    4. js-controller 3.3 jetzt im STABLE!
      hegse last edited by hegse
      Gerade das Update auf die aktuellste Version gemacht.
      Bekomme folgende Meldung angezeigt:
      hegse@Iobroker:~$ iobroker upgrade self
      Update js-controller from @3.3.21 to @3.3.22
      NPM version: 6.14.15
      npm install iobroker.js-controller@3.3.22 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
      In file included from ../authenticate_pam.cc:23:
      ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
      ../../nan/nan.h:2294:7: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       2294 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
      ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
      ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
        107 |   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
      ../../nan/nan.h:1026:46: note: declared here
       1026 |   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
      ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../authenticate_pam.cc:147:83: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’
        147 |   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
      In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67,
                       from ../../nan/nan.h:56,
      /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
       3717 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
      /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note:   candidate expects 2 arguments, 1 provided
      /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
       3720 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
      /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note:   candidate expects 2 arguments, 1 provided
      ../authenticate_pam.cc:150:30: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
        150 |    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
            |                              char [128]
      /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note:   initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 |   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
      ../authenticate_pam.cc:152:69: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’
        152 |   res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
      ../authenticate_pam.cc:155:29: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
        155 |    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
            |                             char [128]
      ../authenticate_pam.cc:160:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
        160 |  username->WriteUtf8(m->username, sizeof(m->username) - 1);
            |                         char [128]
      ../authenticate_pam.cc:161:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
        161 |  password->WriteUtf8(m->password, sizeof(m->password) - 1);
            |                         char [128]
      ../authenticate_pam.cc: At global scope:
      ../authenticate_pam.cc:170:6: error: variable or field ‘init’ declared void
        170 | void init(Handle<Object> exports) {
      ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
      ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
      ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
      In file included from ../../nan/nan.h:56,
      ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope; did you mean ‘int’?
        175 | NODE_MODULE(authenticate_pam, init);
      /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:36: note: in definition of macro ‘NODE_MODULE_X’
        787 |       (node::addon_register_func) (regfunc),                          \
      ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
      make: *** [authenticate_pam.target.mk:111: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
      gyp ERR! System Linux 5.10.0-9-amd64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
      gyp ERR! node -v v14.18.1
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      Soweit läuft alles nach dem Update.
        Thomas Braun Most Active @hegse last edited by
        @hegse
        Ist da zufällig der Adapter terminal installiert? Dann schmeiß den raus.
          hegse @Thomas Braun last edited by
          @thomas-braun ja der ist installiert.
          Alles klar, dann schmeiß ich den mal raus. Besten Dank!
            BlueEssi last edited by
            Hallo zusammen, ist die Liste der inkompatiblen Adapter am Thread-Anfang immer noch aktuell? Ich habe inzwischen leider das Problem, dass 3-4 meiner Adapter auf dieser Liste stehen, aber andere Adapter das Upgrade voraussetzen um auf den aktuellen Stand aufzurüsten.
              apollon77 @BlueEssi last edited by
              @blueessi Die Aussage geht anders rum: Folgende Adapter müssen aktualisiert werden weil sie in den damals aktuellen Versionen nicht vollständig kompatibel waren.
              Das hat mit "eine neue version des Adapters braucht bitte js.cotnroller in Version X" nichts zu tun. Das soll verhindern das Du dir dein System kaputt machst
                BlueEssi @apollon77 last edited by
                @apollon77 Das beantwortet leider nicht meine Frage. Wie bekomme ich raus, ob meine benötigten Adapter mit 3.3 kompatibel sind?
                Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @BlueEssi last edited by
                  @blueessi
                  Im stable-Repo alles auf Stand bringen.
                    @blueessi Wenn Du so rum fragst ist die obige Liste und Infos in diesem Thread (falls wir welche vergessen haben zu adden) aktuell und exakt wie @Thomas-Braun sagt: Wenn alles in Stable aktuell ist - oder du die adapter die du wegen "Zu altem js-controller" nicht updaten kannst gemerkt sind und gleich als erstes nach dem update aktualisiert werden ... dann sollte das nach grobem Wissen passen
                      @apollon77 OK, danke. Es sieht so aus, dass ich mich wohl noch eine Weile gedulden muss um auf 3.3 hochrüsten zu können. Ich hoffe, die "alten" Adapter werden irgendwann überhaupt nachgezogen.
                        @blueessi
                        Wie schaut denn das überhaupt aus bei dir?
                        iobroker update -i
                          @blueessi naja wenn Du genau liesst ist das einzige was die alten Adapter ggf tun ist "Info" logging zu machen das was nicht stimmt ... ehrlich ... Loglevel hochsetzen in der Wartezeit und gut ... ich denke nicht das das vom Update abhalten sollte
                            @apollon77 Ok, das war mir nicht bewusst. Vielleicht könntest du den Hinweis in der Inkompatibilitäts-Auflistung oben ergänzen. Ich werde es testen. Danke.
                              sandro_gera last edited by
                              Hallo an alle,
                              ich hab folgende Fehlermeldung bekommen
                              pi@RaspBerry4BioBroker:~ $ iob upgrade self
                              npm install iobroker.js-controller@3.3.22 --loglevel error --unsafe-perm --prefi                       x "/opt/iobroker" (System call)
                              Server Cannot move /opt/iobroker/iobroker-data/objects.json.new to /opt/iobroker                       /iobroker-data/objects.json: ENOENT: no such file or directory, stat '/opt/iobro                       ker/iobroker-data/objects.json.new'. Try direct write as fallback
                              Das update scheint aber funktioniert zu haben.
                              Muß ich jetzt irgend etwas unternehmen?
                                apollon77 @sandro_gera last edited by
                                @sandro_gera Ne, das ist am Ende nur ne Info meldung. Wenn sonst kein Fehler ds ist ist oder kam alles ok
                                • NWH
                                  NWH last edited by
                                  Hallo
                                  Wollte wie immer das update per Konsole machen, aber diesmal kommt diese Meldung.
                                  Wer kann mir sagen warum ich nicht auf die Version 3.3.22 komme.
                                  Iobrocker läuft auf eine Synology im docker.
                                  Neu gestartet habe ich auch schon.
                                  Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                                    Thomas Braun Most Active @NWH last edited by Thomas Braun
                                    @nwh
                                    Keine Screenshots aus der Konsole. Text als Text in CodeTags posten.
                                    Und auch keine Phantasie-Kommandos verwenden.
                                    apt upgrade
                                    für das System,
                                    für den js-controller.
                                    NWH 1 Reply Last reply Reply Quote 0
                                    • Glasfaser
                                      Glasfaser @NWH last edited by Glasfaser
                                      @nwh sagte in js-controller 3.3 jetzt im STABLE!:
                                      Aber nicht so !!
                                      So:
                                      pkill -u iobroker
                                      • NWH
                                        NWH @Thomas Braun last edited by
                                        Ja tut mir leid. Kommt nicht wieder vor.
                                        Danke für die Info, hat schon funktioniert.
                                          root_ last edited by
                                          Wie komme ich von der 3.3.22 wieder auf die 3.3.21?
                                            Homoran Global Moderator Administrators @root_ last edited by
                                            @root_ sagte in js-controller 3.3 jetzt im STABLE!:
                                            warum willst du das?
                                            in 3.3.22 ist ein Bug behoben worden
                                            344
                                            90468
