      sigi234 Forum Testing Most Active @Zefau last edited by sigi234
      @zefau sagte in jarvis v3.0.0 (beta) - just another remarkable vis:
      @sigi234 sagte in jarvis v3.0.0 - just another remarkable vis:
      Hallo, gibt es schon einen V 3.0.0 Beitrag?
      Dieser hier.
      Bekomme noch immer diese Warn:
      jarvis.0
      2021-12-28 11:13:27.453	warn	alias.0.Geschirrspüler.BSH_Common_Command_PauseProgram is not a valid state
      jarvis.0
      2021-12-28 11:13:27.452	warn	alias.0.Geschirrspüler.BSH_Common_Command_ResumeProgram is not a valid state
      jarvis.0
      2021-12-28 11:13:27.452	warn	alias.0.Geschirrspüler.BSH_Common_Command_StopProgram is not a valid state
      jarvis.0
      2021-12-28 11:13:27.452	warn	http://192.168.178.20:8082/vis.0/yamaha-rx-v481.png is not a valid state
      jarvis.0
      2021-12-28 11:13:27.452	warn	tr-064.0.phonebook.number is not a valid state
      jarvis.0
      2021-12-28 11:13:27.451	warn	tr-064.0.phonebook.name is not a valid state
      jarvis.0
      2021-12-28 11:13:27.451	warn	tr-064.0.phonebook.image is not a valid state
      jarvis.0
      2021-12-28 11:13:27.450	warn	.ACTUAL is not a valid state
      jarvis.0
      jarvis.0
      2021-12-28 11:13:27.449	warn	.ACTUAL is not a valid state
      jarvis.0
      2021-12-28 11:13:27.448	warn	.ACTUAL is not a valid state
      jarvis.0
      jarvis.0
      2021-12-28 11:13:27.447	warn	.ACTUAL is not a valid state
      jarvis.0
      jarvis.0
      2021-12-28 11:13:27.447	warn	hue.0.Philips_hue.Alle.scene_nachtlicht is not a valid state
      jarvis.0
      2021-12-28 11:13:27.447	warn	hue.0.Philips_hue.Alle.scene_gedimmt is not a valid state
      jarvis.0
      2021-12-28 11:13:27.446	warn	hue.0.Philips_hue.Alle.scene_hell is not a valid state
      jarvis.0
      2021-12-28 11:13:27.445	warn	hue.0.Philips_hue.Alle.scene_frühlingsblüten is not a valid state
      jarvis.0
      2021-12-28 11:13:27.444	warn	hue.0.Philips_hue.Alle.scene_nordlichter is not a valid state
      jarvis.0
      2021-12-28 11:13:25.928	warn	hue.0.Philips_hue.Alle.scene_tropendämmerung is not a valid state
      jarvis.0
      2021-12-28 11:13:25.927	warn	hue.0.Philips_hue.Alle.scene_sonnenuntergang_savanne is not a valid state
      jarvis.0
      2021-12-28 11:13:25.927	warn	hue.0.Philips_hue.Alle.scene_energie_tanken is not a valid state
      jarvis.0
      2021-12-28 11:13:25.927	warn	hue.0.Philips_hue.Alle.scene_konzentrieren is not a valid state
      jarvis.0
      2021-12-28 11:13:25.927	warn	hue.0.Philips_hue.Alle.scene_lesen is not a valid state
      jarvis.0
      2021-12-28 11:13:25.927	warn	hue.0.Philips_hue.Alle.scene_entspannen is not a valid state
      jarvis.0
      2021-12-28 11:13:25.718	warn	hue.0.Philips_hue.Büro.scene_nachtlicht is not a valid state
      jarvis.0
      2021-12-28 11:13:25.704	warn	hue.0.Philips_hue.Büro.scene_frühlingsblüten is not a valid state
      jarvis.0
      2021-12-28 11:13:25.695	warn	hue.0.Philips_hue.Büro.scene_nordlichter is not a valid state
      jarvis.0
      2021-12-28 11:13:25.655	warn	hue.0.Philips_hue.Büro.scene_tropendämmerung is not a valid state
      jarvis.0
      2021-12-28 11:13:25.655	warn	hue.0.Philips_hue.Büro.scene_sonnenuntergang_savanne is not a valid state
      jarvis.0
      2021-12-28 11:13:25.655	warn	hue.0.Philips_hue.Büro.scene_energie_tanken is not a valid state
      jarvis.0
      2021-12-28 11:13:25.654	warn	hue.0.Philips_hue.Büro.scene_konzentrieren is not a valid state
      jarvis.0
      2021-12-28 11:13:25.654	warn	hue.0.Philips_hue.Büro.scene_lesen is not a valid state
      jarvis.0
      2021-12-28 11:13:25.654	warn	hue.0.Philips_hue.Büro.scene_entspannen is not a valid state
      jarvis.0
      2021-12-28 11:13:25.654	warn	hue.0.Philips_hue.Küche.scene_scene_storagescene_ is not a valid state
      jarvis.0
      2021-12-28 11:13:25.653	warn	hue.0.Philips_hue.Küche.scene_bewegung is not a valid state
      jarvis.0
      2021-12-28 11:13:25.653	warn	hue.0.Philips_hue.Küche.scene_scene_recoveryscene_ is not a valid state
      jarvis.0
      2021-12-28 11:13:25.653	warn	hue.0.Philips_hue.Küche.scene_nachtlicht is not a valid state
      jarvis.0
      2021-12-28 11:13:25.653	warn	hue.0.Philips_hue.Küche.scene_energie_tanken is not a valid state
      jarvis.0
      2021-12-28 11:13:25.652	warn	hue.0.Philips_hue.Küche.scene_hell is not a valid state
      jarvis.0
      2021-12-28 11:13:25.652	warn	hue.0.Philips_hue.Küche.scene_lesen is not a valid state
      jarvis.0
      2021-12-28 11:13:25.652	warn	hue.0.Philips_hue.Küche.scene_gedimmt_küche is not a valid state
      jarvis.0
      2021-12-28 11:13:25.647	warn	hue.0.Philips_hue.Küche.scene_entspannen is not a valid state
      jarvis.0
      2021-12-28 11:13:25.242	warn	hue.0.Philips_hue.Küche.scene_konzentrieren_küche is not a valid state
      jarvis.0
      2021-12-28 11:13:25.224	warn	hue.0.Philips_hue.Küche.scene_frühlingsblüten is not a valid state
      jarvis.0
      2021-12-28 11:13:25.223	warn	hue.0.Philips_hue.Küche.scene_sonnenuntergang_savanne is not a valid state
      jarvis.0
      2021-12-28 11:13:25.191	warn	hue.0.Philips_hue.Küche.scene_tropendämmerung is not a valid state
      jarvis.0
      2021-12-28 11:13:25.173	warn	hue.0.Philips_hue.Bad_Room.scene_gedimmt_bad is not a valid state
      jarvis.0
      2021-12-28 11:13:25.169	warn	hue.0.Philips_hue.Bad_Room.scene_hell_bad is not a valid state
      jarvis.0
      2021-12-28 11:13:25.162	warn	hue.0.Philips_hue.Bad_Room.scene_nachtlicht_bad is not a valid state
      jarvis.0
      2021-12-28 11:13:25.065	warn	http://192.168.178.20:8082/vis.0/VU_analog.gif is not a valid state
      Edit:
      Erledigt
      • Zefau
        Zefau @RkcCorian last edited by
        @rkccorian sagte in jarvis v3.0.0 - just another remarkable vis:
        etzt wird es richtig angezeigt, allerdings... jegliche Änderung an Adapter-Instanznamen auf der Admin-Übersicht hat keine Auswirkung auf die von JARVIS genutzte Information.
        Kannst du konkretisieren, was du meinst? Wenn du die Informationen änderst, musst du jarvis neu laden.
        Nun ist mir nicht klar, wo der Fehler genau liegt, es ist aber Irreführend, wenn der Name der Admin-Ansicht nicht zu JARVIS passt. Wäre es nicht besser die Info von dort zu holen, wo sie auch der Admin-Adapter herholt?!
        Inwiefern unterscheidet sich dieser und was verwendet denn der Admin-Adapter?
        • Zefau
          Zefau @sigi234 last edited by
          @sigi234 sind keine validen Datenpunkte, also der Wert ist null. Ggf. sind das nur Trigger, die du aber bei der Datenpunkt-Anzeige drin hast?
          sigi234 S 2 Replies Last reply Reply Quote 0
          • Zefau
            Zefau @Penny2912 last edited by
            @penny2912 sagte in jarvis v3.0.0 - just another remarkable vis:
            Ich würde jetzt nochmal zurück auf die 2.2.5 gehen mit einem iobroker restore weil ich mir unsicher bin ob meine Daten noch da sind .
            Deine Daten sind scheinbar kaputt. v3 versucht immer wieder zu konvertieren und scheint in einem Loop zu laufen.
            Was steht denn nach der v3 Installation und dem initialen Aufruf von v3 in den Datenpunkten jarvis.0.devices, jarvis.0.layout bzw. jarvis.0.widgets bei dir drin?
            P 2 Replies Last reply Reply Quote 0
              @zefau sagte in jarvis v3.0.0 - just another remarkable vis:
              Beispiel DP:
                "_id": "hue.0.Philips_hue.Alle.scene_nachtlicht",
                "type": "state",
                "common": {
                  "type": "boolean",
                  "name": "Scene Nachtlicht",
                  "role": "button"
                "native": {
                  "id": "VCwp7y9FqRQfcNJ",
                  "group": "7"
                "from": "system.adapter.hue.0",
                "user": "system.user.admin",
                "ts": 1628695253837,
                "acl": {
                  "object": 1636,
                  "state": 1636,
                  "owner": "system.user.admin",
              • Zefau
                Zefau @sigi234 last edited by Zefau
                Beispiel DP:
                Ich mein den Datenpunkt in jarvis im Gerät bzw. den Datenpunkt in ioBroker - nicht das Objekt.
                  Beispiel DP:
                  Ok, im Objekt steh (null) drinnen, ev. darum?
                    M0nk3y @MCU last edited by M0nk3y
                    @mcu sagte in jarvis v3.0.0 - just another remarkable vis:
                    @andré-müller
                    https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/notifications/reolink-motioneye
                    Falls noch andere Infos für andere mit rein sollen, dann evtl jetzt mitteilen. Danke.
                    Vielleicht sollten wir da "Reolink" als Kamerahersteller rausnehmen.
                    Bei der Lösung von motionEye wird die Kamera (beliebige Hersteller) eingebunden. motionEye nimmt dann bspw. bei Bewegung auf ein NAS auf und hat auch die Mötlichkeit per Webstream das Videobild im LAN zu verteilen - letzteres ist hier im Einsatz.
                    • Zefau
                      Ja, sag ich ja. null ist kein valider Datenpunkt für die Anzeige und i.d.R. nur ein Trigger. Nimm es aus der Datenpunkt-Anzeige raus.
                        Einfach löschen?
                        • Zefau
                          Einfach löschen?
                          Jo, einfach raus nehmen. Sollte mit dem Importer auch nicht mehr passieren, dass das rein rutscht. Das Gerät hast du wahrscheinlich nicht selbst erstellt?
                            Nein , war einfach da als Import.
                              M0nk3y last edited by
                              Ich benötige mal bitte ein Tipp für die Müllvisualisierung. Ich habe in der 2.2er Version ein Screenshot einer solchen Darstellung gesehen:
                              Womit mag das realisiert worden sein? Ist das Bild bei jedem Gerät zugeordnet? Wie/Wo wird das Bild hinterlegt?
                                Algie @M0nk3y last edited by
                                @m0nk3y Hallo, dass wurde mit dem Adapter "Trashschedule" und VIS gemacht und per iFrame in Jarvis eingebunden.
                                  @algie Danke!
                                    Penny2912 @Zefau last edited by
                                    @zefau Also ich bin ja per Backup zurück auf die 2.2.5 und habe dort dann die 3.0.0 drüber installiert. Beim ersten Aufruf von Jarvis v3 ist er in eine Art Loop gekommen und hat die VIS immer wieder neu geladen. Das ist solange passiert bis ich den Tab geschlossen habe. Anschließend habe ich die VIS wieder aufgerufen und dann kam die Einsteiger Tour. Die habe ich mit "Skip" übersprungen und dann war wieder das alte Bild zu sehen: Nur die leeren Container in ihrer richtigen Spalte, aber keine Widgets und keine Daten darin enthalten.
                                    Die Datenpunkte sehen so aus: Datenpunkte.png
                                    Oder brauchst Du den gesamten Inhalt?
                                    Danke schon mal!
                                      MCU @M0nk3y last edited by
                                      @m0nk3y Kann momentan keine Änderungen eingeben. Hardware Defekt. Mach ich dann in ein paar Tagen.
                                        @mcu Alles gut - na dann viel Erfolg bei der Reparatur!
                                          HansWurst 0 @HansWurst 0 last edited by HansWurst 0
                                          @hanswurst-0 sagte in jarvis v3.0.0 - just another remarkable vis:
                                          @zefau genau das habe ich gemacht. Nach der Neuinstallation von v2 wird mir aber angezeigt, dass ich v3 installiert hätte. Daher muss ich denke ich die v3-Dateien manuell entfernen, oder?
                                          @zefau Ok das mit dem Deinstallieren hat nun geklappt, das war mein Fehler. Aber nach Neuinstallation von v2 und dann manuell v3 (beide Installationen ohne Fehler) bekomme ich den gleichen Fehler wie vorher. Die Instanz des Adapters läuft, aber ohne Verbindung zum Host:
                                          Wenn ich versuche Jarvis zu öffnen, bekomme ich den auch schon von anderen Usern bekannten Timeout:
                                          Eine Idee, woran das liegen könnte?
                                          • Zefau
                                            Zefau @HansWurst 0 last edited by
                                            @hanswurst-0 Fehler im ioBroker Log? Die Instanz startet ja schon nicht.
                                            254
                                            4489
                                            2657590
