    4. Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0
      Thomas Braun Most Active @fraso last edited by
      @fraso
      So ganz ist mir noch nicht klar womit du da unterwegs bist.
      Bitte mal
      which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      ausführen.
        fraso @Thomas Braun last edited by
        @thomas-braun sagte in Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0:
        pi@iobroker-pi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
        /usr/bin/node
        /usr/bin/npm
        pi@iobroker-pi:~ $
          @fraso
          sudo ln -s /usr/bin/node /usr/bin/nodejs
          Und dann noch mal das von davor.
            pi@iobroker-pi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v12.22.7
            v12.22.7
            6.14.15
            Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
            Hit:2 http://archive.raspberrypi.org/debian buster InRelease
            Hit:3 https://repos.influxdata.com/debian stretch InRelease
            Hit:4 https://packages.grafana.com/enterprise/deb stable InRelease
            Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
            Fetched 15.0 kB in 2s (7,647 B/s)
            Reading package lists... Done
            Building dependency tree
            1 package can be upgraded. Run 'apt list --upgradable' to see it.
            Hit:1 http://archive.raspberrypi.org/debian buster InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:3 https://packages.grafana.com/enterprise/deb stable InRelease
            Hit:4 https://repos.influxdata.com/debian stretch InRelease
            nodejs:
              Installed: 12.22.7-deb-1nodesource1
              Candidate: 12.22.8-deb-1nodesource1
              Version table:
                 12.22.8-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
             *** 12.22.7-deb-1nodesource1 100
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u1 500
            pi@iobroker-pi:~ $
              Thomas Braun Most Active @fraso last edited by Thomas Braun
              @fraso
              Bitte mal das System updaten.
              Bei influx und grafana sind die auch falschen Repos angelegt.
                Darf ich fragen was genau ich machen soll?
                Das Standard Update Rasperry?
                sudo apt-get upgrade ?
                sudo apt-get dist-upgrade ?
                Danke.
                  @fraso
                  Das zum einen, zum anderen Stretch durch Buster ersetzen bei influx und bei grafana auf die oss-Version gehen.
                  Hat aber mit deinem Problem nicht direkt zu tun, ist aber dennoch falsch.
                    Habe ich gemacht.
                    Die Info mit Stretch durch Buster ersetzen bei influx und bei grafana auf die oss Version gehen... how to?
                    1 Update nodejs (12.22.8-deb-1nodesource1)
                    0 Upgrade
                      @fraso
                      Bitte nochmal auf den jeweiligen Projektseiten schauen. Da gibt es jeweils entsprechende Befehlszeilen.
                        @thomas-braun mache ich. kannst du mich auf die Projektseiten schubsen?
                          @fraso
                          Wie bist du denn an die falschen Links gekommen?
                          https://grafana.com/docs/grafana/latest/installation/debian/
                          Influx:
                          In der
                          /etc/apt/sources.list.d/influxdb.list
                          stretch durch buster ersetzen
                            fraso @Thomas Braun last edited by Negalein
                            pi@iobroker-pi:~ $ sudo apt-get remove --auto-remove grafana-enterprise
                            The following packages will be REMOVED:
                              grafana-enterprise
                            0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                            After this operation, 258 MB disk space will be freed.
                            Do you want to continue? [Y/n] Y
                            (Reading database ... 67759 files and directories currently installed.)
                            Removing grafana-enterprise (8.3.3) ...
                            pi@iobroker-pi:~ $ sudo apt-get install -y apt-transport-https
                            apt-transport-https is already the newest version (1.8.2.3).
                            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            pi@iobroker-pi:~ $ sudo apt-get install -y software-properties-common wget
                            software-properties-common is already the newest version (0.96.20.2-2).
                            wget is already the newest version (1.20.1-1.1).
                            pi@iobroker-pi:~ $ wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
                            OK
                            pi@iobroker-pi:~ $ sudo apt-get update
                            pi@iobroker-pi:~ $ sudo apt-get install grafana
                            The following NEW packages will be installed:
                              grafana
                            0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 41.3 MB of archives.
                            After this operation, 120 MB of additional disk space will be used.
                            Get:1 https://packages.grafana.com/enterprise/deb stable/main armhf grafana armhf 7.0.0 [41.3 MB]
                            Fetched 41.3 MB in 6s (6,691 kB/s)
                            Selecting previously unselected package grafana.
                            (Reading database ... 61681 files and directories currently installed.)
                            Preparing to unpack .../grafana_7.0.0_armhf.deb ...
                            Unpacking grafana (7.0.0) ...
                            Setting up grafana (7.0.0) ...
                            Installing new version of config file /etc/default/grafana-server ...
                            Installing new version of config file /usr/lib/systemd/system/grafana-server.service ...
                            ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
                             sudo /bin/systemctl daemon-reload
                             sudo /bin/systemctl enable grafana-server
                            ### You can start grafana-server by executing
                             sudo /bin/systemctl start grafana-server
                            Processing triggers for systemd (241-7~deb10u8+rpi1) ...
                            pi@iobroker-pi:~ $
                              fraso @fraso last edited by
                              @fraso so richtig gemacht?
                                @fraso sagte in Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0:
                                mmm... jetzt hab ich beide drauf 😞
                                  ... ich habe dann PURGE gemacht:
                                    Thomas Braun Most Active last edited by
                                    @fraso
                                    sudo apt update
                                    apt policy grafana grafana-enterprise
                                      @thomas-braun danke. habe nur noch die 7.0.0 drauf. nehme an das ist die oss. jetzt lese ich mich gerade durch das stretch->buster zeug durch.
                                        @fraso und das hat alles mit Alexa2 zu tun das das nicht geht?
                                          @fraso
                                          Nein. Hab ich doch schon geschrieben. Ist aber dennoch falsch und kann an anderer Stelle für Probleme sorgen.
                                          Die OSS-Version ist übrigens 8.3.3 Stand heute.
                                            @thomas-braun BUSTER - korrekt?
                                            pi@iobroker-pi:~ $ cat /etc/os-release
                                            PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                                            NAME="Raspbian GNU/Linux"
                                            VERSION_ID="10"
                                            VERSION="10 (buster)"
                                            VERSION_CODENAME=buster
                                            ID=raspbian
                                            ID_LIKE=debian
                                            HOME_URL="http://www.raspbian.org/"
                                            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                            pi@iobroker-pi:~ $
                                            1329
