    4. [gelöst] - VIS Intance Id - automatisiert ermitteln
    • BananaJoe
      BananaJoe Most Active @liv-in-sky last edited by
      @liv-in-sky jepp. Bis man den Cache löscht. Was Fully meine ich sogar default macht beim Neuladen
        liv-in-sky @BananaJoe last edited by
        @bananajoe
        probiert doch das mal aus - evtl gibt das eine feste id pro gerät zurück -
        import widget - im widget die widget id noch angleichen !
        [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"<script>\nuuid=function(){\nvar u = 'xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx'.replace(/[xy]/g,\nfunction(c) {\nvar r = Math.random() * 16 | 0,\nv = c == 'x' ? r : (r & 0x3 | 0x8);\nreturn v.toString(16);\n});\nreturn u;\n}\n\n\ngetDeviceId = function(){\nvar current = window.localStorage.getItem(\"_DEVICEID_\")\nif (current) return current;\nvar id = uuid();\nwindow.localStorage.setItem(\"_DEVICEID_\",id);   \nreturn id;\n}\n\nconsole.log(getDeviceId())\n $( \"#w00006\" ).text( getDeviceId());\n\n\n</script>\n"},"style":{"left":"838px","top":"180px","color":"#f4e643","background-color":"#b7aeae"},"widgetSet":"basic"}]
        • BananaJoe
          @liv-in-sky nope, pro Browser und inPrivate Sitzung eine eigene
          JavaScript kann das nicht ... und das ist Absicht
            @bananajoe
            also ich bekomme damit einen eindeutigen , nicht vom cache-löschbaren code zurück - getestet mit fully , chrome und edge
            ich dachte, dass sucht ihr
              @bananajoe und wer macht die vis im private mode auf - oder warum sollte man das
              bahnuhr BananaJoe 2 Replies Last reply Reply Quote 0
              • bahnuhr
                bahnuhr Forum Testing Most Active @liv-in-sky last edited by
                @liv-in-sky sagte in VIS Intance Id - automatisiert ermitteln:
                private mode
                Ich wollte im Wohnzimmer ein tablet das im Vollbild öffnet und dass man nicht so einfach mit esc oder f11 raus kommt.
                Und das ging halt mit edge kiosk.
                BananaJoe liv-in-sky 2 Replies Last reply Reply Quote 0
                • BananaJoe
                  @liv-in-sky Ich, zum simulieren verschiedener Geräte 🙂
                  Dein Skript erstellt eine zufällige ID und speichert diese, richtig? Also nichts anderes als die Instanz-ID und wird somit auch kein löschen der Caches überleben.
                  • BananaJoe
                    BananaJoe Most Active @bahnuhr last edited by
                    @bahnuhr ich wäre ja schon am Ziel da ich pro Gerät eine eigene VIS habe. Aber ich suche noch.
                      liv-in-sky @bahnuhr last edited by
                      @bahnuhr
                      ok - aber dann ist es trotzdem eine eindeutige nummer
                      • bahnuhr
                        @bahnuhr
                        Nein, eben nicht.
                        Weil edge die Nr. nicht speichert und jedes mal eine neue erzeugt (bzw. durch klick erzeugt werden muss)
                          @bananajoe sagte in VIS Intance Id - automatisiert ermitteln:
                          hast du es ausprobiert oder schätzt du nur
                            @bananajoe
                            @bahnuhr
                            ok - ihr habt recht - es überlebt den cache nicht - hatte falsch gelöscht - nutze ein tool, was falsch eingestellt war
                            • BananaJoe
                              @liv-in-sky die hätte wir ja schon mit der Instanz ID. Gesucht wird ein Weg immer das gleiche Gerät eindeutig der Instanz-ID zu zuordnen. Die IP-Adresse wäre da einer. Oder der Gerätename. Das sind aber alles dinge an die man wohl aus Absicht nicht aus JavaScript heraus rankommt. Denn damit könnte man ja einen Benutzer eindeutig identifizieren.
                              Und ausprobiert. 4 Browser = 4 verschiedene IDs, im InPrivate dann noch mal 4 verschiedene. und das ist ja auch ok, sonst hätte der InPrivate Modus ja gar keinen Sinn, geht ja darum das der Benutzer nicht eindeutig zu identifizieren ist oder man Informationen aus seinem Netzwerk auslesen kann
                              • bahnuhr
                                @liv-in-sky
                                Warst aber ganz schön hartnäckig 😉
                                  @bahnuhr hatte es zuerst mit cache der app löschen mit fully getestet - da hatte es bestand - erst nachdem ich am pc den cache richtig gelöscht hatte, mußte ich aufgeben 🙂
                                  • BananaJoe
                                    @liv-in-sky In Fully reicht es wenn man den Webspace oder wie das hies nicht löscht, dann bleibt die ID.
                                    Ich suche gerade was wie mir der ioBroker-Server die Frage beantworten kann. Im Globalen Log kann man z.B. sehen wenn sich ein Client verbindet - mit seiner IP.
                                    Keine Ahnung, eine Websocket aufbauen oder irgendwas was beim Aufruf (Im Idealfall die Instanz-ID mit übertragen) mir auf ioBroker Seite gibt: Jo, IP-sowieso hat mir gerade die ID gesendet. Um es dann in einem Script zu verarbeiten der mir daraus einen Datenpunkt zaubert, z.B. mit der IP als Namen und der ID als Wert
                                    • BananaJoe
                                      @bahnuhr also eine Idee ...
                                      • Pro Gerät eine weitere iobroker.web Instanz installieren mit fortlaufenden Ports. Die lauschen dann z.B. auf 2001, 20002, 20003 usw.
                                      • Pro Gerät dann über einen anderen Port auf die VIS zugreifen
                                      • Im JavaScript was in der VIS hinterlegt ist wird der Wert location.port mit auswerten und für den Namen des Datenpunktes nutzen.
                                      Dann ist
                                      • Port 20001 = Tablet WoZi
                                      • Port 20002 = Handy
                                      • Port 20003 = EchoShow
                                      usw.
                                      Ja, Blöd mit den mehreren Instanzen. Aber eine recht leicht umzusetzenden Idee.
                                      bahnuhr 2 Replies Last reply Reply Quote 2
                                      • bahnuhr
                                        bahnuhr Forum Testing Most Active @BananaJoe last edited by
                                        @bananajoe
                                        du bist der Beste.
                                        Anbei dein Script, mit Ergänzung Port
                                        // Funktion die auf ein Widget wartet,
                                        // Stammt von: https://forum.iobroker.net/topic/48663/howto-skripte-im-vis-editor-mit-jquery
                                        // Modifiziert: 30 Durchläufe maximal, 1 Sekunde Pause dazwischen
                                        function waitForElement(parent, elementPath, wid, widgetName, callBack, counter = 0, debug = false) {
                                                 if (counter < 30) {
                                                     setTimeout(function () {
                                                         if (parent.find(elementPath).length > 0) {
                                                             if (debug) console.log(`[${widgetName} ${wid}] it took ${counter}ms to wait for the element '${elementPath}'`);
                                                             callBack();
                                                         } else {
                                                             if (debug) console.log(`[${widgetName} ${wid}] wait for element '${elementPath}'`);
                                                             counter++
                                                             waitForElement(parent, elementPath, wid, widgetName, callBack, counter, debug);
                                                     }, 1000);
                                                 } else {
                                                    if (debug) console.warn(`[${widgetName} ${wid}] stop waiting after ${counter} retries`);
                                                     callBack();
                                        // Warten auf das (basic - Scren Resolution) Widget, ID ggf. anpassen
                                        waitForElement($('body'),'#w02705', 'dummy', 'dummy', function () {
                                           // Widget ist geladen, auf das Widget klicken, w00001 ist die ID von meinem basic - Screen Resolution Widget
                                            setTimeout( () => {
                                                $('#w02705>div>span>span').trigger('click');
                                            }, 1000);
                                            // und in einen Datenpunkt schreiben
                                            setTimeout( () => {
                                            vis.setValue('javascript.0.System.System.Instanz', vis.instance);
                                            vis.setValue('javascript.0.System.System.Port', location.port);
                                            }, 3000);
                                        }, 0, true);
                                        Funktioniert einwandfrei.
                                        Edge wird geöffnet, es wird geklickt, und instance und port wird in die DP geschrieben.
                                        Super.
                                        Anmerkung:
                                        Am besten wäre es wenn der Entwickler von dem widget dies gleich einbauen könnte (noch besser mit IP).
                                        Müsste @Bluefox sein.
                                        Macht der dies noch selber, oder kümmert sich wer anders darum ?
                                        Egal, Danke an @BananaJoe .
                                        Es läuft, nun gehts weiter mit den Überlegungen.
                                        • bahnuhr
                                          @bananajoe
                                          Noch ein Hinweis von mir.
                                          Das widget Screen Resolution Widget muss auf der default Seite liegen.
                                          Denn diese wird beim Start ja aktiviert.
                                            @bahnuhr
                                            @BananaJoe
                                            da habt ihr eine gute lösung gefunden 👍 wurde gleich notiert
                                            126
                                            18051
