    3. Entwicklung
    4. Synology Chat ...
    Synology Chat ...
    • Glasfaser
      Glasfaser @wrod last edited by Glasfaser
      @wrod
      Beispiel :
      <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="[.;w?/pK-.4zyW!UyYBl" x="163" y="88">
        <value name="OID0">
          <shadow type="field_oid" id="3VnM3u.?JEhM[^n/?X0p">
            <field name="oid">0_userdata.0.Test123</field>
          <block type="variables_set" id="*dQxDuFmm[ppsJg3%3!V">
            <field name="VAR" id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</field>
              <block type="text" id="+_Bx+X)YJc^_8RSz74zE">
                <field name="TEXT">Hier dein Text , ioBroker 2021</field>
              <block type="variables_set" id="u^*rT,0CM,T_]XeGow}h">
                <field name="VAR" id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</field>
                  <block type="text" id="K]+z|W)qG[s?viD8cP}Q">
                    <field name="TEXT">192.168.xxx.xxx</field>
                  <block type="variables_set" id=",|/0@uFO[kJp[pSjyfW~">
                    <field name="VAR" id=",O#!.RmBLV$D$25E`o7/">Syno_Port</field>
                      <block type="text" id="YmIhCu8+dV@OO0U[PWx#">
                        <field name="TEXT">5000</field>
                      <block type="variables_set" id="Z}%_nt.Jz``.b})ifYmx">
                        <field name="VAR" id="Eg)M29q*/71]Q#lGjYO;">Chat_token</field>
                          <block type="text" id="[^9?/_`o:[u8zr_:o:`T">
                            <field name="TEXT">xxxxxxxxxxxxxxxxxxxxx</field>
                          <block type="timeouts_cleartimeout" id="1#Qx;^WXsqqn)X|6E2jF">
                              <block type="timeouts_cleartimeout" id="]P6ccsD65Q=LsNc=*[+u">
                                  <block type="timeouts_settimeout" id=",Vl,JVw3kG.#VrRAqd:b">
                                    <field name="DELAY">1000</field>
                                    <field name="UNIT">ms</field>
                                      <block type="variables_set" id="0jj@r*)y_VPw~)q+,3)N">
                                        <field name="VAR" id=")2,KTR||]G~d7xyd!QUZ">send</field>
                                          <block type="text_join" id="Q^/K[ogSU%663c!lHXyf">
                                            <mutation items="9"></mutation>
                                            <value name="ADD0">
                                              <block type="text" id="Xp!K%fv+S+C7_K~7ka^c">
                                                <field name="TEXT">http://</field>
                                            <value name="ADD1">
                                              <block type="variables_get" id="U#z.iPhHMr!oaBW_.L}$">
                                            <value name="ADD2">
                                              <block type="text" id="|ITd9=%HnJAhhwgaz3|-">
                                                <field name="TEXT">:</field>
                                            <value name="ADD3">
                                              <block type="variables_get" id="_E?oZ@h{l{gD!e{A..FQ">
                                            <value name="ADD4">
                                              <block type="text" id="_^c23]w8ve_wLo_pG;lU">
                                                <field name="TEXT">/webapi/entry.cgi?api=SYNO.Chat.External&amp;method=incoming&amp;version=2&amp;token="</field>
                                            <value name="ADD5">
                                              <block type="variables_get" id="p//Pgq^!$p27`+=TYO0t">
                                            <value name="ADD6">
                                              <block type="text" id="zG0}^=D_TXDv9Tjx8afb">
                                                <field name="TEXT">"&amp;payload={"text":"</field>
                                            <value name="ADD7">
                                              <block type="variables_get" id="];FJ@4Io`JJ?oyGqhlTU">
                                            <value name="ADD8">
                                              <block type="text" id="G|.7zo{,tbQ8-Uo83p,)">
                                                <field name="TEXT">"}</field>
                                          <block type="timeouts_settimeout" id="dUpl:*/S.GOlt6yy5+E?">
                                              <block type="request" id="939:VQbG=f:Lt(8,--UH">
                                                <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                                                <field name="WITH_STATEMENT">TRUE</field>
                                                <field name="LOG"></field>
                                                <value name="URL">
                                                  <shadow type="text" id="1o%c{S``+)7HEh-A%)U^">
                                                  <block type="variables_get" id="vAPQA_YY6uy)ow09^`*K">
                                                  <block type="debug" id="qZVJ(@5Ef)}jneJ%Q)_N">
                                                    <value name="TEXT">
                                                      <shadow type="text" id="S=pA)VcRi34L-{?F`HMz">
                                                      <block type="variables_get" id="N_1)-!F8nh][M#5EAmb6">
                                                        <field name="VAR" id="s`TAk}2fZk|p^o$4+d@t">result</field>
                                                  <block type="debug" id="v:z{{P}3]9(0mcj`VrK7">
                                                    <value name="TEXT">
                                                      <shadow type="text">
                                                      <block type="variables_get" id="/5v?Iwot|ODZ)QhG%957">
      Entweder vorgegeben , oder aus einem Datenpunkt
        wrod last edited by
        @glasfaser Danke! Es läuft!
          Tschaeens @Glasfaser last edited by Tschaeens
          @glasfaser
          Hast du vielleicht eine Idee, warum keine Umlaute (ä, ö) oder zum Beispiel Grad Celcius als Zeichen nicht gehen. Dann kommt im Log immer ein Fehler?
          Liebe Grüße
          Glasfaser 2 Replies Last reply Reply Quote 0
          • Glasfaser
            Glasfaser @Tschaeens last edited by
            @tschaeens sagte in Synology Chat ...:
            Weil der Text noch :
            encodeURIComponent()
            Die Methode encodeURIComponent() kodiert eine Komponente des Uniform Resource Identifier (URI) indem jedes Vorkommen bestimmter Zeichen durch ein, zwei, drei oder vier Escape-Sequenzen ersetzt werden, die der UTF8-Kodierung des Zeichens entsprechen. Vier Escape-Sequenzen werden nur bei Zeichen bestehend aus zwei "Surrogate"-Zeichen verwendet.
            https://www.w3schools.com/jsref/jsref_encodeuricomponent.asp
            Klingelt%20jemand%20an%20der%20Haust%C3%BCr
            22%20%C2%B0C
            warum%20keine%20Umlaute%20(%C3%A4%2C%20%C3%B6)%20und%20kein%2022%20%C2%B0C
            geht hiermit :
             <variables>
               <variable id="$Tar!(b_)qw:24xtP(vj">url</variable>
               <variable id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</variable>
               <variable id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</variable>
               <variable id=",O#!.RmBLV$D$25E`o7/">Syno_Port</variable>
               <variable id="Eg)M29q*/71]Q#lGjYO;">Chat_token</variable>
               <variable id=")2,KTR||]G~d7xyd!QUZ">send</variable>
               <variable type="timeout" id="timeout2">timeout2</variable>
               <variable id="s`TAk}2fZk|p^o$4+d@t">result</variable>
             </variables>
             <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="163" y="38">
               <mutation statements="false">
                 <arg name="url" varid="$Tar!(b_)qw:24xtP(vj"></arg>
               </mutation>
               <field name="NAME">encodeURI</field>
               <field name="SCRIPT">dXJsID0gZW5jb2RlVVJJQ29tcG9uZW50KHVybCk7DQpyZXR1cm4gdXJsOw==</field>
               <comment pinned="false" h="80" w="160">encode URL function</comment>
             <block type="comment" id="sn%:SFkGbJ1*B^:BY`FW" x="162" y="63">
               <field name="COMMENT">// https://forum.iobroker.net/topic/47210/synology-chat/41</field>
                 <block type="on_ext" id="[.;w?/pK-.4zyW!UyYBl">
                   <value name="OID0">
                     <block type="comment" id="uRZ3rr;n#Cb)oaDZB3$)">
                       <field name="COMMENT">encodeURIComponent hinzugefügt</field>
                             <block type="procedures_callcustomreturn" id="GD%^L~Wq_LIL_y86c}(2">
                               <mutation name="encodeURI">
                                 <arg name="url"></arg>
                               </mutation>
                               <value name="ARG0">
                                   <field name="TEXT">warum keine Umlaute (ä, ö) und kein 22 °C</field>
                                   <field name="TEXT">192.168.xxx.xx</field>
                                           <field name="TEXT">xxxxxxxxxxxxxxxxx</field>
                                                           <value name="ADD0">
                                                           <value name="ADD1">
                                                           <value name="ADD2">
                                                           <value name="ADD3">
                                                           <value name="ADD4">
                                                           <value name="ADD5">
                                                           <value name="ADD6">
                                                           <value name="ADD7">
                                                           <value name="ADD8">
                                                               <value name="URL">
        <value name="TEXT">
        <value name="TEXT">
            • Glasfaser
              Glasfaser @Tschaeens last edited by Glasfaser
              oder zum Beispiel
              mit der Änderung oben , können jetzt auch Emoji mit versendet werden
                wrod @wrod last edited by
                @wrod Danke.
                Es sieht nun so aus.
                Immer wenn ein anderer Vorgang (etwa ein anderes Skript) ein eigens erzeugtes Objekt "Nachrichtentext" ändert, wird dieser an mich versendet. Dann wird dieser wieder auf "false" gesetzt.
                Jetzt brauche ich noch Skripts, die auf Abfrage das Objekt "Nachrichtentext" sinnvoll befüllen.
                Gibt es dazu elegante Möglichkeiten, insbesondere für eine Abfrage mehrerer Objekte auf das Überschreiten von Grenzwerten, also etwa
                Wenn <Objekt_X> überschreitet <Grenzwert_X> dann setze Erzeuge Variable <Text> aus <Konstante_X> und ggf <Variable_X> und befülle Objekt <Nachrichtentext>; mit
                • <Objekt A> <Grenzwert A> <Konstante A> <Variable A>
                • <Objekt B> <Grenzwert B> <Konstante C> <Variable C>
                • <Objekt n> <Grenzwert n> <Konstante n> <Variable n>
                Das wäre ja wohl eine Schleife oder Liste in Form von
                Für jedes Elemente in Liste x prüfe und setze.
                Das Skript müsste dann aber wohl ständig abfragen. Lässt sich das auch über eine Liste/Schleife lösen im Sinne von
                Wenn eines der folgenden Elemente sich ändert, dann prüfe?
                Dank im Voraus
                • Glasfaser
                  @wrod sagte in Synology Chat ...:
                  Das würde jetzt diesen Thread "Synology Chat"dafür sprengen .
                  @all
                  Ich habe nochmal das Blockly verkürzt .
                   <variables>
                     <variable id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</variable>
                     <variable id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</variable>
                   </variables>
                   <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="488" y="-512">
                     </mutation>
                   <block type="procedures_defcustomnoreturn" id="c4Zobeu@zHx7@T7RCR[+" x="488" y="-487">
                     <mutation statements="false"></mutation>
                     <field name="NAME">Chat_senden</field>
                     <field name="SCRIPT">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</field>
                   <block type="comment" id="dh?Nq_).+o*LRx@ZBJ/P" x="488" y="-463">
                     <field name="COMMENT">https://forum.iobroker.net/topic/47210/synology-chat/44</field>
                       <block type="comment" id="]-LvUJjLlh6nbfULNnAm">
                         <field name="COMMENT">Synology Chat Daten</field>
                                         <field name="TEXT">Hier dein Token</field>
                                       <block type="comment" id="#X/LLHHf]+a]HP9ULZZA">
                                         <field name="COMMENT">Debugmodus an/aus</field>
                                           <block type="variables_set" id="]Dg;,gKp,/]Sb1cUFi?n">
                                             <field name="VAR" id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</field>
                                               <block type="logic_boolean" id="0~lqDtIM29hgH2or)}mL">
                                               <block type="variables_set" id="W=GM=?`a~14E-J+QXSAQ">
                                                 <field name="VAR" id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</field>
                                                   <block type="logic_boolean" id="*JUO/RsrY?M/l53;H_pF">
                                                   <block type="comment" id="[gDu2J;3btcPa(EESlU!">
                                                     <field name="COMMENT">Ab hier Trigger</field>
                                                       <block type="on_ext" id="9h_zLLHz{65UPzm^$7}e">
                                                         <value name="OID0">
                                                           <shadow type="field_oid" id="NgekYWG@PsA7G02OF}rj">
                                                           <block type="controls_if" id="mSYXDpsYHKUM+j9uSS2s">
                                                               <block type="logic_compare" id="55HN]QCkz$?W=xUf*cx_">
        <field name="OP">EQ</field>
        <block type="on_source" id="l[/NtLhpCNaa5/@gH6X-">
        <block type="logic_boolean" id="),*:R)Nryc!rExr_0IK=">
        </mutation>
        <value name="ARG0">
        <field name="TEXT">Ich bin ein kleiner 🐧</field>
        <block type="timeouts_settimeout" id="ht3)ckT6?(PDbQipm{_z">
        <block type="procedures_callcustomnoreturn" id="[EP#gKV7fF}Y+8x8zkZ^">
        <mutation name="Chat_senden"></mutation>
                                                             <statement name="ELSE">
                                                               <block type="timeouts_cleartimeout" id="TKEEXDr0Qo(}RX.!blS5">
                  @dslraser
                  kann man das schon Produktiv übernehmen , was meinst du oder eher noch eine Testphase !
                  Beispiel :
                  https://forum.iobroker.net/topic/40424/alexa-ansagen-i-telegram-i-email-i-alias-i-visu-i-html?_=1640618730944
                  Das einzigste was mich stört , ich finde keinen Butten um eine ( Test ) -Nachricht im Syn Chat zu löschen !?
                  dslraser Glasfaser 4 Replies Last reply Reply Quote 0
                  • dslraser
                    dslraser Forum Testing Most Active @Glasfaser last edited by dslraser
                    @glasfaser sagte in Synology Chat ...:
                    Ich habe bisher hier nur mitgelesen. Ich habe das Blockly noch nicht probiert, aber auf jeden Fall interessant.
                    EDIT: nur zur Info, hier reicht Wert ( = wahr kann weg wenn Du auf wahr triggern möchtest, sonst nicht Wertnehmen)
                    • dslraser
                      @glasfaser
                      Ich habe mir jetzt mal Chat auf der Syno und auf den Handy installiert.
                      Könntest Du, oder auch wer anders, mal eine Anleitung für „DAU‘s“ (also für mich) erstellen welche Einstellungen auf der Syno für einen Bot (ich habe den bei mir Haus) genannt, gemacht werden müssen um mit dem Bot interagieren zu können.
                      Ich bekomme bisher mit Deinem Blockly nur eine 404 Meldung.
                       {"error":{"code":404,"errors":"bot type error"},"success":false}
                      Glasfaser W 2 Replies Last reply Reply Quote 0
                      • Glasfaser
                        Glasfaser @dslraser last edited by Glasfaser
                        @dslraser
                        Bin kein guter Bescheiber .... aber hier in Bildern :
                        token=%22meintoken%22
                        dein token rein ohne die %22 in der URL am Anfang und am Ende
                        ja ich weiß , ist nur ein TESTSCRIPT ....
                          wrod @dslraser last edited by Homoran
                          @dslraser
                          Ich probiere es mal:
                          • In Synology Chat oben rechts auf Deinen User gehen (hier "A"):
                          • Dort "Einbindung" wählen:
                          • Dann "Eingehende Webhooks": ee734841-0448-49e7-b000-415fad3e9fda-grafik.png
                          • Dort "Erstellen" und einen Absendernamen und Kanal wählen bzw. einen neuen erstellen (z.B. "iobroker_an_user_x"). Im Webhook-Link sind dann die URL und der Token enthalten, den das Script braucht.
                          Das sollte es sein.
                            wrod @Glasfaser last edited by
                            @glasfaser ich habe die %22 mit kopiert. Geht offenkundig auch.
                              @wrod Oh, @Glasfaser war schneller - wie im echten Leben. Bin wohl aus Kupfer.
                              • Glasfaser
                                @wrod
                                Nimm mal den Screenshot mit der URL raus ....
                                SONST bin ich gleich auf deinem Rechner !!!!
                                Homoran dslraser 2 Replies Last reply Reply Quote 0
                                  Homoran Global Moderator Administrators @Glasfaser last edited by
                                  @wrod
                                  Hab mal alle Screens entfernt, war der schnellste Weg - Post war etwas chaotisch formatiert
                                  • dslraser
                                    @glasfaser
                                    Nachrichten kommen jetzt an. Aber es dauert jedes Mal genau 31 Sekunden bei mir. Warum ist das so langsam ? Braucht die Syno so lange um die Bestätigung zu senden ? (in Deiner Funktion wird da glaube ich drauf gewartet, oder ?)
                                    • Glasfaser
                                      @dslraser
                                      Ja , das braucht solange ... keine Ahnung warum , habe mich noch nicht damit befasst .
                                      Auch ohne Result ist es so ...
                                      • dslraser
                                        @all
                                         <variables>
                                         </variables>
                                           </mutation>
        <value name="OID0">
        </mutation>
        <value name="ARG0">
                                        @dslraser
                                        Beispiel :
                                        Kurze Nachrichten gehen durch, aber wenn die Listen oder Nachrichten länger werden nicht.
                                        Längere Nachricht:
                                        {"error":{"code":410,"errors":"msg too long"},"success":false}
                                        Wieviel Zeichen dürfen die denn haben ?
                                        • Glasfaser
                                          @dslraser sagte in Synology Chat ...:
                                          Das habe ich noch nicht getestet .
                                          @glasfaser
                                          Nachtrag :
                                          Wenn ich die fertige URL im Browser eingebe dauert es auch so lange .
                                          • dslraser
                                            @glasfaser
                                            ich habe mal eine Lampe zum triggern genommen...
                                            adapter chat message handler synology synology diskstation
                                            19
                                            184
                                            29922
