    4. Test Adapter OpenKNX 0.6.x
      tombox @tdoc last edited by
      @tdoc
      kannst du mir mal die XML schicken. Vielleicht können wir das problem beheben
      tombox2020@gmail.com
      T M 2 Replies Last reply Reply Quote 0
        wizard2010 last edited by
        I'm getting this error when importing:
        Ignoring Corredor.Aquecimento.PRE_COR_SWITCH_COUNTER because no DPT is assigned to 1339. The GA is not connected to a KO in ETS
        Ignoring Corredor.Aquecimento.PRE_COR_SWITCH_COUNTER_REACHED because no DPT is assigned to 1340. The GA is not connected to a KO in ETS
        Ignoring Corredor.Aquecimento.PRE_COR_SET_POINT_LOWER_HYSTERESIS because no DPT is assigned to 1342. The GA is not connected to a KO in ETS
        Ignoring Corredor.Aquecimento.PRE_COR_SET_POINT_UPPER_HYSTERESIS because no DPT is assigned to 1343. The GA is not connected to a KO in ETS
        Ignoring Corredor.Aquecimento.PRE_COR_OVERHEAT_TEMP because no DPT is assigned to 1344. The GA is not connected to a KO in ETS
        Ignoring Corredor.Aquecimento.PRE_COR_AVG_TEMP because no DPT is assigned to 1345. The GA is not connected to a KO in ETS
        Ignoring Cozinha.Luzes.IN_COZ_LUZES_FAIL_STATUS because no DPT is assigned to 2054. The GA is not connected to a KO in ETS
        Ignoring Cozinha.Aquecimento.PRE_COZ_ON_OFF because no DPT is assigned to 2361. The GA is not connected to a KO in ETS
        Ignoring Cozinha.Aquecimento.PRE_COZ_ON_OFF_STATUS because no DPT is assigned to 2364. The GA is not connected to a KO in ETS
        Ignoring Cozinha.Aquecimento.PRE_COZ_SWITCH_COUNTER because no DPT is assigned to 2365. The GA is not connected to a KO in ETS
        Ignoring Cozinha.Aquecimento.PRE_COZ_SWITCH_COUNTER_REACHED because no DPT is assigned to 2366. The GA is not connected to a KO in ETS
        Ignoring Cozinha.Aquecimento.PRE_COZ_RIGHT_TEMP because no DPT is assigned to 2367. The GA is not connected to a KO in ETS
        Any idea what is wrong here?
        Thanks
          tombox @wizard2010 last edited by
          @wizard2010 This is not an error only a information that this GA is not used in ETS
            wizard2010 @tombox last edited by
            @tombox Thanks your are right 😉
            I'm also getting this warning...
            There is any way to see which datapoints? I'm using free datapoints instead of x/x/x.
              @wizard2010 The adapter receive information on the bus for this address but it is not in the xml file. The Adapter cannot say the name of the datapoint
                @tombox Maybe this datapoints are the ones that were not imported from the xml file due to that ignore error.
                Do you know if it's possible to convert this "3/6/254" in openKNX in order to allow me to check if the number matches with the ones in XML file?
                  ChrisChros last edited by
                  ich bekomme folgende Fehlemeldung bei mir im Log angezeigt:
                  2021-12-29 12:07:47.280 - error: openknx.0 (10336) [error] "2021-12-29T11:07:47.279Z" 'DPT14: Must supply a number value'
                  Leider kann ich die Meldung keiner speziellen GA zuordnen da ich mehrere mit DPT14 habe. Besteht die Möglichkeit das weiter einzugrenzen?
                  T K 2 Replies Last reply Reply Quote 0
                    tombox @ChrisChros last edited by tombox
                    @chrischros Du könntest den Adapter in Log Level Debug setzen. Einfach in Instanzen im Experten modus von info auf debug setzen. Ruhig dann auch hier posten vielleicht können wir die log information verbessern
                    C 2 Replies Last reply Reply Quote 0
                      ChrisChros @tombox last edited by
                      @tombox
                      Danke für den Tipp, werde ich nachher oder heute Abend mal testen.
                      noch eine weitere Meldung die mir aufgefallen ist:
                      State value to set for "openknx.0.Dimmen.Dimmen.Außen_-_Terrasse_-_Spots_-_Dimmen" has to be stringified but received type "object"
                      Die GA ist als DPT 3.007 Dimmer schritte in der ETS parametriert und in ioBroker sieht das Objekt wie folgt aus:
                        "_id": "openknx.0.Dimmen.Dimmen.Außen_-_Terrasse_-_Spots_-_Dimmen",
                        "type": "state",
                        "common": {
                          "desc": "Basetype: 4-bit relative dimming control",
                          "name": "Außen - Terrasse - Spots - Dimmen",
                          "read": true,
                          "role": "state",
                          "type": "object",
                          "write": true
                        "native": {
                          "address": "2/3/13",
                          "answer_groupValueResponse": false,
                          "autoread": true,
                          "bitlength": 4,
                          "dpt": "DPT3.007",
                          "valuetype": "composite"
                        "from": "system.adapter.openknx.0",
                        "user": "system.user.admin",
                        "ts": 1640778698317,
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                          "owner": "system.user.admin",
                      aktuell kann ich da keinen wirklichen fehler entdecken, so sind bei mir alle GAs parametriert die mit Dimmen zu tun haben.
                      Hat jemand ne Idee?
                        @tombox
                        Hier mal der Auszug aus dem Log von der Sekunde in der die Fehlermeldung kam:
                        2021-12-29 13:50:35.027  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.026 Inbound message: 0610042000150453ab002900bce011fe2450010080
                        2021-12-29 13:50:35.028  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.028 (idle):	 zzzz...
                        2021-12-29 13:50:35.029  - debug: openknx.0 (11241) Inbound GroupValue_Write 4/4/80 val: false  dpt: DPT1 to Object: openknx.0.Heizung.Hargassner_Nano_PK.Heizung_Zündung
                        2021-12-29 13:50:35.114  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.113 Inbound message: 0610042000150453ac002900bce011fe2451010080
                        2021-12-29 13:50:35.115  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.115 (idle):	 zzzz...
                        2021-12-29 13:50:35.116  - debug: openknx.0 (11241) Inbound GroupValue_Write 4/4/81 val: false  dpt: DPT1 to Object: openknx.0.Heizung.Hargassner_Nano_PK.Gebläse_Zündung
                        2021-12-29 13:50:35.219  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.218 Inbound message: 0610042000150453ad002900bce011fe2452010080
                        2021-12-29 13:50:35.220  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.219 (idle):	 zzzz...
                        2021-12-29 13:50:35.220  - debug: openknx.0 (11241) Inbound GroupValue_Write 4/4/82 val: false  dpt: DPT1 to Object: openknx.0.Heizung.Hargassner_Nano_PK.Aschenaustragung_aktiv
                        2021-12-29 13:50:35.356  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.356 Inbound message: 0610042000150453ae002900bce011fe2453010080
                        2021-12-29 13:50:35.358  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.357 (idle):	 zzzz...
                        2021-12-29 13:50:35.358  - debug: openknx.0 (11241) Inbound GroupValue_Write 4/4/83 val: false  dpt: DPT1 to Object: openknx.0.Heizung.Hargassner_Nano_PK.Richtung_Aschenaustragung
                        2021-12-29 13:50:35.429  - debug: openknx.0 (11241) Outbound GroupValue_Write to 4/6/0 value 471 from openknx.0.Heizung.Photovoltaik.Photovoltaik-Leistung
                        2021-12-29 13:50:35.431  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.431 (sendDatagram):	>>>>>>> successfully sent seqnum: 1349
                        2021-12-29 13:50:35.431  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.431 Inbound message: 06100421000a04534500
                        2021-12-29 13:50:35.432  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.432 ===== datagram 69 acknowledged by IP router
                        2021-12-29 13:50:35.432  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.432 (idle):	 zzzz...
                        2021-12-29 13:50:35.433  - debug: openknx.0 (11241) Outbound GroupValue_Write to 4/6/1 value 0 from openknx.0.Heizung.Photovoltaik.Batterie-Leistung
                        2021-12-29 13:50:35.434  - error: openknx.0 (11241) [error] "2021-12-29T12:50:35.434Z"  'DPT14: Must supply a number value'
                        2021-12-29 13:50:35.435  - debug: openknx.0 (11241) Outbound GroupValue_Write to 4/6/2 value 464 from openknx.0.Heizung.Photovoltaik.Hausverbrauchs-Leistung
                        2021-12-29 13:50:35.436  - debug: openknx.0 (11241) Outbound GroupValue_Write to 4/6/3 value -7 from openknx.0.Heizung.Photovoltaik.Leistung_am_Netzübergabepunkt
                        2021-12-29 13:50:35.437  - debug: openknx.0 (11241) Outbound GroupValue_Write to 4/6/18 value 402 from openknx.0.Heizung.Photovoltaik.DC-Spannung_an_String_1
                        2021-12-29 13:50:35.438  - debug: openknx.0 (11241) Outbound GroupValue_Write to 4/6/19 value 410 from openknx.0.Heizung.Photovoltaik.DC-Spannung_an_String_2
                        2021-12-29 13:50:35.439  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.439 Inbound message: 0610042000150453af002900bce011fe2454010080
                        2021-12-29 13:50:35.440  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.440 (idle):	 zzzz...
                        2021-12-29 13:50:35.440  - debug: openknx.0 (11241) Inbound GroupValue_Write 4/4/84 val: false  dpt: DPT1 to Object: openknx.0.Heizung.Hargassner_Nano_PK.Einschubschnecke_aktiv
                        2021-12-29 13:50:35.466  - debug: openknx.0 (11241) Outbound GroupValue_Write to 4/6/22 value 237 from openknx.0.Heizung.Photovoltaik.DC-Leistung_an_String_1
                        2021-12-29 13:50:35.468  - debug: openknx.0 (11241) Outbound GroupValue_Write to 4/6/23 value 234 from openknx.0.Heizung.Photovoltaik.DC-Leistung_an_String_2
                        2021-12-29 13:50:35.480  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.480 (sendDatagram):	>>>>>>> successfully sent seqnum: 1350
                        2021-12-29 13:50:35.482  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.482 Inbound message: 06100421000a04534600
                        2021-12-29 13:50:35.482  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.482 ===== datagram 70 acknowledged by IP router
                        2021-12-29 13:50:35.483  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.483 (idle):	 zzzz...
                        2021-12-29 13:50:35.530  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.530 Inbound message: 0610042000150453b0002900bce011fe2455010080
                        2021-12-29 13:50:35.531  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.531 (idle):	 zzzz...
                        2021-12-29 13:50:35.531  - debug: openknx.0 (11241) Inbound GroupValue_Write 4/4/85 val: false  dpt: DPT1 to Object: openknx.0.Heizung.Hargassner_Nano_PK.Richtung_Einschubschnecke
                        2021-12-29 13:50:35.533  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.533 (sendDatagram):	>>>>>>> successfully sent seqnum: 1351
                        2021-12-29 13:50:35.534  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.534 Inbound message: 06100421000a04534700
                        2021-12-29 13:50:35.535  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.535 ===== datagram 71 acknowledged by IP router
                        2021-12-29 13:50:35.535  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.535 (idle):	 zzzz...
                        2021-12-29 13:50:35.583  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.583 (sendDatagram):	>>>>>>> successfully sent seqnum: 1352
                        2021-12-29 13:50:35.584  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.584 Inbound message: 06100421000a04534800
                        2021-12-29 13:50:35.585  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.585 ===== datagram 72 acknowledged by IP router
                        2021-12-29 13:50:35.585  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.585 (idle):	 zzzz...
                        2021-12-29 13:50:35.599  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.599 Inbound message: 0610042000150453b1002900bce011fe2456010080
                        2021-12-29 13:50:35.600  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.600 (idle):	 zzzz...
                        2021-12-29 13:50:35.600  - debug: openknx.0 (11241) Inbound GroupValue_Write 4/4/86 val: false  dpt: DPT1 to Object: openknx.0.Heizung.Hargassner_Nano_PK.Raumaustragung_Sauger_aktiv
                        2021-12-29 13:50:35.634  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.634 (sendDatagram):	>>>>>>> successfully sent seqnum: 1353
                        2021-12-29 13:50:35.635  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.635 Inbound message: 06100421000a04534900
                        2021-12-29 13:50:35.635  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.635 ===== datagram 73 acknowledged by IP router
                        2021-12-29 13:50:35.636  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.636 (idle):	 zzzz...
                        2021-12-29 13:50:35.685  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.685 (sendDatagram):	>>>>>>> successfully sent seqnum: 1354
                        2021-12-29 13:50:35.686  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.686 Inbound message: 06100421000a04534a00
                        2021-12-29 13:50:35.687  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.686 ===== datagram 74 acknowledged by IP router
                        2021-12-29 13:50:35.687  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.687 (idle):	 zzzz...
                        2021-12-29 13:50:35.698  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.698 Inbound message: 0610042000150453b2002900bce011fe2457010080
                        2021-12-29 13:50:35.699  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.699 (idle):	 zzzz...
                        2021-12-29 13:50:35.699  - debug: openknx.0 (11241) Inbound GroupValue_Write 4/4/87 val: false  dpt: DPT1 to Object: openknx.0.Heizung.Hargassner_Nano_PK.Raumaustragung_aktiv
                        2021-12-29 13:50:35.736  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.736 (sendDatagram):	>>>>>>> successfully sent seqnum: 1355
                        2021-12-29 13:50:35.737  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.737 Inbound message: 06100421000a04534b00
                        2021-12-29 13:50:35.737  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.737 ===== datagram 75 acknowledged by IP router
                        2021-12-29 13:50:35.737  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.737 (idle):	 zzzz...
                        2021-12-29 13:50:35.785  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.785 Inbound message: 0610042000150453b3002900bce011fe2458010080
                        2021-12-29 13:50:35.786  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.786 (idle):	 zzzz...
                        2021-12-29 13:50:35.786  - debug: openknx.0 (11241) Inbound GroupValue_Write 4/4/88 val: false  dpt: DPT1 to Object: openknx.0.Heizung.Hargassner_Nano_PK.Richtung_Raumaustragung
                        2021-12-29 13:50:35.788  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.788 (sendDatagram):	>>>>>>> successfully sent seqnum: 1356
                        2021-12-29 13:50:35.789  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.788 Inbound message: 06100421000a04534c00
                        2021-12-29 13:50:35.789  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.789 ===== datagram 76 acknowledged by IP router
                        2021-12-29 13:50:35.790  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.790 (idle):	 zzzz...
                        2021-12-29 13:50:35.848  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.848 Inbound message: 0610042000150453b4002900bce011fe245a010080
                        2021-12-29 13:50:35.849  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.849 (idle):	 zzzz...
                        2021-12-29 13:50:35.850  - debug: openknx.0 (11241) Inbound GroupValue_Write 4/4/90 val: false  dpt: DPT1 to Object: openknx.0.Heizung.Hargassner_Nano_PK.Reinigung_aktiv
                        2021-12-29 13:50:35.947  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.947 Inbound message: 0610042000150453b5002900bce011fe245b010080
                        2021-12-29 13:50:35.949  - debug: openknx.0 (11241) [debug] 2021-12-29 12:50:35.949 (idle):	 zzzz...
                        2021-12-29 13:50:35.949  - debug: openknx.0 (11241) Inbound GroupValue_Write 4/4/91 val: false  dpt: DPT1 to Object: openknx.0.Heizung.Hargassner_Nano_PK.Mischer_Rücklauf_Auf
                        Die Fehlermeldung lautet "DPT14: Must supply a number value" und wurde um 13:50:35.434 Uhr aufgezeichnet. Die Meldung vor der Fehler lautete wie folgt:
                        Das Objekt Batterie-Leistung wird per Modbus ausgelesen und per blockly auf den Bus gesendet.
                        Die Objektdaten von dem Modbus-Objekt lauten wie folgt:
                          "_id": "modbus.0.holdingRegisters.40070_Batterie_Leistung",
                          "type": "state",
                          "common": {
                            "name": "Batterie-Leistung in Watt",
                            "role": "value",
                            "type": "number",
                            "read": true,
                            "write": true,
                            "def": 0,
                            "unit": "W",
                            "custom": {
                              "mqtt-client.0": {
                                "enabled": true,
                                "publish": true,
                                "pubChangesOnly": false,
                                "pubAsObject": false,
                                "qos": false,
                                "retain": false,
                                "subscribe": false,
                                "subChangesOnly": false,
                                "subAsObject": false,
                                "subQos": false,
                                "setAck": false
                              "influxdb.0": {
                                "enabled": true,
                                "storageType": "",
                                "aliasId": "",
                                "changesOnly": true,
                                "debounce": 1000,
                                "changesRelogInterval": 60,
                                "changesMinDelta": 0
                          "native": {
                            "regType": "holdingRegs",
                            "address": 69,
                            "deviceId": 1,
                            "type": "int32sw",
                            "len": 2,
                            "offset": 0,
                            "factor": 1,
                            "poll": true
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                            "file": 1636,
                          "from": "system.adapter.modbus.0",
                          "ts": 1640759338188
                        Die Objekt-Daten von dem KNX-Objekt sehen wie folgt aus:
                          "_id": "openknx.0.Heizung.Photovoltaik.Batterie-Leistung",
                          "type": "state",
                          "common": {
                            "desc": "Basetype: 32-bit floating point value",
                            "name": "Batterie-Leistung",
                            "read": true,
                            "role": "state",
                            "type": "number",
                            "unit": "W",
                            "write": true
                          "native": {
                            "address": "4/6/1",
                            "autoread": true,
                            "bitlength": 32,
                            "dpt": "DPT14.056",
                            "valuetype": "basic"
                          "ts": 1640778701203,
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                        Wie sollte ich eurer Meinung nach der DPT für KNX Objekt aussehen?
                          tdoc @tombox last edited by
                          @tombox
                          Hat sich erledigt. Es kann nichts importiert werden, weil keine DPT definiert sind. Hab für dieses Problem ja eine Lösung gefunden (verwende die bisher erzeugten Objekte weiter). Ansonsten hätte ich mir halt die Arbeit machen müssen und extra für den Import die DPTs definieren müssen. Mach ich vielleicht auch mal. Wie gesagt, das war die Arbeit einer zertifizierten Elektrikerfirma, vor 22 Jahren.
                          Hier gab es mit dem anderen Adapter keine Probleme. Auch die ETS 5 meckert bei einem Prüflauf zwar einiges an, aber nicht die fehlenden DPTs.
                            killroy2 @ChrisChros last edited by killroy2
                            @chrischros said in Test Adapter OpenKNX 0.1.x:
                            wie schreibst du den Wert mit blockly ? Es muss vom Typ number sein.
                            C 1 Reply Last reply Reply Quote 1
                              State value to set for "openknx.0.Dimmen.Dimmen.Außen_-Terrasse-Spots-_Dimmen" has to be stringified but received type "object"
                              Das ist noch ein Problem vom Adapter, führt aber zu keiner Funktionsbeeinträchtigung.
                                mane444 last edited by
                                @killroy2 sagte in Test Adapter OpenKNX 0.1.x:
                                Die Zuordnung zu Status GA wertet der Adapter nicht anhand der alten Konfiguration aus. Das geht jetzt seit v0.1.11 über Alias
                                Die Zuordnung der Status GA über Alias finde ich eine super Lösung. Ich hab das gleich mal getestet, leider findet die momentane Testversion nur 14 von meinen Status GA. Wenn dir das was bei der Entwicklung hilft kann ich dir gerne meine XML schicken.
                                  killroy2 @mane444 last edited by
                                  @mane444 ja schick mal zu, wenn du es veröffentlichen kannst dann irgendwo hier einfügen: https://github.com/iobroker-community-adapters/ioBroker.openknx/issues
                                    tiego last edited by
                                    hatt zufällig jemand eine Lösung gefunden für mein Problem mit
                                    State value to set for "openknx.0.OG.Licht.OG_-_Licht_O5_Zimmer_Eltern_O5_2_Decke_-_dimm" has to be stringified but received type "object"
                                    danke
                                      ChrisChros @tiego last edited by
                                      @tiego
                                      Das ist das gleich Problem wie bei mir weiter oben und von @killroy2 bereits beantwortet.
                                      @killroy2 said in Test Adapter OpenKNX 0.1.x:
                                      Ist noch ein Problem im Adapter, nichts schlimmes.
                                        ChrisChros @killroy2 last edited by
                                        @killroy2 aktuell sieht das bei blockly so bei mir aus:
                                        Muss aber dazu sagen das sind meine ersten Gehversuche mit blockly. Gut möglich das ich die falsche Elemente benutze. Zumindest kann ich hier nicht sehen wo ich den Datentyp definieren kann.
                                          mane444 @tombox last edited by
                                          @tombox
                                          Was mir noch aufgefallen ist beim Erstellen der alias DP werden keine Einheiten eingetragen. z.B. bei Solltemperaturen.
                                            @chrischros es scheint so als würdest du keine Zahl übertragen. Ich versuche gerade ein aussagekräftige Fehlermeldung einzubauen
                                            573
                                            136868
