    4. JavaScript
    5. [Vorlage] Tasmota One Click Firmware Update Vis Javascript.
    • falke69
      falke69 @smartboart last edited by falke69
      @smartboart
      ok. Danke für den Hinweis!
      Habe gerade mal Deinen Hinweis umgesetzt.
      var cacheSelectorTasmotaVersions = $('channel[state.id=sonoff.0.*.Info1_Version]');
      Da erhalte ich für all meine Geräte diese Fehlermeldung:
      javascript.0	2021-07-16 06:12:08.887	warn	(4523) at processTicksAndRejections (internal/process/task_queues.js:84:21)
      javascript.0	2021-07-16 06:12:08.887	warn	(4523) at endReadableNT (_stream_readable.js:1241:12)
      javascript.0	2021-07-16 06:12:08.887	warn	(4523) at IncomingMessage.emit (events.js:326:22)
      javascript.0	2021-07-16 06:12:08.886	warn	(4523) at Object.onceWrapper (events.js:420:28)
      javascript.0	2021-07-16 06:12:08.886	warn	(4523) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1076:12)
      javascript.0	2021-07-16 06:12:08.886	warn	(4523) at Request.emit (events.js:314:20)
      javascript.0	2021-07-16 06:12:08.885	warn	(4523) at Request.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1154:10)
      javascript.0	2021-07-16 06:12:08.885	warn	(4523) at Request.emit (events.js:314:20)
      javascript.0	2021-07-16 06:12:08.884	warn	(4523) at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:185:22)
      javascript.0	2021-07-16 06:12:08.884	warn	(4523) at Request._callback (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:27:17)
      javascript.0	2021-07-16 06:12:08.883	warn	(4523) at script.js.Test.Tasmota_Update:430:42
      javascript.0	2021-07-16 06:12:08.883	warn	(4523) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:801:29)
      javascript.0	2021-07-16 06:12:08.883	warn	(4523) at script.js.Test.Tasmota_Update:446:32
      javascript.0	2021-07-16 06:12:08.881	warn	(4523) getState "sonoff.0.Waschmaschiene.INFO.Hostname" not found (3)
      javascript.0	2021-07-16 06:12:08.881	info	(4523) script.js.Test.Tasmota_Update: Tasmota: Installierte Firmware für Gerät null ist aktuell.
      smartboart 1 Reply Last reply Reply Quote 0
      • smartboart
        smartboart @falke69 last edited by smartboart
        @falke69 ja, du musst das an mehreren Stellen anpassen . Vergleich es mit meiner aktualisierten Version , habe ich oben mittlerweile eingefügt. Die Namensänderung kam mit V 9.5.0 oder eine Version früher...natürlich müssen die states bei dir auch entsprechend *.Info1_Version angelegt worden sein, also auch die neue Verfsion geladen sein.
        falke69 1 Reply Last reply Reply Quote 0
        • falke69
          @smartboart
          vielen Dank!
          Die neue Version habe ich jetzt geladen und soweit eingerichtet.
          Aktuell werden mir im Log Geräte als Warnung angezeigt, die derzeit nicht
          erreichbar sind (Weihnachtsbeleuchtung. 🙂 ).
          Leider habe ich das Problem, dass die OTA URL nicht in das entsprechende Gerät abgesetzt werden kann. Wenn ich das richtig im Script deute, sollten doch die IP Adressen für die entsprechenden Geräte ausgelesen werden sollte.
          javascript.0	2021-07-16 13:28:38.831	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Fehler beim setzen der OTA Minimal URL für: Error: Invalid URI "http:///cm?cmnd=OtaUrl%20http://192.168.178.xxx:8000/Tasmota/tasmota-minimal
          javascript.0	2021-07-16 13:28:21.713	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Folgende IP wurde für das Update vorgewählt:
          javascript.0	2021-07-16 13:28:18.128	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Folgende IP wurde für das Update vorgewählt:
          javascript.0	2021-07-16 13:28:02.246	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Fehler beim setzen der OTA Minimal URL für: Error: Invalid URI "http:///cm?cmnd=OtaUrl%20http://192.168.178.xxx:8000/Tasmota/tasmota-minima
          javascript.0	2021-07-16 13:27:51.423	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Firmwaredownload tasmota-sensors.bin gestartet. /home/pi/Tasmota/tasmota-sensors.bin.gz
          javascript.0	2021-07-16 13:27:51.400	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Firmwaredownload tasmota.bin gestartet. /home/pi/Tasmota/tasmota.bin.gz
          javascript.0	2021-07-16 13:27:51.367	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Firmwaredownload tasmota-minimal.bin gestartet. /home/pi/Tasmota/tasmota-minimal.bin.gz
          • smartboart
            @falke69 sagte in [Vorlage] Tasmota One Click Firmware Update Vis Javascript.:
            erreichbar sind (Weihnachtsbeleuchtung. ).
            Nicht erreichbar für das skript oder generell offline? Also nicht im wlan?
            Aktuell gibt es kein mechanismus der erreichbare und nicht erreichbare geräte unterscheidet. Es wird davon ausgegangen dass alle konfigurierten Geräte auch erreichbar sind.
            Welche version hast du jetzt laufen? Die Testversion oder die von ganz oben? Die Testversion aus den threat vorher habe ich nur mit einzelnen Geräten lauffähig gemacht und getestet noch nicht update all.
            • falke69
              @smartboart
              genau. Das sehe ich aber nicht so schlimm.
              Mir geht es aktuell darum, dass die OTA URL nicht gesetzt werden kann.
              • smartboart
                @falke69 doch nur für das nicht erreichbare Gerät...Die OTA URL wird an das Gerät übertragen. over the air...damit wird dem gerät gesagt wo es das bin file herbekommt. Wenn das Gerät nicht erreichbar ist, kannst die URL dem gerät auch nicht mitteilen.
                • falke69
                  @smartboart
                  Das Gerät, was das Update bekommen soll, ist erreichbar.
                  Bei mir liegt das Gerät auf der id26 und in der Auswahl der Entsprechenden Geräte
                  auch auf der 26.
                  Da muss ich mal schauen, ob ich die Ursache finde.
                  Edit: Ursache gefunden. Habe diese Zeilen vergessen zu erweitern. 😬
                      if(dp.state.val===21)select = Device21;
                      if(dp.state.val===22)select = Device22;
                      if(dp.state.val===23)select = Device23;
                      if(dp.state.val===24)select = Device24;
                      if(dp.state.val===25)select = Device25;
                  • smartboart
                    sehr gut...
                    • falke69
                      @smartboart
                      seit gestern ist nun die 10.0.0 auf dem Markt. Das hat mir zumindest das Script mitgeteilt.🤗
                      Gibt es eine Möglichkeit, die Nachrichten auf nur einen Benutzer bei Telegram zu beschränken, damit nicht jedesmal meine ganze Family diese Nachrichten bekommt?
                      ich habe es schon so versucht:
                      sendTo('telegram.0', { user: 'username', text: '_message' });.
                      da kommt aber nur "_message" in Telegram an.
                      Edit:
                      habe es hinbekommen👍
                      Die entsprechenden Stellen, habe ich mal unten aufgeführt.
                      Vielleicht, kannst / willst Du das ja noch mit in Dein Script einarbeiten.
                      var sendtelegram = true;
                      const user_telegram = '';             //User der die Nachricht bekommen soll
                                      if(sendtelegram){
                                          _message = _message_tmp;
                                       send_telegram(_message, user_telegram); //geändert
                      function send_telegram (_message, user_telegram) {  //geändert
                              text: _message,
                              user: user_telegram,
                              parse_mode: 'HTML'
                        Mike Hellracer @Dragon last edited by Mike Hellracer
                        @dragon
                        kannst du bitte deine Lösung (View/Widgets) zur Verfügung stellen.
                        Ich verwende UHULA Material-Design und möchte aufgrund von kmüpatibilitätsgründen ungern die Material-Design-Widgets installieren.
                          Mike Hellracer @smartboart last edited by Mike Hellracer
                          @smartboart
                          Hi, oben das Script ist aus 2020 ist das das Aktuelle?
                          Und mit dieser Version wird der DP UpdateAll nicht angelegt.
                          Leider funktioniert bei mir dein Widget nicht, aber wenn ich richtig verstanden habe muss ich dann nur den DP auf true setzen um alle zu aktualisieren oder?
                            irgendwie bekomme ich das nicht richtig zum Laufen.
                            Irgendwie kann es die IP der Geräte nicht ermitteln. Der DP stimmt, aber im log steht das die IP nicht ermittelt werden kann.
                            Die veraltete Version der Tasmota Geräte wird angezeigt.
                            Download Verzeichnis ist angelegt. Die Rechte sind gesetzt und der Download der aktuellen Firmware dahin funktioniert auch.
                            Der Download link 'IP-Adresse.8000/Tasmota/tasmota-sensors.bin.gz' und auch 'IP-Adresse:8000/Tasmota/tasmota-sensors.bin.gz' funktionieren nicht.
                            Kann mir jemaand sagen was ich noch prüfen kann bzw, machen muss?
                            • smartboart
                              smartboart @Mike Hellracer last edited by smartboart
                              @mike-hellracer sorry war lange nicht online...
                              Hast du Schreibtechte auf dem downloadverzeichnis?
                              Beachte die Kommentare im Script..
                              Hast du das script aus dem 1. Beitrag kopiert oder die ungetestete Version aus einem Beitrag zwischendrin? Welcher changelog?
                              Werde demnächst eine aktuelle Version hochladen...wird aber deine Probleme nicht lösen, wenn du das Script aus dem 1. Beitrag genommen hats, da die offizielle Version aus dem 1. Beitrag auch funktionieren muss.
                              In der aktuellen und neuen Version brauchst du nur 2 widgets eines zum Selektieren mittels Nummer und eines um zu starten mittels boolean also true setzen ..
                              Tasmota hat ab einer bestimmten Version die State Datenpunkte namentlich geändert..vlt. musst du erstmal auf ne neuere Version hochrüsten.
                              Probier das Script erstmal mit einem device...
                              • smartboart
                                smartboart @smartboart last edited by
                                Neue Version im 1. Beitrag ganz oben hochgeladen.
                                16.07.2021
                                V0.0.7 Optimierungen von cruzix (iobroker-forum) integriert.
                                Danke @ cruzix
                                Komplett Test noch offen. Testversion.
                                01.11.2021
                                V0.0.8 Anregungen von cruzix in das script eingearbeitet und getestet. Hier und da noch diverse Bugfixe.
                                  @smartboart
                                  Super danke dir, ich werde es ausprobieren.
                                  Ich habe die Einträge aus dem Script für Verzeichnis und rechte verwendet.
                                  Welcher User braucht Schreibrechte?
                                  Habe einfach mal den Link in den Browser eingegeben. Muss darauf der Download starten, oder ist der Eintrag in die Tasmota Gui gemeint?
                                  Kannst du ein Beispiel für die 2 Widgets zur Verfügung stellen?
                                  • smartboart
                                    @mike-hellracer es wird mit dem Script der download gestartet und ein lokaler download server zur Verfuegung gestellt..ich möchte in meinem smart home nicht alle Geraete im Internet haben. Die tasmota geraete sind bei mir alle fuer das internet gesperrt.
                                    Beispiel Widgets sind ganz oben..
                                    • smartboart
                                      smartboart @Dragon last edited by smartboart
                                      24.02.2022
                                      V0.1.0 - manuelles Konfig Backup für einzelne Geräte eingebaut.
                                      - automatisches Konfig Backup bei Firmwareupdate implementiert
                                      - Schreibrechte der Download files / Ordner inklusive Unterordner automatisch rekursiv setzen
                                      bei server start sudo chmod -R 777 /home/pi/Tasmota
                                      - Update für zusätzliche sonder Firmware Tasmota32 eingebaut
                                        Ich habe meinen Broker auf Proxmox laufen. Darum existiert kein Benutzer Namens pi und somit auch kein Verzeichnis im Ordner home Namens pi. Das wird auch nicht erstellt...
                                        • smartboart
                                          @dragon dann pass den konfig teil doch einfach an..
                                            Dragon @smartboart last edited by
                                            @smartboart Habe ich, der Ordner wurde aber trotzdem nicht erstellt. Habe ihn zu Fuß erstellt, dann lief alles. Nun zeigt er mir bei ein paar Geräten an es sei eine minimal installiert, das stimmt aber nicht...
                                            smartboart 2 Replies Last reply Reply Quote 0
                                            120
                                            16053
