      speerwerfer @speerwerfer last edited by
      So, ich hab eben extra noch ne neue SD Karte geholt. Hat leider nichts geholfen. Das Modul wird über ein 1A USB Netzteil versorgt, daran kann es also auch nicht liegen ...
      Über den seriellen Monitor sehe ich das hier:
      ets Jun  8 2016 00:22:57
      rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
      mode:DIO, clock div:2
      load:0x3fff0030,len:4
      load:0x3fff0034,len:7248
      ho 0 tail 12 room 4
      load:0x40078000,len:13856
      load:0x40080400,len:4052
      entry 0x40080688
      I (31) boot: ESP-IDF 3.40100.200827 2nd stage bootloader
      I (31) boot: compile time 21:55:31
      I (31) boot: chip revision: 1
      I (34) boot_comm: chip revision: 1, min. bootloader chip revision: 0
      I (41) boot.esp32: SPI Speed      : 40MHz
      I (46) boot.esp32: SPI Mode       : DIO
      I (50) boot.esp32: SPI Flash Size : 4MB
      I (55) boot: Enabling RNG early entropy source...
      I (60) boot: Partition Table:
      I (64) boot: ## Label            Usage          Type ST Offset   Length
      I (71) boot:  0 nvs              WiFi data        01 02 00009000 00004000
      I (79) boot:  1 otadata          OTA data         01 00 0000d000 00002000
      I (86) boot:  2 phy_init         RF data          01 01 0000f000 00001000
      I (94) boot:  3 ota_0            OTA app          00 10 00010000 001db000
      I (101) boot:  4 ota_1            OTA app          00 11 001f0000 001db000
      I (109) boot: End of partition table
      I (113) boot_comm: chip revision: 1, min. application chip revision: 0
      I (120) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x511d4 (332244) map
      I (273) esp_image: segment 1: paddr=0x000611fc vaddr=0x3ffb0000 size=0x05050 ( 20560) load
      I (283) esp_image: segment 2: paddr=0x00066254 vaddr=0x40080000 size=0x00404 (  1028) load
      I (284) esp_image: segment 3: paddr=0x00066660 vaddr=0x40080404 size=0x099b8 ( 39352) load
      I (310) esp_image: segment 4: paddr=0x00070020 vaddr=0x400d0020 size=0x123240 (1192512) map
      I (826) esp_image: segment 5: paddr=0x00193268 vaddr=0x40089dbc size=0x12df8 ( 77304) load
      I (881) boot: Loaded app from partition at offset 0x10000
      I (881) boot: Disabling RNG early entropy source...
      I (882) psram: This chip is ESP32-D0WD
      E (886) cpu_start: Failed to init external RAM!
      abort() was called at PC 0x40081bdf on core 0
      ELF file SHA256: d31ca3157c9027f1
      Backtrace: 0x4008cfb0:0x3ffe3c00 0x4008d3e1:0x3ffe3c20 0x40081bdf:0x3ffe3c40 0x4007931a:0x3ffe3c80 |<-CORRUPTED
      Re-enable cpu cache.
      Rebooting...
        jomjol @speerwerfer last edited by
        @speerwerfer sagte in Wasserzähler - Version 2 - all-in-device:
        ho 0 tail 12 room 4
        entry 0x40080688
        Rebooting...
        Schau die mal die Fehlermeldung genau an:
        Das sieht sehr danach aus, als dein externer PSRAM nicht funktioniert. Zu dem Zeitpunkt ist die Firmware noch nicht mal geladen.
          speerwerfer @jomjol last edited by
          @jomjol said in Wasserzähler - Version 2 - all-in-device:
          Hast du ne Idee, wie ich das am einfachsten testen kann.
            Ich habe einen neuen esp32-cam und nun klappt es sofort ...
              Danielbroker86 last edited by Danielbroker86
              @jomjol Falls du dich wunderst, dass die Download Zahlen steigen.. Matthias Kleine hat dein Projekt aufgefasst und ein Video daraus gedreht
              https://www.youtube.com/watch?v=mDIJEyElkAU&ab_channel=haus-automatisierung.com
                ameisenautomat @Danielbroker86 last edited by ameisenautomat
                Ich würde gerne meinen digitalen Stromzähler auslesen. Es ist ein Zweirichtungszähler. Die Anzeige vom Zähler wechselt alle paar sekunden zwischen verbrauchten und eingespeisten Strom hin und her. Gibt es hier eine Möglichkeit das nur der verbrauchte Strom ausgelesen wird?
                  jomjol @ameisenautomat last edited by
                  @ameisenautomat Das ist leider nicht möglich, da keine synchronisation zwischen den wechselnden Darstellungen und dem Zeitpunkt der Bildaufnahme möglich ist.
                    wusa @jomjol last edited by wusa
                    Hallo Zusammen,
                    mich interessiert das ganze auch sehr.
                    Hier ist mein Wasserzähler:
                    Ist es mit dem Zähler möglich eine Auswertung zu machen?
                    Eine Uhr ist leider durch irgendwelche Erhebungen im Glas verdeckt...
                    Außerdem hab ich mir den "Standard" Aufsatz ausgedruckt, dieser passt leider nicht. Vielleicht kann mir da auch jemand helfen.
                    B D S 3 Replies Last reply Reply Quote 0
                      bombaman @wusa last edited by
                      @wusa
                      Bin da auch gerade dran. Ich probier einfach obs funkioniert. Kamera sollte heute kommen.
                      Für die Wasseruhr hab ich einfach das erste Teil angepasst.
                      Adapter.stl
                      W 2 Replies Last reply Reply Quote 1
                        wusa @bombaman last edited by
                        @bombaman
                        Hast du die selbe Wasseruhr wie ich?
                        Oder wie kann ich das anpassen? Hab bisher nur mal kurz Fusion360 angesehen, aber Konstruktion ist überhaupt nicht meiner Baustelle.
                          @wusa
                          Hab die gleiche Wasseruhr.
                          Habs mit tinkercad angepasst.
                            Danielbroker86 @wusa last edited by Danielbroker86
                            @wusa sollte denke auch damit keine Probleme geben! Versuch doch erstmal die Kamera provisorisch links da an dem Rohr oder was das ist zu befestigen. ich hatte Anfangs ne ne CEWA Rolle verklemmt und darauf die Kamera lose aufbauen. Erstmal irgendwie befestigen dass du zumindest ein Bild bekommst. Referenzen festlegen kannst ohne, dass die Kamera zu sehr sich bewegt und dann siehst du ja direkt ob es funktioniert
                              wusa @Danielbroker86 last edited by
                              @danielbroker86
                              Danke für den Tipp. Mein ESP sollte normal morgen kommen.
                              Werde ich dann direkt mal ausprobieren.
                                @bombaman
                                Dein Adapter ist gerade fertig geworden mit dem Drucken.
                                Passt wunderbar!
                                  @wusa
                                  Gerne
                                    HelmutLinner @bombaman last edited by
                                    @bombaman
                                    Hallo ich versuche die ESP Cam zu starten nachdem ich alles geflasht habe und die dateien auf die SD karte gespeichert habe nach dem Formatieren. Ich habe auch in der wlan.ini datei meine daten reingeschrieben ssid = "xxxx"
                                    password = "xxxx"
                                    Aber ich bekomme immer die Fehlermeldung
                                    open file /sdcard/wlan.ini in mode r
                                    file loaded
                                    No SSID and PASSWORD set!!!Hostname not set.
                                    abort() was called at PC 0x40153c1b on core 0
                                    Ich habe schon "Editor" und "Notepad++" probiert aber es funktioniert nicht
                                    hier nochmal alles:
                                    rst:0x1 (POWERON_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT)
                                    ho 0 tail 12 room 4
                                    entry 0x40080688
                                    I (881) psram: This chip is ESP32-D0WD
                                    I (886) spiram: Found 64MBit SPI RAM device
                                    I (890) spiram: SPI RAM mode: flash 40m sram 40m
                                    I (896) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
                                    I (903) cpu_start: Pro cpu up.
                                    I (907) cpu_start: Application information:
                                    I (911) cpu_start: Project name:     esp32cam-server-only
                                    I (917) cpu_start: App version:      0.0.9.3
                                    I (922) cpu_start: Compile time:     Dec  2 2021 21:53:54
                                    I (929) cpu_start: ELF file SHA256:  d31ca3157c9027f1...
                                    I (934) cpu_start: ESP-IDF:          3.40100.200827
                                    I (940) cpu_start: Starting app cpu, entry point is 0x40081b00
                                    I (0) cpu_start: App cpu up.
                                    I (1838) spiram: SPI SRAM memory test OK
                                    I (1838) heap_init: Initializing. RAM available for dynamic allocation:
                                    I (1838) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
                                    I (1844) heap_init: At 3FFC2A10 len 0001D5F0 (117 KiB): DRAM
                                    I (1851) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
                                    I (1857) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
                                    I (1864) heap_init: At 4009CBB4 len 0000344C (13 KiB): IRAM
                                    I (1870) cpu_start: Pro cpu start user code
                                    I (1875) spiram: Adding pool of 4096K of external SPI memory to heap allocator
                                    I (1900) spi_flash: detected chip: generic
                                    I (1901) spi_flash: flash io: dio
                                    I (1901) cpu_start: Starting scheduler on PRO CPU.
                                    I (0) cpu_start: Starting scheduler on APP CPU.
                                    I (1909) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations
                                    I (1939) main: Using SDMMC peripheral
                                    Type: SDHC/SDXC
                                    Speed: 20 MHz
                                    I (1979) server_ota: Start CheckOTAUpdateCheck ...
                                    I (1989) server_ota: SHA-256 for the partition table: : 9d4a2809ae90fb20709a8ca3dd3ac3462e1e73286bcd31b689060c91de06fa3a
                                    I (2049) server_ota: SHA-256 for bootloader: : fcdaa822cbfd3931bcf8b49d91f2b86a98b93513bdbadb110eecd54f32d13c55
                                    I (2689) server_ota: SHA-256 for current firmware: : c3447097e655d087ac6d2a666307dad4d95e8dd648f4870ac0521f6b4fe209aa
                                    CheckOTAUpdate Partition: ESP_OK
                                    file loaded
                                    Backtrace: 0x4008cfb0:0x3ffc4750 0x4008d3e1:0x3ffc4770 0x40153c1b:0x3ffc4790 0x40153c62:0x3ffc47b0 0x40153ff7:0x3ffc47d0 0x40163257:0x3ffc47f0 0x400dae5b:0x3ffc4810 0x400db033:0x3ffc4840 0x400d3976:0x3ffc49e0 0x400e6dff:0x3ffc4a60
                                    Rebooting...
                                    kann mir da vielleicht jemand helfen ?
                                      bombaman @HelmutLinner last edited by bombaman
                                      @helmutlinner
                                      Ist das eventuell auskommentiert?
                                      Schau mal nach ob am anfang der Zeile ein ; steht.
                                      Das musst du dann löschen.
                                        @bombaman nein dass hab ich schon geschaut
                                        ssid = "xxxx"
                                        password = "xxxx"
                                        hostname = "watermeter"
                                        ;hostname is optional
                                        ;if you want to use a fixed IP you need to specify the following 3 parameters (ip, gateway, netmask) with IP4-Addresses "123.456.789.012"
                                        ;ip = "IP4-ADDRESS"
                                        ;gateway = "IP4-ADDRESS"
                                        ;netmask = "255.255.255.0"
                                        ;in some cases you want to specify the DNS server as well (especially, if it is not identical to the gateway - this is optional for a fixed IP
                                        ;dns = "IP4-ADDRESS"
                                        passt das so wenn ich bei xxx meine SSID und mein passwort rein schreibe ?
                                          @helmutlinner
                                          Passt so. In die Anführungszeichen.
                                            jomjol @bombaman last edited by
                                            @HelmutLinner Ich vermute, dass deine SD Karte zwar erkannt wird, aber trotzdem das File nicht richtig gelesen wird. Das hatte ich auch schonmal bei mir mit unterschiedlichen SD-Karten. Das ist ein echt ungeschickter Fehler, da ich den nicht gut abfangen kann.
                                            Probier bitte mal eine andere SD-Karte - vor allem keine 32GB, sondern deutlich kleiner (4GB).
                                            238
                                            3411
                                            2012278
