    4. GUI Probleme: "Error in GUI"
      Thomas Braun Most Active @Philipp Dorn last edited by
      @philipp-dorn
      Kommentier die Zeile raus.
      Das Ding ist mehr als überflüssig:
      Archive: trusty
      Version: 14.04
      Component: main
      Origin: LP-PPA-webupd8team-java
      Label: Oracle Java (JDK) 8 Installer PPA (DISCONTINUED)
      Architecture: source
        guazzle @Thomas Braun last edited by
        Hallo liebes Forum,
        ich denke ich habe jetzt auch den gleichen Fehler. Habe letztens den iobroker und auch den raspberry geupdatet. Allerdings habe ich jetzt diesen GUI - Error Fehler.
        Folgendes kommt in der F12 Debug ansicht:
        react-dom.production.min.js:216
           DOMException: Failed to execute 'removeChild' on 'Node': The node to be removed is not a child of this node.
        at Oi (http://192.168.178.79:8081/static/js/5.bde6ca2f.chunk.js:2:5519753)
        at jl (http://192.168.178.79:8081/static/js/5.bde6ca2f.chunk.js:2:5531565)
        at t.unstable_runWithPriority (http://192.168.178.79:8081/static/js/5.bde6ca2f.chunk.js:2:5558154)
        at Wa (http://192.168.178.79:8081/static/js/5.bde6ca2f.chunk.js:2:5474540)
        at Vl (http://192.168.178.79:8081/static/js/5.bde6ca2f.chunk.js:2:5529523)
        at ml (http://192.168.178.79:8081/static/js/5.bde6ca2f.chunk.js:2:5525609)
        at http://192.168.178.79:8081/static/js/5.bde6ca2f.chunk.js:2:5474763
        at Ga (http://192.168.178.79:8081/static/js/5.bde6ca2f.chunk.js:2:5474708)
        ii @ react-dom.production.min.js:216
        n.payload @ react-dom.production.min.js:217
        uc @ react-dom.production.min.js:130
        Io @ react-dom.production.min.js:184
        Ui @ react-dom.production.min.js:269
        Cl @ react-dom.production.min.js:250
        _l @ react-dom.production.min.js:250
        El @ react-dom.production.min.js:250
        ml @ react-dom.production.min.js:243
        (anonym) @ react-dom.production.min.js:123
        t.unstable_runWithPriority @ scheduler.production.min.js:18
        Wa @ react-dom.production.min.js:122
        Ga @ react-dom.production.min.js:123
        Ua @ react-dom.production.min.js:122
        hl @ react-dom.production.min.js:237
        enqueueForceUpdate @ react-dom.production.min.js:134
        m.forceUpdate @ react.production.min.js:12
        (anonym) @ ObjectBrowser.js:2163
        setTimeout (asynchron)
        onStateChange @ ObjectBrowser.js:2161
        (anonym) @ Connection.js:482
        SocketClient.findAnswer @ socket.io.js:255
        socket.onmessage @ socket.io.js:163
        Den Lösungsversucht mit iobroker stop, fix und restart habe ich schon versucht aber es kommt immer noch dieser GUI Fehler.
        Ich hoffe ihr könnt mir hier ein wenig helfen - und ich stelle mich nicht zu blöd an - aber bin doch ein rechter Neuling.
        Folgendes kommt bei diesem Befehl update -i
        pi@iobrokerraspberry:~ $ iobroker update -i
        Used repository: stable
        hash unchanged, use cached sources
        update done
        Adapter "admin" : 5.1.25 , installed 5.1.25
        Adapter "backitup" : 2.2.2 , installed 2.2.2
        Adapter "cloud" : 4.1.0 , installed 4.1.0
        Adapter "coronavirus-statistics": 0.8.7 , installed 0.8.7
        Adapter "discovery" : 2.7.3 , installed 2.7.0 [Updateable]
        Adapter "hm-rega" : 3.0.33 , installed 3.0.33
        Adapter "hm-rpc" : 1.14.50 , installed 1.14.50
        Adapter "hs100" : 2.0.6 , installed 2.0.6
        Adapter "info" : 1.9.8 , installed 1.9.8
        Adapter "iot" : 1.8.24 , installed 1.8.22 [Updateable]
        Adapter "javascript" : 5.2.13 , installed 5.2.13
        Controller "js-controller" : 3.3.21 , installed 3.3.21
        Adapter "mercedesme" : 0.0.55 , installed 0.0.55
        Adapter "meross" : 1.6.3 , installed 1.6.3
        Adapter "netatmo" : 1.4.4 , installed 1.4.4
        Adapter "samsung" : 0.2.9 , installed 0.2.9
        Adapter "simple-api" : 2.6.1 , installed 2.6.1
        Adapter "socketio" : 3.1.4 , installed 3.1.5
        Adapter "sunnyportal" : 0.1.5 , installed 0.1.5
        Adapter "tr-064" : 4.2.14 , installed 4.2.14
        Adapter "tradfri" : 3.0.1 , installed 3.0.1
        Adapter "vis" : 1.4.5 , installed 1.4.5
        Adapter "web" : 3.4.9 , installed 3.4.9
        pi@iobrokerraspberry:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        /usr/bin/nodejs
        v12.22.7
        /usr/bin/node
        v12.22.7
        /usr/bin/npm
        6.14.15
        nodejs:
        Installiert: 12.22.7-deb-1nodesource1
        Installationskandidat: 12.22.8-deb-1nodesource1
        Versionstabelle:
        12.22.8-deb-1nodesource1 500
        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
        *** 12.22.7-deb-1nodesource1 100
        100 /var/lib/dpkg/status
        10.24.0~dfsg-1~deb10u1 500
        Vielen Dank für Eure Hilfe.
        Guazzle
          Thomas Braun Most Active @guazzle last edited by
          @guazzle sagte in GUI Probleme: "Error in GUI":
          Glaube nicht. Mach einen eigenen Thread auf und poste da ordentlich in CodeTags.
            Accu last edited by Accu
            ich habe genau den gleichen Fehler bei mir plötzlich. Das letzte was ich gemacht habe war den Admin Adapter zu updaten.
            Browser Cache habe ich geleert. IoBroker neu gestartet:
            pi@Raspi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v12.22.8
            /usr/bin/node
            v12.22.8
            /usr/bin/npm
            6.14.15
            nodejs:
              Installiert:           12.22.8-deb-1nodesource1
              Versionstabelle:
             *** 12.22.8-deb-1nodesource1 500
            pi@Raspi:~ $ iobroker update | grep -i updateable
            Adapter    "admin"         : 5.2.2    , installed 5.2.1 [Updateable]
            Controller "js-controller" : 3.3.22   , installed 3.2.16 [Updateable]
            Ich bin mir nicht sicher, ob es an der von mir installierten nodejs v12 liegt und ob diese auf 14 geupgraded werden muss.
            Ich habe mal quergelesen und mit folgenden Befehl die nodesource.list editiert
            #node 12
            deb https://deb.nodesource.com/node_12.x buster main
            deb-src https://deb.nodesource.com/node_12.x buster main
            #node 14
            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main
            deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main
            und die line #node14 hinzugefügt und auf Buster geändert.
            Allerdings bekomme ich jetzt beim Updaten folgenden Fehler:
            apt-get update
            OK:1 http://archive.raspberrypi.org/debian buster InRelease
            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            OK:3 https://deb.nodesource.com/node_12.x buster InRelease
            Holen:4 https://deb.nodesource.com/node_14.x buster InRelease [4.584 B]
            Fehl:4 https://deb.nodesource.com/node_14.x buster InRelease
              Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 1655A0AB68576280
            W: GPG-Fehler: https://deb.nodesource.com/node_14.x buster InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 1655A0AB68576280
            E: Das Depot »https://deb.nodesource.com/node_14.x buster InRelease« ist nicht signiert.
            N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
            N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
            Error executing command, exiting
            Weiß jemand Rat?
              Thomas Braun Most Active @Accu last edited by
              @accu
              sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com --recv-key 1655A0AB68576280
                @thomas-braun said in GUI Probleme: "Error in GUI":
                pi@Raspi:~ $ sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com --recv-key 1655A0AB68576280
                Executing: /tmp/apt-key-gpghome.2p9iG1zNgE/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com --recv-key 1655A0AB68576280
                gpg: Schlüssel 1655A0AB68576280: "NodeSource <gpg@nodesource.com>" nicht geändert
                gpg: Anzahl insgesamt bearbeiteter Schlüssel: 1
                gpg:                             unverändert: 1
                pi@Raspi:~ $
                Bringt mich leider nicht wirklich weiter:
                pi@Raspi:~ $ sudo apt-get update
                Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                  @accu
                  Dann lösche die nodesource.list und hol die mit dem Installerskript nochmal neu rein.
                    Accu last edited by
                    bin nicht so der Linux pro. kannst du mir kurz schreiben wie man das macht?
                      @accu
                      Schau in meiner Signatur.
                      Löschen der nodesource.list:
                      sudo rm /etc/apt/sources.list.d/nodesource.list
                        Accu @Thomas Braun last edited by
                        habe jetzt mal den upgrade gemacht.
                        pi@Raspi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v14.18.2
                        v14.18.2
                        6.14.15
                        OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                        Alle Pakete sind aktuell.
                        nodejs:
                          Installiert:           14.18.2-deb-1nodesource1
                          Installationskandidat: 14.18.2-deb-1nodesource1
                          Versionstabelle:
                         *** 14.18.2-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                        Leider habe ich immer noch nach dem Reboot den GUI Fehler von oben.
                        Achja im upgrade hat er mir folgendes angezeigt:
                        Distri update hat scheinbar nix gebracht:
                        pi@Raspi:~ $ sudo apt dist-upgrade
                        Paketaktualisierung (Upgrade) wird berechnet... Fertig
                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          @accu
                          Was ist denn das für ein System?
                          sudo apt update
                          sudo apt full-upgrade
                          sudo reboot
                            @thomas-braun was meinst du mit System?
                            pi@Raspi:~ $ sudo apt update
                            OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            OK:2 http://archive.raspberrypi.org/debian buster InRelease
                            pi@Raspi:~ $ sudo apt full-upgrade
                            pi@Raspi:~ $
                            Leider hat alles nichts gebracht. Sobald ich auf die WebGUI vom ioBroker zugreifen will bekomme ich den Fehler:
                            Error in GUI - d.h. es hat nichts bebracht auf node 14 zu gehen 😞
                              @accu
                              Und mit welchen Versionen sind wir da unterwegs?
                              iobroker update -i
                                @accu sagte in GUI Probleme: "Error in GUI":
                                Error in GUI
                                Hast du denn das mal erledigt, was da in dem Fenster vorgeschlagen wird?
                                  Versionen:
                                  pi@Raspi:~ $ iobroker update -i
                                  update done
                                  Adapter    "admin"         : 5.2.3    , installed 5.2.1 [Updateable]
                                  Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
                                  Adapter    "bmw"           : 2.5.0    , installed 2.5.0
                                  Adapter    "denon"         : 1.11.2   , installed 1.11.2
                                  Adapter    "discovery"     : 2.7.3    , installed 2.7.3
                                  Adapter    "dwd"           : 2.7.7    , installed 2.7.7
                                  Adapter    "email"         : 1.0.10   , installed 1.0.10
                                  Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                                  Adapter    "history"       : 1.9.14   , installed 1.9.14
                                  Adapter    "hue"           : 3.5.31   , installed 3.5.31
                                  Adapter    "hue-extended"  : 2.0.0    , installed 2.0.0
                                  Adapter    "iot"           : 1.8.24   , installed 1.8.24
                                  Adapter    "lgtv"          : 1.1.10   , installed 1.1.10
                                  Adapter    "linux-control" : 1.1.3    , installed 1.1.3
                                  Adapter    "luftdaten"     : 1.0.3    , installed 1.0.3
                                  Adapter    "material"      : 1.0.4    , installed 1.0.4
                                  Adapter    "miele"         : 0.1.5    , installed 0.1.5
                                  Adapter    "mielecloudservice": 5.0.2   , installed 5.0.2
                                  Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
                                  Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                                  Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
                                  Adapter    "node-red"      : 2.4.1    , installed 2.4.1
                                  Adapter    "ping"          : 1.5.0    , installed 1.5.0
                                  Adapter    "pushover"      : 2.0.5    , installed 2.0.5
                                  Adapter    "robonect"      : 0.1.4    , installed 0.1.4
                                  Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
                                  Adapter    "scenes"        : 2.3.8    , installed 2.3.8
                                  Adapter    "shelly"        : 4.0.7    , installed 4.0.7
                                  Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                                  Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
                                  Adapter    "sonos"         : 2.1.1    , installed 2.1.1
                                  Adapter    "spotify-premium": 1.0.0   , installed 1.0.0
                                  Adapter    "synology"      : 1.1.3    , installed 1.1.3
                                  Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
                                  Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                                  Adapter    "terminal"      : 0.1.2    , installed 0.1.2
                                  Adapter    "text2command"  : 2.1.1    , installed 2.1.1
                                  Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                                  Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
                                  Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                                  Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                                  Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
                                  Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                                  Adapter    "vis-weather"   : 2.5.5    , installed 2.5.5
                                  Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
                                  Der Admin Adapter erscheint als "updateable" aber irgendwie lässt er sich nicht updaten wenn ich iobroker update && iobroker upgrade mache
                                  bzgl. GitHUB habe ich noch nichts unternommen, weil das ja der Originalposter schon gemacht hatte und ich dachte es läge an der Node Version.
                                    Aber irgendwie kann ich nicht helfen, wenn die Meldungen geheim sind.
                                      Accu last edited by
                                      Was meinst du mit Meldungen geheim?
                                      übrigens beim ioBroker upgrade kam das hier:
                                      Invalid version of "js-controller". Installed "3.2.16", required ">=3.3.22
                                        Thomas Braun Most Active @Accu last edited by Thomas Braun
                                        @accu
                                        Also doch nicht geheim.
                                        Dein js-controller ist zu alt.
                                        iobroker update
                                        iobroker stop
                                        iobroker upgrade self
                                        iobroker upgrade
                                        iobroker start
                                          Accu last edited by
                                          das bringt mich zu meinem ganz alten Problem. Wenn ich den iobroker stoppe und dann upgraden will bekomme ich diesen Fehler:
                                          pi@Raspi:~ $ iobroker stop
                                          pi@Raspi:~ $ iobroker upgrade self
                                          No connection to databases possible ...
                                          pi@Raspi:~ $
                                            @accu
                                            Da ist aber so einiges krumm...
                                            Das kannst du aber in einem eigenen Thread angehen, das hat nur am Rande mit 'Error in GUI' zu tun, denke ich.
                                            iobroker status
                                            4567
