    4. Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0
      fraso @Thomas Braun last edited by
      Habe ich gemacht.
      Die Info mit Stretch durch Buster ersetzen bei influx und bei grafana auf die oss Version gehen... how to?
      1 Update nodejs (12.22.8-deb-1nodesource1)
      0 Upgrade
        Thomas Braun Most Active @fraso last edited by
        @fraso
        Bitte nochmal auf den jeweiligen Projektseiten schauen. Da gibt es jeweils entsprechende Befehlszeilen.
          @thomas-braun mache ich. kannst du mich auf die Projektseiten schubsen?
            Thomas Braun Most Active @fraso last edited by Thomas Braun
            @fraso
            Wie bist du denn an die falschen Links gekommen?
            https://grafana.com/docs/grafana/latest/installation/debian/
            Influx:
            In der
            /etc/apt/sources.list.d/influxdb.list
            stretch durch buster ersetzen
              fraso @Thomas Braun last edited by Negalein
              pi@iobroker-pi:~ $ sudo apt-get remove --auto-remove grafana-enterprise
              Reading package lists... Done
              Building dependency tree
              The following packages will be REMOVED:
                grafana-enterprise
              0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
              After this operation, 258 MB disk space will be freed.
              Do you want to continue? [Y/n] Y
              (Reading database ... 67759 files and directories currently installed.)
              Removing grafana-enterprise (8.3.3) ...
              pi@iobroker-pi:~ $ sudo apt-get install -y apt-transport-https
              apt-transport-https is already the newest version (1.8.2.3).
              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              pi@iobroker-pi:~ $ sudo apt-get install -y software-properties-common wget
              software-properties-common is already the newest version (0.96.20.2-2).
              wget is already the newest version (1.20.1-1.1).
              pi@iobroker-pi:~ $ wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
              OK
              pi@iobroker-pi:~ $ sudo apt-get update
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:3 https://packages.grafana.com/enterprise/deb stable InRelease
              Hit:4 https://repos.influxdata.com/debian stretch InRelease
              Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
              pi@iobroker-pi:~ $ sudo apt-get install grafana
              The following NEW packages will be installed:
                grafana
              0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
              Need to get 41.3 MB of archives.
              After this operation, 120 MB of additional disk space will be used.
              Get:1 https://packages.grafana.com/enterprise/deb stable/main armhf grafana armhf 7.0.0 [41.3 MB]
              Fetched 41.3 MB in 6s (6,691 kB/s)
              Selecting previously unselected package grafana.
              (Reading database ... 61681 files and directories currently installed.)
              Preparing to unpack .../grafana_7.0.0_armhf.deb ...
              Unpacking grafana (7.0.0) ...
              Setting up grafana (7.0.0) ...
              Installing new version of config file /etc/default/grafana-server ...
              Installing new version of config file /usr/lib/systemd/system/grafana-server.service ...
              ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
               sudo /bin/systemctl daemon-reload
               sudo /bin/systemctl enable grafana-server
              ### You can start grafana-server by executing
               sudo /bin/systemctl start grafana-server
              Processing triggers for systemd (241-7~deb10u8+rpi1) ...
              pi@iobroker-pi:~ $
                fraso @fraso last edited by
                @fraso so richtig gemacht?
                  @fraso sagte in Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0:
                  mmm... jetzt hab ich beide drauf 😞
                    ... ich habe dann PURGE gemacht:
                      Thomas Braun Most Active last edited by
                      @fraso
                      sudo apt update
                      apt policy grafana grafana-enterprise
                        @thomas-braun danke. habe nur noch die 7.0.0 drauf. nehme an das ist die oss. jetzt lese ich mich gerade durch das stretch->buster zeug durch.
                          @fraso und das hat alles mit Alexa2 zu tun das das nicht geht?
                            @fraso
                            Nein. Hab ich doch schon geschrieben. Ist aber dennoch falsch und kann an anderer Stelle für Probleme sorgen.
                            Die OSS-Version ist übrigens 8.3.3 Stand heute.
                              @thomas-braun BUSTER - korrekt?
                              pi@iobroker-pi:~ $ cat /etc/os-release
                              PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                              NAME="Raspbian GNU/Linux"
                              VERSION_ID="10"
                              VERSION="10 (buster)"
                              VERSION_CODENAME=buster
                              ID=raspbian
                              ID_LIKE=debian
                              HOME_URL="http://www.raspbian.org/"
                              SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                              BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                              pi@iobroker-pi:~ $
                                @fraso
                                Ja. Deswegen sollst du ja auch das Repository von stretch auf buster umstellen.
                                Grafana ist jetzt umgestellt?
                                  @thomas-braun ich arbeitet dran.. noch keine Ahnung wie. aber google ist mein freund.
                                    @fraso
                                    Vergoogle dich nur nicht...
                                    apt policy grafana
                                    apt policy grafana-enterprise
                                    sagt?
                                      @thomas-braun sagte in Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0:
                                      apt policy grafana
                                      gerade fertig geworden:
                                      pi@iobroker-pi:~ $ apt policy grafana
                                      grafana:
                                        Installed: 8.3.3
                                        Candidate: 8.3.3
                                        Version table:
                                       *** 8.3.3 100
                                              100 /var/lib/dpkg/status
                                           7.0.0 500
                                              500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages
                                      pi@iobroker-pi:~ $ apt policy grafana-enterprise
                                      grafana-enterprise:
                                        Installed: (none)
                                        Candidate: 8.3.3
                                        Version table:
                                           8.3.3 500
                                        @fraso
                                        Da stimmt noch irgendwas nicht.
                                        sudo apt update
                                          sudo apt update
                                          pi@iobroker-pi:~ $ sudo apt update
                                          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                          All packages are up to date.
                                          pi@iobroker-pi:~ $
                                            @fraso
                                            ist falsch.
                                            Das muss
                                            https://packages.grafana.com/oss/deb
                                            heißen. Pass die Datei
                                            /etc/apt/sources.list.d/grafana.list an
                                            1329
