    4. Test Adapter MyVBus v0.6.x Latest
      Thomas Braun Most Active @ChrisChros last edited by
      @chrischros
      iobroker list adapters
      iobroker list instances
        ChrisChros @Thomas Braun last edited by
        @thomas-braun said in Test Adapter MyVBus v0.2.x Latest:
        pi@raspberrypi:/opt/iobroker $ iobroker list adapters
        system.adapter.admin                   : admin          - v5.2.3
        system.adapter.backitup                : backitup       - v2.2.1
        system.adapter.discovery               : discovery      - v2.7.5
        system.adapter.history                 : history        - v1.10.5
        system.adapter.icons-material-png      : icons-material-png - v0.1.0
        system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
        system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
        system.adapter.influxdb                : influxdb       - v2.4.0
        system.adapter.info                    : info           - v1.9.16
        system.adapter.javascript              : javascript     - v5.2.18
        system.adapter.modbus                  : modbus         - v3.4.17
        system.adapter.openknx                 : openknx        - v0.1.10
        system.adapter.socketio                : socketio       - v3.1.5
        system.adapter.vis                     : vis            - v1.4.6
        system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.9
        system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.2
        system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
        system.adapter.vis-metro               : vis-metro      - v1.1.2
        system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
        system.adapter.web                     : web            - v3.4.16
        pi@raspberrypi:/opt/iobroker $ iobroker list instances
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
        + system.adapter.openknx.0                : openknx               : raspberrypi                              -  enabled, bind: 10.10.20.18
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
          Thomas Braun Most Active @ChrisChros last edited by Thomas Braun
          @chrischros sagte in Test Adapter MyVBus v0.2.x Latest:
          /opt/iobroker
          Bist du auch vor bwz. bei der Installation in /opt/iobroker gewesen?
          Mit welchen Meldungen ist die Installation dann erfolgt?
          C 1 Reply Last reply Reply Quote 1
            pi@raspberrypi:/opt/iobroker $ npm install iobroker.resol
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            + iobroker.resol@0.4.0
            removed 4 packages and updated 1 package in 12.659s
            34 packages are looking for funding
              run `npm fund` for details
              Mach mal ein
              iobroker stop
              iobroker upload all
              iobroker start
                @thomas-braun ok ist jetzt soweit durchgelaufen. In den Instanzen wird aber noch immer kein neuer Adapter für Resol oder vbus angezeigt.
                  @chrischros
                  In der Liste der Adapter aber vermutlich schon. Dann eine Instanz händisch hinzufügen.
                    @thomas-braun leider auch nicht. in der Adapterliste finde ich nur den myvbus adapter aber nicht den resol.
                      @chrischros
                      Bei mir tauchte der nach dem upload auf.
                        @thomas-braun ok sehr merkwürdig. habe auch das "Beta (latest)" Repository geladen.
                          @chrischros
                          Das nutzt dir nix, da ist der nämlich nicht drin.
                            @thomas-braun ok und wo kann ich den dann finde?
                              @chrischros
                              Indem du den per npm wie oben installierst. Warum das bei dir nicht funktioniert weiß ich aber auch nicht. Bei mir geht's (tm).
                                ok, danke für deine Hilfe.
                                deinstallieren kann ich den Adapter mit folgendem Befehl oder?
                                sudo rm -r /opt/iobroker/node_modules/iobroker.resol
                                  so habe jetzt den Adapter myvbus ohne Probleme installiert und eingerichtet.
                                    Nein, der muss auch aus den json-Dateien raus.
                                    Stumpf löschen ist zu wenig.
                                    iobroker del resol
                                    liefert?
                                      iobroker del resol
                                      pi@raspberrypi:/opt/iobroker $ iobroker del resol
                                      Delete adapter "resol"
                                      host.raspberrypi object resol deleted
                                      host.raspberrypi object resol.admin deleted
                                      npm uninstall iobroker.resol --loglevel error --prefix "/opt/iobroker" (System call)
                                        @chrischros
                                        Jetzt müsste das eigentlich ausgetragen sein.
                                        iobroker list adapters | grep resol
                                        cd /opt/iobroker
                                        npm list | grep resol
                                          ChrisChros @Thomas Braun last edited by ChrisChros
                                          pi@raspberrypi:~ $ iobroker list adapters | grep resol
                                          pi@raspberrypi:~ $ cd /opt/iobroker
                                          pi@raspberrypi:/opt/iobroker $ npm list | grep resol
                                          │ └─┬ resol-vbus@0.23.0
                                            @chrischros
                                            Ja, sollte jetzt passen.
                                            resol vbus
                                            27
                                            381
                                            86284
