    4. Adapter "smartmeter"
      klassisch Most Active @mich last edited by
      @mich Adapter auf "debug" stellen und dann bitte das log vom Start posten.
        mich @klassisch last edited by
        @klassisch
        2021-12-22 15:16:25.047 - info: host.ioBroker "system.adapter.smartmeter.0" enabled
        2021-12-22 15:16:25.120 - info: host.ioBroker instance system.adapter.smartmeter.0 started with pid 4135
        2021-12-22 15:16:26.549 - debug: smartmeter.0 (4135) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2021-12-22 15:16:26.585 - debug: smartmeter.0 (4135) Objects client ready ... initialize now
        2021-12-22 15:16:26.587 - debug: smartmeter.0 (4135) Objects create System PubSub Client
        2021-12-22 15:16:26.589 - debug: smartmeter.0 (4135) Objects create User PubSub Client
        2021-12-22 15:16:26.590 - debug: smartmeter.0 (4135) Objects client initialize lua scripts
        2021-12-22 15:16:26.612 - debug: smartmeter.0 (4135) Objects connected to redis: 127.0.0.1:9001
        2021-12-22 15:16:26.620 - debug: smartmeter.0 (4135) objectDB connected
        2021-12-22 15:16:26.622 - debug: smartmeter.0 (4135) Redis States: Use Redis connection: 127.0.0.1:9000
        2021-12-22 15:16:26.630 - debug: smartmeter.0 (4135) States create System PubSub Client
        2021-12-22 15:16:26.631 - debug: smartmeter.0 (4135) States create User PubSub Client
        2021-12-22 15:16:26.637 - debug: smartmeter.0 (4135) States connected to redis: 127.0.0.1:9000
        2021-12-22 15:16:26.638 - debug: smartmeter.0 (4135) statesDB connected
        2021-12-22 15:16:26.733 - debug: smartmeter.0 (4135) Plugin sentry Initialize Plugin (enabled=true)
        2021-12-22 15:16:26.952 - info: smartmeter.0 (4135) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.22.8, js-controller: 3.3.21
        2021-12-22 15:16:26.986 - debug: smartmeter.0 (4135) SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"30","anotherQueryDelay":"1000","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":9600,"transportSerialDataBits":8,"transportSerialStopBits":1,"transportSerialParity":"none","transportSerialMessageTimeout":null,"protocolSmlIgnoreInvalidCRC":false}
        2021-12-22 15:16:26.989 - debug: smartmeter.0 (4135) CREATE SERIALPORT: 9600 8 1 none
        2021-12-22 15:16:26.996 - debug: smartmeter.0 (4135) SET MESSAGE TIMEOUT TIMER: 120000
        2021-12-22 15:16:27.015 - debug: smartmeter.0 (4135) connected set to false
        K apollon77 2 Replies Last reply Reply Quote 0
          @mich da sehe ich aber noch keine Fehlermeldung oder timeout meldung oder ein Einlesen von Daten. Ist das das ganze log?
            Homoran Global Moderator Administrators @klassisch last edited by
            @klassisch sagte in Adapter "smartmeter":
            das müsste ggf. nach einiger Zeit noch kommen.
            Hier ist nix
              Homoran Global Moderator Administrators @mich last edited by
              @mich sagte in Adapter "smartmeter":
              Laut Handbuch meines Stromzählers (EMH eHZ-KW8...) sollten auch die Einstellungen passen:
              was steht denn da drin?
                apollon77 @mich last edited by Homoran
                @mich Da kommt nix rein ... aber du hast nicht an der Shell noch die Ausgabe laufen oder? Dann ist ggf der Port geblockt
                  bist du sicher, das /dev/USB0 korrekt ist?
                  hast du nichts wo deine Hardware mit drin steht zur Verfügung?
                    mich last edited by
                    Ich glaub, ich hab mein Problem gefunden:
                    https://smarthome.buanet.de/2020/02/usb-devices-im-iobroker-docker-container-nutzen/
                      deswegen frug ich nach DOCKER
                        apollon77 @Homoran last edited by
                        @homoran du frugst? 🙂
                          marsmännchen last edited by
                          weiss vielleicht jemand ob es möglich ist im Netz Burgenland (Österreich) einen Landis+Gyr E450 mit dem Hinchi-USB und Smartmeteradapter auszulesen?
                          Hat das jemand im Einsatz?
                          Ich hab bis jetzt noch keine funktionierende Einstellung gefunden.
                          Die opt. Schnittstelle ist frei, und ich bekomme mit minicom auch alle 5sec. allerhand Daten. Aber mein Adapter bleibt bei "Verbunden mit Gerät oder Dienst" immer rot.
                          MfG
                          Patrick
                          Homoran A 2 Replies Last reply Reply Quote 0
                            Homoran Global Moderator Administrators @marsmännchen last edited by
                            @marsmännchen sagte in Adapter "smartmeter":
                            das klingt nach verschlüsselter Übertragung
                            Das kann der Adapter nicht
                              marsmännchen @Homoran last edited by
                              @homoran JA GENAU! Danke!
                              Die verschlüsseln. Daran liegt es? Na wenigstens liege ich mit meiner Vermutung richtig. Dann kann ich schon mal aufhören den Adapter zu quälen.
                              Ich habe den Energielieferanten angeschrieben ob er die Verschlüsselung deaktivieren kann.
                              Mal sehen. In einem anderen Forum wird behauptet das es möglich ist.
                              Vielen dank!! Frohe Feiertage
                                auch hier 🙂
                                da gab es irgendeinen Workaround - musst mal suchen (daher weiss ich es ja mirt der Ösi-Verschlüsselung)
                                  hotwire last edited by
                                  ich habe Dank großer Unterstützung eines Freunds IOBroker mit dem adapter Smartmeter auf einem Rasperry 4 laufen.
                                  Zweck der Aktion ist, endlichen die Ursache der hohen Grundlast in meinem Elternhaus zu finden.
                                  Es läuft eigentlich auf Anhieb, allerdings wird mir der Aktualwert der Leistung nicht übertragen.
                                  Der Zweirichtungszähler ist ein Itron 3.HZ-AC-D1-A1 Die Zählerpin ist eingegeben, und die Pinabfrage ausgeschaltet.
                                  Im Display wird nun der Aktualwert der Leistung in Zeile 2 dauerhaft angezeigt.
                                  Wie kann ich nun die Smartmeterinstanz so konfigurieren, dass mir diese Daten geloggt werden?
                                    klassisch Most Active @hotwire last edited by
                                    @hotwire Bezieht sich die Frage generell auf Logging in ioBroker oder auf den Smartmeter-Adapter?
                                    Der Smartmeteradapter zeigt in den Objekten alles an, was vom Zähler kommt. Da kann und muß man nichts einstellen.
                                    Wenn etwas nicht angezeigt wird, dann schickt es der Zähler nicht.
                                    also nochmals die Anleitung vom Zähler und vom Betreiber durchackern. Vielleicht muß man da zusätzlich noch was einschalten bei diesem Blinkcode-Menue.
                                    Ich habe auch einen itron, allerdings nur Bezug, kein Zweirichtung
                                    Da kommt die Momentanleistung unter
                                    smartmeter.0.1-0:16_7_0__255
                                      Homoran Global Moderator Administrators @klassisch last edited by Homoran
                                      @hotwire
                                      z.B. INFO - ON
                                        @klassisch
                                        Also ich dachte das man beim Adapter Smartmeter einen Parameter setzen muss, um alle Daten vom Zähler zu holen. Der Lesekopf hat auch Infrarot LED zum schreiben.
                                        Ja, dann werde ich erstmal googeln müssen, was am Zähler noch einstellbar ist.
                                        @Homoran
                                        Wo soll /kann ich Info ON setzen? Am Zähler oder beim Adapter Smartmeter
                                          klassisch Most Active @hotwire last edited by klassisch
                                          @hotwire sagte in Adapter "smartmeter":
                                          Am Zähler. Neben der Pin muß man mit "Info on" die aAusgabe aktivieren. Aber vielleicht hat Dein Zähler noch andere Eingabeerfordernisse.
                                          Wenn Dein Zähler ein "kleines Smartmeter" vom Typ "Moderne Meßeinrichtung" ist, dann kommen die Daten etwa im Sekundentakt automatisch auf der IR-Infoschnittstelle raus. Das ist im FNN-Lastenheft vorgeschrieben. Protokoll wäre dann SML
                                          Wenn Dein Zähler aber ein großes "Modernes Meßsystem" ist, dann ist für die Info-Schnittstelle nichts vorgeschrieben und jeder Betreiber macht, was er will. Dann kann man die Daten entweder über die HAN Schnittstelle oder über das Portal des Betreibers holen. Sowas bekommt man heute typischerweise bei >6000kWh/a oder Einspeisungleistung > 7000kWp
                                          Wenn Dein Zähler etwas ganz anderes ist, z.B. ein etwas älterer Einspeisezähler, dann kann der auch eine D0 Schnittstelle haben und sich ganz anders verhalten. Der Smartmerter-Adapter unterstützt zwar viel, aber man sollte wissen, wie der Zähler konfiguriert ist.
                                            hotwire @klassisch last edited by
                                            @klassisch
                                            Ich denke es handelt hier sich um "kleines Smartmeter".
                                            Der Zähler hat keine Internetanbindung, falls das mit HAN Schnittstelle / Portal gemeint ist.
                                            Mit "Info On" wird die Ausgabe über die optische Schnittstelle generell freigeschaltet, oder werden mehr Parameter freigeschaltet? Die Ausgabe der Zählerstände funktioniert ja, aber eben nur die.
                                            Das die SML genormt ist, war ich eben der Meinung das alle Parameter die angezeigt werden, auch an der optischen Schnittstelle ausgegeben werden.
                                            Ich möchte mich für die bisherigen Hinweise bedanken, und wünsche euch ein frohes Weihnachtsfest.
                                            3625
                                            2286836
