    4. Test Adapter OpenKNX 0.6.x
      ChrisChros @tombox last edited by
      @tombox und hier noch der Auszug aus dem Log bezüglich des mehrmaligen sendens.
      zuerst habe ich eine "5" schrieben lassen:
      2021-12-30 20:37:18.240 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "5" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:18.241 - debug: openknx.0 (4520) [debug] 2021-12-30 19:37:18.241 (sendDatagram): >>>>>>> successfully sent seqnum: 736
      2021-12-30 20:37:18.242 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "5" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:18.243 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "5" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:18.244 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "5" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:18.245 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "5" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:18.246 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "5" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:18.247 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "5" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:18.248 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "5" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:18.249 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "5" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:18.250 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "5" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:18.251 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "5" from openknx.0.Heizung.Photovoltaik.Autarkie
      anschließend dann noch eine "50":
      2021-12-30 20:37:34.867 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "50" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:34.868 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "50" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:34.869 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "50" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:34.870 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "50" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:34.871 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "50" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:34.872 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "50" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:34.881 - debug: openknx.0 (4520) [debug] 2021-12-30 19:37:34.881 (sendDatagram): >>>>>>> successfully sent seqnum: 1051
      2021-12-30 20:37:34.911 - debug: openknx.0 (4520) [debug] 2021-12-30 19:37:34.911 Inbound message: 06100421000a04331b00
      2021-12-30 20:37:34.912 - debug: openknx.0 (4520) [debug] 2021-12-30 19:37:34.912 ===== datagram 27 acknowledged by IP router
      2021-12-30 20:37:34.912 - debug: openknx.0 (4520) [debug] 2021-12-30 19:37:34.912 (idle): zzzz...
      2021-12-30 20:37:34.940 - debug: openknx.0 (4520) [debug] 2021-12-30 19:37:34.940 (sendDatagram): >>>>>>> successfully sent seqnum: 1052
      2021-12-30 20:37:34.940 - debug: openknx.0 (4520) [debug] 2021-12-30 19:37:34.940 Inbound message: 06100421000a04331c00
      2021-12-30 20:37:34.941 - debug: openknx.0 (4520) [debug] 2021-12-30 19:37:34.941 ===== datagram 28 acknowledged by IP router
      2021-12-30 20:37:34.941 - debug: openknx.0 (4520) [debug] 2021-12-30 19:37:34.941 (idle): zzzz...
      2021-12-30 20:37:34.950 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "50" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:34.951 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "50" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:34.952 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "50" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:34.953 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "50" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:34.954 - debug: openknx.0 (4520) Outbound GroupValue_Write to 4/6/7 value "50" from openknx.0.Heizung.Photovoltaik.Autarkie
      2021-12-30 20:37:34.965 - debug: openknx.0 (4520) [debug] 2021-12-30 19:37:34.965 (sendDatagram): >>>>>>> successfully sent seqnum: 1053
      2021-12-30 20:37:34.968 - debug: openknx.0 (4520) [debug] 2021-12-30 19:37:34.968 Inbound message: 06100421000a04331d00
        tombox @ChrisChros last edited by
        @chrischros dann liegt es am skript dass der wert zu oft geschrieben wird. kannst ja mal nur Änderung aktivieren
          ChrisChros @tombox last edited by ChrisChros
          @tombox so habe das ganze mal mit "nur Änderungen" getestet und bekomme das gleiche Ergebnis.
          Bin mir auch nicht sicher ob es wirklich am Skript liegt, denn ich ändere den Wert des Objekts den das Skript erzeugt. Somit sollte das Skript garnicht aktiv sein.
            @chrischros Du kannst ja den Wert auch direkt unter Objekte setzen dann sollte es nicht passieren
              @tombox habe ich ja gemacht. Ich bin direkt unter Objekte / Javascript / ... und habe dort den Wert geändert.
                @chrischros ich meine eigentlich openknx.0.Heizung.Photovoltaik.Autarkie
                  @tombox Da wird nix geschrieben, da sehe ich nichts im Gruppenmonitor von der ETS.
                  Flags an der GA sind gesetzt, sogar zeitweise alle mal gesetzt, aber leider ohne erfolg.
                  Die Werte werden aber aktualisiert wenn sie sich ändern. Aber über den ioBroker kann ich die in den Objekten nicht ändern.
                  Sorry falsch. kann doch über die openKNX Objekte schreiben. Mache gleich noch mal einen Log wie es dann aussieht.
                  Im Gruppenmonitor wird der Wert nur einmal geschrieben.
                  Wenn du Adapter die irgendein Gerät auslesen das nicht auf dem KNX Bus ist, wie bekommst du die Werte dann auf den BUS?
                  Hier noch der Auszug aus dem Log.
                  2021-12-30 22:43:28.339 - debug: openknx.0 (5488) [debug] 2021-12-30 21:43:28.339 *** deferring inbound_TUNNELING_REQUEST_L_Data.ind until transition sendDatagram => idle
                  2021-12-30 22:43:28.340 - debug: openknx.0 (5488) [debug] 2021-12-30 21:43:28.340 (sendDatagram): >>>>>>> successfully sent seqnum: 270
                  2021-12-30 22:43:28.341 - debug: openknx.0 (5488) [debug] 2021-12-30 21:43:28.340 Inbound message: 06100421000a04730e00
                  2021-12-30 22:43:28.341 - debug: openknx.0 (5488) [debug] 2021-12-30 21:43:28.341 ===== datagram 14 acknowledged by IP router
                  2021-12-30 22:43:28.341 - debug: openknx.0 (5488) [debug] 2021-12-30 21:43:28.341 (idle): zzzz...
                  2021-12-30 22:43:28.351 - debug: openknx.0 (5488) [debug] 2021-12-30 21:43:28.351 (idle): zzzz...
                  2021-12-30 22:43:28.352 - debug: openknx.0 (5488) Inbound GroupValue_Write 4/4/19 val: 0 dpt: DPT14 to Object: openknx.0.Heizung.Hargassner_Nano_PK.Temperatur_Boiler_1
                  2021-12-30 22:43:28.355 - debug: openknx.0 (5488) Outbound GroupValue_Write to 4/6/7 value "50" from openknx.0.Heizung.Photovoltaik.Autarkie
                  2021-12-30 22:43:28.367 - debug: openknx.0 (5488) [debug] 2021-12-30 21:43:28.367 (sendDatagram): >>>>>>> successfully sent seqnum: 271
                  2021-12-30 22:43:28.400 - debug: openknx.0 (5488) [debug] 2021-12-30 21:43:28.400 Inbound message: 061004200016047381002900bce011141806020040ff
                  2021-12-30 22:43:28.400 - debug: openknx.0 (5488) [debug] 2021-12-30 21:43:28.400 *** deferring inbound_TUNNELING_REQUEST_L_Data.ind until transition sendTunnReq_waitACK => idle
                  2021-12-30 22:43:28.401 - debug: openknx.0 (5488) [debug] 2021-12-30 21:43:28.401 Inbound message: 06100421000a04730f00
                  2021-12-30 22:43:28.401 - debug: openknx.0 (5488) [debug] 2021-12-30 21:43:28.401 ===== datagram 15 acknowledged by IP router
                  Auch wenn ich den Wert dann wieder zurück auf "0" schreibe wird nur einmal der Befehl raus gegeben.
                    @chrischros kannst auch das skript mir per pn schicken
                      killroy2 last edited by killroy2
                      release 0.1.13 ist verfügbar
                      T 1 Reply Last reply Reply Quote 2
                        Tontechniker @killroy2 last edited by
                        @killroy2 Vielen Dank für den Adapter! Habe mittlerweile ohne größere Probleme alles auf openknx umgestellt.
                        Hans
                          tdoc last edited by tdoc
                          nochmal zurück zur Problematik mit den DPTs (Datenpunkttpyen).
                          Aktueller Stand:
                          • Ältere KNX-Projekte (vor ETS5) können mit openknx zur Zeit nicht importiert werden. Das liegt daran, dass erst seit ETS5 DPT den Gruppenadressen zugeordnet werden (können, müssen).
                          • Ältere KNX-Projekte laufen aber natürlich weiterhin problemlos, KNX und ETS ist weitgehend abwärtskompatibel. ETS4 (und älter!) kann auch problemlos in ETS5 konvertiert werden und dort weiterbenutzt werden. Es fehlen dann halt die DTP.
                          • fehlende DPT sind per definitionem (KNX) somit zwar ärgerlich, aber durchaus zulässig.
                          Was bedeuten fehlende DPT (bei älteren KNX-Installationen) für die Praxis? Natürlich läuft das KNX-Projekt weiterhin, kann auch nach Konversion zu ETS5 ohne DPT weiterhin verwendet und programmiert und parametriert werden. Unschön ist lediglich, dass u.U. beispielsweise ein (ganz neues) Anzeigegerät nicht weiß, was es mit den Werten anfangen soll. Es ist ein 2-Byte-Wert, aber welche Einheiten z.B.? Trotzdem fließen natürlich die Daten in der Installation weiterhin. Und in der Praxis muss man dann bei Installation eines neuen Gerätes eben einen Datenpunkttyp ergänzen, falls die Geräteanzeige unsinnig aussieht.
                          Schlussfolgerung: Fehlende Datenpunkttypen sollten kein Ausschlusskriterium für den Import sein. Dort, wo es stört (wegen der Weiterverarbeitung der Daten) muss der Anwender halt selbst später den passenden DPT in iobroker (oder in der ETS) ergänzen. Aber doch bitte kein Zwang, das schon vorher bei vielleicht 1000 GAs machen zu müssen!
                          Der andere Adapter von Chefkoch in der Version 1.x hatte damit keine Probleme. Und der neue Adapter in Version 2.x ist nunmehr auch dementsprechend angepasst worden (siehe https://github.com/ioBroker/ioBroker.knx/issues/128#issuecomment-989205691😞
                          "Ich habe in V2.0.5 den Importfilter für ETS4 projekte überarbeitet/angepasst. damit sollte es laufen" (letzter Eintrag).
                          malotira created this issue in ioBroker/ioBroker.knx
                          closed KNX Import aus ETS 4 schreibt keine Datenpunkte (DPT) in den Adapter. #128
                          T K 3 Replies Last reply Reply Quote 0
                            tombox @tdoc last edited by
                            @tdoc Ich habe dazu mal ein PR gemacht. Die Werte würde aber alle als hex werte dargestellt da keine Information existieren wie die Werte umgewandelt werden müssen
                              killroy2 @tdoc last edited by
                              @tombox
                              ich glaube mit der Änderung ist im nicht geholfen, er müsste sich dann selber um die Konvertierung der Datentypen (komplex zB Float) kümmern anhand von auch wieder nicht verfügbaren Regeln.
                              @tdoc
                              DPTs bestehen aus einer
                              main number - mit dem Datentyp
                              und
                              subnumber (right) - mit Range + Unit
                              Zur Datenverarbeitung ist es notwendig den Datentyp zu kennen. Die subnumber ist optional.
                              Der ETS4 Export, sowohl im XML und CSV Format, erzeugt nicht die DPT Informationen.
                              Der Chefkoch Adapter nutzt ein proprietäres ETS Austauschformat und kann dort in den Tiefen nach den notwendigerweise Vorhandenen Informationen graben.
                              Gegen welche Konvention der openknx Adapter verstossen soll müsstest du schon aufzeigen denn ich sehe keine. Das Konzept der ETS4 wahr wohl eher keine externen Tools zu supporten.
                              Du sagst du kannst zu ETS5 konvertieren. Wie sieht der XML Export dort ins eigene Format aus warum nimmst du den Output nicht von dort?
                                tombox @tdoc last edited by tombox
                                @tdoc Feature ist fertig.
                                @killroy2 Möchte das fertige Feature nicht integrieren weil es für ihn persönlich kein Vorteil bringt. Ich denke man sollte den Nutzer da nicht bevormunden und lieber die rohdaten anzeigt anstatt es zu verbieten
                                https://github.com/iobroker-community-adapters/ioBroker.openknx/pull/80#issuecomment-1004165231
                                TA2k created this issue in iobroker-community-adapters/ioBroker.openknx
                                closed allow no DPT import and controling #80
                                  tdoc @killroy2 last edited by tdoc
                                  @tdoc
                                  und
                                  Hier einfach mal ein Auszug aus meiner aktuellen ETS5, die ich auch für Änderungen,umparametrieren etc. benutze. Wie du siehst, fehlen fast überall die DPT. Das kommt vom ursprünglichen Projekt, damals gab es noch keine DPT. Es ist halt eine sehr alte Installation,hat ein Elektriker vor 20 Jahren gemacht. Konvertierung aus dem ursprünglichen Projekt in ETS5 liegt mir also vor und funktioniert auch völlig problemlos. Trotz der fehlenden DPT (die ich nur bei Bedarf mal nachträglich einpflege).
                                  Es wäre also grundsätzlich schon eine große Hilfe für ALLE alten KNX-Installationen, wenn man auch ohne DPT deinen Adpater benutzen könnte. Insbesondere könnte man importieren, so geht es nicht ohne weiteres. Aber wie gesagt, ich hab trotzdem für mich eine Lösung gefunden und benutze deinen Adapter gerne. Er ist gut. Macht bitte weiter so!
                                  Thorsten Missenberger 1 Reply Last reply Reply Quote 0
                                  • Thorsten Missenberger
                                    Thorsten Missenberger @tdoc last edited by
                                    @tdoc
                                    Du kannst doch die ganzen 1bit Werte in der ETS markieren und dann in den Eigenschaften auf z.B. 1bit Schalten stellen.
                                    Das hat bei mir keine 30 minuten für 2000 GA gedauert
                                    K T 2 Replies Last reply Reply Quote 1
                                      killroy2 @Thorsten Missenberger last edited by
                                      Dafür gibt es dynamische Ordner wo man sich einen Filter für leere Datentypen bauen kann
                                      und von den vermutlich wenigen uneindeutigen zB signed/unsigned muss man es mit den KOs abgleichen.
                                        tdoc @Thorsten Missenberger last edited by
                                        @thorsten-missenberger
                                        Ja natürlich gibt es für dieses Problem einige Lösungsmöglichkeiten. Allerdings werde ich auch nicht der einzige sein, der eine alte KNX-Installation am Laufen hat und dann erst mal vom vergeblichen XML-Importversuch frustriert ist. Für solche alten KNX-Installationen sollte es m.E. eben eine einfache Lösung geben (vielleicht auch nur einen Hinweis in der read.me). Am praktischsten wäre aber eine Checkbox, die eben einen raw Import zulässt (also ohne DPT) und trotzdem Objekte erzeugt (in Abhängigkeit von der Länge würde die Importprozedur halt bei 1 bit z.B. erst mal provisorisch Datentyp 1.000 erzeugen, das ist am einfachsten)
                                        Letztlich kommen die alten KNX-Installationen sehr gut ohne DPT aus. Jedes Gerät interpretiert eben die Rohdaten so, wie ihm vom Hersteller vorgegeben. Die DPT sind natürlich für die Übersichtlichkeit besser. Probleme gibt es aber erst, wenn andere Programme wie iobroker ins Spiel kommen und dann natürlich nicht wissen, was sie mit diesen Rohdaten anfangen sollen.
                                        Grundsätzlich muss man aber so oder so Hand anlegen:
                                        • entweder manuell in der knxproj Datei (und danach importieren)
                                        • oder eben später manuell im iobroker (wenn es eine checkbox gäbe, die Rohdaten-Import zulässt)
                                          Und grundsätzlich muss der user wissen, dass es bei alten KNX-Installationen dieses Problem geben kann und wie er es lösen muss.
                                          killroy2 @tdoc last edited by killroy2
                                          @tdoc said in Test Adapter OpenKNX 0.1.x:
                                          Die Länge 1 bit sieht der Adapter nicht, weder beim Import noch auf dem Bus.
                                          Erstmal gehts darum überhaupt Daten in IOB zu bringen, aktuell verweigert sich der Adapter.
                                          Ich weiss nicht wie gut dir da der "Rohwert" (das ist ein Bytearray) hilft.
                                          -Für boolsche Werte kriegst du ein 1 Byte grosses Interface. Willst du später die DPTs korrigieren musst du überall in deinen Applikationion auf neuen Schnittstellen umstellen.
                                          -Alle anderen Datentypen sind ohne händische Eingabe in der ETS oder im Objekt eh nicht nutzbar, ausser du willst dich selber um die Dekodierung der Datentypen kümmern
                                          Es deshalb weniger problematisch das Feature mit einer Checkbox umzusetzen die besagt "importiere GAs ohne DPT Zuweisung als Logikwert"
                                          Ist der Wert auf dem Bus >1Byte kommt eine Warnung und wird ignoriert, und alle 1 Byte Werte !=0 werden als true interpretiert.
                                            tombox @killroy2 last edited by
                                            @killroy2
                                            Auch nicht boolsche Werte werden gut angezeigt und sind nutzbar, es gibt kein Grund es auf Logikwerte zu begrenzen.
                                            Ich denke der Nutzer sollte hier entscheiden was er wie nutzen möchte und man sollte ihn nicht beschränken weil man denkt er könnte vielleicht damit nicht umgehen.
                                            573
                                            136866
