Dez  9 15:56:00 2021] 3f215040.serial: ttyS0 at MMIO 0x3f215040 (irq = 86, b                                                ase_baud = 50000000) is a 16550
            [Do Dez  9 15:56:00 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power do                                                mains driver
            [Do Dez  9 15:56:00 2021] sdhost: log_buf @ (ptrval) (f7507000)
            [Do Dez  9 15:56:00 2021] Indeed it is in host mode hprt0 = 00021501
            [Do Dez  9 15:56:00 2021] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
            [Do Dez  9 15:56:00 2021] of_cfs_init
            [Do Dez  9 15:56:00 2021] of_cfs_init: OK
            [Do Dez  9 15:56:00 2021] Waiting for root device PARTUUID=c089f643-02...
            [Do Dez  9 15:56:00 2021] usb 1-1: new high-speed USB device number 2 using dwc_                                                otg
            [Do Dez  9 15:56:00 2021] Indeed it is in host mode hprt0 = 00001101
            [Do Dez  9 15:56:00 2021] usb 1-1: New USB device found, idVendor=0424, idProduc                                                t=9514, bcdDevice= 2.00
            [Do Dez  9 15:56:00 2021] usb 1-1: New USB device strings: Mfr=0, Product=0, Ser                                                ialNumber=0
            [Do Dez  9 15:56:00 2021] hub 1-1:1.0: USB hub found
            [Do Dez  9 15:56:00 2021] hub 1-1:1.0: 5 ports detected
            [Do Dez  9 15:56:00 2021] usb 1-1.1: new high-speed USB device number 3 using dw                                                c_otg
            [Do Dez  9 15:56:01 2021] usb 1-1.1: New USB device found, idVendor=0424, idProd                                                uct=ec00, bcdDevice= 2.00
            [Do Dez  9 15:56:01 2021] usb 1-1.1: New USB device strings: Mfr=0, Product=0, S                                                erialNumber=0
            [Do Dez  9 15:56:01 2021] smsc95xx v2.0.0
            [Do Dez  9 15:56:01 2021] libphy: smsc95xx-mdiobus: probed
            [Do Dez  9 15:56:01 2021] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f                                                980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:92:dd:e5
            [Do Dez  9 15:56:01 2021] usb 1-1.3: new high-speed USB device number 4 using dw                                                c_otg
            [Do Dez  9 15:56:01 2021] usb 1-1.3: New USB device found, idVendor=0781, idProd                                                uct=5581, bcdDevice= 1.00
            [Do Dez  9 15:56:01 2021] usb 1-1.3: New USB device strings: Mfr=1, Product=2, S                                                erialNumber=3
            [Do Dez  9 15:56:01 2021] usb 1-1.3: Product: Ultra
            [Do Dez  9 15:56:01 2021] usb 1-1.3: Manufacturer: SanDisk
            [Do Dez  9 15:56:01 2021] usb 1-1.3: SerialNumber: 01010f872deb9d63a3d4e8ffaf20e                                                69fbd99873d69863668b51c4bc503f4fb424b4b00000000000000000000a3a518a7ff032f0081558                                                1073ba95e65
            [Do Dez  9 15:56:01 2021] usb-storage 1-1.3:1.0: USB Mass Storage device detecte                                                d
            [Do Dez  9 15:56:01 2021] scsi host0: usb-storage 1-1.3:1.0
            [Do Dez  9 15:56:02 2021] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra                                                            1.00 PQ: 0 ANSI: 6
            [Do Dez  9 15:56:02 2021] sd 0:0:0:0: [sda] 240353280 512-byte logical blocks: (                                                123 GB/115 GiB)
            [Do Dez  9 15:56:02 2021] sd 0:0:0:0: [sda] Write Protect is off
            [Do Dez  9 15:56:02 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
            [Do Dez  9 15:56:02 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: e                                                nabled, doesn't support DPO or FUA
            [Do Dez  9 15:56:02 2021]  sda: sda1 sda2
            [Do Dez  9 15:56:02 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk
            [Do Dez  9 15:56:02 2021] EXT4-fs (sda2): mounted filesystem with ordered data m                                                ode. Opts: (null)
            [Do Dez  9 15:56:02 2021] VFS: Mounted root (ext4 filesystem) readonly on device                                                 8:2.
            [Do Dez  9 15:56:02 2021] devtmpfs: mounted
            [Do Dez  9 15:56:02 2021] Freeing unused kernel memory: 1024K
            [Do Dez  9 15:56:02 2021] Run /sbin/init as init process
            [Do Dez  9 15:56:02 2021]   with arguments:
            [Do Dez  9 15:56:02 2021]     /sbin/init
            [Do Dez  9 15:56:02 2021]   with environment:
            [Do Dez  9 15:56:02 2021]     HOME=/
            [Do Dez  9 15:56:02 2021]     TERM=linux
            [Do Dez  9 15:56:03 2021] systemd[1]: System time before build time, advancing c                                                lock.
            [Do Dez  9 15:56:03 2021] NET: Registered protocol family 10
            [Do Dez  9 15:56:03 2021] Segment Routing with IPv6
            [Do Dez  9 15:56:03 2021] systemd[1]: systemd 241 running in system mode. (+PAM                                                 +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GN                                                UTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hie                                                rarchy=hybrid)
            [Do Dez  9 15:56:03 2021] systemd[1]: Detected architecture arm.
            [Do Dez  9 15:56:03 2021] systemd[1]: Set hostname to <RaspBee-II-Phoscon>.
            [Do Dez  9 15:56:04 2021] random: systemd: uninitialized urandom read (16 bytes                                                 read)
            [Do Dez  9 15:56:04 2021] systemd[1]: Created slice system-getty.slice.
            [Do Dez  9 15:56:04 2021] systemd[1]: Reached target Swap.
            [Do Dez  9 15:56:04 2021] systemd[1]: Started Dispatch Password Requests to Cons                                                ole Directory Watch.
            [Do Dez  9 15:56:04 2021] systemd[1]: Set up automount Arbitrary Executable File                                                 Formats File System Automount Point.
            [Do Dez  9 15:56:04 2021] systemd[1]: Listening on Syslog Socket.
            [Do Dez  9 15:56:04 2021] systemd[1]: Listening on udev Control Socket.
            [Do Dez  9 15:56:04 2021] systemd[1]: Listening on Journal Socket.
            [Do Dez  9 15:56:04 2021] i2c /dev entries driver
            [Do Dez  9 15:56:05 2021] EXT4-fs (sda2): re-mounted. Opts: (null)
            [Do Dez  9 15:56:05 2021] systemd-journald[122]: Received request to flush runti                                                me journal from PID 1
            [Do Dez  9 15:56:06 2021] vc_sm_cma: module is from the staging directory, the q                                                uality is unknown, you have been warned.
            [Do Dez  9 15:56:06 2021] mc: Linux media interface: v0.10
            [Do Dez  9 15:56:06 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory drive                                                r
            [Do Dez  9 15:56:06 2021] [vc_sm_connected_init]: start
            [Do Dez  9 15:56:06 2021] [vc_sm_connected_init]: installed successfully
            [Do Dez  9 15:56:06 2021] random: crng init done
            [Do Dez  9 15:56:06 2021] random: 7 urandom warning(s) missed due to ratelimitin                                                g
            [Do Dez  9 15:56:06 2021] videodev: Linux video capture interface: v2.00
            [Do Dez  9 15:56:06 2021] snd_bcm2835: module is from the staging directory, the                                                 quality is unknown, you have been warned.
            [Do Dez  9 15:56:06 2021] bcm2835_mmal_vchiq: module is from the staging directo                                                ry, the quality is unknown, you have been warned.
            [Do Dez  9 15:56:06 2021] bcm2835_v4l2: module is from the staging directory, th                                                e quality is unknown, you have been warned.
            [Do Dez  9 15:56:06 2021] bcm2835_isp: module is from the staging directory, the                                                 quality is unknown, you have been warned.
            [Do Dez  9 15:56:06 2021] bcm2835_codec: module is from the staging directory, t                                                he quality is unknown, you have been warned.
            [Do Dez  9 15:56:06 2021] bcm2835-codec bcm2835-codec: Device registered as /dev                                                /video10
            [Do Dez  9 15:56:06 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
            [Do Dez  9 15:56:06 2021] bcm2835-isp bcm2835-isp: Device node output[0] registe                                                red as /dev/video13
            [Do Dez  9 15:56:06 2021] bcm2835-isp bcm2835-isp: Device node capture[0] regist                                                ered as /dev/video14
            [Do Dez  9 15:56:06 2021] bcm2835-isp bcm2835-isp: Device node capture[1] regist                                                ered as /dev/video15
            [Do Dez  9 15:56:06 2021] bcm2835-isp bcm2835-isp: Device node stats[2] register                                                ed as /dev/video16
            [Do Dez  9 15:56:06 2021] bcm2835-isp bcm2835-isp: Register output node 0 with m                                                edia controller
            [Do Dez  9 15:56:06 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with                                                 media controller
            [Do Dez  9 15:56:06 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with                                                 media controller
            [Do Dez  9 15:56:06 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with                                                 media controller
            [Do Dez  9 15:56:06 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
            [Do Dez  9 15:56:06 2021] bcm2835_audio bcm2835_audio: card created with 8 chann                                                els
            [Do Dez  9 15:56:06 2021] bcm2835-codec bcm2835-codec: Device registered as /dev                                                /video11
            [Do Dez  9 15:56:06 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
            [Do Dez  9 15:56:06 2021] bcm2835-codec bcm2835-codec: Device registered as /dev                                                /video12
            [Do Dez  9 15:56:06 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
            [Do Dez  9 15:56:06 2021] bcm2835-codec bcm2835-codec: Device registered as /dev                                                /video18
            [Do Dez  9 15:56:06 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
            [Do Dez  9 15:56:06 2021] usbcore: registered new interface driver uas
            [Do Dez  9 15:56:07 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
            [Do Dez  9 15:56:10 2021] rtc-pcf85063 1-0051: registered as rtc0
            [Do Dez  9 15:56:10 2021] rtc-pcf85063 1-0051: setting system clock to 2021-12-0                                                9T14:56:11 UTC (1639061771)
            [Do Dez  9 15:56:10 2021] i2c i2c-1: new_device: Instantiated device pcf85063 at                                                 0x51
            [Do Dez  9 15:56:10 2021] uart-pl011 3f201000.serial: no DMA platform data
            [Do Dez  9 15:56:10 2021] 8021q: 802.1Q VLAN Support v1.8
            [Do Dez  9 15:56:10 2021] cfg80211: Loading compiled-in X.509 certificates for r                                                egulatory database
            [Do Dez  9 15:56:11 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9c                                                ea7'
            [Do Dez  9 15:56:11 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents                                                :2 across:307200k FS
            [Do Dez  9 15:56:11 2021] SMSC LAN8700 usb-001:003:01: attached PHY driver [SMSC                                                 LAN8700] (mii_bus:phy_addr=usb-001:003:01, irq=POLL)
            [Do Dez  9 15:56:11 2021] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of rem                                                ote wakeup
            [Do Dez  9 15:56:11 2021] smsc95xx 1-1.1:1.0 eth0: Link is Down
            [Do Dez  9 15:56:13 2021] smsc95xx 1-1.1:1.0 eth0: Link is Up - 100Mbps/Full - f                                                low control off
            [Do Dez  9 15:56:13 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes read                                                y
            [Do Dez  9 15:56:14 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (s                                                yscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_                                                ms instead
            [Do Dez  9 15:56:14 2021] Bluetooth: Core ver 2.22
            [Do Dez  9 15:56:14 2021] NET: Registered protocol family 31
            [Do Dez  9 15:56:14 2021] Bluetooth: HCI device and connection manager initializ                                                ed
            [Do Dez  9 15:56:14 2021] Bluetooth: HCI socket layer initialized
            [Do Dez  9 15:56:14 2021] Bluetooth: L2CAP socket layer initialized
            [Do Dez  9 15:56:14 2021] Bluetooth: SCO socket layer initialized
            [Do Dez  9 15:56:14 2021] Bluetooth: HCI UART driver ver 2.3
            [Do Dez  9 15:56:14 2021] Bluetooth: HCI UART protocol H4 registered
            [Do Dez  9 15:56:14 2021] Bluetooth: HCI UART protocol Three-wire (H5) registere                                                d
            [Do Dez  9 15:56:14 2021] Bluetooth: HCI UART protocol Broadcom registered
            [Do Dez  9 15:56:15 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
            [Do Dez  9 15:56:15 2021] Bluetooth: BNEP filters: protocol multicast
            [Do Dez  9 15:56:15 2021] Bluetooth: BNEP socket layer initialized
            • SMS
              SMS last edited by SMS
              Hi
              Ich habe heute auch das Update durchgeführt. Von 3.3.18 auf 3.3.21
              Mein System beinhaltet 1 Master und drei Slaves. Bei zwei Slaves und dem Master gab es keine Probleme. Bei einem Slave hat es irgendwie nicht geklappt. Der startet nicht mehr ... Am PI leuchtet die rote LED und die grüne blinkt ein paar Mal kurz auf.
              Am TV angeschlossen steht in der letzten Zeile:
              [ 4.936401] ---[ end Kernel panic - not syncing: Can not allocate SWIOTLB buffer earlier and can't now provide you with the DMA bounce buffer ]---
              Woran kann das liegen bzw. was kann ich tun?
              Danke und schönen vierten Advent.
                Thomas Braun Most Active @SMS last edited by
                @sms sagte in js-controller 3.3 jetzt im STABLE!:
                https://forum-raspberrypi.de/forum/thread/51271-kernel-panic-swiotlb/
                SMS 1 Reply Last reply Reply Quote 0
                • SMS
                  SMS @Thomas Braun last edited by
                  @thomas-braun Die Seite habe ich schon gefunden, nur finde ich den Parameter: "gpu_mem=" nicht in der config.txt
                    @sms
                    Dann trag ihn ein. Bei mir schaut das so aus:
                    [all]
                    enable_uart=1
                    gpu_mem=32
                    Wenn das System gleich ohne Desktop im RunLevel 3 liefe, dann dürfte es an der Stelle erst gar kein Problem geben. Knips den Desktop-Kram aus!
                    • SMS
                      @thomas-braun also das ist keine Desktop Version, sondern die "Lite". Gerade mal bei den anderen PI's geschaut, dort gibt es den Eintrag "GPU_mem" auch nicht.
                        @sms
                        Hast du den denn jetzt eingetragen?
                        • SMS
                          SMS @Thomas Braun last edited by SMS
                          @thomas-braun ausprobiert ja, keine Änderung
                          # For more options and information see
                          # http://rpf.io/configtxt
                          # Some settings may impact device functionality. See link above for details
                          # uncomment if you get no picture on HDMI for a default "safe" mode
                          #hdmi_safe=1
                          # uncomment this if your display has a black border of unused pixels visible
                          # and your display can output without overscan
                          #disable_overscan=1
                          # uncomment the following to adjust overscan. Use positive numbers if console
                          # goes off screen, and negative if there is too much border
                          #overscan_left=16
                          #overscan_right=16
                          #overscan_top=16
                          #overscan_bottom=16
                          # uncomment to force a console size. By default it will be display's size minus
                          # overscan.
                          #framebuffer_width=1280
                          #framebuffer_height=720
                          # uncomment if hdmi display is not detected and composite is being output
                          #hdmi_force_hotplug=1
                          # uncomment to force a specific HDMI mode (this will force VGA)
                          #hdmi_group=1
                          #hdmi_mode=1
                          # uncomment to force a HDMI mode rather than DVI. This can make audio work in
                          # DMT (computer monitor) modes
                          #hdmi_drive=2
                          # uncomment to increase signal to HDMI, if you have interference, blanking, or
                          # no display
                          #config_hdmi_boost=4
                          # uncomment for composite PAL
                          #sdtv_mode=2
                          #uncomment to overclock the arm. 700 MHz is the default.
                          #arm_freq=800
                          # Uncomment some or all of these to enable the optional hardware interfaces
                          dtparam=i2c_arm=on
                          #dtparam=i2s=on
                          dtparam=spi=off
                          # Uncomment this to enable infrared communication.
                          #dtoverlay=gpio-ir,gpio_pin=17
                          #dtoverlay=gpio-ir-tx,gpio_pin=18
                          # Additional overlays and parameters are documented /boot/overlays/README
                          # Enable audio (loads snd_bcm2835)
                          dtparam=audio=on
                          [pi4]
                          # Enable DRM VC4 V3D driver on top of the dispmanx display stack
                          dtoverlay=vc4-fkms-v3d
                          max_framebuffers=2
                          [all]
                          #dtoverlay=vc4-fkms-v3d
                          enable_uart=1
                          dtoverlay=w1-gpio
                          gpu_mem=32
                          Trage ich 16 statt 32 ein, kommt zwar keine Fehlermeldung, aber der TV wird dunkel und es geht nicht weiter ...
                          • Negalein
                            Hallo
                            Habe heute den JS-Controller auf 3.3.22 upgedatet.
                            Lt. Info ist er jetzt auf 3.3.22
                            Aber ich bekam Fehler beim Update.
                            Was haben die zu bedeuten?
                            nega@ioBroker:~$ iob upgrade self
                            Update js-controller from @3.3.19 to @3.3.22
                            NPM version: 6.14.13
                            npm install iobroker.js-controller@3.3.22 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                            /bin/sh: 1: cmake: not found
                            make: *** [config_deps.target.mk:13: /opt/iobroker/node_modules/cpu-features/deps/cpu_features/build/Makefile] Error 127
                            gyp ERR! build error
                            gyp ERR! stack Error: `make` failed with exit code: 2
                            gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                            gyp ERR! stack     at ChildProcess.emit (events.js:375:28)
                            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
                            gyp ERR! System Linux 5.11.22-5-pve
                            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                            gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
                            gyp ERR! node -v v14.17.1
                            gyp ERR! node-gyp -v v5.1.0
                            gyp ERR! not ok
                            liv-in-sky Thomas Braun 2 Replies Last reply Reply Quote 0
                              liv-in-sky @Negalein last edited by liv-in-sky
                              @negalein
                              evtl hilft das
                              https://forum.iobroker.net/topic/50461/error-bei-adapter-updates-bin-sh-1-cmake-not-foundmake?_=1640161794760
                              oder hier
                              https://forum.iobroker.net/topic/47576/adapter-updates-fehler-cmake-not-found?_=1640161794767
                              • Negalein
                                Negalein Global Moderator @liv-in-sky last edited by
                                @liv-in-sky sagte in js-controller 3.3 jetzt im STABLE!:
                                evtl hilft das
                                Merci
                                hab gesucht und nichts gefunden.
                                Aber hätt ich nach cmake und nicht nach ckmake gesucht, wäre ich fündig geworden! 😂
                                  Thomas Braun Most Active @Negalein last edited by
                                  @negalein
                                  cmake: not found
                                  bedeutet, dass das Paket cmake fehlt. Nachinstallieren.
                                  Negalein apollon77 2 Replies Last reply Reply Quote 2
                                  • Negalein
                                    Negalein Global Moderator @Thomas Braun last edited by
                                    @thomas-braun sagte in js-controller 3.3 jetzt im STABLE!:
                                    cmake: not found
                                    schon erledigt 🙂
                                      @negalein
                                      hatte das problem auch - @Thomas-Braun hatte damals geholfen - daher wußte ich, dass es threads gibt 🙂
                                        gerade das update angestoßen, daher nun die Frage, ging da was schief bzw ist das relevant?
                                        root@IoBroker:~# iob upgrade self
                                        Update js-controller from @3.3.21 to @3.3.22
                                        In file included from ../src/binding.cc:1:
                                        /home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUN                            CTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)                            ’} [-Wcast-function-type]
                                               (node::addon_register_func) (regfunc),                          \
                                        /home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’
                                           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                        ../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’
                                         NODE_MODULE(cpufeatures, init)
                                          Thomas Braun Most Active @crunchip last edited by
                                          @crunchip
                                          Nö, das ist normaler Output beim bauen von nodejs-Modulen.
                                            apollon77 @Thomas Braun last edited by
                                            @thomas-braun Wir werden es im Installer hinzufügen
                                            344
                                            90463
