    4. Zigbee iobroker Error while opening serialport
    • Omnedon
      Omnedon @Thomas Braun last edited by
      ich bekomme leider meinen Zigbee Adapter nicht zum Laufen:
      zigbee.0 PID Zeit error Nachricht
      zigbee.0 944	2021-12-20 10:20:46.402	error	Error herdsman start
      zigbee.0 944	2021-12-20 10:20:46.401	error	Failed to start Zigbee
      zigbee.0 944	2021-12-20 10:20:46.401	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0 944	2021-12-20 10:20:36.208	error	Error herdsman start
      zigbee.0 944	2021-12-20 10:20:36.204	error	Failed to start Zigbee
      zigbee.0 944	2021-12-20 10:20:36.202	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      zigbee.0 944	2021-12-20 10:20:36.199	error	Re-commissioning your network will require re-pairing of all devices!
      zigbee.0 944	2021-12-20 10:20:36.197	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
      zigbee.0 944	2021-12-20 10:20:36.196	error	Please update configuration to prevent further issues.
      zigbee.0 944	2021-12-20 10:20:36.195	error	- Channel List: configured=11, adapter=14
      zigbee.0 944	2021-12-20 10:20:36.193	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
      zigbee.0 944	2021-12-20 10:20:36.192	error	- Extended PAN ID: configured=00124b00229819e0, adapter=ddddddddddddddda
      zigbee.0 944	2021-12-20 10:20:36.190	error	- PAN ID: configured=6754, adapter=6755
      zigbee.0 944	2021-12-20 10:20:36.189	error	Configuration is not consistent with adapter state/backup!
      zigbee.0 715	2021-12-20 10:20:17.803	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
      Den Port habe ich über
      ls -l /dev/serial/by-id
      insgesamt 0
      lrwxrwxrwx 1 root root 13 Dez 19 15:25 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
      auf ttyUSB0 eingestellt:
      Vielen Dank für die Hilfe!
      Viele Grüße
        Thomas Braun Most Active @Omnedon last edited by Thomas Braun
        @omnedon sagte in Zigbee iobroker Error while opening serialport:
        Du sollst aber auf
        /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
        umstellen.
        Und die einzelnen Einstellungen sollten übereinstimmen:
        Omnedon Asgothian 2 Replies Last reply Reply Quote 0
        • Omnedon
          danke für die schnelle Antwort!
          Die "configured" Werte kann ich in der Instanz ändern und wo kann ich die "adapter"-Werte anpassen?
          • Asgothian
            Asgothian Developer @Thomas Braun last edited by
            @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
            Du sollst aber auf
            umstellen.
            Ist irrelevant. Der Fehler hat nichts mit dem Port zu tun.
            @Omnedon
            Das von Dir gepostet Log beinhaltet:
            • den Grund warum es nicht läuft:
            • was genau nicht übereinstimmt:
            • Was zu tun ist um den adapter trotzdem zu starten (wenn die Konfigurationsanpassung absichtlich ist)
            • Was passiert wenn Du das tust:
            Du hast also 2 Möglichkeiten:
            • Konfiguration so einstellen wie es im backup steht
            • backup löschen, neu starten, alles neu pairen.
            A.
            • Asgothian
              Asgothian Developer @Omnedon last edited by
              Nirgends. Du kannst entweder das Backup löschen um alles neu aufzubauen oder die Konfigurationswerte anpassen.
              A.
                Thomas Braun Most Active @Asgothian last edited by
                @asgothian sagte in Zigbee iobroker Error while opening serialport:
                Stimmt, ich würde aber trotzdem den 'besseren' link verwenden.
                Omnedon 1 Reply Last reply Reply Quote 0
                • Omnedon
                  @thomas-braun @Asgothian
                  Vielen Dank - es geht. 👍
                  Ich muss mich an die eigene Nase fassen: 👃
                  Wer nicht lesen kann .... 👓
                  Nochmal herzlichen Dank!
                    calli236 last edited by calli236
                    Hallo ich habe ein Problem mit meinem Zigbee Netzwerk und zwar ist im iobroker alles grün in den instancen aber wenn ich ein gerät hinzufügen möchte kommt das
                    ***Error: Failed to open the network: Error: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":96,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,45,2,11,254,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)')
                        at Object.func (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:322:27)
                        at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32). undefined
                    Error: Failed to open the network: Error: Cannot execute command, in Inter-PAN mode
                        at ZStackAdapter.checkInterpanLock (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:1023:19)
                        at Object.func (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:197:18)
                        at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:42)
                        at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:22). undefined
                    Pairing started***
                      Thomas Braun Most Active @calli236 last edited by
                      @calli236 sagte in Zigbee iobroker Error while opening serialport:
                      Hört sich nach Firmware an. Was daran geändert?
                        calli236 @Thomas Braun last edited by
                        @thomas-braun said in Zigbee iobroker Error while opening serialport:
                        Hatte gestern das erstmal das Problem das er nicht mehr ging und habe darauf hin alles geupdatet
                          @calli236
                          Ich vermute, da ist beim flash was schief gelaufen. Kein Verify gemacht oder sowas.
                          C Glasfaser 2 Replies Last reply Reply Quote 0
                            @thomas-braun ich habe so ein tool von Elzershark benutzt dafür
                            • Glasfaser
                              Glasfaser @Thomas Braun last edited by
                              Ja ... bitte nicht aufregen
                              tool von Elzershark
                                Tja, herzlichen Glückwunsch...
                                Die 'superdollen Mega-HaX0r-Tolls' von dem Kollegen kannste dir an den Hut binden. Das ist quasi durch die Bank Murks.
                                C 2 Replies Last reply Reply Quote 1
                                  @thomas-braun na toll
                                    @thomas-braun was sollte ich jetzt am bestem machen
                                      @calli236
                                      Versuchen nochmal drüber zu flashen vielleicht.
                                      Aber dann nicht mit dem windigen Zeug von der Spatzenforelle.
                                        @thomas-braun ok 😄 und wie flashe ich es dann ?
                                          @calli236
                                          Keine Ahnung. Was haste denn da für Hardware?
                                          Den von mir verwendeten Zigbee-Stick flashe ich immer danach über die Kommandozeile:
                                          https://slae.sh/projects/cc2652/#flashing
                                            @thomas-braun ich hab ein cc2531 aber der war schon mit firmeware hab ich bei amazon bestellt und der ging bis gestern tadellos
                                            231
                                            42305
