    4. [Problem] Adpater tankerkönig - Arbeitsspeicher läuft voll
      jawr last edited by
      ich habe mich gestern gewundert, warum mein Server so langsam reagiert. Ein Blick in die logs von iobroker brachte dann folgendes:
      2017-03-09 20:57:12.105 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.106 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.107 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.108 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.109 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.110 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.111 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.112 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.113 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.114 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.115 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.116 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.117 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.118 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.119 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed
      2017-03-09 20:57:12.120 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just execute
      >! Ich habe dann mal die Anzahl der Einträge gezählt:
      cat /opt/iobroker/log/iobroker.2017-03-09.log |grep "instance system.adapter.tankerkoenig.0 does not started, because just executed" | wc -l
      1459416
      Der Adapter spielt ein bisschen verrückt.
      Die Zeitplanung für den Adapter ist wie folgt, also Standard:
      Woran kann das liegen?
      Gruß,
      jawr
        jawr last edited by
        Ich push das nochmal nach oben, kann mir nicht vorstellen das ich der Einzige bin mit so einem Problem.
        Gruß,
        jawr
          jawr last edited by
          Guckt hier eigentlich auch mal ein Entwickler in diesen Forenbereich? Irgendeiner muss doch eine Idee dazu haben?!
          Gruß,
          jawr
            Zu deinen letzten beiden Fragen:
            @jawr:
            kann mir nicht vorstellen das ich der Einzige bin mit so einem Problem. `
            Anscheinend schon 😉 ich jedenfalls habe das nicht.
            Sollen jetzt alle anderen 2000 Nutzer das auch bestätigen?
            @jawr:
            Guckt hier eigentlich auch mal ein Entwickler in diesen Forenbereich? `
            Denke ich schon, aber….
            • seit Erstellung des Threads sind gerade mal 5 Tage vergangen.
            • wenn es nicht nachvollziehbar ist, kann es der Entwickler in der kurzen Zeit evtl. noch nicht provozieren.
            Wenn ich aber dein log ansehe schließe ich aus:
            @jawr:
            host.odroid-jessie64 `
            dass du ioBroker auf odroid laufen hast. Welcher?
            Und ggf. ein 64bit Betriebssystem. Welches?
            Ebenfalls wäre eine Angabe der nodejs Version, der npm Version und sonstiger Betriebssystemdaten sehr hilfreich.
            Ich denke, dass es an deiner speziellen Umgebung liegen könnte dass du tatsächlich der Einzige bist.
            Rainer
              pix last edited by
              Hallo jawr,
              schön, dass du den Adapter nutzt. Ich kann den Fehler allerdings nicht nachvollziehen. Mein Adapter spuckt die Meldung nicht aus, sondern der js-controller oder admin.
              Vielleicht machst du dir einmal die Mühe und deinstallierst den Adapter. Dann neu installieren. Voriges Copy&Paste der Tankstellen IDs und deiner API-id aus den Adaptereinstellungen sind obligatorisch. Wenn der Adapter neu installiert und eingestellt, sind die Datenpunkte identisch zu vorher, du brauchst also deine VIS-Views oder Skript nicht zu ändern.
              Pix
                jawr last edited by
                zu den Fragen:
                uname -m
                aarch64
                Also 64 bit, um genauer zu sein ein Odroid C2 mit debian jessie 64 bit auf einem Amlogic ARM Cortex-A53(ARMv8) 1.5Ghz quad core CPU.
                Zur nodejs Version:
                node -v
                v6.9.1
                npm Version
                 npm -v
                3.10.8
                Das werde ich machen und eine Rückmeldung dazu geben.
                Gruß,
                jawr
                  Ich kenne das Betriebssystem so nicht (nativ von debian.org? ggf. als netinstall?)
                  ich hätte es zuerst hiermit versucht.
                  https://www.armbian.com/odroid-c2/
                  und hier ist eine ausführliche Beschreibung von fitti
                  http://forum.iobroker.net/viewtopic.php?f=17&t=3797
                  Aber versuche erstmal pix' Ratschläge. Ich denke nämlich auch, dass das helfen könnte. Augenscheinlich läuft ja die restliche Installation einwandfrei.
                  Rainer
                    jawr last edited by
                    Ich habe den Adapter nun deinstalliert und wieder installiert, scheint nun alles OK zu sein. Ich finde das ja irgendwie immer unbefriedigend wenn man nicht weiß woran es letztendlich gelegen hat. Naja, hauptsache es läuft nun. Logfile sieht nun so aus:
                    2017-03-17 10:35:00.813  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 32571
                    2017-03-17 10:35:02.873  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                    2017-03-17 10:35:02.918  - info: tankerkoenig.0 objects written
                    2017-03-17 10:36:02.927  - info: tankerkoenig.0 force terminating adapter after 1 minute
                    2017-03-17 10:36:03.456  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                    2017-03-17 10:40:00.813  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 32642
                    2017-03-17 10:40:02.879  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                    2017-03-17 10:40:02.929  - info: tankerkoenig.0 objects written
                    2017-03-17 10:41:02.935  - info: tankerkoenig.0 force terminating adapter after 1 minute
                    2017-03-17 10:41:03.466  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                    2017-03-17 10:45:00.813  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 32713
                    2017-03-17 10:45:02.908  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                    2017-03-17 10:45:02.952  - info: tankerkoenig.0 objects written
                    2017-03-17 10:46:02.955  - info: tankerkoenig.0 force terminating adapter after 1 minute
                    2017-03-17 10:46:03.487  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                    2017-03-17 10:50:00.814  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 316
                    2017-03-17 10:50:02.882  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                    2017-03-17 10:50:02.926  - info: tankerkoenig.0 objects written
                    2017-03-17 10:51:02.937  - info: tankerkoenig.0 force terminating adapter after 1 minute
                    2017-03-17 10:51:03.466  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                    2017-03-17 10:55:00.816  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 388
                    2017-03-17 10:55:02.888  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                    2017-03-17 10:55:02.932  - info: tankerkoenig.0 objects written
                    2017-03-17 10:56:02.944  - info: tankerkoenig.0 force terminating adapter after 1 minute
                    2017-03-17 10:56:03.473  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                    2017-03-17 11:00:00.814  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 459
                    2017-03-17 11:00:02.871  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                    2017-03-17 11:00:02.915  - info: tankerkoenig.0 objects written
                    2017-03-17 11:01:02.927  - info: tankerkoenig.0 force terminating adapter after 1 minute
                    2017-03-17 11:01:03.456  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                    2017-03-17 11:05:00.815  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 544
                    2017-03-17 11:05:02.887  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                    2017-03-17 11:05:02.931  - info: tankerkoenig.0 objects written
                    2017-03-17 11:06:02.939  - info: tankerkoenig.0 force terminating adapter after 1 minute
                    2017-03-17 11:06:03.471  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                    2017-03-17 11:10:00.813  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 655
                    2017-03-17 11:10:03.056  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                    2017-03-17 11:10:03.105  - info: tankerkoenig.0 objects written
                    2017-03-17 11:11:03.115  - info: tankerkoenig.0 force terminating adapter after 1 minute
                    2017-03-17 11:11:03.644  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                    2017-03-17 11:15:00.814  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 726
                    2017-03-17 11:15:03.010  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                    2017-03-17 11:15:03.054  - info: tankerkoenig.0 objects written
                    2017-03-17 11:16:03.066  - info: tankerkoenig.0 force terminating adapter after 1 minute
                    2017-03-17 11:16:03.603  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                    2017-03-17 11:20:00.813  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 810
                    2017-03-17 11:20:02.894  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                    Gruß,
                    jawr
                      @jawr:
                      ch finde das ja irgendwie immer unbefriedigend wenn man nicht weiß woran es letztendlich gelegen hat. `
                      Kann ich nachvollziehen.
                      Aber dein log:
                      @jawr:
                      2017-03-09 20:57:12.107 - warn: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 does not started, because just executed `
                      sagt ja, dass es nicht ein Problem des Adapters sondern eine Meldung des Hosts ist.
                      Für mich sieht das danach aus, als ob bereits eine Instanz läuft wenn der cron diese nochmal starten will.
                      Mit der Deinstallation der Instanz (oder wirklich des Adapters????) hast du diesen Prozess natürlich abgeschossen.
                      Rainer
                        jawr last edited by
                        Ich habe im Reiter Instanzen den Löschen Button genutzt, also anscheinend nur die Instanz gelöscht. Ich werde das mal im Auge behalten ob es über die Tage nun stabil läuft.
                        Gruß,
                        jawr
                          jawr last edited by
                          So ich habe nun mal den Adapter neu installiert und bislang keine Probleme, im Log stehen nur noch diese Einträge:
                          2017-03-21 15:06:02.922  - info: tankerkoenig.0 force terminating adapter after 1 minute
                          2017-03-21 15:06:03.451  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                          2017-03-21 15:10:00.723  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 23536
                          2017-03-21 15:10:02.801  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                          2017-03-21 15:10:02.845  - info: tankerkoenig.0 objects written
                          2017-03-21 15:11:02.858  - info: tankerkoenig.0 force terminating adapter after 1 minute
                          2017-03-21 15:11:03.388  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                          2017-03-21 15:15:00.724  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 23640
                          2017-03-21 15:15:02.840  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                          2017-03-21 15:15:02.884  - info: tankerkoenig.0 objects written
                          2017-03-21 15:16:02.894  - info: tankerkoenig.0 force terminating adapter after 1 minute
                          2017-03-21 15:16:03.425  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                          2017-03-21 15:20:00.724  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 23726
                          2017-03-21 15:20:02.823  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                          2017-03-21 15:20:02.867  - info: tankerkoenig.0 objects written
                          2017-03-21 15:21:02.878  - info: tankerkoenig.0 force terminating adapter after 1 minute
                          2017-03-21 15:21:03.408  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                          2017-03-21 15:25:00.725  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 23796
                          2017-03-21 15:25:02.910  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                          2017-03-21 15:25:02.954  - info: tankerkoenig.0 objects written
                          2017-03-21 15:26:02.967  - info: tankerkoenig.0 force terminating adapter after 1 minute
                          2017-03-21 15:26:03.497  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                          2017-03-21 15:30:00.724  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 23871
                          2017-03-21 15:30:02.903  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                          2017-03-21 15:30:02.948  - info: tankerkoenig.0 objects written
                          2017-03-21 15:31:02.960  - info: tankerkoenig.0 force terminating adapter after 1 minute
                          2017-03-21 15:31:03.490  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                          2017-03-21 15:35:00.733  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 started with pid 23947
                          2017-03-21 15:35:02.840  - info: tankerkoenig.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.9.1
                          2017-03-21 15:35:02.884  - info: tankerkoenig.0 objects written
                          2017-03-21 15:36:02.896  - info: tankerkoenig.0 force terminating adapter after 1 minute
                          2017-03-21 15:36:03.427  - info: host.odroid-jessie64 instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                          Für mich sieht das so aus das der Adapter alle 5 Minuten neu gestartet wird? Ist das so richtig?
                          Gruß,
                          jawr
                            pix last edited by
                            Hallo jawr,
                            ja, das ist so richtig. So ist es in den Adaptereinstellungen bzw. Instanzeinstellungen ja festgelegt. Der Adapter startet, holt die Daten von Tankerkönig, schreibt sie in die Datenpunkte und sollte sich dann beenden. Tut er das nicht von selbst, wird er durch einen zusätzlichen Mechanismus beendet (force terminating).
                            Pix
                            Edit: Hab gerade nochmal in den Code geguckt. "Force Terminating" (eigentlich adapter.stop() ) wird in jedem Falle ausgelöst. Ist vielleicht etwas unschön, sollte ich mal verbessern.
                                    setTimeout(function () {
                                        adapter.log.info('force terminating adapter after 1 minute');
                                        adapter.stop();
                                    }, 60000);
                              pix last edited by
                              hab es schnell angepasst. Version 1.0.4 steht nun über npm, also auch in Admin zum Update bereit.
                              Pix
                                jawr last edited by
                                Muss ich irgendwas machen das im Reiter Adapter die neue Version auftaucht bzw wie kann ich über npm auf der Konsole updaten?
                                Gruß,
                                jawr
                                  pix last edited by
                                  Ich glaube, um Mitternacht kommt das Update der Adapterliste. Sonst gibt es den Knopf mit den zwei Pfeilen für Updates.
                                  Pix
                                    jawr last edited by
                                    Guten MOrgen,
                                    hatte vergessen zu sagen das ich das Updatesymbol natürlich schon versucht hatte. Bei mir sieht es immer noch so aus
                                    Gruß,
                                    jawr
                                    1850
