      MCU @Nonixnarrez last edited by
      @nonixnarrez
      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/beispiele/geraete-einstellungen/datenpunkt-eigenschaften/ip-adresse-href
        MCU @j1s2e3 last edited by MCU
        @j1s2e3
        Da muss ein boolean rein, da der Datenpunkt Anzeige ja ein boolean ist:
        {"false":"aus","true":"an"}
        Wie sind die Einstellungen zur SwitchAction?
          @j1s2e3 Web-Adapter neugestartet?
            sigi234 Forum Testing Most Active @Zefau last edited by sigi234
            @zefau
            Seit Version 18 kommt das:
            jarvis.0
            2021-12-21 15:39:20.445	warn	alias.0.Geschirrspüler.BSH_Common_Command_PauseProgram is not a valid state
            jarvis.0
            2021-12-21 15:39:20.344	warn	alias.0.Geschirrspüler.BSH_Common_Command_ResumeProgram is not a valid state
            jarvis.0
            2021-12-21 15:39:20.276	warn	alias.0.Geschirrspüler.BSH_Common_Command_StopProgram is not a valid state
            jarvis.0
            2021-12-21 15:39:19.974	warn	http://192.168.178.20:8082/vis.0/yamaha-rx-v481.png is not a valid state
            jarvis.0
            2021-12-21 15:39:19.902	warn	tr-064.0.phonebook.number is not a valid state
            jarvis.0
            2021-12-21 15:39:19.814	warn	tr-064.0.phonebook.name is not a valid state
            jarvis.0
            2021-12-21 15:39:19.709	warn	tr-064.0.phonebook.image is not a valid state
            jarvis.0
            2021-12-21 15:39:19.703	warn	.ACTUAL is not a valid state
            jarvis.0
            2021-12-21 15:39:19.702	warn	.ACTUAL is not a valid state
            jarvis.0
            jarvis.0
            jarvis.0
            jarvis.0
            2021-12-21 15:39:19.701	warn	.ACTUAL is not a valid state
            jarvis.0
            2021-12-21 15:39:19.353	warn	.ACTUAL is not a valid state
            jarvis.0
            2021-12-21 15:39:19.298	warn	hue.0.Philips_hue.Alle.scene_nachtlicht is not a valid state
            jarvis.0
            2021-12-21 15:39:19.245	warn	hue.0.Philips_hue.Alle.scene_gedimmt is not a valid state
            jarvis.0
            2021-12-21 15:39:19.167	warn	hue.0.Philips_hue.Alle.scene_hell is not a valid state
            jarvis.0
            2021-12-21 15:39:19.086	warn	hue.0.Philips_hue.Alle.scene_frühlingsblüten is not a valid state
            jarvis.0
            2021-12-21 15:39:19.000	warn	hue.0.Philips_hue.Alle.scene_nordlichter is not a valid state
            jarvis.0
            2021-12-21 15:39:18.893	warn	hue.0.Philips_hue.Alle.scene_tropendämmerung is not a valid state
            jarvis.0
            2021-12-21 15:39:18.788	warn	hue.0.Philips_hue.Alle.scene_sonnenuntergang_savanne is not a valid state
            jarvis.0
            2021-12-21 15:39:18.706	warn	hue.0.Philips_hue.Alle.scene_energie_tanken is not a valid state
            jarvis.0
            2021-12-21 15:39:18.609	warn	hue.0.Philips_hue.Alle.scene_konzentrieren is not a valid state
            jarvis.0
            2021-12-21 15:39:18.438	warn	hue.0.Philips_hue.Alle.scene_lesen is not a valid state
            jarvis.0
            2021-12-21 15:39:18.308	warn	hue.0.Philips_hue.Alle.scene_entspannen is not a valid state
            jarvis.0
            2021-12-21 15:39:18.223	warn	hue.0.Philips_hue.Büro.scene_nachtlicht is not a valid state
            jarvis.0
            2021-12-21 15:39:18.142	warn	hue.0.Philips_hue.Büro.scene_frühlingsblüten is not a valid state
            jarvis.0
            2021-12-21 15:39:18.036	warn	hue.0.Philips_hue.Büro.scene_nordlichter is not a valid state
            jarvis.0
            2021-12-21 15:39:17.878	warn	hue.0.Philips_hue.Büro.scene_tropendämmerung is not a valid state
            jarvis.0
            2021-12-21 15:39:17.669	warn	hue.0.Philips_hue.Büro.scene_sonnenuntergang_savanne is not a valid state
            jarvis.0
            2021-12-21 15:39:17.541	warn	hue.0.Philips_hue.Büro.scene_energie_tanken is not a valid state
            jarvis.0
            2021-12-21 15:39:17.401	warn	hue.0.Philips_hue.Büro.scene_konzentrieren is not a valid state
            jarvis.0
            2021-12-21 15:39:17.302	warn	hue.0.Philips_hue.Büro.scene_lesen is not a valid state
            jarvis.0
            2021-12-21 15:39:17.175	warn	hue.0.Philips_hue.Büro.scene_entspannen is not a valid state
            jarvis.0
            2021-12-21 15:39:17.127	warn	hue.0.Philips_hue.Küche.scene_scene_storagescene_ is not a valid state
            jarvis.0
            2021-12-21 15:39:17.073	warn	hue.0.Philips_hue.Küche.scene_bewegung is not a valid state
            jarvis.0
            2021-12-21 15:39:17.023	warn	hue.0.Philips_hue.Küche.scene_scene_recoveryscene_ is not a valid state
            jarvis.0
            2021-12-21 15:39:16.946	warn	hue.0.Philips_hue.Küche.scene_nachtlicht is not a valid state
            jarvis.0
            2021-12-21 15:39:16.881	warn	hue.0.Philips_hue.Küche.scene_energie_tanken is not a valid state
            jarvis.0
            2021-12-21 15:39:16.830	warn	hue.0.Philips_hue.Küche.scene_hell is not a valid state
            jarvis.0
            2021-12-21 15:39:16.771	warn	hue.0.Philips_hue.Küche.scene_lesen is not a valid state
            jarvis.0
            2021-12-21 15:39:16.715	warn	hue.0.Philips_hue.Küche.scene_gedimmt_küche is not a valid state
            jarvis.0
            2021-12-21 15:39:16.622	warn	hue.0.Philips_hue.Küche.scene_entspannen is not a valid state
            jarvis.0
            2021-12-21 15:39:16.544	warn	hue.0.Philips_hue.Küche.scene_konzentrieren_küche is not a valid state
            jarvis.0
            2021-12-21 15:39:16.488	warn	hue.0.Philips_hue.Küche.scene_frühlingsblüten is not a valid state
            jarvis.0
            2021-12-21 15:39:16.440	warn	hue.0.Philips_hue.Küche.scene_sonnenuntergang_savanne is not a valid state
            jarvis.0
            2021-12-21 15:39:16.392	warn	hue.0.Philips_hue.Küche.scene_tropendämmerung is not a valid state
            jarvis.0
            2021-12-21 15:39:16.340	warn	hue.0.Philips_hue.Bad_Room.scene_gedimmt_bad is not a valid state
            jarvis.0
            2021-12-21 15:39:16.293	warn	hue.0.Philips_hue.Bad_Room.scene_hell_bad is not a valid state
            jarvis.0
            2021-12-21 15:39:16.237	warn	hue.0.Philips_hue.Bad_Room.scene_nachtlicht_bad is not a valid state
            jarvis.0
            2021-12-21 15:39:16.166	warn	http://192.168.178.20:8082/vis.0/VU_analog.gif is not a valid state
            Ebenso kommt bei den Bar Charts das : (bei mouseover in den Balken)
              MCU @sigi234 last edited by
              @sigi234 Welches Hintergrundbild nutzt du?
                sigi234 Forum Testing Most Active @MCU last edited by
                @mcu sagte in jarvis v3.0.0 (beta) - just another remarkable vis:
                background-image: url("https://images.hdqwalls.com/download/black-gradient-b9-1920x1080.jpg");
                  j1s2e3 @MCU last edited by
                  @mcu said in jarvis v3.0.0 (beta) - just another remarkable vis:
                  @j1s2e3
                  Sorry, habe den falschen Screenshot erwischt. Das hatte ich auch schon angepasst. Habe vorher schon alles mögliche ausprobiert. D.h. die Booleanvariante unter Anzeigevariante ist so drin, und geht trotzdem nicht.
                  Default. Habe nix dran geändert.
                    @j1s2e3 Das sollte so aussehen:
                    Mach mal bitte ein Upload von jarvis:
                    iobroker upload jarvis
                    aus der console
                    Welche Version? v3.0.0-beta.18
                      Nee hatte ich nicht. Eben probiert, nach F5 in Jarvis dauert es jetzt ca. 10 Sekunden bis Sonnenauf- und Sonnenuntergang angezeigt werden. Kalendarwoche ist sofort da.
                        aus der console
                        v3.0.0-beta.18
                        iobroker upload habe ich gemacht. Dann iobroker neu gestartet. Alles beim alten. Geht nicht.
                        Dann habe ich den DP on_on gelöscht und neu angelegt. SwitchAction->Einstellungen sieht jetzt so aus:
                        Immerhin habe ich jetzt 2 Auswahlmöglichkeiten für den Datenpunktwert im Dropdownmenu.
                          j1s2e3 @j1s2e3 last edited by
                          @MCU
                          Jarvis-Update mache ich immer so ^^^
                          Und noch eine Info. Ich hatte vorher Jarvis V2 am laufen. Evtl. ist beim Update/Konvertieren irgendwas schief gelaufen???
                            @j1s2e3 Das Update passt schon so. Upload auf der console hast du auch gemacht?
                            Hat mit der Umsetzung v2-> v3 nichts zu tun.
                              j1s2e3 @MCU last edited by j1s2e3
                              Ja, habe das upload gemacht:
                              root@pi:/opt/iobroker# iobroker upload jarvis
                              upload [15] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/zefau.jpg zefau.jpg image/jpeg
                              upload [14] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/words.js words.js application/javascript
                              upload [13] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/jarvis.png jarvis.png image/png
                              upload [12] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/index_m.html index_m.html text/html
                              upload [11] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [10] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [9] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [8] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [7] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [6] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [5] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [4] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [3] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [2] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [1] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/admin.js admin.js application/javascript
                              upload [0] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/admin.css admin.css text/css
                              upload [100] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/moon_24.3f480ec5.png img/moon_24.3f480ec5.png image/png
                              upload [90] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/moon_15.a88798db.png img/moon_15.a88798db.png image/png
                              upload [80] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/web/icon-512-maskable.png icons/web/icon-512-maskable.png image/png
                              upload [70] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/ios/AppIcon@2x.png icons/ios/AppIcon@2x.png image/png
                              upload [60] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/ios/AppIcon-29@2x~ipad.png icons/ios/AppIcon-29@2x~ipad.png image/png
                              upload [50] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/icon-192x192.png icons/icon-192x192.png image/png
                              upload [40] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/android/res/mipmap-xxhdpi/ic_launcher.png icons/android/res/mipmap-xxhdpi/ic_launcher.png image/png
                              upload [30] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/android/res/mipmap-anydpi-v26/ic_launcher.xml icons/android/res/mipmap-anydpi-v26/ic_launcher.xml application/xml
                              upload [20] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icon-128x128.png icon-128x128.png image/png
                              upload [19] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icon-1024x1024.png icon-1024x1024.png image/png
                              upload [18] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/materialdesignicons-webfont.606b1642.woff2 fonts/materialdesignicons-webfont.606b1642.woff2 font/woff2
                              upload [17] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/materialdesignicons-webfont.5dff34d5.woff fonts/materialdesignicons-webfont.5dff34d5.woff font/woff
                              upload [16] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/flUhRq6tzZclQEJ-Vdg-IuiaDsNcIhQ8tQ.cf9862e8.woff2 fonts/flUhRq6tzZclQEJ-Vdg-IuiaDsNcIhQ8tQ.cf9862e8.woff2 font/woff2
                              upload [15] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/flUhRq6tzZclQEJ-Vdg-IuiaDsNa.40fa1be9.woff fonts/flUhRq6tzZclQEJ-Vdg-IuiaDsNa.40fa1be9.woff font/woff
                              upload [14] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOmCnqEu92Fr1Mu4mxM.9b78ea3b.woff fonts/KFOmCnqEu92Fr1Mu4mxM.9b78ea3b.woff font/woff
                              upload [13] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOlCnqEu92Fr1MmYUtfBBc-.b555d228.woff fonts/KFOlCnqEu92Fr1MmYUtfBBc-.b555d228.woff font/woff
                              upload [12] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOlCnqEu92Fr1MmWUlfBBc-.0344cc3c.woff fonts/KFOlCnqEu92Fr1MmWUlfBBc-.0344cc3c.woff font/woff
                              upload [11] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOlCnqEu92Fr1MmSU5fBBc-.877b9231.woff fonts/KFOlCnqEu92Fr1MmSU5fBBc-.877b9231.woff font/woff
                              upload [10] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOlCnqEu92Fr1MmEU9fBBc-.ddd11dab.woff fonts/KFOlCnqEu92Fr1MmEU9fBBc-.ddd11dab.woff font/woff
                              upload [9] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOkCnqEu92Fr1MmgVxIIzQ.9391e6e2.woff fonts/KFOkCnqEu92Fr1MmgVxIIzQ.9391e6e2.woff font/woff
                              upload [8] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/favicon.ico favicon.ico image/vnd.microsoft.icon
                              upload [7] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/vendor.2d4cce86.css css/vendor.2d4cce86.css text/css
                              upload [6] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/app.b35c1dd2.css css/app.b35c1dd2.css text/css
                              upload [5] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/5.b4273620.css css/5.b4273620.css text/css
                              upload [4] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/4.16536d15.css css/4.16536d15.css text/css
                              upload [3] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/3.1d9edfe1.css css/3.1d9edfe1.css text/css
                              upload [2] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/1.2364fbbf.css css/1.2364fbbf.css text/css
                              upload [1] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/apple-touch-icon.png apple-touch-icon.png image/png
                              upload [0] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/apple-icon-120x120.png apple-icon-120x120.png image/png
                              ... das kaum raus.
                              Danach service iobroker restart.
                                @j1s2e3 Cache im Browser gelöscht? Und dann bin ich draussen.
                                Cache im Web-Adapter ist aus?
                                  Cache gelöscht -> keine Änderung. Switch geht nicht und unter SwitchAction->Einstellung gibt es nur das config#componentOptions#_all#val#options#val
                                  Anderen Browser probiert -> das gleiche
                                  Nochmal neuen DP angelegt, SwitchAction ausgewählt, Einstellungen wie gehabt. Rohwert(val) sehe ich nicht.
                                  Cache im Webadapter ist aus
                                    @j1s2e3 Das muss sich @zefau selbst anschauen.
                                    • U
                                      uwe72 @MCU last edited by
                                      @Zefau Bin grad dran am Pro-Abo abschließen. Der Pro Account ist verknüpft an eine Linux-ID. Werden in 2-3 Wochen den Server austauschen. Kriegen wir den Pro-Account dann umgebogen auf das neue System?
                                      U Zefau 2 Replies Last reply Reply Quote 0
                                      • U
                                        uwe72 @uwe72 last edited by uwe72
                                        Frage: Hab gerade meine VIS von V2 auf V3 migriert. Habe große HTML-Tabellen. In V2 wurde die sauber dargestellt.
                                        In V3 habe ich den komischen Effekt, dass die Tabelle sehr klein wird wenn ich das Fenster groß ziehen. Kann mir jemand einen Tipp geben?
                                          MCU @uwe72 last edited by MCU
                                          @uwe72 Nimm mal die Scale contents to fit widget raus:
                                          ausschalten
                                          Sind das eigene HTML-Tabellen, die selbst erstellt werden?
                                          U 1 Reply Last reply Reply Quote 1
                                          • U
                                            @mcu hat funktioniert. Danke!
                                            Ja, ist in Iobroker selber geschriebenes HTML in JavaScript
                                            1.2k
                                            254
                                            4489
                                            2657786
