    4. Test Adapter KNX v2.x
    • Glasfaser
      Glasfaser @schmid_no1 last edited by
      @schmid_no1
      Bitte keine Screenshot´s
      Log Ausgaben komplett in Code-Tags </> setzen
        host.raspberrypi
        	2021-12-18 15:43:45.443	error	instance system.adapter.knx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.raspberrypi
        	2021-12-18 15:43:45.442	error	Caught by controller[0]: at processTimers (internal/timers.js:500:7)
        host.raspberrypi
        	2021-12-18 15:43:45.442	error	Caught by controller[0]: at listOnTimeout (internal/timers.js:559:11)
        host.raspberrypi
        	2021-12-18 15:43:45.441	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:267377)
        host.raspberrypi
        	2021-12-18 15:43:45.441	error	Caught by controller[0]: at _0x1239e8 (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:258738)
        host.raspberrypi
        	2021-12-18 15:43:45.440	error	Caught by controller[0]: at Function.each (/opt/iobroker/node_modules/iobroker.knx/node_modules/underscore/underscore-node-f-pre.js:1316:7)
        host.raspberrypi
        	2021-12-18 15:43:45.439	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.knx/knx.js:1:259948
        host.raspberrypi
        	2021-12-18 15:43:45.428	error	Caught by controller[0]: ReferenceError: actGAcomObjectInstanceRefId_GARefId is not defined
        knx.0
        	2021-12-18 15:43:44.745	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        knx.0
        	2021-12-18 15:43:44.743	info	terminating
        knx.0
        	2021-12-18 15:43:44.724	error	actGAcomObjectInstanceRefId_GARefId is not defined
        knx.0
        	2021-12-18 15:43:44.723	error	ReferenceError: actGAcomObjectInstanceRefId_GARefId is not defined at /opt/iobroker/node_modules/iobroker.knx/knx.js:1:259948 at Function.each (/opt/iobroker/node_modules/iobroker.knx/node_modules/underscore/underscore-node-f-pre.js:1316:7) at _0x1239e8 (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:258738) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:267377) at listOnTimeout (internal/timers.js:559:11) at processTimers (internal/timers.js:500:7)
        knx.0
        	2021-12-18 15:43:44.718	error	uncaught exception: actGAcomObjectInstanceRefId_GARefId is not defined
          schmid_no1 @Glasfaser last edited by
          @glasfaser so richtig?
          • Glasfaser
            @schmid_no1 sagte in Test Adapter KNX v2.x:
            JA ,
            denn Screenshot´s kann man schlecht lesen , bzw . Fehler sind abgeschnitten und man kann daraus nicht Zitieren .......
              Habe ich ein Problem mit meiner .knxproj Datei
              chefkoch009 1 Reply Last reply Reply Quote 0
              • chefkoch009
                chefkoch009 Developer @schmid_no1 last edited by
                @schmid_no1 Was ist das für eine ETS Version, welche Version haben Dein
                1. Admin
                2. nodejs
                3. js-controller
                4. knx-adapter
                VG
                chefkoch009
                • Y
                  YellowFlash @chefkoch009 last edited by
                  @chefkoch009 said in Test Adapter KNX v2.x:
                  @yellowflash Da war ich mit den Requirements leider etwas unaufmerksam.
                  iobroker-horst:~# cd /opt/iobroker
                  iobroker-horst:/opt/iobroker# npm i iobroker.admin@5.1.28
                  iobroker-horst:/opt/iobroker# iobroker u admin
                  Damit sollte es laufen.
                  VG
                  chefkoch009
                  Danke, nun startet der Adapter wieder und nimmt Verbindung auf.
                    schmid_no1 @chefkoch009 last edited by
                    @chefkoch009
                    Hallo Chefkoch009 Versionen wie folgt:
                    ETS 5.5.2
                    Admin 5.1.25
                    nodejs v14.17.2
                    js-controller 3.3.21
                    KNX-adapter2.0.5
                    alles sauber installiert.
                    Ich bin hergegangen und löschte alles was mit dem KNX adapter (1.0.45) zu tun hatte. Ich wollte alles mit dem neuen Adapter einlesen. Hier kam die Fehlermeldung, die ich oben einstellte.
                    Habe ein downgrade des KNX-Adapters gemacht, mein projekt eingelesen und bin dann wieder auf 2.0.5. Jetzt geht es, aber der Upload ging bei mir nicht mit dem neuen.
                    • U
                      urs77 last edited by
                      Hallo, ich habe aktuell 510 GA. Lohnt sich im moment noch nicht, eine Lizenz zu kaufen. Das werde ich erst nach der nächsten Erweiterung im Haus machen.
                      Was passiert aber jetzt bei einem Update (ohne Lizenz): geht der Adapter gar nicht mehr? Oder fallen 10 Objekte weg? Wenn ich in ETS 10 Objekte lösche: reicht es, die knxproj neu einzulesen und iobroker erkennt, dass GA fehlen oder muss ich alles entfernen und komplett neu einrichten?
                      Danke und vg
                      • chefkoch009
                        chefkoch009 Developer @urs77 last edited by
                        @urs77
                        Klar läuft er, aber er kommuniziert nicht mehr mit dem KNX Bus.
                        Nein, da fällt nichts weg.
                        Es werden nur neue hinzugefügt, bestehende bleiben vorhanden.
                        VG
                        chefkoch009
                        • U
                          urs77 @chefkoch009 last edited by
                          @chefkoch009 ok danke
                          "Es werden nur neue hinzugefügt, bestehende bleiben vorhanden." bedeutet dann: in ETS auf unter 500 GA reduzieren und im iobroker erst alle Objekte unterhalb von knx löschen und knxproj vollständig neu laden und gegebenfalls alles neu einrichten?
                          • chefkoch009
                            @urs77 du brauchst im iobroker nur die löschen, die in deinem neuen Projekt auch wegfallen.
                            VG
                            chefkoch009
                              loverz last edited by loverz
                              Ohne den Tag vor dem Abend zu loben:
                              Bin gerade von 1.0.20 auf 2.0.5 hoch und es scheint auf Anhieb zu laufen.
                              Hatte bisher mit allen v1.x höher als 1.0.20 das Problem, dass meine Rollläden nicht die aktuelle Position rückgemeldet haben, daher bin ich auf 1.0.20 geblieben.
                              Habe nun in der 2.0.5 direkt über die "GA-Tools" die Zuordnung von Aktor und Status gemacht.
                              -Denkt ihr, dass das Problem damit weg ist?
                              -Muss ich diese Zuordnung nur bei den Rollos machen, oder auch bei Lampen etc.?
                              -Was bewirkt diese Zuordnung denn genau?
                              -Ist die Zuordnung wieder weg, wenn ich ein neues KNX Projekt einlese?
                              ->Ggf. Nur wenn ich diesen Haken weglasse:
                              Danke erstmal für die Weiterentwicklung, ich bin begeistert!
                              Edit: Hab wohl doch zu früh gelobt: Es gibt wieder Probleme, die mit 1.0.20 einwandfrei gelaufen sind:
                              Mir ist aufgefallen, dass die Rollladen-Positionen wieder nicht richtig rückgemeldet werden, obwohl ich die Status-GA und die Aktor-GA verknüpft habe:
                              Außerdem ist mir aufgefallen, dass der Adapter es nicht gebacken bekommt, wenn ich in der ETS Software eine Gruppenadresse anlege, die nicht mit einem Aktor, sondern nur mit einem Wandtaster (z.B. MDT Glastaster) verknüpft ist.
                              Dies wird z.B. benötigt, wenn man eine Indikator-LED am Taster steuern möchte, oder wenn man einen Knopf von diesen Wandtastern in iobroker auswerten möchte
                              Wenn ich nun einen Wert von iobroker über diese Gruppenadresse an den Glastaster senden möchte, dann kommt dieser Befehl nicht an.
                              Hier so ein Objekt:
                                "_id": "knx.0.OG.Jalousie.Bad_Indikator",
                                "type": "state",
                                "common": {
                                  "name": "Bad Indikator",
                                  "type": "boolean",
                                  "read": false,
                                  "write": true,
                                  "role": "switch",
                                  "min": false,
                                  "max": true
                                "native": {
                                  "dpt": "DPT1.001",
                                  "address": "2/3/13",
                                  "addressRefId": "P-039B-0_GA-327",
                                  "statusGARefId": "",
                                  "actGARefId": ""
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                                  "owner": "system.user.admin",
                                "user": "system.user.admin",
                                "ts": 1640167746052
                              Ich weiß nicht, was da los ist! Wieso geht bis 1.0.20 alles einwandfrei und danach kommt es immer wieder zu diesen massiven Problemen??
                                tombox @loverz last edited by tombox
                                @lover
                                vielleicht gibst du auch mal dem openKNX Adapter eine Chance (läuft auch parallel zu knx adapter), der kann von jedem verbessert werden vielleicht funktioniert der besser. Wir nehmen gerne Verbesserungswünsche entgegen.
                                https://forum.iobroker.net/topic/50352/test-adapter-openknx-0-1-x
                                L 1 Reply Last reply Reply Quote 2
                                • Hant0r
                                  Hant0r last edited by
                                  @andreask sagte in Test Adapter KNX v2.x:
                                  Das bedeutet, wenn ich in der ETS den Bereich Reports -> Projektstatistik öffne, ist die Anzahl der gezeigten Gruppenadressen ausschlaggebend. Richtig? Danach staffelt sich dann die Kosten.
                                  Na super!
                                  Habe 693 Gruppenadressen ... und ich habe nur mein privates Haus das ich hier betreibe.
                                  Dabei ist der Garten noch nicht mal fertig ausgebaut 😞
                                  Heißt entweder greife ich tief in die Tasche oder ich muss mit der Version 1 weiter vorlieb nehmen?
                                  Und die ETS Version darf ich auch nicht auf >5.7.5 udpaten?
                                    loverz @tombox last edited by
                                    @tombox wenn das mit dem Umzug der Scripte klappt, dann werde ich umziehen, sieht sehr vielversprechend aus der openknx Adapter. Danke!
                                    Gott sei dank habe ich ein SD Image gemacht, bevor ich auf 2.x hier hoch bin.
                                    Hab nun mein Image mit 1.0.20 eingespielt und alles funktioniert wieder!
                                    • chefkoch009
                                      chefkoch009 Developer @loverz last edited by
                                      @loverz
                                      komisch....warum nur?
                                      Ich möchte an dieser Stelle darauf hinweisen, das das hier der Thread vom KNX Adapter ist und nicht der von openknx.
                                      VG
                                      chefkoch009
                                      L T 2 Replies Last reply Reply Quote 0
                                        loverz @chefkoch009 last edited by
                                        @chefkoch009 das ist mir auch klar.
                                        Ich würde auch bei deinem Adapter bleiben, das wäre ja das einfachste, wenn du mal auf meine Probleme eingehen würdest und Hilfestellung geben könntest wäre das echt super!
                                        Ich frage nochmal explizit: Was hat sich an ALLEN Versionen nach 1.0.20 geändert, dass ich plötzlich diese massiven Probleme habe?
                                        Ich habe hier im Forum auch von anderen gelesen, die auch mit diesem Problem kämpfen.
                                        M chefkoch009 2 Replies Last reply Reply Quote 0
                                          marlan99 @loverz last edited by
                                          @loverz hilft nicht explizit bei deinem Problem.
                                          chefkoch009 hat in anderen Beiträgen immer wieder darauf hingewiesen, dass eine saubere Konfiguration der ETS der wichtigste Punkt ist, damit die Zuordnungen korrekt abgebildet werden können.
                                          Ich hatte hierzu ein paar Stunden investiert und auch nach der Version 1.0.20 keine Probleme mehr (mit Ausnahme von ein paar DPT welche nicht korrekt funktionierten)
                                          Bei dem Umstieg auf die V2 (bis zur jetzigen 2.0.5) habe ich auch weiterhin keine Probleme mit der Funktion. Im Gegenteil alle von mir verwendeten DPT werden mittlerweile korrekt angewendet.
                                          Ich glaube mich zu erinnern, dass es irgendwo eine Liste gibt was in der ETS zu beachten war?
                                          @chefkoch009 wenn ich nicht falsch liege kannst du hier evtl. nochmal darauf hinweisen?
                                            loverz @marlan99 last edited by
                                            @marlan99 an meiner ETS hat sich halt nichts geändert, die blieb immer gleich.
                                            Klar kann es sein, dass ich es nicht so programmiert habe wie es heute gefordert wird, aber soll ich deshalb einen Programmierer bestellen, der alles ummuddelt?
                                            In der 2.0.5 gibt es die GA Tools, welche die Zuordnung auch nachträglich anpassen lassen, aber auch das geht nicht gut, weil es offensichtlich nicht an den Zuordnungen liegt…
                                            Es sind einfache Situationen: Ich steuere den Standby Eingang meines MDT Glastasters per iobroker an. Dazu eine GA, die nur den Standby Eingang hat (eben kein Aktor).
                                            Nichtmal diese einfache Situation klappt mehr nach 1.0.20…
                                            31.7k
                                            79.8k
                                            421
                                            69415
