    4. Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0
    • haselchen
      haselchen Most Active @fraso last edited by haselchen
      @fraso
      Dann bitte ein Log hier posten in Codetags
        fraso @haselchen last edited by Negalein
        @haselchen
        host.iobroker-pi
        2021-12-19 22:18:22.469	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        alexa2.0
        2021-12-19 22:18:22.216	debug	Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/devices-v2/device?cached=true&_=XXX","method":"GET","timeout":10000,"headers":{}}
        alexa2.0
        2021-12-19 22:18:22.216	debug	Alexa-Remote: No authentication check needed (time elapsed 244)
        alexa2.0
        2021-12-19 22:18:22.215	debug	Alexa-Remote: Response: [{"commsId":"amzn1.comms.id.person.amzn1~amzn1.account.XXX","directedId":"amzn1.account.XXX","phoneCountryCode":"49","phoneNumber":"XXX","firstName":"XXX","lastName":"XXX","phoneticFirstName":null,"phoneticLastName":null,"commsProvisionStatus":"PROVISIONED","isChild":false,"personIdV2":"amzn1.actor.person.oid.XXX","signedInUser":true,"commsProvisioned":true,"enrolledInAlexa":true,"speakerProvisioned":false}]
        alexa2.0
        2021-12-19 22:18:21.974	debug	Alexa-Remote: Sending Request with {"host":"alexa-comms-mobile-service.amazon.com","path":"/accounts","method":"GET","timeout":10000,"headers":{}}
        alexa2.0
        2021-12-19 22:18:21.973	debug	Alexa-Remote: No authentication check needed (time elapsed 1)
        alexa2.0
        2021-12-19 22:18:21.972	debug	Alexa-Remote: Authentication checked: true
          Thomas Braun Most Active @fraso last edited by
          @fraso sagte in Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0:
          Ich habe verzweifelt Alexa2.0 v3.12.0. über die Katze installiert.
          Warum? Das ist nicht der normale Installationsweg.
            fraso @Thomas Braun last edited by
            Ich habe den gleichen effekt mit der Version alexa2 v3.11.2 gehabt und hoffte auf eine Lösung mit der "neueren" Version. Beide Adapter bringen das gleiche Ergebnis.
              @fraso
              So ganz ist mir noch nicht klar womit du da unterwegs bist.
              Bitte mal
              which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
              ausführen.
                @thomas-braun sagte in Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0:
                pi@iobroker-pi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                /usr/bin/node
                /usr/bin/npm
                pi@iobroker-pi:~ $
                  @fraso
                  sudo ln -s /usr/bin/node /usr/bin/nodejs
                  Und dann noch mal das von davor.
                    pi@iobroker-pi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.22.7
                    v12.22.7
                    6.14.15
                    Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                    Hit:3 https://repos.influxdata.com/debian stretch InRelease
                    Hit:4 https://packages.grafana.com/enterprise/deb stable InRelease
                    Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
                    Fetched 15.0 kB in 2s (7,647 B/s)
                    Reading package lists... Done
                    Building dependency tree
                    1 package can be upgraded. Run 'apt list --upgradable' to see it.
                    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    Hit:3 https://packages.grafana.com/enterprise/deb stable InRelease
                    Hit:4 https://repos.influxdata.com/debian stretch InRelease
                    nodejs:
                      Installed: 12.22.7-deb-1nodesource1
                      Candidate: 12.22.8-deb-1nodesource1
                      Version table:
                         12.22.8-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                     *** 12.22.7-deb-1nodesource1 100
                            100 /var/lib/dpkg/status
                         10.24.0~dfsg-1~deb10u1 500
                    pi@iobroker-pi:~ $
                      Thomas Braun Most Active @fraso last edited by Thomas Braun
                      @fraso
                      Bitte mal das System updaten.
                      Bei influx und grafana sind die auch falschen Repos angelegt.
                        Darf ich fragen was genau ich machen soll?
                        Das Standard Update Rasperry?
                        sudo apt-get upgrade ?
                        sudo apt-get dist-upgrade ?
                        Danke.
                          @fraso
                          Das zum einen, zum anderen Stretch durch Buster ersetzen bei influx und bei grafana auf die oss-Version gehen.
                          Hat aber mit deinem Problem nicht direkt zu tun, ist aber dennoch falsch.
                            Habe ich gemacht.
                            Die Info mit Stretch durch Buster ersetzen bei influx und bei grafana auf die oss Version gehen... how to?
                            1 Update nodejs (12.22.8-deb-1nodesource1)
                            0 Upgrade
                              @fraso
                              Bitte nochmal auf den jeweiligen Projektseiten schauen. Da gibt es jeweils entsprechende Befehlszeilen.
                                @thomas-braun mache ich. kannst du mich auf die Projektseiten schubsen?
                                  @fraso
                                  Wie bist du denn an die falschen Links gekommen?
                                  https://grafana.com/docs/grafana/latest/installation/debian/
                                  Influx:
                                  In der
                                  /etc/apt/sources.list.d/influxdb.list
                                  stretch durch buster ersetzen
                                    fraso @Thomas Braun last edited by Negalein
                                    pi@iobroker-pi:~ $ sudo apt-get remove --auto-remove grafana-enterprise
                                    The following packages will be REMOVED:
                                      grafana-enterprise
                                    0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                                    After this operation, 258 MB disk space will be freed.
                                    Do you want to continue? [Y/n] Y
                                    (Reading database ... 67759 files and directories currently installed.)
                                    Removing grafana-enterprise (8.3.3) ...
                                    pi@iobroker-pi:~ $ sudo apt-get install -y apt-transport-https
                                    apt-transport-https is already the newest version (1.8.2.3).
                                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                    pi@iobroker-pi:~ $ sudo apt-get install -y software-properties-common wget
                                    software-properties-common is already the newest version (0.96.20.2-2).
                                    wget is already the newest version (1.20.1-1.1).
                                    pi@iobroker-pi:~ $ wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
                                    OK
                                    pi@iobroker-pi:~ $ sudo apt-get update
                                    pi@iobroker-pi:~ $ sudo apt-get install grafana
                                    The following NEW packages will be installed:
                                      grafana
                                    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                    Need to get 41.3 MB of archives.
                                    After this operation, 120 MB of additional disk space will be used.
                                    Get:1 https://packages.grafana.com/enterprise/deb stable/main armhf grafana armhf 7.0.0 [41.3 MB]
                                    Fetched 41.3 MB in 6s (6,691 kB/s)
                                    Selecting previously unselected package grafana.
                                    (Reading database ... 61681 files and directories currently installed.)
                                    Preparing to unpack .../grafana_7.0.0_armhf.deb ...
                                    Unpacking grafana (7.0.0) ...
                                    Setting up grafana (7.0.0) ...
                                    Installing new version of config file /etc/default/grafana-server ...
                                    Installing new version of config file /usr/lib/systemd/system/grafana-server.service ...
                                    ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
                                     sudo /bin/systemctl daemon-reload
                                     sudo /bin/systemctl enable grafana-server
                                    ### You can start grafana-server by executing
                                     sudo /bin/systemctl start grafana-server
                                    Processing triggers for systemd (241-7~deb10u8+rpi1) ...
                                    pi@iobroker-pi:~ $
                                      fraso @fraso last edited by
                                      @fraso so richtig gemacht?
                                        mmm... jetzt hab ich beide drauf 😞
                                          ... ich habe dann PURGE gemacht:
                                            Thomas Braun Most Active last edited by
                                            @fraso
                                            sudo apt update
                                            apt policy grafana grafana-enterprise
                                            1329
