    4. modbus adapter Problem nach Update
    • Glasfaser
      Glasfaser @Luzzi last edited by Glasfaser
      @luzzi
      Bitte das Log in Code-Tags </> posten !
      Normalerweise folge ich dem Grundsatz... never change a running system.
      Falscher Gedanke ...
      EDIT:
      und ein Screenshot von Allgemein Einstellung
        Luzzi @Glasfaser last edited by
        @glasfaser
        Hier das Log```
        2021-12-24 16:06:24.506 - info: modbus.0 (2708617) Connected to slave 192.168.1.46
        2021-12-24 16:06:24.506 - debug: modbus.0 (2708617) [DevID_2] Poll start ---------------------
        2021-12-24 16:06:24.507 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 71 - 100 registers
        2021-12-24 16:06:24.674 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 71 DONE
        2021-12-24 16:06:24.676 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 187 - 1 registers
        2021-12-24 16:06:24.701 - info: kecontact.0 (95071) change additional power from regard from -731 to -744
        2021-12-24 16:06:24.778 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 187 DONE
        2021-12-24 16:06:24.778 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 206 - 37 registers
        2021-12-24 16:06:24.886 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 206 DONE
        2021-12-24 16:06:27.888 - debug: modbus.0 (2708617) [DevID_2] Poll start ---------------------
        2021-12-24 16:06:27.889 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 71 - 100 registers
        2021-12-24 16:06:27.965 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 71 DONE
        2021-12-24 16:06:27.967 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 187 - 1 registers
        2021-12-24 16:06:27.973 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 187 DONE
        2021-12-24 16:06:27.974 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 206 - 37 registers
        2021-12-24 16:06:28.042 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 206 DONE
        2021-12-24 16:06:28.045 - info: kecontact.0 (95071) change additional power from regard from -744 to -764
        2021-12-24 16:06:30.006 - info: javascript.0 (115330) script.js.common.TestSayIT: sayIt: es läuft
        2021-12-24 16:06:30.031 - info: sayit.0 (95626) saying: es läuft
        2021-12-24 16:06:31.044 - debug: modbus.0 (2708617) [DevID_2] Poll start ---------------------
        2021-12-24 16:06:31.045 - debug: modbus.0 (2708617) [DevID_2/holdingRegs] Poll address 71 - 100 registers
        2021-12-24 16:06:32.047 - warn: modbus.0 (2708617) Error: undefined
        2021-12-24 16:06:32.047 - error: modbus.0 (2708617) Request timed out.
        2021-12-24 16:06:32.047 - error: modbus.0 (2708617) Client in error state.
        2021-12-24 16:06:32.048 - warn: modbus.0 (2708617) Poll error count: 1 code: {"err":"timeout","timeout":1000}
        2021-12-24 16:06:32.048 - debug: modbus.0 (2708617) Socket closed with error
        2021-12-24 16:06:32.049 - debug: modbus.0 (2708617) Clearing timeout of the current request.
        2021-12-24 16:06:32.049 - debug: modbus.0 (2708617) Cleaning up request fifo.
        2021-12-24 16:06:33.049 - debug: modbus.0 (2708617) Closing client on purpose.
        2021-12-24 16:06:33.049 - info: modbus.0 (2708617) Disconnected from slave 192.168.1.46
        Und hier noch die Einstellungen:
        • Glasfaser
          @luzzi
          nimm den mal raus
            @glasfaser
            Hatte ich schon einmal probiert. Stand im Forum etwas dazu. Es bringt aber keine Verbesserung.
            Ich muss noch ergänzen. Der Adapter springt immer von grün auf rot und wieder auf grün.
            • Glasfaser
              @luzzi
              Nimm mal mein Register und lege dazu eine neue Instanz an , die andere ausschalten
              _address	name	description	unit	type	len	factor	offset	formula	role	room	poll	wp	cw	isScale
              40000	C_SunSpec_ID	"Wert = ""SunS"" (0x53756e53). Identifiziert dies eindeutig als eine SunSpec Modbus-Karte"		uint32be	2	1	0		value		true	false	false	false
              40002	C_SunSpec_DID	Wert = 0x0001. Identifiziert dies eindeutig als einen SunSpec “Common Block“		uint16be	1	1	0		value		true	false	false	false
              40003	C_SunSpec_Länge	65 = Länge eines Blocks in 16-bit Registern		uint16be	1	1	0		value		true	false	false	false
              40004	C_Hersteller	"Bei SunSpec eingetragener Wert = ""SolarEdge"""		string	16	1	0		value		true	false	false	false
              40020	C_Modell	Spezifischer SolarEdge Wert		string	16	1	0		value		true	false	false	false
              40044	C_Version	Spezifischer SolarEdge Wert		string	8	1	0		value		true	false	false	false
              40052	C_Seriennummer	Eindeutiger SolarEdge Wert		string	16	1	0		value		true	false	false	false
              40068	C_Geräteadresse	Modbus-ID der entsprechenden Einheit		uint16be	1	1	0		value		true	false	false	false
              40069	C_SunSpec_DID	101 = Einphasig, 102 = Spaltphase, 103 = Dreiphasig		uint16be	1	1	0		value		true	false	false	false
              40070	C_SunSpec_Länge	50 = Länge des Modellblocks	Register	uint16be	1	1	0		value		true	false	false	false
              40071	I_AC_Strom	AC-Gesamtstromwert	A	uint16be	1	1	0		value		true	false	false	false
              40072	I_AC_StromA	AC-Phase A (L1) Stromwert	A	uint16be	1	1	0		value		true	false	false	false
              40073	I_AC_StromB	AC-Phase B (L2) Stromwert	A	uint16be	1	1	0		value		true	false	false	false
              40074	I_AC_StromC	AC-Phase C (L3) Stromwert	A	uint16be	1	1	0		value		true	false	false	false
              40075	I_AC_Strom_SF	AC-Strom Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
              40076	I_AC_SpannungAB	AC-Spannung Phase AB (L1-L2) Wert	V	uint16be	1	1	0		value		true	false	false	false
              40077	I_AC_SpannungBC	AC-Spannung Phase BC (L2-L3) Wert	V	uint16be	1	1	0		value		true	false	false	false
              40078	I_AC_SpannungCA	AC-Spannung Phase CA (L3-L1) Wert	V	uint16be	1	1	0		value		true	false	false	false
              40079	I_AC_SpannungAN	AC-Spannung Phase A-N (L1-N) Wert	V	uint16be	1	1	0		value		true	false	false	false
              40080	I_AC_SpannungBN	AC-Spannung Phase B-N (L2-N) Wert	V	uint16be	1	1	0		value		true	false	false	false
              40081	I_AC_SpannungCN	AC-Spannung Phase C-N (L3-N) Wert	V	uint16be	1	1	0		value		true	false	false	false
              40082	I_AC_Spannung_SF	AC-Spannung Skalierungsfaktor	V	int16be	1	1	0		value		true	false	false	false
              40083	I_AC_Leistung	AC-Leistungswert	W	uint16be	1	1	0		value		true	false	false	false
              40084	I_AC_Leistung_SF	AC-Leistung Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
              40085	I_AC_Frequenz	Frequenzwert	Hz	uint16be	1	1	0		value		true	false	false	false
              40086	I_AC_Frequenz_SF	Frequenz Skalierungsfaktor		int16be	1	1	0		value		true	false	false	false
              40087	I_AC_VA	Scheinleistung	VA	uint16be	1	1	0		value		true	false	false	false
              40088	I_AC_VA_SF	Scheinleistung Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
              40089	I_AC_VAR	Blindleistung	VAR	uint16be	1	1	0		value		true	false	false	false
              40090	I_AC_VAR_SF	Blindleistung Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
              40091	I_AC_PF	Leistungsfaktor	%	uint16be	1	1	0		value		true	false	false	false
              40092	I_AC_PF_SF	Leistungsfaktor Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
              40093	I_AC_Energie_WH	AC Gesamt-Energieproduktion	Wh	uint32be	2	1	0		value		true	false	false	false
              40095	I_AC_Energie_WH_SF	AC Gesamtenergie Skalierungsfaktor	SF	uint16be	1	1	0		value		true	false	false	false
              40096	I_DC_Strom	DC-Stromwert	A	uint16be	1	1	0		value		true	false	false	false
              40097	I_DC_Strom_SF	DC-Strom Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
              40098	I_DC_Spannung	DC-Spannungswert	V	uint16be	1	1	0		value		true	false	false	false
              40099	I_DC_Spannung_SF	DC-Spannung Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
              40100	I_DC_Leistung	DC-Leistungswert	W	uint16be	1	1	0		value		true	false	false	false
              40101	I_DC_Leistung_SF	DC-Leistung Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
              40103	I_Temp_Kühler	Kühlkörpertemperatur	°C	uint16be	1	1	0		value		true	false	false	false
              40106	I_Temp_SF	Kühlkörpertemperatur Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
              40107	I_Status	Betriebszustand (1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup)		uint16be	1	1	0		value		true	false	false	false
              40108	I_Status_Anbieter	Anbieter-spezifischer Betriebszustand sowie Fehlercodes: 1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup		uint16be	1	1	0		value		true	false	false	false
              40123	C_Manufacturer	Meter manufacturer		string	32	1	0		value		true	false	false	false
              40139	C_Model	Meter model		string	32	1	0		value		true	false	false	false
              40155	C_Option	Export + Import, Production, consumption		string	16	1	0		value		true	false	false	false
              40190	M_AC_Current	AC Current (sum of active phases)	A	uint16be	1	1	0		value		true	false	false	false
              40194	M_AC_Current_S F	AC Current Scale Factor	SF	int16be	1	1	0		value		true	false	false	false
              40206	M_AC_Power	Total Real Power (sum of active phases)	W	int16be	1	1	0		value		true	false	false	false
              40210	M_AC_Power_SF	AC Real Power Scale Factor	SF	int16be	1	1	0		value		true	false	false	false
              40226	M_Exported	Total Exported Real Energy	Wh	uint32be	2	1	0		value		true	false	false	false
              40234	M_Imported	Total Imported Real Energy	Wh	uint32be	2	1	0		value		true	false	false	false
              40242	M_Energy_W_SF	Real Energy Scale Factor	SF	int16be	1	1	0		value		true	false	false	false
              57664	Battery 1 Device ID	Batterie Geräte ID		uint16be	1	1	0		value		true	false	false	false
              57666	Battery 1 Rated Energy	Batterie Nennkapazität	Wh	floatsw	2	1	0		value		true	false	false	false
              57668	Battery 1 Max Charge Continues Power	Batterie maximale Ladeleistung	W	floatsw	2	1	0		value		true	false	false	false
              57670	Battery 1 Max Discharge Continues Power	Batterie maximale Entladeleistung	W	floatsw	2	1	0		value		true	false	false	false
              57672	Battery 1 Max Charge Peak  Power	Batterie maximale Ladespitzenleistung	W	floatsw	2	1	0		value		true	false	false	false
              57674	Battery 1 Max Discharge Peak  Power	Batterie maximale Entladespitzenleistung	W	floatsw	2	1	0		value		true	false	false	false
              57708	Battery 1 Average Temperature	Batterie Durchschnittstemperatur	°C	floatsw	2	1	0		value		true	false	false	false
              57710	Battery 1 Max Temperature	Batterie maximale Temperatur	°C	floatsw	2	1	0		value		true	false	false	false
              57712	Battery 1 Instantaneous Voltage	Batterie momentane Spannung	V	floatsw	2	1	0		value		true	false	false	false
              57714	Battery 1 Instantaneous Current	Batterie momentane Stromstärke	A	floatsw	2	1	0		value		true	false	false	false
              57716	Battery 1 Instantaneous Power	Batterie momentane Leistung	W	floatsw	2	1	0		value		true	false	false	false
              57718	Battery 1 Lifetime Export Energy Counter	Batterie Gesamtenergie entladen	Wh	uint64le	4	1	0		value		true	false	false	false
              57722	Battery 1 Lifetime Import Energy Counter	Batterie Gesamtenergie geladen	Wh	uint64le	4	1	0		value		true	false	false	false
              57726	Battery 1 Max Energy	Batteriekapazität aktualisiert nach Alterung	Wh	floatsw	2	1	0		value		true	false	false	false
              57728	Battery 1 Available Energy	Batterie verfügbare Energie	Wh	floatsw	2	1	0		value		true	false	false	false
              57730	Battery 1 State of Health (SOH)	Batterie Verhältnis von Nennkapazität zu Batteriekapazität nach Alterung	%	floatsw	2	1	0		value		true	false	false	false
              57732	Battery 1 State of Energy (SOE)	Batterie Ladezustand (verfügbare Energie zu mögliche Kapazität)	%	floatsw	2	1	0		value		true	false	false	false
              57734	Battery 1 Status	Batterie Zustand (0 = Aus, 1 = Standby, 2 = Initialisierung, 3 = Laden, 4 = Entladen, 5 = Fehler, 6 = Leerlauf)		uint32sw	2	1	0		level
                Luzzi @Glasfaser last edited by Luzzi
                @glasfaser
                Gleiches Verhalten
                Wechselt von rot auf grün und dann wieder auf rot
                2021-12-24 16:35:19.596 - info: host.ioBroker-Prod instance system.adapter.modbus.1 started with pid 2749409
                2021-12-24 16:35:20.006 - warn: husq-automower.0 (96342) checkAMatHome >> homeLocation.latitude and/or homeLocation.longitude not set or failure on reading!
                2021-12-24 16:35:20.301 - debug: modbus.1 (2749409) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2021-12-24 16:35:20.355 - debug: modbus.1 (2749409) Objects client ready ... initialize now
                2021-12-24 16:35:20.356 - debug: modbus.1 (2749409) Objects create System PubSub Client
                2021-12-24 16:35:20.357 - debug: modbus.1 (2749409) Objects create User PubSub Client
                2021-12-24 16:35:20.358 - debug: modbus.1 (2749409) Objects client initialize lua scripts
                2021-12-24 16:35:20.372 - debug: modbus.1 (2749409) Objects connected to redis: 127.0.0.1:9001
                2021-12-24 16:35:20.378 - debug: modbus.1 (2749409) objectDB connected
                2021-12-24 16:35:20.379 - debug: modbus.1 (2749409) Redis States: Use Redis connection: 127.0.0.1:9000
                2021-12-24 16:35:20.386 - debug: modbus.1 (2749409) States create System PubSub Client
                2021-12-24 16:35:20.387 - debug: modbus.1 (2749409) States create User PubSub Client
                2021-12-24 16:35:20.394 - debug: modbus.1 (2749409) States connected to redis: 127.0.0.1:9000
                2021-12-24 16:35:20.394 - debug: modbus.1 (2749409) statesDB connected
                2021-12-24 16:35:20.578 - debug: modbus.1 (2749409) Plugin sentry Initialize Plugin (enabled=true)
                2021-12-24 16:35:20.868 - info: modbus.1 (2749409) starting. Version 3.4.14 in /opt/iobroker/node_modules/iobroker.modbus, node: v14.18.2, js-controller: 3.3.21
                2021-12-24 16:35:21.005 - error: modbus.1 (2749409) Invalid holdingRegisters address: -1
                2021-12-24 16:35:21.006 - debug: modbus.1 (2749409) Initialize Objects for disInputs: []
                2021-12-24 16:35:21.006 - debug: modbus.1 (2749409) Initialize Objects for coils: []
                2021-12-24 16:35:21.007 - debug: modbus.1 (2749409) Initialize Objects for inputRegs: []
                2021-12-24 16:35:21.007 - debug: modbus.1 (2749409) Initialize Objects for holdingRegs: [{"_address":-1,"name":"C_SunSpec_ID","description":"Wert = \"SunS\" (0x53756e53). Identifiziert dies eindeutig als eine SunSpec Modbus-Karte","unit":"","type":"uint32be","len":"2","factor":"1","offset":"0","formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":-1},{"_address":1,"name":"C_SunSpec_DID","description":"Wert = 0x0001. Identifiziert dies eindeutig als einen SunSpec “Common Block“","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":1,"id":"holdingRegisters.1_C_SunSpec_DID"},{"_address":2,"name":"C_SunSpec_Länge","description":"65 = Länge eines Blocks in 16-bit Registern","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":2,"id":"holdingRegisters.2_C_SunSpec_Länge"},{"_address":3,"name":"C_Hersteller","description":"Bei SunSpec eingetragener Wert = \"SolarEdge\"","unit":"","type":"string","len":16,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":3,"id":"holdingRegisters.3_C_Hersteller"},{"_address":19,"name":"C_Modell","description":"Spezifischer SolarEdge Wert","unit":"","type":"string","len":16,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":19,"id":"holdingRegisters.19_C_Modell"},{"_address":43,"name":"C_Version","description":"Spezifischer SolarEdge Wert","unit":"","type":"string","len":8,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":43,"id":"holdingRegisters.43_C_Version"},{"_address":51,"name":"C_Seriennummer","description":"Eindeutiger SolarEdge Wert","unit":"","type":"string","len":16,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":51,"id":"holdingRegisters.51_C_Seriennummer"},{"_address":67,"name":"C_Geräteadresse","description":"Modbus-ID der entsprechenden Einheit","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":67,"id":"holdingRegisters.67_C_Geräteadresse"},{"_address":68,"name":"C_SunSpec_DID","description":"101 = Einphasig, 102 = Spaltphase, 103 = Dreiphasig","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":68,"id":"holdingRegisters.68_C_SunSpec_DID"},{"_address":69,"name":"C_SunSpec_Länge","description":"50 = Länge des Modellblocks","unit":"Register","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":69,"id":"holdingRegisters.69_C_SunSpec_Länge"},{"_address":70,"name":"I_AC_Strom","description":"AC-Gesamtstromwert","unit":"A","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":70,"id":"holdingRegisters.70_I_AC_Strom"},{"_address":71,"name":"I_AC_StromA","description":"AC-Phase A (L1) Stromwert","unit":"A","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":71,"id":"holdingRegisters.71_I_AC_StromA"},{"_address":72,"name":"I_AC_StromB","description":"AC-Phase B (L2) Stromwert","unit":"A","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":72,"id":"holdingRegisters.72_I_AC_StromB"},{"_address":73,"name":"I_AC_StromC","description":"AC-Phase C (L3) Stromwert","unit":"A","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":73,"id":"holdingRegisters.73_I_AC_StromC"},{"_address":74,"name":"I_AC_Strom_SF","description":"AC-Strom Skalierungsfaktor","unit":"SF","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":74,"id":"holdingRegisters.74_I_AC_Strom_SF"},{"_address":75,"name":"I_AC_SpannungAB","description":"AC-Spannung Phase AB (L1-L2) Wert","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":75,"id":"holdingRegisters.75_I_AC_SpannungAB"},{"_address":76,"name":"I_AC_SpannungBC","description":"AC-Spannung Phase BC (L2-L3) Wert","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":76,"id":"holdingRegisters.76_I_AC_SpannungBC"},{"_address":77,"name":"I_AC_SpannungCA","description":"AC-Spannung Phase CA (L3-L1) Wert","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":77,"id":"holdingRegisters.77_I_AC_SpannungCA"},{"_address":78,"name":"I_AC_SpannungAN","description":"AC-Spannung Phase A-N (L1-N) Wert","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":78,"id":"holdingRegisters.78_I_AC_SpannungAN"},{"_address":79,"name":"I_AC_SpannungBN","description":"AC-Spannung Phase B-N (L2-N) Wert","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":79,"id":"holdingRegisters.79_I_AC_SpannungBN"},{"_address":80,"name":"I_AC_SpannungCN","description":"AC-Spannung Phase C-N (L3-N) Wert","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":80,"id":"holdingRegisters.80_I_AC_SpannungCN"},{"_address":81,"name":"I_AC_Spannung_SF","description":"AC-Spannung Skalierungsfaktor","unit":"V","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":81,"id":"holdingRegisters.81_I_AC_Spannung_SF"},{"_address":82,"name":"I_AC_Leistung","description":"AC-Leistungswert","unit":"W","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":82,"id":"holdingRegisters.82_I_AC_Leistung"},{"_address":83,"name":"I_AC_Leistung_SF","description":"AC-Leistung Skalierungsfaktor","unit":"SF","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":83,"id":"holdingRegisters.83_I_AC_Leistung_SF"},{"_address":84,"name":"I_AC_Frequenz","description":"Frequenzwert","unit":"Hz","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":84,"id":"holdingRegisters.84_I_AC_Frequenz"},{"_address":85,"name":"I_AC_Frequenz_SF","description":"Frequenz Skalierungsfaktor","unit":"","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":85,"id":"holdingRegisters.85_I_AC_Frequenz_SF"},{"_address":86,"name":"I_AC_VA","description":"Scheinleistung","unit":"VA","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":86,"id":"holdingRegisters.86_I_AC_VA"},{"_address":87,"name":"I_AC_VA_SF","description":"Scheinleistung Skalierungsfaktor","unit":"SF","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":87,"id":"holdingRegisters.87_I_AC_VA_SF"},{"_address":88,"name":"I_AC_VAR","description":"Blindleistung","unit":"VAR","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":88,"id":"holdingRegisters.88_I_AC_VAR"},{"_address":89,"name":"I_AC_VAR_SF","description":"Blindleistung Skalierungsfaktor","unit":"SF","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":89,"id":"holdingRegisters.89_I_AC_VAR_SF"},{"_address":90,"name":"I_AC_PF","description":"Leistungsfaktor","unit":"%","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":90,"id":"holdingRegisters.90_I_AC_PF"},{"_address":91,"name":"I_AC_PF_SF","description":"Leistungsfaktor Skalierungsfaktor","unit":"SF","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":91,"id":"holdingRegisters.91_I_AC_PF_SF"},{"_address":92,"name":"I_AC_Energie_WH","description":"AC Gesamt-Energieproduktion","unit":"Wh","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":92,"id":"holdingRegisters.92_I_AC_Energie_WH"},{"_address":94,"name":"I_AC_Energie_WH_SF","description":"AC Gesamtenergie Skalierungsfaktor","unit":"SF","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":94,"id":"holdingRegisters.94_I_AC_Energie_WH_SF"},{"_address":95,"name":"I_DC_Strom","description":"DC-Stromwert","unit":"A","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":95,"id":"holdingRegisters.95_I_DC_Strom"},{"_address":96,"name":"I_DC_Strom_SF","description":"DC-Strom Skalierungsfaktor","unit":"SF","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":96,"id":"holdingRegisters.96_I_DC_Strom_SF"},{"_address":97,"name":"I_DC_Spannung","description":"DC-Spannungswert","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":97,"id":"holdingRegisters.97_I_DC_Spannung"},{"_address":98,"name":"I_DC_Spannung_SF","description":"DC-Spannung Skalierungsfaktor","unit":"SF","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":98,"id":"holdingRegisters.98_I_DC_Spannung_SF"},{"_address":99,"name":"I_DC_Leistung","description":"DC-Leistungswert","unit":"W","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":99,"id":"holdingRegisters.99_I_DC_Leistung"},{"_address":100,"name":"I_DC_Leistung_SF","description":"DC-Leistung Skalierungsfaktor","unit":"SF","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":100,"id":"holdingRegisters.100_I_DC_Leistung_SF"},{"_address":102,"name":"I_Temp_Kühler","description":"Kühlkörpertemperatur","unit":"°C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":102,"id":"holdingRegisters.102_I_Temp_Kühler"},{"_address":105,"name":"I_Temp_SF","description":"Kühlkörpertemperatur Skalierungsfaktor","unit":"SF","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":105,"id":"holdingRegisters.105_I_Temp_SF"},{"_address":106,"name":"I_Status","description":"Betriebszustand (1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup)","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":106,"id":"holdingRegisters.106_I_Status"},{"_address":107,"name":"I_Status_Anbieter","description":"Anbieter-spezifischer Betriebszustand sowie Fehlercodes: 1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":107,"id":"holdingRegisters.107_I_Status_Anbieter"},{"_address":122,"name":"C_Manufacturer","description":"Meter manufacturer","unit":"","type":"string","len":32,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":122,"id":"holdingRegisters.122_C_Manufacturer"},{"_address":138,"name":"C_Model","description":"Meter model","unit":"","type":"string","len":32,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":138,"id":"holdingRegisters.138_C_Model"},{"_address":154,"name":"C_Option","description":"Export + Import, Production, consumption","unit":"","type":"string","len":16,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":154,"id":"holdingRegisters.154_C_Option"},{"_address":189,"name":"M_AC_Current","description":"AC Current (sum of active phases)","unit":"A","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":189,"id":"holdingRegisters.189_M_AC_Current"},{"_address":193,"name":"M_AC_Current_S F","description":"AC Current Scale Factor","unit":"SF","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":193,"id":"holdingRegisters.193_M_AC_Current_S_F"},{"_address":205,"name":"M_AC_Power","description":"Total Real Power (sum of active phases)","unit":"W","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":205,"id":"holdingRegisters.205_M_AC_Power"},{"_address":209,"name":"M_AC_Power_SF","description":"AC Real Power Scale Factor","unit":"SF","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":209,"id":"holdingRegisters.209_M_AC_Power_SF"},{"_address":225,"name":"M_Exported","description":"Total Exported Real Energy","unit":"Wh","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":225,"id":"holdingRegisters.225_M_Exported"},{"_address":233,"name":"M_Imported","description":"Total Imported Real Energy","unit":"Wh","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":233,"id":"holdingRegisters.233_M_Imported"},{"_address":241,"name":"M_Energy_W_SF","description":"Real Energy Scale Factor","unit":"SF","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":241,"id":"holdingRegisters.241_M_Energy_W_SF"},{"_address":17663,"name":"Battery 1 Device ID","description":"Batterie Geräte ID","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17663,"id":"holdingRegisters.17663_Battery_1 Device ID"},{"_address":17665,"name":"Battery 1 Rated Energy","description":"Batterie Nennkapazität","unit":"Wh","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17665,"id":"holdingRegisters.17665_Battery_1 Rated Energy"},{"_address":17667,"name":"Battery 1 Max Charge Continues Power","description":"Batterie maximale Ladeleistung","unit":"W","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17667,"id":"holdingRegisters.17667_Battery_1 Max Charge Continues Power"},{"_address":17669,"name":"Battery 1 Max Discharge Continues Power","description":"Batterie maximale Entladeleistung","unit":"W","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17669,"id":"holdingRegisters.17669_Battery_1 Max Discharge Continues Power"},{"_address":17671,"name":"Battery 1 Max Charge Peak Power","description":"Batterie maximale Ladespitzenleistung","unit":"W","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17671,"id":"holdingRegisters.17671_Battery_1 Max Charge Peak Power"},{"_address":17673,"name":"Battery 1 Max Discharge Peak Power","description":"Batterie maximale Entladespitzenleistung","unit":"W","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17673,"id":"holdingRegisters.17673_Battery_1 Max Discharge Peak Power"},{"_address":17707,"name":"Battery 1 Average Temperature","description":"Batterie Durchschnittstemperatur","unit":"°C","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17707,"id":"holdingRegisters.17707_Battery_1 Average Temperature"},{"_address":17709,"name":"Battery 1 Max Temperature","description":"Batterie maximale Temperatur","unit":"°C","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17709,"id":"holdingRegisters.17709_Battery_1 Max Temperature"},{"_address":17711,"name":"Battery 1 Instantaneous Voltage","description":"Batterie momentane Spannung","unit":"V","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17711,"id":"holdingRegisters.17711_Battery_1 Instantaneous Voltage"},{"_address":17713,"name":"Battery 1 Instantaneous Current","description":"Batterie momentane Stromstärke","unit":"A","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17713,"id":"holdingRegisters.17713_Battery_1 Instantaneous Current"},{"_address":17715,"name":"Battery 1 Instantaneous Power","description":"Batterie momentane Leistung","unit":"W","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17715,"id":"holdingRegisters.17715_Battery_1 Instantaneous Power"},{"_address":17717,"name":"Battery 1 Lifetime Export Energy Counter","description":"Batterie Gesamtenergie entladen","unit":"Wh","type":"uint64le","len":4,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17717,"id":"holdingRegisters.17717_Battery_1 Lifetime Export Energy Counter"},{"_address":17721,"name":"Battery 1 Lifetime Import Energy Counter","description":"Batterie Gesamtenergie geladen","unit":"Wh","type":"uint64le","len":4,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17721,"id":"holdingRegisters.17721_Battery_1 Lifetime Import Energy Counter"},{"_address":17725,"name":"Battery 1 Max Energy","description":"Batteriekapazität aktualisiert nach Alterung","unit":"Wh","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17725,"id":"holdingRegisters.17725_Battery_1 Max Energy"},{"_address":17727,"name":"Battery 1 Available Energy","description":"Batterie verfügbare Energie","unit":"Wh","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17727,"id":"holdingRegisters.17727_Battery_1 Available Energy"},{"_address":17729,"name":"Battery 1 State of Health (SOH)","description":"Batterie Verhältnis von Nennkapazität zu Batteriekapazität nach Alterung","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17729,"id":"holdingRegisters.17729_Battery_1 State of Health (SOH)"},{"_address":17731,"name":"Battery 1 State of Energy (SOE)","description":"Batterie Ladezustand (verfügbare Energie zu mögliche Kapazität)","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17731,"id":"holdingRegisters.17731_Battery_1 State of Energy (SOE)"},{"_address":17733,"name":"Battery 1 Status","description":"Batterie Zustand (0 = Aus, 1 = Standby, 2 = Initialisierung, 3 = Laden, 4 = Entladen, 5 = Fehler, 6 = Leerlauf)","unit":"","type":"uint32sw","len":"2","factor":"1","offset":"0","formula":"","role":"level","poll":false,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":17733,"id":"holdingRegisters.17733_Battery_1 Status"}]
                2021-12-24 16:35:21.009 - debug: modbus.1 (2749409) Add undefined: {"type":"state","common":{"name":"Wert = \"SunS\" (0x53756e53). Identifiziert dies eindeutig als eine SunSpec Modbus-Karte","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":-1,"deviceId":2,"type":"uint32be","len":"2","offset":"0","factor":"1","poll":true}}
                2021-12-24 16:35:21.010 - debug: modbus.1 (2749409) Add holdingRegisters.1_C_SunSpec_DID: {"_id":"holdingRegisters.1_C_SunSpec_DID","type":"state","common":{"name":"Wert = 0x0001. Identifiziert dies eindeutig als einen SunSpec “Common Block“","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":1,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.010 - debug: modbus.1 (2749409) Add holdingRegisters.2_C_SunSpec_Länge: {"_id":"holdingRegisters.2_C_SunSpec_Länge","type":"state","common":{"name":"65 = Länge eines Blocks in 16-bit Registern","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":2,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.010 - debug: modbus.1 (2749409) Add holdingRegisters.3_C_Hersteller: {"_id":"holdingRegisters.3_C_Hersteller","type":"state","common":{"name":"Bei SunSpec eingetragener Wert = \"SolarEdge\"","role":"value","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":3,"deviceId":2,"type":"string","len":16,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.011 - debug: modbus.1 (2749409) Add holdingRegisters.19_C_Modell: {"_id":"holdingRegisters.19_C_Modell","type":"state","common":{"name":"Spezifischer SolarEdge Wert","role":"value","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":19,"deviceId":2,"type":"string","len":16,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.011 - debug: modbus.1 (2749409) Add holdingRegisters.43_C_Version: {"_id":"holdingRegisters.43_C_Version","type":"state","common":{"name":"Spezifischer SolarEdge Wert","role":"value","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":43,"deviceId":2,"type":"string","len":8,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.011 - debug: modbus.1 (2749409) Add holdingRegisters.51_C_Seriennummer: {"_id":"holdingRegisters.51_C_Seriennummer","type":"state","common":{"name":"Eindeutiger SolarEdge Wert","role":"value","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":51,"deviceId":2,"type":"string","len":16,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.011 - debug: modbus.1 (2749409) Add holdingRegisters.67_C_Geräteadresse: {"_id":"holdingRegisters.67_C_Geräteadresse","type":"state","common":{"name":"Modbus-ID der entsprechenden Einheit","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":67,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.012 - debug: modbus.1 (2749409) Add holdingRegisters.68_C_SunSpec_DID: {"_id":"holdingRegisters.68_C_SunSpec_DID","type":"state","common":{"name":"101 = Einphasig, 102 = Spaltphase, 103 = Dreiphasig","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":68,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.012 - debug: modbus.1 (2749409) Add holdingRegisters.69_C_SunSpec_Länge: {"_id":"holdingRegisters.69_C_SunSpec_Länge","type":"state","common":{"name":"50 = Länge des Modellblocks","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"Register"},"native":{"regType":"holdingRegs","address":69,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.012 - debug: modbus.1 (2749409) Add holdingRegisters.70_I_AC_Strom: {"_id":"holdingRegisters.70_I_AC_Strom","type":"state","common":{"name":"AC-Gesamtstromwert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"A"},"native":{"regType":"holdingRegs","address":70,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.012 - debug: modbus.1 (2749409) Add holdingRegisters.71_I_AC_StromA: {"_id":"holdingRegisters.71_I_AC_StromA","type":"state","common":{"name":"AC-Phase A (L1) Stromwert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"A"},"native":{"regType":"holdingRegs","address":71,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.013 - debug: modbus.1 (2749409) Add holdingRegisters.72_I_AC_StromB: {"_id":"holdingRegisters.72_I_AC_StromB","type":"state","common":{"name":"AC-Phase B (L2) Stromwert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"A"},"native":{"regType":"holdingRegs","address":72,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.013 - debug: modbus.1 (2749409) Add holdingRegisters.73_I_AC_StromC: {"_id":"holdingRegisters.73_I_AC_StromC","type":"state","common":{"name":"AC-Phase C (L3) Stromwert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"A"},"native":{"regType":"holdingRegs","address":73,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.013 - debug: modbus.1 (2749409) Add holdingRegisters.74_I_AC_Strom_SF: {"_id":"holdingRegisters.74_I_AC_Strom_SF","type":"state","common":{"name":"AC-Strom Skalierungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":74,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.014 - debug: modbus.1 (2749409) Add holdingRegisters.75_I_AC_SpannungAB: {"_id":"holdingRegisters.75_I_AC_SpannungAB","type":"state","common":{"name":"AC-Spannung Phase AB (L1-L2) Wert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":75,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.014 - debug: modbus.1 (2749409) Add holdingRegisters.76_I_AC_SpannungBC: {"_id":"holdingRegisters.76_I_AC_SpannungBC","type":"state","common":{"name":"AC-Spannung Phase BC (L2-L3) Wert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":76,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.014 - debug: modbus.1 (2749409) Add holdingRegisters.77_I_AC_SpannungCA: {"_id":"holdingRegisters.77_I_AC_SpannungCA","type":"state","common":{"name":"AC-Spannung Phase CA (L3-L1) Wert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":77,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.014 - debug: modbus.1 (2749409) Add holdingRegisters.78_I_AC_SpannungAN: {"_id":"holdingRegisters.78_I_AC_SpannungAN","type":"state","common":{"name":"AC-Spannung Phase A-N (L1-N) Wert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":78,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.015 - debug: modbus.1 (2749409) Add holdingRegisters.79_I_AC_SpannungBN: {"_id":"holdingRegisters.79_I_AC_SpannungBN","type":"state","common":{"name":"AC-Spannung Phase B-N (L2-N) Wert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":79,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.015 - debug: modbus.1 (2749409) Add holdingRegisters.80_I_AC_SpannungCN: {"_id":"holdingRegisters.80_I_AC_SpannungCN","type":"state","common":{"name":"AC-Spannung Phase C-N (L3-N) Wert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":80,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.015 - debug: modbus.1 (2749409) Add holdingRegisters.81_I_AC_Spannung_SF: {"_id":"holdingRegisters.81_I_AC_Spannung_SF","type":"state","common":{"name":"AC-Spannung Skalierungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":81,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.015 - debug: modbus.1 (2749409) Add holdingRegisters.82_I_AC_Leistung: {"_id":"holdingRegisters.82_I_AC_Leistung","type":"state","common":{"name":"AC-Leistungswert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"W"},"native":{"regType":"holdingRegs","address":82,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.016 - debug: modbus.1 (2749409) Add holdingRegisters.83_I_AC_Leistung_SF: {"_id":"holdingRegisters.83_I_AC_Leistung_SF","type":"state","common":{"name":"AC-Leistung Skalierungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":83,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.016 - debug: modbus.1 (2749409) Add holdingRegisters.84_I_AC_Frequenz: {"_id":"holdingRegisters.84_I_AC_Frequenz","type":"state","common":{"name":"Frequenzwert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"Hz"},"native":{"regType":"holdingRegs","address":84,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.016 - debug: modbus.1 (2749409) Add holdingRegisters.85_I_AC_Frequenz_SF: {"_id":"holdingRegisters.85_I_AC_Frequenz_SF","type":"state","common":{"name":"Frequenz Skalierungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":85,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.016 - debug: modbus.1 (2749409) Add holdingRegisters.86_I_AC_VA: {"_id":"holdingRegisters.86_I_AC_VA","type":"state","common":{"name":"Scheinleistung","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"VA"},"native":{"regType":"holdingRegs","address":86,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.017 - debug: modbus.1 (2749409) Add holdingRegisters.87_I_AC_VA_SF: {"_id":"holdingRegisters.87_I_AC_VA_SF","type":"state","common":{"name":"Scheinleistung Skalierungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":87,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.017 - debug: modbus.1 (2749409) Add holdingRegisters.88_I_AC_VAR: {"_id":"holdingRegisters.88_I_AC_VAR","type":"state","common":{"name":"Blindleistung","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"VAR"},"native":{"regType":"holdingRegs","address":88,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.017 - debug: modbus.1 (2749409) Add holdingRegisters.89_I_AC_VAR_SF: {"_id":"holdingRegisters.89_I_AC_VAR_SF","type":"state","common":{"name":"Blindleistung Skalierungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":89,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.017 - debug: modbus.1 (2749409) Add holdingRegisters.90_I_AC_PF: {"_id":"holdingRegisters.90_I_AC_PF","type":"state","common":{"name":"Leistungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":90,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.018 - debug: modbus.1 (2749409) Add holdingRegisters.91_I_AC_PF_SF: {"_id":"holdingRegisters.91_I_AC_PF_SF","type":"state","common":{"name":"Leistungsfaktor Skalierungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":91,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.018 - debug: modbus.1 (2749409) Add holdingRegisters.92_I_AC_Energie_WH: {"_id":"holdingRegisters.92_I_AC_Energie_WH","type":"state","common":{"name":"AC Gesamt-Energieproduktion","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"Wh"},"native":{"regType":"holdingRegs","address":92,"deviceId":2,"type":"uint32be","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.018 - debug: modbus.1 (2749409) Add holdingRegisters.94_I_AC_Energie_WH_SF: {"_id":"holdingRegisters.94_I_AC_Energie_WH_SF","type":"state","common":{"name":"AC Gesamtenergie Skalierungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":94,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.018 - debug: modbus.1 (2749409) Add holdingRegisters.95_I_DC_Strom: {"_id":"holdingRegisters.95_I_DC_Strom","type":"state","common":{"name":"DC-Stromwert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"A"},"native":{"regType":"holdingRegs","address":95,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.019 - debug: modbus.1 (2749409) Add holdingRegisters.96_I_DC_Strom_SF: {"_id":"holdingRegisters.96_I_DC_Strom_SF","type":"state","common":{"name":"DC-Strom Skalierungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":96,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.019 - debug: modbus.1 (2749409) Add holdingRegisters.97_I_DC_Spannung: {"_id":"holdingRegisters.97_I_DC_Spannung","type":"state","common":{"name":"DC-Spannungswert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":97,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.019 - debug: modbus.1 (2749409) Add holdingRegisters.98_I_DC_Spannung_SF: {"_id":"holdingRegisters.98_I_DC_Spannung_SF","type":"state","common":{"name":"DC-Spannung Skalierungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":98,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.019 - debug: modbus.1 (2749409) Add holdingRegisters.99_I_DC_Leistung: {"_id":"holdingRegisters.99_I_DC_Leistung","type":"state","common":{"name":"DC-Leistungswert","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"W"},"native":{"regType":"holdingRegs","address":99,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.020 - debug: modbus.1 (2749409) Add holdingRegisters.100_I_DC_Leistung_SF: {"_id":"holdingRegisters.100_I_DC_Leistung_SF","type":"state","common":{"name":"DC-Leistung Skalierungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":100,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.020 - debug: modbus.1 (2749409) Add holdingRegisters.102_I_Temp_Kühler: {"_id":"holdingRegisters.102_I_Temp_Kühler","type":"state","common":{"name":"Kühlkörpertemperatur","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":102,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.020 - debug: modbus.1 (2749409) Add holdingRegisters.105_I_Temp_SF: {"_id":"holdingRegisters.105_I_Temp_SF","type":"state","common":{"name":"Kühlkörpertemperatur Skalierungsfaktor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":105,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.020 - debug: modbus.1 (2749409) Add holdingRegisters.106_I_Status: {"_id":"holdingRegisters.106_I_Status","type":"state","common":{"name":"Betriebszustand (1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup)","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":106,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.021 - debug: modbus.1 (2749409) Add holdingRegisters.107_I_Status_Anbieter: {"_id":"holdingRegisters.107_I_Status_Anbieter","type":"state","common":{"name":"Anbieter-spezifischer Betriebszustand sowie Fehlercodes: 1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":107,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.021 - debug: modbus.1 (2749409) Add holdingRegisters.122_C_Manufacturer: {"_id":"holdingRegisters.122_C_Manufacturer","type":"state","common":{"name":"Meter manufacturer","role":"value","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":122,"deviceId":2,"type":"string","len":32,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.021 - debug: modbus.1 (2749409) Add holdingRegisters.138_C_Model: {"_id":"holdingRegisters.138_C_Model","type":"state","common":{"name":"Meter model","role":"value","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":138,"deviceId":2,"type":"string","len":32,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.021 - debug: modbus.1 (2749409) Add holdingRegisters.154_C_Option: {"_id":"holdingRegisters.154_C_Option","type":"state","common":{"name":"Export + Import, Production, consumption","role":"value","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":154,"deviceId":2,"type":"string","len":16,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.022 - debug: modbus.1 (2749409) Add holdingRegisters.189_M_AC_Current: {"_id":"holdingRegisters.189_M_AC_Current","type":"state","common":{"name":"AC Current (sum of active phases)","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"A"},"native":{"regType":"holdingRegs","address":189,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.022 - debug: modbus.1 (2749409) Add holdingRegisters.193_M_AC_Current_S_F: {"_id":"holdingRegisters.193_M_AC_Current_S_F","type":"state","common":{"name":"AC Current Scale Factor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":193,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.022 - debug: modbus.1 (2749409) Add holdingRegisters.205_M_AC_Power: {"_id":"holdingRegisters.205_M_AC_Power","type":"state","common":{"name":"Total Real Power (sum of active phases)","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"W"},"native":{"regType":"holdingRegs","address":205,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.022 - debug: modbus.1 (2749409) Add holdingRegisters.209_M_AC_Power_SF: {"_id":"holdingRegisters.209_M_AC_Power_SF","type":"state","common":{"name":"AC Real Power Scale Factor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":209,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.023 - debug: modbus.1 (2749409) Add holdingRegisters.225_M_Exported: {"_id":"holdingRegisters.225_M_Exported","type":"state","common":{"name":"Total Exported Real Energy","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"Wh"},"native":{"regType":"holdingRegs","address":225,"deviceId":2,"type":"uint32be","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.023 - debug: modbus.1 (2749409) Add holdingRegisters.233_M_Imported: {"_id":"holdingRegisters.233_M_Imported","type":"state","common":{"name":"Total Imported Real Energy","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"Wh"},"native":{"regType":"holdingRegs","address":233,"deviceId":2,"type":"uint32be","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.023 - debug: modbus.1 (2749409) Add holdingRegisters.241_M_Energy_W_SF: {"_id":"holdingRegisters.241_M_Energy_W_SF","type":"state","common":{"name":"Real Energy Scale Factor","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"SF"},"native":{"regType":"holdingRegs","address":241,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.023 - debug: modbus.1 (2749409) Add holdingRegisters.17663_Battery_1 Device ID: {"_id":"holdingRegisters.17663_Battery_1 Device ID","type":"state","common":{"name":"Batterie Geräte ID","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":17663,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.024 - debug: modbus.1 (2749409) Add holdingRegisters.17665_Battery_1 Rated Energy: {"_id":"holdingRegisters.17665_Battery_1 Rated Energy","type":"state","common":{"name":"Batterie Nennkapazität","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"Wh"},"native":{"regType":"holdingRegs","address":17665,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.024 - debug: modbus.1 (2749409) Add holdingRegisters.17667_Battery_1 Max Charge Continues Power: {"_id":"holdingRegisters.17667_Battery_1 Max Charge Continues Power","type":"state","common":{"name":"Batterie maximale Ladeleistung","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"W"},"native":{"regType":"holdingRegs","address":17667,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.024 - debug: modbus.1 (2749409) Add holdingRegisters.17669_Battery_1 Max Discharge Continues Power: {"_id":"holdingRegisters.17669_Battery_1 Max Discharge Continues Power","type":"state","common":{"name":"Batterie maximale Entladeleistung","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"W"},"native":{"regType":"holdingRegs","address":17669,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.024 - debug: modbus.1 (2749409) Add holdingRegisters.17671_Battery_1 Max Charge Peak Power: {"_id":"holdingRegisters.17671_Battery_1 Max Charge Peak Power","type":"state","common":{"name":"Batterie maximale Ladespitzenleistung","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"W"},"native":{"regType":"holdingRegs","address":17671,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.024 - debug: modbus.1 (2749409) Add holdingRegisters.17673_Battery_1 Max Discharge Peak Power: {"_id":"holdingRegisters.17673_Battery_1 Max Discharge Peak Power","type":"state","common":{"name":"Batterie maximale Entladespitzenleistung","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"W"},"native":{"regType":"holdingRegs","address":17673,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.025 - debug: modbus.1 (2749409) Add holdingRegisters.17707_Battery_1 Average Temperature: {"_id":"holdingRegisters.17707_Battery_1 Average Temperature","type":"state","common":{"name":"Batterie Durchschnittstemperatur","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":17707,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.025 - debug: modbus.1 (2749409) Add holdingRegisters.17709_Battery_1 Max Temperature: {"_id":"holdingRegisters.17709_Battery_1 Max Temperature","type":"state","common":{"name":"Batterie maximale Temperatur","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":17709,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.025 - debug: modbus.1 (2749409) Add holdingRegisters.17711_Battery_1 Instantaneous Voltage: {"_id":"holdingRegisters.17711_Battery_1 Instantaneous Voltage","type":"state","common":{"name":"Batterie momentane Spannung","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":17711,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.025 - debug: modbus.1 (2749409) Add holdingRegisters.17713_Battery_1 Instantaneous Current: {"_id":"holdingRegisters.17713_Battery_1 Instantaneous Current","type":"state","common":{"name":"Batterie momentane Stromstärke","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"A"},"native":{"regType":"holdingRegs","address":17713,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.026 - debug: modbus.1 (2749409) Add holdingRegisters.17715_Battery_1 Instantaneous Power: {"_id":"holdingRegisters.17715_Battery_1 Instantaneous Power","type":"state","common":{"name":"Batterie momentane Leistung","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"W"},"native":{"regType":"holdingRegs","address":17715,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.026 - debug: modbus.1 (2749409) Add holdingRegisters.17717_Battery_1 Lifetime Export Energy Counter: {"_id":"holdingRegisters.17717_Battery_1 Lifetime Export Energy Counter","type":"state","common":{"name":"Batterie Gesamtenergie entladen","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"Wh"},"native":{"regType":"holdingRegs","address":17717,"deviceId":2,"type":"uint64le","len":4,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.026 - debug: modbus.1 (2749409) Add holdingRegisters.17721_Battery_1 Lifetime Import Energy Counter: {"_id":"holdingRegisters.17721_Battery_1 Lifetime Import Energy Counter","type":"state","common":{"name":"Batterie Gesamtenergie geladen","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"Wh"},"native":{"regType":"holdingRegs","address":17721,"deviceId":2,"type":"uint64le","len":4,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.026 - debug: modbus.1 (2749409) Add holdingRegisters.17725_Battery_1 Max Energy: {"_id":"holdingRegisters.17725_Battery_1 Max Energy","type":"state","common":{"name":"Batteriekapazität aktualisiert nach Alterung","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"Wh"},"native":{"regType":"holdingRegs","address":17725,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.027 - debug: modbus.1 (2749409) Add holdingRegisters.17727_Battery_1 Available Energy: {"_id":"holdingRegisters.17727_Battery_1 Available Energy","type":"state","common":{"name":"Batterie verfügbare Energie","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"Wh"},"native":{"regType":"holdingRegs","address":17727,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.027 - debug: modbus.1 (2749409) Add holdingRegisters.17729_Battery_1 State of Health (SOH): {"_id":"holdingRegisters.17729_Battery_1 State of Health (SOH)","type":"state","common":{"name":"Batterie Verhältnis von Nennkapazität zu Batteriekapazität nach Alterung","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":17729,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.027 - debug: modbus.1 (2749409) Add holdingRegisters.17731_Battery_1 State of Energy (SOE): {"_id":"holdingRegisters.17731_Battery_1 State of Energy (SOE)","type":"state","common":{"name":"Batterie Ladezustand (verfügbare Energie zu mögliche Kapazität)","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":17731,"deviceId":2,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                2021-12-24 16:35:21.028 - debug: modbus.1 (2749409) Add holdingRegisters.17733_Battery_1 Status: {"_id":"holdingRegisters.17733_Battery_1 Status","type":"state","common":{"name":"Batterie Zustand (0 = Aus, 1 = Standby, 2 = Initialisierung, 3 = Laden, 4 = Entladen, 5 = Fehler, 6 = Leerlauf)","role":"level","type":"number","read":false,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":17733,"deviceId":2,"type":"uint32sw","len":"2","offset":"0","factor":"1","poll":false}}
                2021-12-24 16:35:21.110 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.NaN_C_SunSpec_ID
                2021-12-24 16:35:21.110 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40002_C_SunSpec_DID
                2021-12-24 16:35:21.110 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40003_C_SunSpec_Länge
                2021-12-24 16:35:21.111 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40004_C_Hersteller
                2021-12-24 16:35:21.111 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40020_C_Modell
                2021-12-24 16:35:21.111 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40044_C_Version
                2021-12-24 16:35:21.111 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40052_C_Seriennummer
                2021-12-24 16:35:21.111 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40068_C_Geräteadresse
                2021-12-24 16:35:21.112 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40069_C_SunSpec_DID
                2021-12-24 16:35:21.112 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40070_C_SunSpec_Länge
                2021-12-24 16:35:21.112 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40071_I_AC_Strom
                2021-12-24 16:35:21.112 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40072_I_AC_StromA
                2021-12-24 16:35:21.112 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40073_I_AC_StromB
                2021-12-24 16:35:21.113 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40074_I_AC_StromC
                2021-12-24 16:35:21.113 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40075_I_AC_Strom_SF
                2021-12-24 16:35:21.113 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40076_I_AC_SpannungAB
                2021-12-24 16:35:21.113 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40077_I_AC_SpannungBC
                2021-12-24 16:35:21.113 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40078_I_AC_SpannungCA
                2021-12-24 16:35:21.114 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40079_I_AC_SpannungAN
                2021-12-24 16:35:21.114 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40080_I_AC_SpannungBN
                2021-12-24 16:35:21.114 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40081_I_AC_SpannungCN
                2021-12-24 16:35:21.114 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40082_I_AC_Spannung_SF
                2021-12-24 16:35:21.114 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40083_I_AC_Leistung
                2021-12-24 16:35:21.114 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40084_I_AC_Leistung_SF
                2021-12-24 16:35:21.115 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40085_I_AC_Frequenz
                2021-12-24 16:35:21.115 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40086_I_AC_Frequenz_SF
                2021-12-24 16:35:21.115 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40087_I_AC_VA
                2021-12-24 16:35:21.115 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40088_I_AC_VA_SF
                2021-12-24 16:35:21.115 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40089_I_AC_VAR
                2021-12-24 16:35:21.116 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40090_I_AC_VAR_SF
                2021-12-24 16:35:21.116 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40091_I_AC_PF
                2021-12-24 16:35:21.116 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40092_I_AC_PF_SF
                2021-12-24 16:35:21.116 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40093_I_AC_Energie_WH
                2021-12-24 16:35:21.116 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40095_I_AC_Energie_WH_SF
                2021-12-24 16:35:21.117 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40096_I_DC_Strom
                2021-12-24 16:35:21.117 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40097_I_DC_Strom_SF
                2021-12-24 16:35:21.117 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40098_I_DC_Spannung
                2021-12-24 16:35:21.117 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40099_I_DC_Spannung_SF
                2021-12-24 16:35:21.117 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40100_I_DC_Leistung
                2021-12-24 16:35:21.118 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40101_I_DC_Leistung_SF
                2021-12-24 16:35:21.118 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40103_I_Temp_Kühler
                2021-12-24 16:35:21.118 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40106_I_Temp_SF
                2021-12-24 16:35:21.118 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40107_I_Status
                2021-12-24 16:35:21.118 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40108_I_Status_Anbieter
                2021-12-24 16:35:21.118 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40123_C_Manufacturer
                2021-12-24 16:35:21.119 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40139_C_Model
                2021-12-24 16:35:21.119 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40155_C_Option
                2021-12-24 16:35:21.119 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40190_M_AC_Current
                2021-12-24 16:35:21.119 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40194_M_AC_Current_S_F
                2021-12-24 16:35:21.119 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40206_M_AC_Power
                2021-12-24 16:35:21.120 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40210_M_AC_Power_SF
                2021-12-24 16:35:21.120 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40226_M_Exported
                2021-12-24 16:35:21.120 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40234_M_Imported
                2021-12-24 16:35:21.120 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.40242_M_Energy_W_SF
                2021-12-24 16:35:21.120 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57664_Battery_1 Device ID
                2021-12-24 16:35:21.120 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57666_Battery_1 Rated Energy
                2021-12-24 16:35:21.121 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57668_Battery_1 Max Charge Continues Power
                2021-12-24 16:35:21.121 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57670_Battery_1 Max Discharge Continues Power
                2021-12-24 16:35:21.121 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57672_Battery_1 Max Charge Peak Power
                2021-12-24 16:35:21.121 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57674_Battery_1 Max Discharge Peak Power
                2021-12-24 16:35:21.121 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57708_Battery_1 Average Temperature
                2021-12-24 16:35:21.122 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57710_Battery_1 Max Temperature
                2021-12-24 16:35:21.122 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57712_Battery_1 Instantaneous Voltage
                2021-12-24 16:35:21.122 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57714_Battery_1 Instantaneous Current
                2021-12-24 16:35:21.122 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57716_Battery_1 Instantaneous Power
                2021-12-24 16:35:21.122 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57718_Battery_1 Lifetime Export Energy Counter
                2021-12-24 16:35:21.122 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57722_Battery_1 Lifetime Import Energy Counter
                2021-12-24 16:35:21.123 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57726_Battery_1 Max Energy
                2021-12-24 16:35:21.123 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57728_Battery_1 Available Energy
                2021-12-24 16:35:21.123 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57730_Battery_1 State of Health (SOH)
                2021-12-24 16:35:21.123 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57732_Battery_1 State of Energy (SOE)
                2021-12-24 16:35:21.123 - debug: modbus.1 (2749409) Remove old object modbus.1.holdingRegisters.57734_Battery_1 Status
                2021-12-24 16:35:30.006 - info: javascript.0 (115330) script.js.common.TestSayIT: sayIt: es läuft
                2021-12-24 16:35:30.014 - info: sayit.0 (95626) saying: es läuft
                2021-12-24 16:35:30.320 - info: modbus.1 (2749409) Connected to slave 192.168.1.46
                2021-12-24 16:35:30.321 - debug: modbus.1 (2749409) [DevID_2] Poll start ---------------------
                2021-12-24 16:35:30.322 - debug: modbus.1 (2749409) Initialization of scale factors done!
                2021-12-24 16:35:30.322 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 1 - 100 registers
                2021-12-24 16:35:30.414 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 1 DONE
                2021-12-24 16:35:30.418 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 102 - 68 registers
                2021-12-24 16:35:30.531 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 102 DONE
                2021-12-24 16:35:30.533 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 189 - 5 registers
                2021-12-24 16:35:30.542 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 189 DONE
                2021-12-24 16:35:30.544 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 205 - 5 registers
                2021-12-24 16:35:30.673 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 205 DONE
                2021-12-24 16:35:30.674 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 225 - 17 registers
                2021-12-24 16:35:30.733 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 225 DONE
                2021-12-24 16:35:30.734 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 17663 - 12 registers
                2021-12-24 16:35:30.782 - debug: modbus.1 (2749409) Received pdu describes an error.
                2021-12-24 16:35:30.783 - warn: modbus.1 (2749409) Poll error count: 1 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                2021-12-24 16:35:36.786 - debug: modbus.1 (2749409) [DevID_2] Poll start ---------------------
                2021-12-24 16:35:36.786 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 1 - 100 registers
                2021-12-24 16:35:38.789 - warn: modbus.1 (2749409) Error: undefined
                2021-12-24 16:35:38.790 - error: modbus.1 (2749409) Request timed out.
                2021-12-24 16:35:38.790 - error: modbus.1 (2749409) Client in error state.
                2021-12-24 16:35:38.791 - warn: modbus.1 (2749409) Poll error count: 2 code: {"err":"timeout","timeout":2000}
                2021-12-24 16:35:38.792 - debug: modbus.1 (2749409) Socket closed with error
                2021-12-24 16:35:38.792 - debug: modbus.1 (2749409) Clearing timeout of the current request.
                2021-12-24 16:35:38.793 - debug: modbus.1 (2749409) Cleaning up request fifo.
                2021-12-24 16:35:39.792 - debug: modbus.1 (2749409) Closing client on purpose.
                2021-12-24 16:35:39.793 - info: modbus.1 (2749409) Disconnected from slave 192.168.1.46
                2021-12-24 16:35:44.793 - debug: modbus.1 (2749409) [DevID_2] Poll start ---------------------
                2021-12-24 16:35:44.794 - debug: modbus.1 (2749409) [DevID_2/holdingRegs] Poll address 1 - 100 registers
                • Glasfaser
                  Glasfaser @Luzzi last edited by
                  @luzzi
                  Von ioBroker aus , prüfe mal mit :
                  nc -zv 192.168.1.46 502
                  ( NC ist vom Linux Programm NETCAT , wenn es nicht geht dann nachinstallieren)
                    Luzzi @Glasfaser last edited by
                    @glasfaser
                    Probiere es aus. Wird eine Zeit dauern, bzw. nicht mehr Heute.
                    Gebe dann ein Feedback.
                    Aber schon mal Danke für die Unterstützung.
                    • Glasfaser
                      @luzzi
                      Du kannst auch in deiner alten Instanz Pool ausschalten außer der ersten , damit nur eine gepoolt wird .
                        @glasfaser
                        Ohne, dass ich irgendetwas weiter angepasst habe, läuft die Abfrage Heute wieder.
                        Bei den Einstellungen ist mir aufgefallen, dass neu die Wartezeit mit 999 eingestellt ist.
                        Ich bin mir ziemlich sicher, dass ich dort 1000 hatte.
                        Ev. hat es aber auch mit dem Verhalten der SolarEdge zu tun. Die geht in einen Sleep-Modus, wenn kein Storm produziert wird. Ev. hat er die Verbindung auch blockiert, da ich längere Zeit nicht mehr abgefragt habe.
                        Alias habe ich übrigens jetzt wieder aktiviert. Da ansonsten die Objekte nicht mehr gleich heissen.
                        Danke dir auf jeden Fall für deine Tipps 😉
                        282
