      sigi234 Forum Testing Most Active @Zefau last edited by sigi234
      @zefau
      Seit Version 18 kommt das:
      jarvis.0
      2021-12-21 15:39:20.445	warn	alias.0.Geschirrspüler.BSH_Common_Command_PauseProgram is not a valid state
      jarvis.0
      2021-12-21 15:39:20.344	warn	alias.0.Geschirrspüler.BSH_Common_Command_ResumeProgram is not a valid state
      jarvis.0
      2021-12-21 15:39:20.276	warn	alias.0.Geschirrspüler.BSH_Common_Command_StopProgram is not a valid state
      jarvis.0
      2021-12-21 15:39:19.974	warn	http://192.168.178.20:8082/vis.0/yamaha-rx-v481.png is not a valid state
      jarvis.0
      2021-12-21 15:39:19.902	warn	tr-064.0.phonebook.number is not a valid state
      jarvis.0
      2021-12-21 15:39:19.814	warn	tr-064.0.phonebook.name is not a valid state
      jarvis.0
      2021-12-21 15:39:19.709	warn	tr-064.0.phonebook.image is not a valid state
      jarvis.0
      2021-12-21 15:39:19.703	warn	.ACTUAL is not a valid state
      jarvis.0
      2021-12-21 15:39:19.702	warn	.ACTUAL is not a valid state
      jarvis.0
      jarvis.0
      jarvis.0
      jarvis.0
      2021-12-21 15:39:19.701	warn	.ACTUAL is not a valid state
      jarvis.0
      2021-12-21 15:39:19.353	warn	.ACTUAL is not a valid state
      jarvis.0
      2021-12-21 15:39:19.298	warn	hue.0.Philips_hue.Alle.scene_nachtlicht is not a valid state
      jarvis.0
      2021-12-21 15:39:19.245	warn	hue.0.Philips_hue.Alle.scene_gedimmt is not a valid state
      jarvis.0
      2021-12-21 15:39:19.167	warn	hue.0.Philips_hue.Alle.scene_hell is not a valid state
      jarvis.0
      2021-12-21 15:39:19.086	warn	hue.0.Philips_hue.Alle.scene_frühlingsblüten is not a valid state
      jarvis.0
      2021-12-21 15:39:19.000	warn	hue.0.Philips_hue.Alle.scene_nordlichter is not a valid state
      jarvis.0
      2021-12-21 15:39:18.893	warn	hue.0.Philips_hue.Alle.scene_tropendämmerung is not a valid state
      jarvis.0
      2021-12-21 15:39:18.788	warn	hue.0.Philips_hue.Alle.scene_sonnenuntergang_savanne is not a valid state
      jarvis.0
      2021-12-21 15:39:18.706	warn	hue.0.Philips_hue.Alle.scene_energie_tanken is not a valid state
      jarvis.0
      2021-12-21 15:39:18.609	warn	hue.0.Philips_hue.Alle.scene_konzentrieren is not a valid state
      jarvis.0
      2021-12-21 15:39:18.438	warn	hue.0.Philips_hue.Alle.scene_lesen is not a valid state
      jarvis.0
      2021-12-21 15:39:18.308	warn	hue.0.Philips_hue.Alle.scene_entspannen is not a valid state
      jarvis.0
      2021-12-21 15:39:18.223	warn	hue.0.Philips_hue.Büro.scene_nachtlicht is not a valid state
      jarvis.0
      2021-12-21 15:39:18.142	warn	hue.0.Philips_hue.Büro.scene_frühlingsblüten is not a valid state
      jarvis.0
      2021-12-21 15:39:18.036	warn	hue.0.Philips_hue.Büro.scene_nordlichter is not a valid state
      jarvis.0
      2021-12-21 15:39:17.878	warn	hue.0.Philips_hue.Büro.scene_tropendämmerung is not a valid state
      jarvis.0
      2021-12-21 15:39:17.669	warn	hue.0.Philips_hue.Büro.scene_sonnenuntergang_savanne is not a valid state
      jarvis.0
      2021-12-21 15:39:17.541	warn	hue.0.Philips_hue.Büro.scene_energie_tanken is not a valid state
      jarvis.0
      2021-12-21 15:39:17.401	warn	hue.0.Philips_hue.Büro.scene_konzentrieren is not a valid state
      jarvis.0
      2021-12-21 15:39:17.302	warn	hue.0.Philips_hue.Büro.scene_lesen is not a valid state
      jarvis.0
      2021-12-21 15:39:17.175	warn	hue.0.Philips_hue.Büro.scene_entspannen is not a valid state
      jarvis.0
      2021-12-21 15:39:17.127	warn	hue.0.Philips_hue.Küche.scene_scene_storagescene_ is not a valid state
      jarvis.0
      2021-12-21 15:39:17.073	warn	hue.0.Philips_hue.Küche.scene_bewegung is not a valid state
      jarvis.0
      2021-12-21 15:39:17.023	warn	hue.0.Philips_hue.Küche.scene_scene_recoveryscene_ is not a valid state
      jarvis.0
      2021-12-21 15:39:16.946	warn	hue.0.Philips_hue.Küche.scene_nachtlicht is not a valid state
      jarvis.0
      2021-12-21 15:39:16.881	warn	hue.0.Philips_hue.Küche.scene_energie_tanken is not a valid state
      jarvis.0
      2021-12-21 15:39:16.830	warn	hue.0.Philips_hue.Küche.scene_hell is not a valid state
      jarvis.0
      2021-12-21 15:39:16.771	warn	hue.0.Philips_hue.Küche.scene_lesen is not a valid state
      jarvis.0
      2021-12-21 15:39:16.715	warn	hue.0.Philips_hue.Küche.scene_gedimmt_küche is not a valid state
      jarvis.0
      2021-12-21 15:39:16.622	warn	hue.0.Philips_hue.Küche.scene_entspannen is not a valid state
      jarvis.0
      2021-12-21 15:39:16.544	warn	hue.0.Philips_hue.Küche.scene_konzentrieren_küche is not a valid state
      jarvis.0
      2021-12-21 15:39:16.488	warn	hue.0.Philips_hue.Küche.scene_frühlingsblüten is not a valid state
      jarvis.0
      2021-12-21 15:39:16.440	warn	hue.0.Philips_hue.Küche.scene_sonnenuntergang_savanne is not a valid state
      jarvis.0
      2021-12-21 15:39:16.392	warn	hue.0.Philips_hue.Küche.scene_tropendämmerung is not a valid state
      jarvis.0
      2021-12-21 15:39:16.340	warn	hue.0.Philips_hue.Bad_Room.scene_gedimmt_bad is not a valid state
      jarvis.0
      2021-12-21 15:39:16.293	warn	hue.0.Philips_hue.Bad_Room.scene_hell_bad is not a valid state
      jarvis.0
      2021-12-21 15:39:16.237	warn	hue.0.Philips_hue.Bad_Room.scene_nachtlicht_bad is not a valid state
      jarvis.0
      2021-12-21 15:39:16.166	warn	http://192.168.178.20:8082/vis.0/VU_analog.gif is not a valid state
      Ebenso kommt bei den Bar Charts das : (bei mouseover in den Balken)
        MCU @sigi234 last edited by
        @sigi234 Welches Hintergrundbild nutzt du?
          sigi234 Forum Testing Most Active @MCU last edited by
          @mcu sagte in jarvis v3.0.0 (beta) - just another remarkable vis:
          background-image: url("https://images.hdqwalls.com/download/black-gradient-b9-1920x1080.jpg");
            j1s2e3 @MCU last edited by
            @mcu said in jarvis v3.0.0 (beta) - just another remarkable vis:
            @j1s2e3
            Da muss ein boolean rein, da der Datenpunkt Anzeige ja ein boolean ist:
            {"false":"aus","true":"an"}
            Sorry, habe den falschen Screenshot erwischt. Das hatte ich auch schon angepasst. Habe vorher schon alles mögliche ausprobiert. D.h. die Booleanvariante unter Anzeigevariante ist so drin, und geht trotzdem nicht.
            Wie sind die Einstellungen zur SwitchAction?
            Default. Habe nix dran geändert.
              MCU @j1s2e3 last edited by MCU
              @j1s2e3 Das sollte so aussehen:
              Mach mal bitte ein Upload von jarvis:
              iobroker upload jarvis
              aus der console
              Welche Version? v3.0.0-beta.18
                @j1s2e3 Web-Adapter neugestartet?
                Nee hatte ich nicht. Eben probiert, nach F5 in Jarvis dauert es jetzt ca. 10 Sekunden bis Sonnenauf- und Sonnenuntergang angezeigt werden. Kalendarwoche ist sofort da.
                  aus der console
                  v3.0.0-beta.18
                  iobroker upload habe ich gemacht. Dann iobroker neu gestartet. Alles beim alten. Geht nicht.
                  Dann habe ich den DP on_on gelöscht und neu angelegt. SwitchAction->Einstellungen sieht jetzt so aus:
                  Immerhin habe ich jetzt 2 Auswahlmöglichkeiten für den Datenpunktwert im Dropdownmenu.
                    j1s2e3 @j1s2e3 last edited by
                    @MCU
                    Jarvis-Update mache ich immer so ^^^
                    Und noch eine Info. Ich hatte vorher Jarvis V2 am laufen. Evtl. ist beim Update/Konvertieren irgendwas schief gelaufen???
                      @j1s2e3 Das Update passt schon so. Upload auf der console hast du auch gemacht?
                      Hat mit der Umsetzung v2-> v3 nichts zu tun.
                        j1s2e3 @MCU last edited by j1s2e3
                        Ja, habe das upload gemacht:
                        root@pi:/opt/iobroker# iobroker upload jarvis
                        upload [15] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/zefau.jpg zefau.jpg image/jpeg
                        upload [14] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/words.js words.js application/javascript
                        upload [13] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/jarvis.png jarvis.png image/png
                        upload [12] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/index_m.html index_m.html text/html
                        upload [11] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [10] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [9] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [8] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [7] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [6] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [5] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [4] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [3] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [2] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [1] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/admin.js admin.js application/javascript
                        upload [0] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/admin.css admin.css text/css
                        upload [100] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/moon_24.3f480ec5.png img/moon_24.3f480ec5.png image/png
                        upload [90] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/moon_15.a88798db.png img/moon_15.a88798db.png image/png
                        upload [80] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/web/icon-512-maskable.png icons/web/icon-512-maskable.png image/png
                        upload [70] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/ios/AppIcon@2x.png icons/ios/AppIcon@2x.png image/png
                        upload [60] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/ios/AppIcon-29@2x~ipad.png icons/ios/AppIcon-29@2x~ipad.png image/png
                        upload [50] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/icon-192x192.png icons/icon-192x192.png image/png
                        upload [40] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/android/res/mipmap-xxhdpi/ic_launcher.png icons/android/res/mipmap-xxhdpi/ic_launcher.png image/png
                        upload [30] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/android/res/mipmap-anydpi-v26/ic_launcher.xml icons/android/res/mipmap-anydpi-v26/ic_launcher.xml application/xml
                        upload [20] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icon-128x128.png icon-128x128.png image/png
                        upload [19] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icon-1024x1024.png icon-1024x1024.png image/png
                        upload [18] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/materialdesignicons-webfont.606b1642.woff2 fonts/materialdesignicons-webfont.606b1642.woff2 font/woff2
                        upload [17] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/materialdesignicons-webfont.5dff34d5.woff fonts/materialdesignicons-webfont.5dff34d5.woff font/woff
                        upload [16] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/flUhRq6tzZclQEJ-Vdg-IuiaDsNcIhQ8tQ.cf9862e8.woff2 fonts/flUhRq6tzZclQEJ-Vdg-IuiaDsNcIhQ8tQ.cf9862e8.woff2 font/woff2
                        upload [15] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/flUhRq6tzZclQEJ-Vdg-IuiaDsNa.40fa1be9.woff fonts/flUhRq6tzZclQEJ-Vdg-IuiaDsNa.40fa1be9.woff font/woff
                        upload [14] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOmCnqEu92Fr1Mu4mxM.9b78ea3b.woff fonts/KFOmCnqEu92Fr1Mu4mxM.9b78ea3b.woff font/woff
                        upload [13] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOlCnqEu92Fr1MmYUtfBBc-.b555d228.woff fonts/KFOlCnqEu92Fr1MmYUtfBBc-.b555d228.woff font/woff
                        upload [12] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOlCnqEu92Fr1MmWUlfBBc-.0344cc3c.woff fonts/KFOlCnqEu92Fr1MmWUlfBBc-.0344cc3c.woff font/woff
                        upload [11] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOlCnqEu92Fr1MmSU5fBBc-.877b9231.woff fonts/KFOlCnqEu92Fr1MmSU5fBBc-.877b9231.woff font/woff
                        upload [10] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOlCnqEu92Fr1MmEU9fBBc-.ddd11dab.woff fonts/KFOlCnqEu92Fr1MmEU9fBBc-.ddd11dab.woff font/woff
                        upload [9] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOkCnqEu92Fr1MmgVxIIzQ.9391e6e2.woff fonts/KFOkCnqEu92Fr1MmgVxIIzQ.9391e6e2.woff font/woff
                        upload [8] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/favicon.ico favicon.ico image/vnd.microsoft.icon
                        upload [7] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/vendor.2d4cce86.css css/vendor.2d4cce86.css text/css
                        upload [6] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/app.b35c1dd2.css css/app.b35c1dd2.css text/css
                        upload [5] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/5.b4273620.css css/5.b4273620.css text/css
                        upload [4] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/4.16536d15.css css/4.16536d15.css text/css
                        upload [3] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/3.1d9edfe1.css css/3.1d9edfe1.css text/css
                        upload [2] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/1.2364fbbf.css css/1.2364fbbf.css text/css
                        upload [1] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/apple-touch-icon.png apple-touch-icon.png image/png
                        upload [0] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/apple-icon-120x120.png apple-icon-120x120.png image/png
                        ... das kaum raus.
                        Danach service iobroker restart.
                          @j1s2e3 Cache im Browser gelöscht? Und dann bin ich draussen.
                          Cache im Web-Adapter ist aus?
                            Cache gelöscht -> keine Änderung. Switch geht nicht und unter SwitchAction->Einstellung gibt es nur das config#componentOptions#_all#val#options#val
                            Anderen Browser probiert -> das gleiche
                            Nochmal neuen DP angelegt, SwitchAction ausgewählt, Einstellungen wie gehabt. Rohwert(val) sehe ich nicht.
                            Cache im Webadapter ist aus
                              @j1s2e3 Das muss sich @zefau selbst anschauen.
                              • U
                                uwe72 @MCU last edited by
                                @Zefau Bin grad dran am Pro-Abo abschließen. Der Pro Account ist verknüpft an eine Linux-ID. Werden in 2-3 Wochen den Server austauschen. Kriegen wir den Pro-Account dann umgebogen auf das neue System?
                                U Zefau 2 Replies Last reply Reply Quote 0
                                • U
                                  uwe72 @uwe72 last edited by uwe72
                                  Frage: Hab gerade meine VIS von V2 auf V3 migriert. Habe große HTML-Tabellen. In V2 wurde die sauber dargestellt.
                                  In V3 habe ich den komischen Effekt, dass die Tabelle sehr klein wird wenn ich das Fenster groß ziehen. Kann mir jemand einen Tipp geben?
                                    MCU @uwe72 last edited by MCU
                                    @uwe72 Nimm mal die Scale contents to fit widget raus:
                                    ausschalten
                                    Sind das eigene HTML-Tabellen, die selbst erstellt werden?
                                    U 1 Reply Last reply Reply Quote 1
                                    • U
                                      @mcu hat funktioniert. Danke!
                                      Ja, ist in Iobroker selber geschriebenes HTML in JavaScript
                                      • Zefau
                                        Zefau @uwe72 last edited by
                                        @uwe72 sagte in jarvis v3.0.0 (beta) - just another remarkable vis:
                                        Wie kommst du darauf? Ist nicht verknüpft.
                                        M U 2 Replies Last reply Reply Quote 0
                                          MCU @Zefau last edited by MCU
                                          @zefau
                                          Der Pro-Account ist doch an die ioBrokerID geknüpft?
                                          Wenn das komplette ioBroker-System, durch ein Restore vom "alten" System auf ein neues Hardwaresystem gespielt wird, hat dann ioBroker noch die gleiche ioBrokerID?
                                          Und ist somit die Pro-Lizenz (jarvis) dann noch gültig?
                                          • U
                                            uwe72 @Zefau last edited by
                                            @zefau ich meine dies hier:
                                            Siehe unten links in gelb.
                                            1.2k
                                            254
                                            4489
                                            2657786
