    4. Test Adapter MyVBus v0.6.x Latest
      ChrisChros @Thomas Braun last edited by
      @thomas-braun said in Test Adapter MyVBus v0.2.x Latest:
      iobroker list instances
      pi@raspberrypi:/opt/iobroker $ iobroker list adapters
      system.adapter.admin                   : admin          - v5.2.3
      system.adapter.backitup                : backitup       - v2.2.1
      system.adapter.discovery               : discovery      - v2.7.5
      system.adapter.history                 : history        - v1.10.5
      system.adapter.icons-material-png      : icons-material-png - v0.1.0
      system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
      system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
      system.adapter.influxdb                : influxdb       - v2.4.0
      system.adapter.info                    : info           - v1.9.16
      system.adapter.javascript              : javascript     - v5.2.18
      system.adapter.modbus                  : modbus         - v3.4.17
      system.adapter.openknx                 : openknx        - v0.1.10
      system.adapter.socketio                : socketio       - v3.1.5
      system.adapter.vis                     : vis            - v1.4.6
      system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.9
      system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.2
      system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
      system.adapter.vis-metro               : vis-metro      - v1.1.2
      system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
      system.adapter.web                     : web            - v3.4.16
      pi@raspberrypi:/opt/iobroker $ iobroker list instances
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.openknx.0                : openknx               : raspberrypi                              -  enabled, bind: 10.10.20.18
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
        Thomas Braun Most Active @ChrisChros last edited by Thomas Braun
        @chrischros sagte in Test Adapter MyVBus v0.2.x Latest:
        /opt/iobroker
        Bist du auch vor bwz. bei der Installation in /opt/iobroker gewesen?
        Mit welchen Meldungen ist die Installation dann erfolgt?
        C 1 Reply Last reply Reply Quote 1
          pi@raspberrypi:/opt/iobroker $ npm install iobroker.resol
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          + iobroker.resol@0.4.0
          removed 4 packages and updated 1 package in 12.659s
          34 packages are looking for funding
            run `npm fund` for details
            Mach mal ein
            iobroker stop
            iobroker upload all
            iobroker start
              @thomas-braun ok ist jetzt soweit durchgelaufen. In den Instanzen wird aber noch immer kein neuer Adapter für Resol oder vbus angezeigt.
                @chrischros
                In der Liste der Adapter aber vermutlich schon. Dann eine Instanz händisch hinzufügen.
                  @thomas-braun leider auch nicht. in der Adapterliste finde ich nur den myvbus adapter aber nicht den resol.
                    @chrischros
                    Bei mir tauchte der nach dem upload auf.
                      @thomas-braun ok sehr merkwürdig. habe auch das "Beta (latest)" Repository geladen.
                        @chrischros
                        Das nutzt dir nix, da ist der nämlich nicht drin.
                          @thomas-braun ok und wo kann ich den dann finde?
                            @chrischros
                            Indem du den per npm wie oben installierst. Warum das bei dir nicht funktioniert weiß ich aber auch nicht. Bei mir geht's (tm).
                              ok, danke für deine Hilfe.
                              deinstallieren kann ich den Adapter mit folgendem Befehl oder?
                              sudo rm -r /opt/iobroker/node_modules/iobroker.resol
                                so habe jetzt den Adapter myvbus ohne Probleme installiert und eingerichtet.
                                  Nein, der muss auch aus den json-Dateien raus.
                                  Stumpf löschen ist zu wenig.
                                  iobroker del resol
                                  liefert?
                                    iobroker del resol
                                    pi@raspberrypi:/opt/iobroker $ iobroker del resol
                                    Delete adapter "resol"
                                    host.raspberrypi object resol deleted
                                    host.raspberrypi object resol.admin deleted
                                    npm uninstall iobroker.resol --loglevel error --prefix "/opt/iobroker" (System call)
                                      @chrischros
                                      Jetzt müsste das eigentlich ausgetragen sein.
                                      iobroker list adapters | grep resol
                                      cd /opt/iobroker
                                      npm list | grep resol
                                        ChrisChros @Thomas Braun last edited by ChrisChros
                                        pi@raspberrypi:~ $ iobroker list adapters | grep resol
                                        pi@raspberrypi:~ $ cd /opt/iobroker
                                        pi@raspberrypi:/opt/iobroker $ npm list | grep resol
                                        │ └─┬ resol-vbus@0.23.0
                                          @chrischros
                                          Ja, sollte jetzt passen.
                                            @thomas-braun ok dank dir für die Hilfe. Werde jetzt erst mal bei dem myvbus Adapter bleiben.
                                            resol vbus
                                            27
                                            381
                                            86339
