    3. Entwicklung
    4. Synology Chat ...
    Synology Chat ...
    • Glasfaser
      Glasfaser @dslraser last edited by
      @dslraser
      Ich kann dir das Test Blockscript schicken wo ich noch am Basteln bin funktioniert aber , wenn es reicht !?
       <variables>
         <variable id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</variable>
         <variable id=",O#!.RmBLV$D$25E`o7/">Syno_Port</variable>
         <variable id="Eg)M29q*/71]Q#lGjYO;">Chat_token</variable>
         <variable id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</variable>
         <variable id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</variable>
         <variable id="yW]q[i/Yfz.,5Z+Vb.a,">URL_ioBroker</variable>
         <variable id=")2,KTR||]G~d7xyd!QUZ">send</variable>
         <variable type="timeout" id="timeout1">timeout1</variable>
         <variable id="s`TAk}2fZk|p^o$4+d@t">result</variable>
       </variables>
       <block type="procedures_defcustomnoreturn" id=")M6lvmD#MPU2;=lc,6D:" x="713" y="-112">
         <mutation statements="false"></mutation>
         <field name="NAME">loesche Bild</field>
         <field name="SCRIPT">dW5saW5rKCcwX3VzZXJkYXRhLjAnLCAnc3lub2xvZ3kvYmlsZC5qcGcnLChlKT0+ew0KDQogICAgaWYoZSkgbG9nKGUpDQoNCn0pDQoNCg==</field>
       <block type="procedures_defcustomnoreturn" id="Fh|~ouZqovH}}ZEi:0P{" x="713" y="-87">
         <field name="NAME">Bild_holen</field>
         <field name="SCRIPT">DQoNCg0KcmVxdWVzdCgNCg0KICB7DQoNCiAgICB1cmw6IFVSTF9TbmFwc2hvdCAsDQoNCiAgICBlbmNvZGluZzogbnVsbCwNCg0KICB9LA0KDQogIChlcnJvciwgcmVzcG9uc2UsIGJvZHkpID0+IHsNCg0KICAgIGlmICghZXJyb3IgJiYgYm9keSkgew0KDQogICAgICB3cml0ZUZpbGUoIjBfdXNlcmRhdGEuMCIsICIvc3lub2xvZ3kvYmlsZC5qcGciLCBib2R5KTsNCg0KICAgIH0NCg0KICB9DQoNCik7DQo=</field>
       <block type="on_ext" id="[.;w?/pK-.4zyW!UyYBl" x="-262" y="63">
         <value name="OID0">
           <shadow type="field_oid" id="3VnM3u.?JEhM[^n/?X0p">
             <field name="oid">0_userdata.0.Testbutton</field>
           <block type="variables_set" id="u^*rT,0CM,T_]XeGow}h">
             <field name="VAR" id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</field>
               <block type="text" id="K]+z|W)qG[s?viD8cP}Q">
                 <field name="TEXT">192.168.xxx.x</field>
               <block type="variables_set" id=",|/0@uFO[kJp[pSjyfW~">
                 <field name="VAR" id=",O#!.RmBLV$D$25E`o7/">Syno_Port</field>
                   <block type="text" id="YmIhCu8+dV@OO0U[PWx#">
                     <field name="TEXT">5000</field>
                   <block type="variables_set" id="Z}%_nt.Jz``.b})ifYmx">
                     <field name="VAR" id="Eg)M29q*/71]Q#lGjYO;">Chat_token</field>
                       <block type="text" id="[^9?/_`o:[u8zr_:o:`T">
                         <field name="TEXT">hier dein Token</field>
                       <block type="variables_set" id="m/`Hepc#d!=l=Yu?E{!6">
                         <field name="VAR" id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</field>
                           <block type="text" id="naz0gbDT{!MOKW]c|g8{">
                             <field name="TEXT">Es klingelt an der Haustuer</field>
                           <block type="variables_set" id="fT*7tvvXRtyOgN,6C,2?">
                             <field name="VAR" id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</field>
                               <block type="text" id="N]=+,oldD=_C5-KIA*6[">
                                 <field name="TEXT">Hier habe ich ein direktlink von meiner Hikvision Snapshot</field>
                               <block type="procedures_callcustomnoreturn" id="J8Bxi=.l@zrRJkcGT150">
                                 <mutation name="Bild_holen"></mutation>
                                   <block type="variables_set" id="Q8SV]H7m2;RCEIl!I32S">
                                     <field name="VAR" id="yW]q[i/Yfz.,5Z+Vb.a,">URL_ioBroker</field>
                                       <block type="text" id="Cw;l)b1L4K(P86t9=T}E">
                                         <field name="TEXT">http://192.168.xxxxxxx:8082/0_userdata.0/synology/bild.jpg</field>
                                       <block type="timeouts_cleartimeout" id="1#Qx;^WXsqqn)X|6E2jF">
                                           <block type="timeouts_cleartimeout" id="]P6ccsD65Q=LsNc=*[+u">
                                             <field name="NAME">timeout1</field>
                                               <block type="timeouts_settimeout" id=",Vl,JVw3kG.#VrRAqd:b">
                                                 <field name="DELAY">4000</field>
                                                 <field name="UNIT">ms</field>
                                                   <block type="variables_set" id="0jj@r*)y_VPw~)q+,3)N">
                                                     <field name="VAR" id=")2,KTR||]G~d7xyd!QUZ">send</field>
                                                       <block type="text_join" id="Q^/K[ogSU%663c!lHXyf">
                                                         <mutation items="11"></mutation>
                                                         <value name="ADD0">
                                                           <block type="text" id="Xp!K%fv+S+C7_K~7ka^c">
                                                             <field name="TEXT">http://</field>
                                                         <value name="ADD1">
                                                           <block type="variables_get" id="U#z.iPhHMr!oaBW_.L}$">
                                                         <value name="ADD2">
                                                           <block type="text" id="|ITd9=%HnJAhhwgaz3|-">
                                                             <field name="TEXT">:</field>
                                                         <value name="ADD3">
                                                           <block type="variables_get" id="_E?oZ@h{l{gD!e{A..FQ">
                                                         <value name="ADD4">
                                                           <block type="text" id="_^c23]w8ve_wLo_pG;lU">
                                                             <field name="TEXT">/webapi/entry.cgi?api=SYNO.Chat.External&amp;method=incoming&amp;version=2&amp;token="</field>
                                                         <value name="ADD5">
                                                           <block type="variables_get" id="p//Pgq^!$p27`+=TYO0t">
                                                         <value name="ADD6">
                                                           <block type="text" id="zG0}^=D_TXDv9Tjx8afb">
                                                             <field name="TEXT">"&amp;payload={"text":"</field>
                                                         <value name="ADD7">
                                                           <block type="variables_get" id="];FJ@4Io`JJ?oyGqhlTU">
                                                         <value name="ADD8">
                                                           <block type="text" id="G|.7zo{,tbQ8-Uo83p,)">
                                                             <field name="TEXT">", "file_url": "</field>
                                                         <value name="ADD9">
                                                           <block type="variables_get" id="v/9SP;]`*blX7Qt=h~Eu">
                                                         <value name="ADD10">
                                                           <block type="text" id="z1]{?Af3zI_+#txN*=UR">
                                                             <field name="TEXT">"}</field>
                                                       <block type="timeouts_settimeout" id="dUpl:*/S.GOlt6yy5+E?">
                                                         <field name="DELAY">1000</field>
                                                           <block type="request" id="939:VQbG=f:Lt(8,--UH">
                                                             <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                                                             <field name="WITH_STATEMENT">TRUE</field>
                                                             <field name="LOG"></field>
                                                             <value name="URL">
                                                               <shadow type="text" id="1o%c{S``+)7HEh-A%)U^">
                                                               <block type="variables_get" id="vAPQA_YY6uy)ow09^`*K">
                                                               <block type="debug" id="qZVJ(@5Ef)}jneJ%Q)_N">
        <value name="TEXT">
        <shadow type="text" id="S=pA)VcRi34L-{?F`HMz">
        <block type="variables_get" id="N_1)-!F8nh][M#5EAmb6">
        <field name="VAR" id="s`TAk}2fZk|p^o$4+d@t">result</field>
                                                               <block type="debug" id="v:z{{P}3]9(0mcj`VrK7">
        <value name="TEXT">
        <shadow type="text">
        <block type="variables_get" id="/5v?Iwot|ODZ)QhG%957">
      Ich baue es gerade auf die gekürzte Version um .
      • dslraser
        dslraser Forum Testing Most Active @Glasfaser last edited by
        @glasfaser sagte in Synology Chat ...:
        Das ist wohl das Problem, ich nehme immer den Link vom Synology Adapter, aber damit kommt eine Fehlermeldung.
        • Glasfaser
          @dslraser
          setze mal ein Debug , was als Wert in URL_Snapshot geschrieben wird .
          Ich teste immer mit einem Dummy Link:
          Beispiel :
          https://upload.wikimedia.org/wikipedia/commons/a/aa/Sun920607.jpg
          dslraser Glasfaser 2 Replies Last reply Reply Quote 0
          • dslraser
            es wird genau der Link geschrieben der in dem DP steht. Wenn ich diese Link in den Browser eingebe, dann ist sofort das Bild zu sehen. Hast Du den Syno Adapter installiert ?
            • Glasfaser
              @dslraser sagte in Synology Chat ...:
              Logo ... habe ich den .
              Auch mit diesem Link funktioniert es ....
              Oder versuche mal .
              Kopiere den Link daraus und trage Ihn ein , also nicht per wert holen
              • dslraser
                schon probiert, gleiche Fehlermeldung
                • Glasfaser
                  @dslraser
                  is not in the cert's list:
                  Kenn diese Meldung nicht ... hast du noch mehr im Log dazu stehen
                  • dslraser
                    dslraser Forum Testing Most Active @Glasfaser last edited by dslraser
                    @glasfaser
                    nein, leider nur das
                    EDIT: doch noch was, dieser Error Code
                    {"error":{"code":117},"success":false}
                    • Glasfaser
                      Glasfaser @dslraser last edited by Glasfaser
                      Diese Meldung sagt aus ... vom Chatserver , das der Inhalt Bild fehlt .
                      ist leer .
                      Was kommt hiermit als Ausgabe
                      <block xmlns="https://developers.google.com/blockly/xml" type="request" id="jGRe=jAvY7pi~/M7zdOV" x="338" y="88">
                       <value name="URL">
                         <shadow type="text" id="Kcq}@/lN.7+@VX{.Sl1~">
                           <field name="TEXT">Hier dein Link</field>
                         <block type="debug" id="!N5up[B{T/LTTi-_ecn9">
                           <value name="TEXT">
                             <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="J`/`lk[1@05UD[2~T+TL">
                             <block type="variables_get" id="Hh~k_N+@YbO%UvlA/@bU">
                               <field name="VAR" id="%3Mff6CD,)5FpTyqT-?!">result</field>
                             <block type="debug" id="?da:0)J$|KrxbYk`B}(B">
                               <value name="TEXT">
                                 <block type="variables_get" id="+W;=rb#yQo|PE}[-2UtT">
                                   <field name="VAR" id="k/Bs#bIB:Ff8L9lv4^-d">stdout</field>
                                 <block type="debug" id="RXN$G!=O`P9nhNpVu#(N">
                                   <value name="TEXT">
                                     <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="Lbpbr1oEFz|ETX~l$^Cs">
                                     <block type="variables_get" id=",4pl9#rI2/9w19HTHk~o">
                                       <field name="VAR" id="Cjr.[GB6284iu*rOZxn}">stderr</field>
                                     <block type="debug" id=";K*88rm67)kSl|OR`?4:">
                                       <value name="TEXT">
                                         <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="y:/8xVy;=1lXAoSk~x)4">
                                         <block type="variables_get" id="@Rs4BpAt%r]mmn4Aj_::">
                                           <field name="VAR" id="_qJ[C$+4||[A|G%Qg~xD">error</field>
                      • dslraser
                        Damit schmiert mir die ganze JS-Instanz ab...
                        • Glasfaser
                          @dslraser
                          Ist dann sowas enthalten im Log
                          �J�)ԃ�hp1�@�S$t�i�@皙�Q2�BH@�461Hh
                          1�4�J�S
                          k(��Gz�[�P�%����4PEJ�@✍��<�1Q��
                          .j5#8�<���G�>�%#c��/Z�i<�z�c@���<⣐�b�#Rs���h
                          C�(�<�)��~���g�V�"��'�1�?ZkR�1L�g�=s���F��R�o�1@
                          9����������HǠ��'���zӍ0��@�JM�0h�KL�S���"�>���9�
                          6�@��ך3��6��?���K����:����$]�WN��eFp����&\q�@����i�U�5Z"��PV�
                          H�i���
                          H�i��#ja��0�f�E<�i��#4ʐ�$t�m����R*$<��r(�����Wk�[�횭(��n����(��q3R/��R���+ץ<��)�^j3��;�m��h=)9ݜҚJB�N�ɧ�AA��ݏji'84�N�i�n\�4�I{z��A�6y��g�Ӕ��iO_ZpA���<�܌�4�rzSB�I h�(&�N(Ƞ��qG}���zRP:�uQ@j(8� ��s�c�zs}�A�K�Pf��E(P �Z��r8�4gҀ��3Q���֞��5�(h�P?����♌����f�p)ꅎR�4�IS�6XR�����N;�R~\Te�@ A�'��dSI�8=(A �A9�
                          �i+)>��h��ihGJ(Q@.i)}�1��H�4�@��8�E4�h4
                          &��- '�\R�E �@-��1IR�`c��E����&��sN$���@4��
                          &h'�]ԡ��ih���4�Ӂy�zSM%'���ڀHh�9�@i)3K�J1K֓4��M5!釭4�����d����]�1�*՚zӕ�9���ܛ�Ac�
                          [4�;��G#6�l�Yj����EV�0�
                          �EԲ'<�z�MJ�TԈA�ڀ,�r��rW�r�hpi�j jE�@�L�@�"�e7�q����A�Q:�4�ER�n �b�;�����R�m(�R�m(�R�R�QN�J(�
                          • dslraser
                            nein
                            • dslraser
                              @glasfaser
                              sowas kommt zuerst
                              TypeError: Converting circular structure to JSON
                              • Glasfaser
                                @dslraser
                                Komisch , das ist ein normaler Result .
                                das mit den Zeichen ist das Bild von der Cam was zurückkommt .
                                Aber es darf nicht JS abschmieren dadurch .
                                • Glasfaser
                                  Glasfaser @Glasfaser last edited by
                                  Beispiel :
                                  Hast du mal , anstatt dem Cam Link , das hier gemacht !?
                                  • dslraser
                                    Nichtmal das klappt...Ich habe gerade keine Idee was bei mir hier schief läuft.
                                    • dslraser
                                      Stop, das geht...
                                      • Glasfaser
                                        @dslraser
                                        Also liegt das Bild auch nicht dann in
                                        Targe in der URL_ioBrocker auch den Link vom Bild ein , was ist dann
                                        EDIT :
                                        OK hat sich überschnitten
                                        • Glasfaser
                                          @dslraser
                                          Also gibt es Probleme beim Bild holen , von dem Syn Link .
                                          Mhh ....
                                          Vielleicht braucht er länger zum Bild holen , setze mal ein Timeout nach dem Bildholen , so das die anderen abläufe später kommen .
                                          • Glasfaser
                                            @dslraser
                                            Hier die gekürzte Version "Chatnachricht mit Umlaute und Bildversand"
                                             <variables>
                                               <variable id="$Tar!(b_)qw:24xtP(vj">url</variable>
                                               <variable id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</variable>
                                               <variable id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</variable>
                                             </variables>
                                             <block type="procedures_defcustomnoreturn" id="Fh|~ouZqovH}}ZEi:0P{" x="488" y="-537">
                                             <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="488" y="-512">
                                                 <arg name="url" varid="$Tar!(b_)qw:24xtP(vj"></arg>
                                               </mutation>
                                               <field name="NAME">encodeURI</field>
                                               <field name="SCRIPT">dXJsID0gZW5jb2RlVVJJQ29tcG9uZW50KHVybCk7DQpyZXR1cm4gdXJsOw==</field>
                                               <comment pinned="false" h="80" w="160">encode URL function</comment>
                                             <block type="procedures_defcustomnoreturn" id="c4Zobeu@zHx7@T7RCR[+" x="488" y="-487">
                                               <field name="NAME">Chat_senden</field>
                                               <field name="SCRIPT">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</field>
                                             <block type="comment" id="dh?Nq_).+o*LRx@ZBJ/P" x="488" y="-463">
                                               <field name="COMMENT">https://forum.iobroker.net/topic/47210/synology-chat/98</field>
                                                 <block type="comment" id="]-LvUJjLlh6nbfULNnAm">
                                                   <field name="COMMENT">Synology Chat Daten</field>
                                                           <field name="TEXT">Deine IP</field>
        <field name="TEXT">Dein Token</field>
        <field name="TEXT">Dein Snapshot Link</field>
        <field name="TEXT">http://192.168.xxx.xxx:8082/0_userdata.0/synology/bild.jpg</field>
        <block type="variables_set" id="*dQxDuFmm[ppsJg3%3!V">
        <block type="procedures_callcustomreturn" id="GD%^L~Wq_LIL_y86c}(2">
        <mutation name="encodeURI">
        <arg name="url"></arg>
        </mutation>
        <value name="ARG0">
        <block type="text" id="+_Bx+X)YJc^_8RSz74zE">
        <field name="TEXT">Alarm an der  Haustür</field>
        <block type="comment" id="#X/LLHHf]+a]HP9ULZZA">
        <field name="COMMENT">Debugmodus an/aus</field>
        <block type="variables_set" id="]Dg;,gKp,/]Sb1cUFi?n">
        <field name="VAR" id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</field>
        <block type="logic_boolean" id="0~lqDtIM29hgH2or)}mL">
        <block type="variables_set" id="W=GM=?`a~14E-J+QXSAQ">
        <field name="VAR" id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</field>
        <block type="logic_boolean" id="*JUO/RsrY?M/l53;H_pF">
        <block type="comment" id="[gDu2J;3btcPa(EESlU!">
        <field name="COMMENT">Ab hier Trigger</field>
        <block type="on_ext" id="9h_zLLHz{65UPzm^$7}e">
        <value name="OID0">
        <shadow type="field_oid" id="NgekYWG@PsA7G02OF}rj">
        <field name="oid">0_userdata.0.Test123</field>
        <block type="controls_if" id="mSYXDpsYHKUM+j9uSS2s">
        <block type="on_source" id="l[/NtLhpCNaa5/@gH6X-">
        <block type="procedures_callcustomnoreturn" id="eimW+=5+~Y|quii}_lBH">
        <block type="timeouts_settimeout" id="ht3)ckT6?(PDbQipm{_z">
        <field name="DELAY">2000</field>
        <block type="procedures_callcustomnoreturn" id="[EP#gKV7fF}Y+8x8zkZ^">
        <mutation name="Chat_senden"></mutation>
        <statement name="ELSE">
        <block type="timeouts_cleartimeout" id="TKEEXDr0Qo(}RX.!blS5">
                                            adapter chat message handler synology synology diskstation
                                            19
                                            184
                                            26403
