    4. Influx arbeitet nicht mehr stabil
      Altersrentner @crunchip last edited by
      @crunchip
      pi@raspberrypi:~ $ systemctl status influxdb
      ● influxdb.service - InfluxDB is an open-source, distributed, time series database
         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
         Active: active (running) since Sun 2021-12-26 12:42:21 CET; 1 day 6h ago
           Docs: man:influxd(1)
       Main PID: 31517 (influxd)
          Tasks: 12 (limit: 4915)
         CGroup: /system.slice/influxdb.service
                 └─31517 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
      Dec 26 12:42:29 raspberrypi influxd[31517]: ts=2021-12-26T11:42:29.832169Z lvl=info msg="Reading file" log_id=0YedcTRl000 eng
      Dec 26 12:42:29 raspberrypi influxd[31517]: ts=2021-12-26T11:42:29.848178Z lvl=info msg="Reading file" log_id=0YedcTRl000 eng
      Dec 26 12:42:29 raspberrypi influxd[31517]: ts=2021-12-26T11:42:29.850544Z lvl=info msg="Reading file" log_id=0YedcTRl000 eng
      Dec 26 12:42:29 raspberrypi influxd[31517]: ts=2021-12-26T11:42:29.852423Z lvl=info msg="Reading file" log_id=0YedcTRl000 eng
      Dec 26 12:42:29 raspberrypi influxd[31517]: ts=2021-12-26T11:42:29.964367Z lvl=info msg="Opened shard" log_id=0YedcTRl000 ser
      Dec 26 12:42:31 raspberrypi influxd[31517]: ts=2021-12-26T11:42:31.059900Z lvl=info msg="Reading file" log_id=0YedcTRl000 eng
      Dec 26 12:42:31 raspberrypi influxd[31517]: ts=2021-12-26T11:42:31.881537Z lvl=info msg="Opened shard" log_id=0YedcTRl000 ser
      Dec 26 12:42:32 raspberrypi influxd[31517]: ts=2021-12-26T11:42:32.217254Z lvl=info msg="Opened shard" log_id=0YedcTRl000 ser
      Dec 26 12:42:32 raspberrypi influxd[31517]: ts=2021-12-26T11:42:32.403288Z lvl=info msg="Opened shard" log_id=0YedcTRl000 ser
      Dec 26 12:42:32 raspberrypi influxd[31517]: ts=2021-12-26T11:42:32.895490Z lvl=info msg="Opened shard" log_id=0YedcTRl000 ser
      lines 1-19/19 (END)
        crunchip Forum Testing Most Active @Altersrentner last edited by
        @altersrentner ok, läuft
        und der Port stimmt auch?
        netstat -tulpen
          @crunchip sagte in Influx arbeitet nicht mehr stabil:
          netstat -tulpen
          pi@raspberrypi:~ $ netstat -tulpen
          (Not all processes could be identified, non-owned process info
           will not be shown, you would have to be root to see it all.)
          tcp        0      0 192.168.178.41:2000     0.0.0.0:*               LISTEN      1001       438847355  -
          tcp        0      0 192.168.178.41:2001     0.0.0.0:*               LISTEN      1001       438847342  -
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18629      -
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          440637079  -
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        438413446  -
          tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       444599966  -
          tcp        0      0 192.168.178.41:8701     0.0.0.0:*               LISTEN      1001       438847340  -
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       438846252  -
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       438846245  -
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       438848082  -
          tcp6       0      0 :::8083                 :::*                    LISTEN      1001       438853955  -
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       438852854  -
          tcp6       0      0 :::22                   :::*                    LISTEN      0          18631      -
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          440637078  -
          tcp6       0      0 :::3000                 :::*                    LISTEN      115        21031      -
          tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       444599965  -
          udp        0      0 0.0.0.0:35316           0.0.0.0:*                           108        13988      -
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       438852962  -
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19477      -
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          440634218  -
          udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       438851959  -
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       438849204  -
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13986      -
          udp6       0      0 :::546                  :::*                                0          20423      -
          udp6       0      0 :::58981                :::*                                108        13989      -
          udp6       0      0 :::5353                 :::*                                108        13987      -
          pi@raspberrypi:~ $
            @altersrentner nochmal mit sudo davor
              pi@raspberrypi:~ $ sudo netstat -tulpen
              tcp        0      0 192.168.178.41:2000     0.0.0.0:*               LISTEN      1001       438847355  19873/io.hm-rpc.2
              tcp        0      0 192.168.178.41:2001     0.0.0.0:*               LISTEN      1001       438847342  19839/io.hm-rpc.0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18629      545/sshd
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          440637079  1343/cupsd
              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        438413446  31517/influxd
              tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       444599966  12996/sshd: pi@pts/
              tcp        0      0 192.168.178.41:8701     0.0.0.0:*               LISTEN      1001       438847340  19846/io.hm-rpc.1
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       438846252  19548/iobroker.js-c
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       438846245  19548/iobroker.js-c
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       438848082  19596/io.admin.0
              tcp6       0      0 :::8083                 :::*                    LISTEN      1001       438853955  20892/io.web.0
              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       438852854  20598/io.socketio.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          18631      545/sshd
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          440637078  1343/cupsd
              tcp6       0      0 :::3000                 :::*                    LISTEN      115        21031      512/grafana-server
              tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       444599965  12996/sshd: pi@pts/
              udp        0      0 0.0.0.0:35316           0.0.0.0:*                           108        13988      426/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       438852962  20517/io.shelly.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19477      476/dhcpcd
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          440634218  1344/cups-browsed
              udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       438851959  20510/io.mihome.0
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       438849204  19949/io.mihome-vac
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13986      426/avahi-daemon: r
              udp6       0      0 :::546                  :::*                                0          20423      476/dhcpcd
              udp6       0      0 :::58981                :::*                                108        13989      426/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        13987      426/avahi-daemon: r
              pi@raspberrypi:~ $
                Thomas Braun Most Active @Altersrentner last edited by
                @altersrentner sagte in Influx arbeitet nicht mehr stabil:
                Der lauscht ja auch auf 8088
                  crunchip Forum Testing Most Active @Thomas Braun last edited by
                  @thomas-braun das ist schon richtig, den braucht man doch fürs backup/rdp
                  aber es fehlt udp6
                  udp6       0      0 :::8089                 :::*                                999        35805      140/influxd
                  Thomas Braun A 2 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @crunchip last edited by
                    @crunchip
                    Aber hier wird doch bei Hausnummer 8086 geklingelt?
                    influx 192.168.178.41:8086
                    Aber ich hab influxdb auch nicht im Einsatz... Da bin ich besser mal ruhig. 😄
                      aber es fehlt udp6
                      Und was heißt das jetzt?
                      MfG Michael
                        @thomas-braun braucht man fürs backup , z.b mit dem backitup, dafür muss das aktiv sein(in meinem Fall nicht, da ich das nicht nutze)
                        # Bind address to use for the RPC service for backup and restore.
                        # bind-address = "127.0.0.1:8088"
                          @altersrentner seh mal in der config nach, ein wenig nach unten blättern, bei [http]
                          da müsste folgendes stehen
                           # The bind address used by the HTTP service.
                             bind-address = ":8086"
                          die config rufst du so auf
                          nano /etc/influxdb/influxdb.conf
                            @crunchip Was soll ich damit machen?
                            Backitup ist bei mir nicht aktiviert
                              @altersrentner du sollst in die config sehen, ob es so aussieht wie gezeigt
                                [http]
                                  # Determines whether HTTP endpoint is enabled.
                                  # enabled = true
                                  # bind-address = ":8086"
                                  # Determines whether user authentication is enabled over HTTP/HTTPS.
                                  # auth-enabled = false
                                  # The default realm sent back when issuing a basic auth challenge.
                                  # realm = "InfluxDB"
                                  @altersrentner aus dieser Zeile
                                  #bind-address = ":8086"
                                  machst du
                                    @Altersrentner
                                    Und dann influxdb neustarten.
                                      @Altersrentner
                                      sudo service influxdb restart
                                        machst du
                                        OK habe ich gemacht,
                                        Wie speichern und wie conf verlassen?
                                        Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                          @altersrentner
                                          Strg-X, Rückfrage bestätigen.
                                            @altersrentner sehe gerade, diese muss auch aktiviert werden
                                               enabled = true
                                            also auch die # davor entfernen
                                            influx grafana vis
                                            15293
